View Full Version : Honda Civic / Del Sol (1992 - 2000)
- My Honda Civic 1994
- TEIN Basics or D2 RS
- head and block swap question
- Glove box compatibility
- Stolen 99 Silver hatch (Orlando, FL)
- NEED FEEDBACK civic EG ralley car?
- ECU Help
- Integra cams into a B16a2
- initial startup problems!!! wierd noise/ no revs??? need help!
- suspension fork question??
- OBD2B motor into OBD2A 96 Civic EX
- skunk 2 lowering springs Vs Tein lowering springs , which one best ???
- ground control coilover problem :[
- Is this normal? CTR Steering Wheel Issue!!
- Car has been sitting.. Isnt cranking :(
- (del Sol) Removal of third brake light. Help.
- leakdown test results, help!!
- Shortshifter?
- WEAK VTEC
- head problems
- teggy sideskirts on ek?
- question about steering wheel swap
- Car Shuts Off When Giving Gas HELP PLZ
- will LS axies fit GSR tranny?
- heva ya try this befor
- Alternator Problem Thanks!
- obd2 ls head on a obd1 ls block?
- o2 sensor affect performance?
- Ls Vtec Bogging when pushing it Sounds like Misfire/Backfire
- 99 si cluster ?
- motor mounts
- Here it is, Ek9 wiring for the milky white plug - might wanna sticky this....
- leaky oil pump seal
- 96-00 Auto Tranny Worries
- Four door wing fits del Sol?
- engine light problem
- skunk 2 Coilover sleeves on Tokikos Vs lowering springs On Tokikos... Whats best ??? HELP PLEASE???
- Which B18 and Civic?
- stock si intake!!! got pic
- civic ground control? which one for front and back.
- check light codes????
- Hi people!
- 98 coilovers
- Oil leak in a 93 Civic hatchback
- idle problems! b18 in 96 civic
- GIVE ME LINKS
- Dash
- My D16
- axle won't go back in the hub!!!
- Hondata I/M Gaskets
- ignition key hard to turn??
- car drives fine; just sometime chokes at 30-40 mph or 80-90 mph
- how do you find out if your s200 hondata have boost option?
- ECU for Emissions. (NJ)
- What should i replace while tranny's out?
- 2000 struts to 96 struts
- Ultra Bright Blinker? What?
- EK auto to manual pedal assembly???
- Why am I still a Restricted Trial User after over 4 and a half years?
- Block ?
- Can someone identify this ecu??
- EMERGENCY!!! I'm stranded....fuel pump fuse 96 del sol b16 help please!!!
- what all could cause my car to flood????
- Back pressure and smog?
- DEL SOL MOTOR MOUNTS
- does anybody like this drop?
- Question - Will pads ware quicker!?!
- camber kit installed.
- EG6 SIR SI parts. Civic 92-95 Question?
- carbon fiber front bumper
- RPMs are hopping how to do i check vacuum leak?
- Steering wheel Help
- OPINIONS plz?
- problem: 95 civic wheel wobble/shake
- Honda D-series D16Y3
- A/C Clutch or Compressor Froze
- Crank Pulley HELP!!
- 00 Civic CX Hatch break pads..
- chip
- window regulator...
- where is the location of the PCV valve for 96 honda civic EX?
- another stolen civic (sf bay area)
- Identifying different Head's.
- problem with my shift linkage
- Air Conditioning sometimes work sometimes does not
- 2000 gsr obll into 92-95 civic coupe dx
- hx rim hitting front caliper on 94 ej1?!
- 98 auto dx not starting!! HELP!!!
- hid help
- Radio doesnt work, plugged in the back
- weird clicking noise coming from my axles?
- Should I reset the ecu to get gains from newly installed intake and exhaust?
- Lets talk Civic Wheel offset! Need some help soon so I can order my work Wheels!
- eg fog wiring
- Rim and tire question...lowered with 15's ok?
- Question about Exhaust Piping
- 97 Civic Radio with keyless, TIPS
- p30 ecu tuning
- Are darkened tail lights legal?
- Have a important question i need help please
- Power Door Locks (del sol)
- I need help getting to my eg gauge cluster!!!
- vibrant universal flat black muffler
- brake upgrade?
- throttle body and tps
- another problem need suggestions
- OBD1 swap questions
- new lca's... got a Q
- ECU Difference?
- Need to lighten up the EH9
- type-r swaybar for civics 92-95
- Painting "H" in centercaps
- dx/vtec or ex motor
- Civic Intake Manifold Tweak?
- Brake job, need advises.please
- the only dumb question is the 1 that is not asked..
- Gov Chip?
- Problem w/ window (track related?
- turbo time? for civic ex
- Can some1 teach me how to modify my civic EG6 Vtec B16a?
- Using oil, but not sure where...
- HELP! halfshaft.
- What does it take to run Ethenoyl?
- Exhaust Question
- jdm window visors fit with out modifications????????
- have a 97 civic with a 99 si climate control
- auto to manual swap EK pedal assembly on a EG?
- ANYONE LOOKING FOR A GLASS TOP????
- Door and Heater problem...
- need sum info on h22 swap
- another eg question - locks/ignition
- Such a rough day I need help
- JDM D15B Swap
- wat am i driving?
- skunk2 struts
- help plz !!!!
- Rear endlink question
- check engine tps code HELP
- RPM Shooting up
- 99 ek and 99 ex coupe doors interchangable?
- Idle surge after motor swap on 99 Civic EX w/ d16y7...HELP
- track?
- Edelbrock victor x, good idea or bad idea?
- need help passing smog any advice will help thanks....
- PassWordJDM Intake
- factory rims question
- grinding in 2nd and 3rd in high rpm
- eg6 vs vr6
- Replaced O2 sensor still getting a code 43.
- Opinions on Greddy Turbo Kits
- Pm
- need help with friends car doing a weird idle problem
- question about b18a1 motors
- SO CONFUSED!!! Weird Noise HELP!!!
- del sol body question
- which dizzy do i have?
- HELP ME FIND SOME CTR 5 LUG CONVERSION KIT
- HID Problem
- **HELP** F20b into Ek Motor Mount Problem
- gas pedal throttle???
- seibon deck lid ?
- OBDII code 90?
- aem hybrid intake question
- Del Sol 1997 A/C
- poormans type r or h22
- 98 civic rear disc conversion help
- RPM idle HELP
- 5spd Swap Question!Help Asap
- Timing/TDC?
- Ext. Mods or 5spd swap
- shift linakge pin removal
- 99 civic rear wheel bearing replacement help need (drum brakes)
- Stolen FBP EM1
- which half shaft having alxe binding up
- need help wiring in my map sensor
- Help me camshaft question gsr b16...
- Need help s100 or s300 for my n/a setup?
- del sol eg front end conversion
- loosing brake fluid-fyi
- brake knuckles
- HELP ME!!! Harness Issues
- EM1 Brake Parts ?
- oxygen sensor heater circuit
- what intake manifold should I buy?
- 93' eg 4dr front bumper
- Any Wiring How-To's
- Powersteeering problems
- *HELP* with my sputtering Del Sol VTEC
- Need Help!!! Asap!!
- how do i install ebrake lines on ek
- ecu????
- How to fix saggy rear bumper...
- Cleaning headlight plugs?...
- noobie! repost
- Rear brake caliper piston removal.
- Couple questions about an ek hatch.
- need O2 sensor help
- EXPLAINN!!!
- CAR STOLEN MD/VA/DC area****
- DSM injectors run nice, got some ?'s
- '97 Civic - RH, Lower Engine Mount/ torque stopper
- Is this a bad brake master cylinder?
- NO POWER TO VEHICLES IGNITION WIRE FOR CD PLAYER
- SOHC to B18C (TypeR) Motor swap... Do I have to add any sensor wires to the ECU
- hx rims with falken tires, good price?
- F23 block,h22 head reliability?
- How do you remove the rear seats on a 93 Civic hatch
- ls vtec conversion
- blue smoke, new valve stem seals, good compression, no oil on plugs.
- D16Y8 upgrade path
- anybody got wiring diagram for EG JDM folding mirrors
- H22 in Del Sol
- please help on colors
- 92 EG Tune up
- AEM 5 bar and 3.5 bar map sensor wiring the same?
- When car is on, and I steer right or left, I can hear a squeak.
- Hello All, New to the Forum! Also have a question, PLEase HELP!
- What a fun morning already...
- Honda Civic Si Engine harness..
- civic 96 driveshaft
- d16y7 engine with a d16y8 intake
- How can I just use engine start button instead of usin a key
- steelies?
- Tein: Type Flex Vs Mono Flex
- Oil Pan
- walbeo 255lph fuel pump in stock civic
- EG shut off while driving and wont start HELP!!!
- Which Ecu Should I run?
- Fan does not want to turn on.
- quick dumb q Auto tranny...please help
- injector wires??
- radiator cooling fan and a/c fan does not work
- Need help with parts for LS/VTEC build-swap
- degreasing an engine bay and undercarriage?
- How to instal a Knock Sensor on a B16a??????????
- quick release steering wheel on a 92 hatch
- my eg's clutch oil is leaking :(
- oil pump
- Weird noise in motor after 4000 RPM?????????
- Need help with front disk brake
- injctors?????
- POOR MAN TYPE RR!!!!HELP
- Hello new comer.
- tranny question real quick.....
- tein s techs...
- mishimoto radiator hose size problem
- Best Motor Swap for EG
- looking for upgrade suggestions
- HOw do i send a pm to someone?
- help with horn.
