View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need help quick
- K20 in a EG6 shell
- -running lightSTOPped working-
- lip question..
- How to check CEL on '96 civic?
- brake pad shims, just 1 pad?
- my hx rims...HELP!!!
- diagram please
- Wheel Adapters??
- Tom's car on the Travel Channel?
- Turbo piping for sale. should i buy them?
- A good cheap catback system for my EX
- 96-98 hatch or 99-00 coupe???
- Civic: Acceleration Rattle When Cold
- How much did you pay for this...
- A throughly built D16Z6-sleeper--can u help me?
- What can you use to remove a stuck spark plug?
- what tires to get..
- sluggish del sol---help
- guaging interest: carbon fiber blockoff's(radio,climate control,etc. etc.)
- ATTENTION DFW Area: WTB H&R Race Springs Immediately
- Who makes spherical bearings (metal/solid bushings) for EK's?
- i will be posting pics of my championship white eg soon NY represent
- Auto to Manual ECU problem
- Emissions OBD Test w/ Hybrid EK
- Pics of GSR rims?
- 96 JDM ITR Brake master cylinder and brake booster work on my 00 Si?
- blackout need some advice
- CTR Trailing Arms interchangable with OEM 99 DX Hatch Trailing Arms???
- who wants to make $50 or so in MN...help vss
- Anyone know where to get a B20 Shortblock for cheap in So Cali?
- Fuel Pump delsol
- Exhaust going on today....
- 4040 prop valve replacement on EG
- Is this worth it?
- B16B, B18C5 stroker
- storage space for sol
- CX muffler on an Si?
- Tokico Illuminas suck ass!
- Interior Wraping Question
- After a 1000 searches..For EG Which end links for Beaks on GSR LCA? GSR or ITR?
- is an 8.8lb flywheel ok to run on a stock car with an exedy organic?
- what kinda recaro....
- Question on Honda cx's and there exhaust system
- Whats going on with these cars?!
- which ecu do i need???
- Lock Sticking
- Bolt pattern
- what do you think?
- CTR OEM rear lip
- AC on a CX with b18 very quick Q
- clock went out
- theft attempt in West Palm Beach
- power steer
- Direct Drop?
- TECH SCHOOL
- where the cheapest skunk2 coil overs??
- bad 02 sensor?
- Integra suspension in 97 civic CX
- NEED Door Trim
- EG Rear upper strut brace with SiR interior
- SPark turbo
- Playin in the snow all morning......
- DOHC ZC AND SOHC D16Y7????
- How about these?
- b16a or b18c
- 94 cx hatchback
- Pacific Performance Engine for sale
- Ext. Zenki Lug nuts on HX
- suggestions please..
- how can you tell if MAP sensor is bad?
- Speed, need more speed!!!
- Anyone know what color this ek is? racerdres old car
- SOHC help please!!!! asap
- need help please on deciding what to do with my EG....
- Need thoughts/advice on suspension setup..
- Where do these plugs of my wiring harness go?
- search failed ...... how can i tell 5speed P28 from Auto P28?
- '00 B16 into EK coupe tomorrow
- would a japanness d15b vtec motor fit a 2000 civic dx
- Integra to Civic front end conversion
- How loud is the ES Oval Universal Muffler
- b18 block
- First NW meet for 2004!
- Videos of my hatch....gotta have quicktime though.
- Spark Racing h22 to (92-95) civic mounts?
- Gauge Lighting Problem
- Pics of my grocery getter with my new camera.
- Carsound cat 02 bung question (for 99-00 Civic Si)
- car didn't pass mil/cel obd tests, what went wrong?
- I <3 my Hatch decal......... where to find them?
- good price?
- can anyone tell what kit this is?
- skunk2 coilovers: which are front and rear?
- To All The Honda Guru's This Is a SERIOUS Question....
- H&R Race on Eg
- No Spark
- Trying to get a loan from the credit union, do you think they'll give it to me if...
- My Suspension...
- Help with Removing Lower Transmission Brace/Changin Oil Pan on 96 LX
- Throttle body gasket question...
- exhaust shops in NJ
- 92 integra gs does it have a b series motor????????
- EG Horn Problem
- Name the best place to buy an OEM Civic clutch...
- Greddy, Tenabe and DC???
- can i swap my p2e with a p28??
- new pistons and piston ring question
- Are B16 and ITR exhaust manifoolds interchangeable?
- Air Ride Suspension?
- exhaust manifold ex coupe dx hatch
- del sol sir gauge cluster
- Sorry for the dumb swap question
- '96-'00/jdm type-r front end conversion?????
- Roll bars for del sols?
- rpm too short
- where can i find a GSR wiring diagram online?
- Turn signal won't cancel
- honk button doesnt work
- would a d16b vtec motor fit a 2000 civic dx (asap)
- How did you tighten your top strut bolt?
- Sorry search doesnt work for me!?! Does anyone remember seeing yellow headlight bulbs for sale??
- Welding cracked exhaust manifold?
- SoCal Sols
- what fuse in the 97 hatch is the cigarette lighter?
- Which to chose and where to find?
- CTR Calipers - Anything Interchangable?
- squeak squeak go away???
- 5th gen Auto and Manual Clusters the same?
- Strange problem with rpm's....
- dc sports lower tie bar
- EG Tein SS need ITR LCA ?!?!
- whats a fair price for a this
- still wont start
- Body kit or factory?....if body kit what is good?
- kilometer to miles per hour conversion
- what tranny code is this s8c with lsd
- how to remove pins from a plug (the new search sucks)
- sticking throttle body civic si
- honda integra engine
- some short shifters suck
- Cutting bump stop
- HELP! power locks not working
- Shifter help please
- valve cover gasket installation
- I JUST FAILED B.A.R.! :(
- christmas presents for the rides
- what is wrong with my car?
- SELLING CAI & AEM BYPASS $100
- Looking for a Norman Clark from NY
- B20 ECU?
- where to put gauges
- So I spun out and hit a tree this morning..... ANYONE know where I can get a new bumper!?
- Where to buy OEM parts?
- Help plz! problem w/catback exhaust installation (92 civic hb cx)
- Advice on a new car? Selling my coupe...
- bolt on my crankshaft accessorie pulley came off while driving
- pic of my car
- Problem with Jdm integra type r in Eg
- 94 hatchback shell
- Valve Adjustment specs???
- Prelude Calipers on a EG?
- will gsr front lower comtrol arms fit on a ek hatch
- cf hood gap problems!!!
- Wilwood brake questions
- Help me decide whats broke?
- Another brake question.. Dispell a myth for me.
- Dimensions Of a J's Racing Intake
- Short Shifter Install
- aem jackass install help me....
- 96-00 civic hatch swaybar fitting
- Let's See Some EJ1 Coupes
- funny rattle...need help
- Need help, any one know part number for 99 Civic EX valve cover vent hose?
- ? about fog lights
- Pistons?
- are 98 civic hatchbacks milano or roma red?
- Clifford alarm on 97 civic
- ***HELP***p28 ecu auto or manual***HELP NEEDED***confused
- no heat!?!
- Differences between I/M
- B16 with 84mm pistons?
- Has anybody seen this? Link Inside
- my gauge has problem, who can fix it?
- DIY clutch changing
- Mental problem with my car.
- Calling all users with lowered cars or catbacks with pictures of them!
- good place to get painted fenders?
- Steering Wheel off center and brakes not catching til almost all the way down???
- 00-01 ITR Cams, ITR intake valve springs, need retainers?
- vtec solenoid
- what ecu for a 99-00 NON vtec sohc??
- Misshift: Never thought it would happen to me
- Are JE pistons stock in a 2000 B16A2?
- Warning: Nagano Japanese Motors
- wire VAFC to show intake air temp
- eg hatch gsr question
- topic visit counters
- Dash wiring like whoa
- civic si cluster in my 98 LX
- 96 Ek Amber Cluster Problem
- **** How To DIY: Anti-Tailgating - Wire Your Brake Lights To A Switch! w/ Pictures!****
- ***How To DIY: Reground Your Civic w/ pictures! ****
- Pic request: LS mesh rims on EK Sedan,coupe or hatch
- Gloved or Bloody Knuckles?
- I need some sympathy
- exhaust question
- IN KNEED OF A OPTIONAL ASHTRAY FOR THE USDM/JDM CONSOLE & A FLIP DOWN STORGE DIN
- Anyone have a type r steering rack in there ek civic
- turbo'd, but now there are problems
- Headlights, how the HELL do I clear out my stock 96 CiViC EX headlights... DAMN THAT AMBER PIECE...
- finally a site to my hx pic
- Simple question... 2000 CTR ECU plug up to a 2000 Civic Si harness?
- Parts FS/ Please Move
- THREAD FOR ME BEING A GOOD SELLER/BUYER
- b series tranny code s8c anyone know what it from
- Wiring Issue on 92 HB DX with a 99 GSR
- Where to buy JDM OEM parts?
- How do i take apart the rear defroster switch ??????????
- brake pad squeel?
- Stock bumper????
- what a pretty good?
- EG JDM SiR Gauge Cluster
- antenna replacement help
- anyone got a wrecked car they are parting out?
- 99 ek hatch pics--NOOB--
- Cam Dynamics
- Need to know ROTOR SIZES for the following:
- SRS light - on?? how to turn off?
- want a quicker steering rack for my ek hatch ... any suggestions
- View Counter?
- Stolen: Black Turbo 99 Civic SI>> San Antonio, TX
- speedmaster wheels??
- Anyone know the Weight Ratio of an Honda Del Sol?
- WTB: 96+ civic shell
- how to reflare brake lines?
- Alarm messed with my Cluster
- Has anyone relocated their battery to the trunk?
- jumpy odometer.
- B series fuel sytem question...
- My civic was recovered in Philadelphia!
- what clips
- WHERE CAN I FIND A USED NITROUS KIT FOR AROUND 200+ SHIPPING AND.......
- check out my new TIGHT sticker
- Question.... please answer...
- prodigy motorsports?
- head-replacement gone odd
- OBD2-OBD1 - NEED HELP
- My brake lights wont light up??????Can anyone help me???
- rear suspension rattles (searched...)
