View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Interior : Sunvisor Clips
- eg and ek rear mount the same?
- Comptech Sway Bar/Tie Bar
- anyone converted to cable clutch?
- D-series shift linkage
- help, possible missing ecu plug?
- Eg EX Cluster Swap into 95 CX-Cruise Control Flashes Periodically?Shift Light or Other?Searched...
- Where do I buy headlight Bulbs for my JDM housing??
- stage 2 cams with oversized valves question
- Brake question......NEED QUICK RESPONSE
- EM1 Si custom seat covers
- rear wheel bearing torque? 92 Si hatch
- p06 for now
- Hard to star
- rear disk brake question
- amp rating on ignition switch 96 civic
- opinion
- evap code
- another cicvic bites the dust........HAHAHA!!!
- gathers overhead mounted speakers
- del sol motor mount
- arrgh my car wont move
- I know this is bad, but how bad???
- requesting a pic of the EG optional center console
- what catback to buy for a 98 civic hx??
- Paint prep (removing leftover window sealant)
- Civic Type R muffler tip size
- Carbon fiber plus rain
- where to find factory style 96-98 fog lights??
- 92 95 sedan civic exhaust on eg hatch
- 97 coupe bezel cover; removing.
- OFF TOPIC BUT I NEED TO KNOW!!
- Busted motor mount
- Crank Woodruff Key Gone: Crank Snout Damaged
- swap time has come but i need help first
- will a zc trans fit on d16z6
- break lights wont work!!!! need help!!!!!!!!!!
- dim headlights
- cost of rentin a paint booth?
- b16a2 in a 99 civic ex
- ***Stolen 93 GSR socal***
- Hunsaker Synkro Racing Seats
- GSR mounts
- Bent something, dont know what it is....
- Wilwood and 15" wheels again
- USDM ITR Seats in a 00 SI
- Opinions on axles.
- my boy is having headlight problems!
- Good adjustable shocks
- 92-95 Honda Civic dash radio surround bezel??? CAn't remove
- GSR rear seat in 92-95 EG
- New here and to Civics...got some q's
- ABS ????
- GSR disc brakes in EG question
- turbo injectors
- auto to manual help??
- 96-98 civic coupe midsection??
- my b20b swap in EJ2
- b16 vs b18 axle???
- Which cams will you use on your ITR?
- my car shocks me
- Starting problem
- Ahhh, what bumper is this?
- automatic to manual transmission swap
- EJ coupe... needs..
- 93 muffler on 98 civic HB
- little green and yellow cluster plugs?
- gauge cluster question
- RETROFIT HID'S on eg?
- Axle
- gauge mount in vents... a few questions
- What timing belt to use on z6/y7 mini me?
- Exhaust that wont Scrape
- Help! Erratic speedometer and headlight dimming issue
- auto - manual
- Brakes
- replace wheel stud. I'VE SEARCH. can't find answer to my question
- Bolt size?
- WTF is wrong with my horn?
- Using obd0 head with obd1 sensors on obd1 engine?
- GSR Shifter in an EK?
- H3 yellow bulbs for 99-00 fogs...asap help...
- tranny question
- engine prob
- 2000 y8 motor, in 98 DX car, running obd1... possible issues?
- huh??
- EG fog lights
- LS BORED TO 2.0L.
- Lip problem, can't decide **Searched**
- buddy club spec 2 exhaust on EG sedan
- I'm new, and i got a question.
- gauge cluster removal
- 94 delsol auto to stick
- jdm oem stock in dash... help needed for install... anyone?
- invidia cf hood????????????
- I need a name change!!!
- interchangable tps sensor?
- turbo question
- gas hog!!
- D16Y7 block w/ D15B7 head questions
- Best suspension for a 1995 honda civic coupe ex
- anybody have install pics or details on doing full race traction bars on EK
- Dust plate fitment during auto to manual?!?!?!
- del sol center caps 14" rims
- BONE STOCK JDM B16A first gen in an EM1 1/4 TIME!
- help me with me seats
- ITBs i need help
- Short Shifter myth buster?
- honda's new factory turbo engine
- axles?
- Will 96-00 Civic A/C system work w/ my 97 Hatch w/ b16 swap?
- japanese red guages
- need night time pic of ek4 cluster
- Civic won't start after driving hard
- The Million Mile Civic?
- Tire size question
- Civic Sir axle vs Integra axle
- ok i have motor probs
- seat rail for aftermarket seats
- 98dx
- CONVERTIN A MANUAL DOOR TO POWER DOOR ON A 95 HONDA CIVIC COUPE
- How To Tell If You Need A New Ignition Switch or Ignition Cylinder?
- Very important, need input!
- H2B kit
- which Intake Manifold is best for my D???
- interchangeable suspension between civics
- password jdm intake on a '00 civic ex?
- engine bay paint code? vsm ek
- Vtech tranny and Vtech timmer
- Z6 Turbo, B18B S/C or H22a
- pic request.....
- BAR Sticker Problems.
- B16 Weird idle and popping
- help the cruse control will now work!!!
- length from header to rear control arm coupe/hatch
- Black Box Clicking; What is it and Why?
- Car sprayed but when can i hand wash?
- air bag deactivation question *searched*
- VALVE CLEARANCE
- what are other good sites?
- b16 idle problem
- I've Been Toying around with doing a custom exhaust myself
- LOSS OF POWER?
- Should I regap spark plugs???
- JDM tinted door glass?
- ek to lude frontend ever done ?
- Best setting for KYB AGX rear shocks (daily driver)
- Starter Wire
- EG side marker measurements.
- TRANNY CODE QUESTION
- honda centercaps for rotas
- 95 civic with air ride
- car won't turn over..
- Hondata RealorFake?
- PGM-FI INTAKE MANIFOLD HELP!
- weird question
- knock sensor help
- 1/4 window molding replacement.
- are these real vision?
- Quick Question : What is my engine model #?
- TYPE R ECU
- Need Help Changing Climate Control Color
- Trying to lower the REAR of my Sedan.
- Crank Question
- Help Removing Tar from my trunk
- Are 99-00 SI front calipers the same as those on a 94-01 integra???
- Is a front and rear sway bar off a Itr good swap for Vtec-delsol?
- What type of alternator is this?
- Suspension from a 89 civic fit a 92 civic cx?
- Gas tank capacity on 99 Civic SI
- BRAKE PROBLEM
- HALFWAY DONE! b16a into 96 coupe. wiring q's.
- Are acura disk and 92-95 civic drum hubs the same??
- Commuter car question --> 93 civic or 89 accord?
- Is the stock D16z6 exhaust manifold the same as the stock d15B series exhaust manifold?
- What is....
- How can i tell which model my Y80 hydro transmission came from?
- will ek9 mygen intake fit an EG?
- Stripped out rear upper control arm threads. Need a fix..
- desperate for help, jdm b16a swap in a 99 civic hatch. honda experts chime innn!
- D16A1 in a 97 EX?
- Auto Hard 2-3 Upshift Downshift 1997 Civic
- Oxygen sensor???
- **Post pics of your Civic Sedan**
- I'm new and need some ideas.
- would a 98 hatchback taillight work for a 2000?
- 93 civic dx ecu prob i think
- New Civic
- Why won't my transmission come off?
- 94-01 Type R Power Folding mirrors fits 96-00 Civics?
- Injectors and Fuel Pump needed or not?
- del sol/ civic shell
- a little help??
- San Diego engine rebuilders question.
- Funky timing belt wear... only 3000 miles on the belt! Why oh why??
- Which stock front seats fit EK/EM chassis?
- parts needed for a mini me swap?!?!
- 99-00 SI seats in EJ1 question...
- Avatar Question
- ITR head question
- Ignition box help
- em1 suspension on a eg6
- Help type r engine into a Eg
- EK hatch LS swap help..
- Got in accident, other guys fault (he had NO INSURANCE!)
- 94 Civic EG Hatch with 97 F22b1 Accord drivetrain questions
- b18c5 swap with ls mounts?
- 99' HX CVT Help
- need help with mounts on 00 civic
- bad install or poor construction
- Help finding a honda?
- bike rack for EK civic
- distributor
- Help!! I hit a curb
- engine harness differences, p07 pinout vs p28 pinout
- 91 Si rotors fit a 92 Si
- 95 ex w/ b18c1 vtec not working car boggs
- Help!! Distributor Rotor headache
- 92-95 civic hatchback rolled fender pix anyone??
- Help: how to install a DIY chip from phearable.net
- Alternatives to OMNIpower Clutch master cylinder?
- HELP w/exhaust...
- Tried teg forum and no response.. HELP... B-series tranny problem... HELP
- Will civic ex lugs fit on a 98 ex w/99-00 civic si rims?
- anyone ever swap a d16z6 into a 96-up civic hb?
- Need Clarification: DC knuckles on an EK
- A dumb Vtec hook up Question on a D15B motor how to hook up for vtec??
- Transmission Question - Will a '95si 5spd work on a 97ex 5spd?
- delsol d16y6 engine issue
- Weird water pump question
- tranny issues
- 96 hatch with itr 96-97 suspension
- brake light problem wiring geniuses requested
- Sparco or other side mount....fittment question
- ITR short shifter
- exhaust system
- jdm eg sir steering wheel...can you use cruise control?
- power to ecu
- 97 civic ex headight bulb install?
- new car pics and couple of questions
- 4 point front lower tie bar question.
- Code 65 again.. ahh..
- Upgrading brakes on '98 Civic Dx
- CEL Probems
- question on cf hood?
- squeeking/grinding sound from camgear area
- Snapping sound when clucth is engaged??
- need help finishing a gsr rear disc swap on a 1993 ex SEARCHED
- Stock Exhuast size for a '99 EX Sedan?
- Adjusting TPS Problem. Please Help!
