View Full Version : Honda Civic / Del Sol (1992 - 2000)
- help spot some fakers
- eg questions
- Help! Randomly cutting out then running fine
- SEALING THE CHASSIS
- funny noise from a dumped sol
- Strange brake setup on my '93 Civic EX
- Timing: Now or Later???
- Strange Grinding nosie, cannot locate.
- motor build ?'s
- k20 swap into civic or just get a RSX?
- remove intake manifold gasket
- EK9, It's a miracle...
- Eg Paint Help!!!
- 1997 d16y8 head options / thorttle body..
- cleaning up the boost
- dust boot piston problem
- auto tranny help
- Eg clutch troubleshoot
- can i use an ls engine harnes in an eg
- New Memeber ! NY
- d16y8 or d16z6 block
- d15 d16 block difference
- ek d15 to a b18c4 engine
- i need ek4 d15 wireing diagram
- Anyone running J's Racing front lip for EG? Which sides?
- Spoon Thermostat and or Mugen Fan Switch?
- Vtec question
- Domani Front?anyone know where i can find one
- 2000 civic AC PROBLEM!
- H.I.D. problem. (flickering bulb)
- How can I fix my civic:(
- engine and tranny swap question
- Help with clutch problem
- Exahust Muffler Choice. Help me decide once again....LoL
- tranny ?
- Honda civic hatch 97 No spark please help
- D16 sohc vtec or ZC sohc vtec?
- 92 Honda Civic JDM B16 Swap not starting (Searched)
- Gauge Cluster Issues on 92' EG Civic..
- air/fuel ratio guage installation question..
- vtec problems
- Just bought 2000 Civic EX list of problems
- SPC LCA's
- Overheating problems with new thermostat!
- car not starting
- d15b7 Budget Build
- Stolen 94 EG Civic hatch in MKE area!
- idling problems already cleaned iacv and adjusted screw
- H23a1 into a 95 dx
- H22 axles for civic
- Need your help Honda Tech, ignition Problems
- What is this? PICS
- natey57's EJ8 Build
- replacing my head from y7 to d15b7
- cast iron or welded tube manifold?
- New motor???
- 92 Civic Hatchback wiper arm replacement
- Freeing a stuck bolt on the auto tranny for drain and refill.
- One peice flywheel
- what zc
- Hubcaps
- Irish Newbie (EK4 SiR)
- Auto tranny problems need help!
- 96 ex 4 door auto drive lights flashing???????
- just bought
- Which airbox for B16A in EK, + GSR tranny bolts.
- New CA cat woes......
- Rear lip AND mudflaps on 97 coupe - possible?
- white smoke
- Trunk tray/base cracked what did you use to replace?
- CEL light wont read codes
- need advice on b20 vtec swap
- anyone know much about EG CLUSTERS!?
- B20b engine swap
- Civic Swap - D16 to B16
- Booster, MC and prop valve from NSX in EK?
- Problem:Code 14 IACV
- noob question plz dont flame
- Integra Cluster into EG Civic
- Where do they go?? (big blue wiring connectors behind dash)
- new need a little help
- [DIY] 92-95 2DR & 3DR JDM/EDM Civic "Walk-in" Rear Passenger Seating Upgrade
- eg coupe lowering help plz!
- injectors integra type s on a d15? HELP!!!!
- exhaust flange 10cm to 12cm adapter?
- Del Sol One piece headlights
- b16a2 slow launch
- Help....stupid problem
- no VTEC... HELP PLEASE
- Needle's on my cluster broke. Now what ?
- Oil pan fitment besides b16 for my b16a.
- bigger wheel affect speedometer?
- Need Help finding the right suspension for my EJ2.
- 1992 civic exhaust system question?
- 94 Civic Speedometer issue
- air duct for 96-98 ek front
- Bypass Valve Question
- Need help with 95 Civic transmission compatibility
- need shock tower plug pinouts
- Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
- engine tranny combo
- 16deg on timing gun when OBTC is lined up with triangle? Is this right? Searched
- GOING RHD
- Sad day for my ek :(
- code 21 and code 6 --dont have a vtec motor
- Quick TB Question
- Distributor help
- 97 hatch converted to obd1 d15b bottom end z6 head Wont start
- Failed smog, 2000 gsr swap w/ BAR 2000 civic cx
- need fast help with sensor please
- City lights?
- 92 civic speedometer problems
- power window conversion complete, nothing works
- mini-me swap help (ecu)
- EG short shifter
- ???b18c1 swap in ek.Need help???
- will f22 iacv fit h22
- VALVE COVER
- check engine light help
- 99-00 Ek Foglights cracked?!
- Need help with part number!!!
- Lost of power
- b16b wont run right
- 95 cx needs some power
- I need help! Please Give me your input.
- project EG hatch
- Screeching metal sound when loading engine/transmission.
- integra sway bar on 99 civic
- cracked my oil pan.. help asap pls
- o2 sensor issue
- A/C Help
- Sputtering high load/heavy throttle
- Trouble Code PO113
- Anyone with viper alarm
- Aftermarket gunna fit?/
- type r wing on eg coupe in carbon fiber. what do u think?
- need to make seat brackets. HELP!
- Motor Swap Questions
- My gold ek, need your opinion on my car plz and what color should i pain my calipers
- The Aftermath of the Civic-Inputs requested!
- HELP!!! TPS code 7
- edm eg bumper moldings
- Fuel Pressure too high? 44-45psi
- DId any one tried putting HX wheels on EX to improve MPG?
- EG H22 Axles???
- Cluster to use for a 92 Civic Cx? (NOOB ?)
- Is this Rear Bumper OEM? PICS INSIDE
- 1999 civic si: water draining into trunk
- How do i fix these check engine light codes NEED HELP ASAP!!!
- will my srs light come on if i remove airbag?
- Upper ball joint removal
- post pics of 16" xxr on eg
- Heating Problem
- foglight wiring question
- video of civic AWD off-road
- kill switch
- 1992 Civic Performance Help!
- Thermostat Housing Leaks
- NEED HELP FROM YOU SI GUYS
- What do i need to do a B16B Swap????
- 93 integra starting problem
- b series power steering pump
- Front Rotors Warping Constantly!
- CEL wont light up
- CODES
- d15b (dual vtec solenoid) into 99 hatch
- pw:jdm 3point brace hits gsr tb cable bracket on gsr ek swap
- I'm new. and young and dumb.
- Are the 1992-95 headlights/taillights interchangable?
- Rear hub bolt(Disc) .
- ways to keep engine bay cool
- CONFUSED???? 36 MM 5 Lug ??? Broke my axels
- Timing belt d15b/z6 head i dont know if this is timed right help plz!
- Idle issue (Might be linked to coolant leak?)...Searched, Tested...need help
- BMC CDA Induction Kit vs Mugen for EK? - pics included
- acura el
- better or not?
- swapped intake mani and cracked fuel injector
- B16A rear mount problem.. plz help
- Touched ground w/ positve post....
- what do you guys think of my 99 ebp...
- possible after market steering wheel issues?
- H22a civic idle issue
- Can't get crank bolt off engine. HELP!
- what should i do to my eg wit a h2b in it?
- anybody know what rims these are?
- 36mm 5lug converison axels Q's....
- How to check Tranny Fluid
- ECU P27 need "RM2"
- How to replace rear wiper on EG hatch?
- flooding and no compression NEED HELP!
- Is there a clutch master cylinder rebuild kit availible anywhere for a eg civic?
- Idleing Problems??
- H22 civic EK 98
- K20 swap on a 96' civic hatch
- how to tell
- LS into EJ8
- anyone have no radio?
- transmission ?
- stereo harness HELP 95 civc!
- d1678 throttle body?
- Stolen Del Sol
- Copart Question
- Is this a good deal? OEM cat and harness $80 ??
- Roof/window leak
- help!!! civic eg!
- ls into 96 ek
- Any 99-00 si's for sale around MD
- o2 sensor for h22a and P13 ecu
- MAF location on LS/VTEC
- 95 Civic Ex with H22 swap turbo
- 95 Civic Ex with H2 swap turbo
- Q about a dizzy on my swap..
- spare tire well removal
- another poor mpg thread...
- Engine sometimes not redlining at 7200 rpm
- Bogging during acceleration JDM B16 in EG
- falls flat on face 92 d15b
- b18c5 crx swap to 97 ek coupe.
- Temp Gauge innacurate? Fan not operating?
- New member from Nw Ohio
- whirring noise because of alignment?
- Sway bar question
- Em1 insurance
- Where to Purchase a New Engine for a 1993 civic?
- Stupid Question?
- Buying 97 Civic question
- Transmission Fluid
- whining noise help please
- Engine and Tranny Oil leak and P1337, P1381.. Please help NOOB
- Need help with clutch fluid leak *PICS*
- Where is my Air conditioning sensor? Details inside
- car wont start... cold weather maybe?
- advice on how to wire up my b18c engine?
- Wont start no CEL when in "on position"
- p73 ecu b16 no vtec wtf???
- EK hatch sunroof? Looking for EDM roof skin and part number...
- Problem with brake lights. HELP!!
- How to swap a B18 motor in a 92 civic vtec
- obx highflow cat need answer quick!!!!!!!!!!!!
- clutch fluid leaks inside car
- For My 98EK-LX and 95EG-HB.....How do i fix these problem??
- noob trans question.
- can some one help me out with a seat please (LA CALI)
- My EG and $1000
- Honda newb, what mounts to get?
- clicking/ knocking noise need help please
- 1992 civic si b16a swap help
- new to the honda game need opinions on turbo kit
- the boot....security question
