View Full Version : Honda Civic / Del Sol (1992 - 2000)
- What head gasket is stock on the d16z6?
- Bad Axle
- Where is b20z? He still ows me a lip or $125
- Where to get d16z6 head parts
- Is this motor worth putting money into?
- 92-95 underdash civic fuse box diagram
- Widest tire that will fit?
- Illegal IM swap questions
- 195/45/16's on an EK?
- new ride
- vtec spool valve leaking
- del sol ashtray door not closing! i have pictures this time...
- Pic request: 92-95 EG w. jdmshit 'type-r style' front/rear lips
- magnaflow cat-back
- Help with car not starting
- S2000 Calipers on GSR spindles on an EG
- Tranny won't come out...
- Electrical ground point for EJ6
- So Basic B18B Questions And Suggestions?
- D15B JDM SOHC VTEC..
- http://www.carpartswholesale.com ?
- Will putting smaller rims make me have more "umph"?
- Skunk2 stage 1 cams with stock valve train
- B16A Civic Coupes?
- Cat Back or custom piping
- www.japanmotorimport.com ???
- What to do?? New DC Sports cat-back just broke in half while driving????????
- timming belt broke!!!!
- Put Tein S-tech on and type r style lips
- need pic's of civic coupes with any style rotas on
- Need Help With IAC
- GROUND CONTROL QUESTION
- h22 civic hatch axle break!!!
- How much drop for 205/45/16's on EJ6 (EK Hatch)
- Exhaust difference of EG vx/cx from EG dx/si
- why is my d16z6 turbo slow?
- Suspesion Sounds
- What Do you Guys Think of the CAR?
- 98 prelude rear seat in a 96 civic coupe....
- Interested in expanding my knowledge
- D16 v-tec in what kinda honda ?
- Couple del Sol questions.
- D15b timing question??
- Put in my HID Conversion kit on my EG. (Stock vs. HID quick comparison pics)
- 99-00 si vs new si!!
- Help on b16a swap !!!!
- Anyone kno what exactly is used in making Carbon fiber?
- Mini Me Problem
- . best point for vtec?
- front splash guard?
- Civic Rims
- Del Sol JDM targa top
- simple question on intake manifold *pics*
- buzzing fuel pump?
- Help me locate a vac line!
- need ECU in Del sol Pic
- Broken Hatch Help!!!!!
- What is stock wheel size for 95 Si?
- ac on gsr swap
- Gauge Instrument Cluster Not Working - Looking for Civic Diagrams
- need some help....
- 96 civic cx engine code 67?
- what is wrong with my engine?!?!?!
- Rear hub bearing sizes ?
- 1 piece headlights
- 2000 Civic Si fork part number
- help... exhaust installation problem---civic owners especially HX
- Revs to 2500 everytime I put the clutch in! WTF is wrong?
- Valve Cover
- 94-01 Integra rails fit 92-95 Civic?
- Strut bar
- who is from rochester in here?
- Weight of rear windows in eg hatch...
- WTB: Complete Manual Transmission
- I finally got the car done!!!!
- is this car worth the buy?
- what could cause this lean crap
- Paintin SI fog lights lens (99-00)
- my b20t
- Clutch problem/need help
- Looking for a so-cal shop
- How Does The Map Sensor Look On The Throttle Body????
- oupground control cutom kit, how about these rates...
- 94 civic ex - Thermostat location?
- axles ?'s
- painting interior ???
- power locks on a del sol?
- Right hand drive shell?
- How do i pull the door panels off my 93 ex?
- looking for HID how-to post I saw in a clasified ad awhile back
- anyone know what kind of engine this is?
- problem with chipped P28
- Amber bulb condoms
- This post is for Southside Atlanta, GA members that know about South Honda
- suEKpsension tehcniques swaybars install instructions HELP?
- Detachable stearing wheel hub?
- Cheapest place to get OEM fogs?
- 92 vx hatch
- question about O2 sensor
- Question about my d16y8
- LS/vtec in 94 coupe
- car wont "warm up"
- swapped in a gsr..now high idle problems..
- First time posting up pics.... Lorton Prison wo0t
- Budget Boost question, CRX HF exhaust manifold will it fit on 92-95 D15B7 Head
- Z6 intake manifold onto Vx?
- *help* power steering pully
- Are the threads the same on all SS?
- D16Z6 Parts for a 93 Civic Coupe....
- help!! funny noise when i hit v-tec
- new civic...engine trouble
- What rims/springs/coilovers on 92 vx Tahitian green pearl civic hatch?
- Identify the severity of these problems **pics**
- Wattage of bulbs for factory fogs????
- Will Mugen Twin loop fit on a 5G coupe?
- what motor mounts do i need??
- timing belt
- B18C1 hatches 1/4 times/hp
- auto to manual?????
- My Possible N/A B18c1 setup
- going ls vtec soon,i have some questions
- which valve cover???
- suspension recommendation for 99 si u.k equivalent
- Pressing axle into transmission, any tips or how tos?
- check engine light
- Z6 tranny gear recognition help
- Y8 mainfold vacuum connections! Need Help!
- EG Front on Del Sol
- Del Sol Headlight Adjustments
- 94 to 96 tranny question. Please help if you can.
- Shaving Door Handles
- Semi-n00b Questions, bare with me please
- Gauge Cluster Question
- safest way to remove finger prints...
- Fujitsubo RM-01A vs. JIC Magic 505S ST PICTURES PLEASE!!! Owners vouch for your exhaust likes/dislik
- coilovers fit?
- powder coat, paint, or SI's
- searched.nothing! d16 rods
- Antithief question
- Anyone have the video of Cheesefrog?
- Fog light question
- offsets?
- Trouble with car not igniting...
- what are some other good civic only message boards?
- Whos got the most custom interior?
- What seats will swap into my 93 ex? Also will new center console swap?
- Engine Died/Choke While Driving
- 96-00 DX Tranny Question
- Remote Start for a 5 Speed
- 1 abused sob ...... pix!!!
- roundabout price for GSR blades ?
- Name That Plug
- will wilwood big brake kit fit
- tranny rebuild pricing
- Thermal Catback for 92 hatch
- name that noise
- shakin under acceleration??? im confused...
- help with wheel gap...
- any one switched from vw to honda?
- AutoLock Stuck. HELP!!!!
- ek map light
- HELP!*tried search cant find where to check codes!
- Bye bye boost!
- Cut wire OBD1 harness, Help Wanted, Identify this wire!
- Getting condensation out
- NEWS for those who use HONDA Oil Filter
- A/C Slider knobs
- can someone run a carfax for me?
- Long Island is going strong!!
- i suck at life. cant remove window crank from car
- 94-01 Integra springs fit 92-95 hatch?
- which chip programs?
- Guage Cluster???
- RS-R ex-mag exhaust
- Bseries - Pic
- cluster question..
- Draining transmission fluid...what tool????
- Under my engine stamp what are these 7 or 8 numbers!?!!
- eg clear corners or ambers?? pics inside..
- coupe tails fit on hb??
- Fuse for the fuel pump ?
- Selling my baby soon...$$$ suggestions
- How do you install pads on drum brakes?
- shock strut question
- my dog loves honda parts
- Work XR-01 Jwing pics PLEASE!
- Does a 01 civic have a ....
- Learning Throttle Position on VAFC d16z6
- ls axel problems
- map sensor help wiring
- Anyone compare the light pattern for a CTR headlamp next to a USDM one with HID's?
- EK hatch not starting up: corrosion?
- 99-00 a/c console in a 96-98 Civic....Is this possible?
- ek rear wiper removal
- cut bump stops on stock springs?
- Coilovers Vs. Lowering Springs
- Brake Problems - Rotor Problems
- Revoming the header
- Picture Request. Bent DCsport strut bar
- Need help with getting my transaxle apart from the bellhousing
- D16Z6 Oil Filter
- Insurance Question
- J's racing chip, and carsound high flow cat questions
- stupid question...
- CTR Cams
- Replica spoon power mirrors
- anyone know where i can get an exhaust silencer???
- edelbrock turbo installed
- my new wife beater EK ls/vtecken
- On Board Diagnostics is garbage! Please read...
- On Board Diagnostics is garage! Please read...
- Would you gut your cat
- Post Your Civic COupe 1/4miles times.... mods/set-up!! wooo wooo
- A freind of mine says CAI could cause my gas mileage to go down?? and partial venting about a misinf
- 5th cx and dx injectors the same?
- wiring 96 dx iacv for a 93 cx plug?
- Went to 'ye old strip tonight. Just looking for comparisons.
- header question
- NEW PICS. nice day in Dirty Jersey
- Motor mount insert kit, Prothane or Energy Suspension??
- Anyone used this? Tech Edge O2 Simulator... only $37 + shipping
- How to wire factory fogs to come on without headlights????
- aftermarket fuel filter and a 93 civic with swap
- Installing Neuspeed/Koni shocks (EK)
- Body shop in San Jose, CA ?? Anbody know of any good ones? Help
- Took my car to the track for the first time...
- Del sol pully help!
- This is priceless - b18c5-eh2?
- Items missing
- y8 or Z6 in EG???????????
- Secondary O2 Sensor Wiring for EK with B16 swap
- Ground control coilovers. spring rate?
- fs: B18B1
- why is it leaking from here?
- CF Oem style power mirrors for EK coupe
- Need some help figuring out comp of JDM D15B block with D15b7 head
- motor swap
- Do headers make a big difference in Horse-Power?
- New Rims..
- insurance woes....
- What size slicks work best for you?
- What is the piping diameter for the stock 99-00 Si exhaust?
- 14's
- HELP: B18B into 1999 Civic HB- List step, parts, problems. ?????
- Rotor scratches on caliper...
- recurring P0420
- H3 HID kits?????any good ones out there?
- What do you think of this trade???
- So what i i suppose to do when my air conditioniner makes a fujnny noise?
- Simple question...
