View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1996 Honda Civic EX Headlight bulb retaining clip screw
- d16y8 ignitor part change?
- Looking for hard brake line for my 1999 Civic Si
- Gas smell on oil/Smoke at high rpm
- 96 CX bell housing on an S40-B000 Ex trans?
- No crank, no start. What am I missing?
- RPM Gauge Question
- Marketplace access? How?
- No crank no start issue,
- 96 honda civic P1300 code
- Need help fixing my 93 del sol 1.6l 5spd
- Turbo Civic 98 D16Y8 on STOCK INTERNALS
- 98 civic LX Automatic - Dies and will not shift from park
- EG/DC2 driver's strut tower plug pinout
- 95 civic coupe nothing happening when turning on combination light switch
- H2B question
- Wheres the connectors?
- Rebuilding my old '94 Hatch
- Mb6 vti ecu plugs photo
- Spam message?
- transmission issues thud and high pitched grinding97 civic ex sedan
- Series of questions For the D16Y7
- Targa top seals
- Mini Me Swap D16y8 Head on Y7 Block
- B16a2 dizzy questions
- Leaking rack & pinion
- 1992 eh3 bad clutch master cylinder?
- Del Sol idle issue
- y8 head, y8 adjustable gear, z6 cam, z6 block
- 1994 Honda Civic limp mode
- Chipped P28 not engaging vtec on 2000 Honda Civic Si EM1
- VSS issue does this fit
- D16A Manifold ?
- Turn signal on left side not working. Neither are left side hazard lights
- 1994 del sol SI brake upgrade?
- d16z6 swap won't crank but can jump starter
- Distributor fail
- Civic EJ9 timing belt tensioner setup
- Civic 6gen hatchback and sedan floor mat dimensions
- 98 civic LX Automatic transmission and Engine swap
- Anyone knows this head ? P1j , Looks like vtec-e but from what motor
- Dc2 brake upgrade
- B20v with pr3 head
- How bad does this rust look? 98 EK9 hatch, passenger rear quarterpanel
- OBD scanner low voltage.
- Civic 1996 (D15) - IACV Voltage Reading - KOEOff/KOEOn
- Mb6 vtis no spark, need ideas
- d16z6
- OBD1 Harness Won’t Fit D15B Dizzy?
- Honda civic esi FI
- D15B7 Head, stuck valves?
- Antenna connector
- B20B all motor build and swap into 97 HB
- 96 ek y7 troublin blues
- 97 Civic hatch ECU failure
- 15 inch long muffler on eg hatch?
- D15b GODS 😂😂😂Timing queries
- 2000 Civic Ex rpm
- Fixing up 93 civic dx with 2001 civic parts.
- Please help D16Y8 14-15mpg!
- climate control swap 98 to 99/00 ek
- Turbo b16 help!! E85
- 99 civic ex harness on b16a2
- F22a1 swapped em1 civic
- 98 d16y8 to d15 or d16
- what is this part called
- 2000 Civic dies under acceleration, blows 80a ignition fuse
- 1996 Civic D16Y7 sputter on acceleration
- B18 swap 97 civic hb
- Core support bent from accident, looking for advice
- D15z4 throttle body/stock air filter
- 1995 Honda Civic EX (1.6 ltr VTEC) After Head and Valve Job Questions
- B18B1 crank won't turn after torquing down main caps
- 2000 civic steering issues
- 97 Civic HB - won't start - please help...
- Built b16 ticking noise
- D16z6 throwing code 4 can't figure it out?!?
- Putting a 93-95 D15B7 in a 92 civic Dx.
- 92 Honda Civic timing issue wont start
- 1999 civic wiring harness. Need help identifying!
- Radio/headunit stopped working
- Electric
- Lots of questions about building my D16 Motor (Bottom End)
- 1992 eg wont start HELP!!!!!
- Dim battery light
- CVs
- O2 Sensor Compatibility?
- 2000 cx clutch master cylinder problem
- B18 Swapped Delsol CODE 4!! Check Engine Light Code
- I have P0505 surging/jerking.... unless I create a vacuum leak???
- I've looked everywhere and can't find answers for a very specific problem. Please hel
- EG Coupe dash wiring help!!!
- Gas problems/leaks please help
- Which p28 has cruise control
- EG Thin Side Moldings ??
- I know their clutches suck but XTD Flywheels any good?
- Quick Tie-Rod Help/Question
- Replacement Parts
- alignment pin on crank 4 flywheel? D16Y7 97hatch
- Real or Fake Mugen EK9 Intake
- Vtec responding weak..
- Ek sedan project
- N help ID trans
- Turbo
- Two different AC idler pulleys on the 6th gen (video)
- 96 civic wire harness
- 1996-2000 Honda civic Maximum Operating Voltage
- Vacuum Diagram??
- 1993 Civic EX Coupe Intermittent Hesitation on Acceleration
- 99 civic ex start problem
- My speedometer says that I'm going 40 mph only at idle
- 2000 Civic suddlenly won't start
- Newer floormats into EG hatch?
- D16y7 into a 92 hatch
- d15b7 connecting rod/piston rings
- Rear Chassis Brace
- Front Lower Brace
- I NEED HELP!!!
- Honda Civic - no acceleration
- Squeaky/Creaking Noise From Front Driver Side
- D16z6 idle surge, NOT vacuum leak or FITV
- D15B7 Del Sol automatic
- 2000 Integra vs Civic Si rear wheel bearing/hub
- Looking for Decibel levels for a quieter cabin in a 95 Civic Sedan
- What is this connector for?
- how to remove tailgate/hatch glass in EK
- 96 civic dx sedan p0700 & p1753
- D16y7 - Need some Info
- 94 LX. Losing Oil. Need ideas
- Help please, changed my intake manifold and now
- Stock Scion FRS vs EG hatch stock b20 vtec ?
- Re shell ek to eg
- 99 civic - check engine light
- Steps to replace 94 DX front end?
- Timming belt loose and jump time
- Project Civic
- Oil pressure issues....
- 1997 honda civic lx d16y7 5 speed. Bad misfire on number 2 cylinder help please
- P505 code. 2000 EX D16Y8 auto.
- No start
- Passenger side front wheel clunk
- 2000 Honda Civic Cx Hard Start Issue
- D16y8 swap into 94 honda covic
- new del sols, well new to me - electric grimlins
- Fuse #19 blows no matter what
- Chasis wire harness
- Starter solenoid
- CABIN HARNESS HELP
- Honda Civic Ek3 1997 Ferio - RPM fluctuate from 300 to 1100
- Identifying a block without engine stamp
- This look normal?
- comp cam springs reliable?
- Aem fuel rail for B16a engine
- code 6 and 7
- Question for Ferio Ballade and coupe owners
- Typical surging idle/hunting idle and high idle
- Would EH6 coils fit an EG1 Del Sol ?
- Head Light Problems
- Engine bore help!!!
- What spark plugs should I be using on my Del Sol turbo setup
- 98 Civic DX D16Y7 Blown Head Gasket or Bad Water Pump?
- 1994 Honda Civic Struggles to start
- Civic 1992 low idle rpm?
- Honda civic ek swap b16a2 check engine light and doesnt turn on ???
- Turn signal issue
- Obd2a into obd2b
- Driver side trunk lock won’t unlock
- Civic Brake issue
- del Sol dome light issues
- Ls/vtec with OEM cams need degree????
- 93 Honda Civic ex overheating
- interior panel
- using the JDM D16A manifold?
- 2000 Civic EX w/ OBD1 B16 Swap Project and O2 Codes
- obd2b harness to obd1 distributor
- Not sure what to do?
- 96 Honda Civic ex coupe automatic
- Bought an EJ8 with swapped rear spindles -- alignment?
- Wiring Recaro seat in 99 Civic DX
- 15x8 +25 wheels
- 94 Civic DX Wheel/Tire Fitment
- Identify sensor
- Em1 rear subframe replacement cost
- GSR trans locked out of 1st and second gear
- Update on JDM H-swap EK
- Soch Vtec ecu needed to replace p2c non vtec ecu
- Ek civic 4dr b20 swap not running right
- 92 civic cranks slow/sluggish a few times then starts
- 93 Civic Hatchback running hot/overheating
- 95 eg h22a swap fuel injector issue
- 98 Civic EX stock transmission?
- P0135 P0141!!
- 97 Civic Dx misfire horribly when warm, any advice plz? :(
- H2b swap slipping clutch??
- Type r knucleson my EG
- D16y8 using oil and bad cat
- I need some ecu ASAP
- 95 civic fuel sending unit works.. but not in the tank
- 1999 civic vp sedan door harness repair no power windows just power locks
- 93 EG DX swap to type r
- Exhaust Fitment Question
- About to buy a '94 Del Sol Base Model S, need advice for swap
- 2000 Civic EX d16y8 Auto to Manual swap Wiring issues - Need help
- Wide body
- 1999 Civic Si oil pan interchange queston
- Help Choosing a cat
- Intake manifold using B16A of b16b better
- Ran 2 low on fuel? No start. Stock 96cx
- 98 auto d16y8 swap with 92 manual b15d7
- belt problems
- Helms civic eg owners manual?
- 1999 civic high idle and surging up until 2k rpm
- Speedometer Off
- What am I missing?
- 500hp high or low comp?
- anyone in sd area wanna chill while i finish my kswap (question too)
- B18B1 civic
- 94 Civic power steering
- California State referee ecu issue
- Is this block useable? Cylinder walls have light rust
- Tanabe coilovers
- Delsol B18b Auto to Manual Swap HELP!
- cruise control not working
- Radio problems
- Del Sol, the Door panel fix
- 1993 Honda Civic hatch fuse 24 issue
- RPM's not working after new Dizzy 99 ej6 b18cr
- 2000 CIVIC LX Noise T-T...
- OEM Bushings Kit
- 1a auto good?
- Should I get coil overs on my stock eh3?
- 1995 civic dx not turning over help D15B7 motor
- Can I inercool a non turbo d16y8
- 1995 civic dx
- Classic Import Companies for 5th Gen Civics
- P0335 98 civic ex need help!
- P1457 pending code
- 92 civic cranks but no start
- Fuel injectors not functioning properly when engine is warm
- Engine Swapped and won't start
- 93 civic hatchback won't start
- Gauge lights & Parking lights not working
- Replace Flywheel Friction Disc?
- Steering Rack Options
- Good D16y7 Turbo advice
- D15B JDM V-TEC wont start and I’m stumped.
- Removing Balljoint from main arm
- Selecting Rear Strut Brace
- Best Headlight Inserts for EG Housing?
- 92 D16Z6 idle issue
