View Full Version : Honda Civic / Del Sol (1992 - 2000)
- shocks...
- engine swap question... B16A in EG Hatch... and some exhaust questions
- B16 air intake fit GSR?
- power windows ... aftermarket... how to remove?
- help solve this idle problem (searched)
- White EK9
- Missing LCA Bolt For ASR Subframe Brace
- 1996-1998 fog light question...(yes i have searched)
- Radiator fan works at first, then wont turn on.....
- si lip install
- Barb fitting to the top right of oil filter on B16A? What is it?
- help with ek auto tranny
- gsr master cylinder swap into 93 si hatch
- Koni Yellow w/ Part # = What Car?
- help with ek auto tranny and something else going on
- Where can I find a 99 Si rear motor mount? OEM distributors?
- rear toe adjustment question
- Shaking at 60
- VC rubbing hood...b18c in a 95 Coupe
- h22a or d16 turbo
- Intake Air Temperature (IAT) Sensor Circuit High Voltage
- Starter cable assy. caught on fire?? WTH!
- a/c install?
- 96-00 auto to manual.
- fireing order for d-seires
- oil burning and black oil in b18c1 ek
- CRANK TIMING!! - Cant See The Markings - How- To Fix?
- is this the evap purge solenoid?
- which timing belt do i use non v-tech or v-tech
- d16z6 bottom end with d16y7 head
- ITR 5 Lug In 92 Si Hatch ?
- EG HATCH guage cluster question
- What is a good compression test reading on a B16?
- Engine hestitation
- Will it look good.
- headgasket or what? HELP needed ASAP
- Help with rear t bracket.
- Turn signals - Blinking speed
- del Sol weight
- door panel removal and what is this plug for?
- vtec engagement problem
- 95 Civic EX - Turn signal no longer goes off after completing turn
- B16a Block with CTR pistons what u think?
- Final Product- Self Shaved and Molded Hatch
- FUEL MAGNATIZER??
- motor mount help!!
- ITR axle back muffler section on EG hatch
- 00 Civic si
- 94 del sol engin temp sensor
- internals/turbo
- whats the diff...
- ls turbo help
- Difference between B-series non vtec and vtec parts
- password JDM 3pt front strut tower bar question!
- what do you think of this deal???
- 93 sol AT idle problem, Please help
- SiZe For Slick In An EG
- Del Sol radiator support
- choosing suspension rates
- Finally finished my del Sol
- Car Blogging
- Over heating problem.... HELP please
- hwo do i know if this tranny has lsd?
- b-series headers.
- Oil Change....
- erratic stumbling and/or stalling
- need smog on b16 swap ..........so cal area
- im getting a 98' civic hb. i need tips and ideas for whats next, include pics pleaseee
- Revs problems
- Wiring Diagram for EK9 Navigation system
- need new muffler for greddy evo cat system.. 2000 civic si
- A/C Compressor kicking on and off while driving?
- WTF?! Plug you clock into you hazards...
- how to build a flip flop trunk for 1997 honda civic ex????
- Wiring Diagrams??
- EX and Si rim difference
- dc5 type r brakes on eg
- what is needed to put ac in 93 ex with ls/vtec?
- Brake Upgrades?
- d15b vtec ecu wireing for my 92 civic dx
- in TN k20 swap??
- Is it loose wires or a burned out fuse?
- ek's potential
- Oh my gosh, it's my clutch!
- Vacum lines WHERE???
- Alignment/tire ?, Shop f'ing with me??
- Carbon Fibre Tailgates
- SAFC2 HELP ASAP!!! PLEASE
- b18c on half radiator
- Fucking thieves, stole my tach lol..
- aem tru time cam gear
- AC Fan
- Service or Shop Manual???
- bad sounding exaust
- Transporting an engine
- CODE Problem with Stock Headunit
- f*ck my car was stollen
- people with sparco seats in 96-00 civic
- PRO EK HELP NEEDED
- The crank pulley bolt from hell!!!!
- Oil / Transmission Fluid Query
- purplehead light bulbs
- What could it be?
- car like it wants to die pls help
- SiR-II Complete Changeover into 5th Gen DX Hatch?
- Upper Driver side mount always craking?
- 1997 EK 5th Gear Restricted????
- IACV problem, cleaned it worked good then back to bad.... gimme some opinions
- afc AND uberdata ???
- ARC induction box..fittment?
- headlight beep (How to)?/guage light question
- center console questions about swap
- intake question..
- Topic searched, please help
- what can i tune for my 96 civic HX
- 3 angle valve job.
- Ticket....help a brother out..
- EDM D15b2 to D16z6 swap
- ignition problem
- Rotor and cap ls/vtec, help!
- Tire question?
- Window Trim?
- Need Help
- gsr motor with skunk2 intake manifold
- need a DIY for painting rims
- anybody want some cash? yes, im that desperate
- horsepower estimate?
- idle/timing/ everythig problem
- cluster swap help..
- Help! Front hub/brake disc bolt lug was loose
- suspension question about sway bar install
- think i'm a little too low...
- would only having 2 bolt holding on my dizzy cause a slight misfire at idle?
- Vtec question
- h22a in a 98 civic ex (good) ?
- EvAp hoses d series??? need help asap
- z6 turbo or b20
- Do Integra air bag trays work on ek's?
- ok apexi world sport question SEARCHED
- how to take out radio bezel in eg
- only heater works no fan
- HELP PLEASE!!!! Clutch HELP....
- ek9...best cams???
- which swap is better?????
- n e 1 in birmingham wanna sell an ex tranz
- 94 DX Help
- Leaking coolant behind engine??
- o2 Sensor related question! -Footnotes inside!-
- Timing issues??? from a start.
- TB Question. Need help ASAP
- Very weird idle surge problem...
- Where do you get your exhausts installed?
- 99-00 ctr style lip fitment* 1 1/2" LONGER and painted*
- Rear fog light for a Del Sol
- will this p28 work
- No VTEC engagement
- $1400 what to do with it
- Which will fit and what do you think?
- Random Misfire, Car died on me yesterday
- Random CELs
- Axle Nut Blues...
- problems with low rpms
- WTF!?@!?!@ DID I DO WRONG?????
- h22 with b series transmission
- Were does this plug go?
- back yard special products??
- password bulb quick Question
- d16Y8 head with d15b7 intake mani?
- Post your angled exhaust on you EK or EG!
- good summer coolant/water mixture?
- List of all necessary sensors on intake manifold?
- Pace Setter Exhaust?
- Carfax Needed
- jdm steering wheel cover
- 00 USDM GRS Engine specs
- swapable d series heads
- Need new tranny 94 4d LX, and a few questions Options
- brakes hard > soft > hard (yes I searched)
- car keeps dying..??? help
- b20 ecu in civic
- axle seal leakng after axle swap
- My Projecter Lights have a problem!
- anybody have a car for sale in northeast ohio?
- all neccessary bushings to rebuild steering rack?
- Rod Knock? Need some info on eg
- b18/b20 eg gas mileage anyone?
- tranny code problems.
- 99-00 Si OEM floor mats
- WTF? Crank pulley setup? Timing belt guides?
- RHD conversion almost done, but a few ??'s
- Car won't start...
- trannt bracket help
- 91 B16A -> 97 EX
- Has anyone here ran with no O2 senser at 1 point?
- CARB Badge
- Engine issues with EM1
- 98 civic hatchback exhaust fit on 1.6 EL? (civic coupe)
- 92 Honda civic no spark!
- Gresham OR, civic at a party last night
- Another "wont start after swap."
- AC Switching on off... ALL THE TIME!
- 100 Watt Bulb In 99-00 Si Foglights?
- What are the signs of a bad fuel pressure regulator?
- Better mileage? K&N drop in, or AEM SRI?
- Eg brake woes!!!
- How much u think i'd have to spend for ls powered EG?
- excessive vibration
- exhaust issues with skunk 2...advice?
- Window Problem... any ideas?
- Which power steering pump for my LS?!
- how do you get the window crank off?
- fuel pump ques.!
- Taillight problem
- Looking for parts to buy.
- stock shift light , engine swap ?
- Power window problems
- Need help quick!!!! (Swap info)
- obd2a engine harness on obd2b motor, will it be ok?
- Roll cages for the EG civic hatchback. Where to get a cage Fabricated????
- HELP: Swapped B18c1 into EG DX....
- Average cost to replace CV Joint?
- power to dash went out Help
- GSR Cams and camgears + b16a3
- acceleration problems
- Edj00macate me on D series
- Brake line help
- help with my tach
- EK dx hatch- how do i remove engine harness from car to pull engine
- headers question
- intake manifold question
- WTB Valve Adjustment Tool 10mm Jam Nut
- ECU WHAT IS THE DIFF. ?
- b16a2 swap
- i've search. have different question. turbo d16 opinion
- settle a bet for me???
- Honda Decals/Stickers
- what does a timing belt kit cost for a B16?
- Stupid Question But Help Me Out...
- HELP: T fitting from oil pressure sensor broke off
- Need to find out the correct mm socket size for spindle/driveaxle nut...
- Need some help here. Shift linkage question.
- d series header weight dc 4-2-1 1pc vs. oem 2pc
- xtd cltch intall got a problem i think HELPPP
- ek sidemarker
- idle problem
- 99-00 SI and 94-01 Tranny Bracket question
- Need help with b16a2 swap
- how to get a rhd car imported
- turbo kit
- vtec-e
