View Full Version : Honda Civic / Del Sol (1992 - 2000)
- jdm d15b swap troubles... please please read....
- Possibly buying a Civic Si
- electrical issue with tach
- VTEC light?
- JDM D15B into an 98 EJ Ferio
- CRX shocks interchangable with 96-00 Civic?
- Question about CTR Rear Sway Bar
- 97 Civic Radio Install
- JDM SiR Fog Yellow Lights?
- eg coupe and ferio headlights
- y5 block y8 head?
- about this tenzo r air/fuel ratio guage
- Omni Coilovers
- blown cat?
- AEM Fuel rails????
- Why get a Honda?
- Qwik Qwestion
- help, b16 sir2 into eg
- H22, what next?
- b16a...high idle on cold startup!
- what tires on ek-civic-dx with rota circuit8
- 94 honda del sol si how hard is it to put B18B1 into my sol
- Anyone Know anything about Chasis??!?!
- how to clean engine /intake manifold?
- somethings wrong
- Dumb swap ??
- D-series to D-series: Axel removal
- Anyone have a 92-95 HB Rear Diffusor?
- AEBS and PCV Valve?
- Dashboard Covers
- Auto to Manual conversion? How much?
- Hybrid EX/Si/ZC tranny
- H & R racing springs with Bilsteins shocks
- Help newbie!
- Rattling at WOT
- transmition problem
- Already used search :(... tachometer problems!
- Mini-me vs. JDM d15 vtec swap
- HELP: installing a front lip for del sol
- NEED HELP VTEC
- My B18C5. I need Help/Advice
- How do you change the trun lights in a 2002 civic ex
- why the dont have an civic si Forum????? Like type r's!!!!
- who runs springs where the headers join the test pipe/cat??
- why do some people not like the transmition mount...
- Question about a stabilizer bar on a 93 del sol
- Congratulations to B18C5-EH2!
- Iceman CAI Throttle Body Inlet Info?
- Those with Apexi N1 exhaust or other straight style exhaust
- Where to find a good deal on wheels...
- would da9 seat brackets fit?
- SRR Final drive in VX tranny....SEARCHED already
- gsr/k20/b18c5??????!!!
- Converting SOHC non vtec motor to SOHC VTEC?
- do I need to upgrade headstuds?
- Hydrolocking?
- 92-95 Civic Hatchback rear disc brakes on EK
- DENSO O2 Sensor...any good?
- DIY post??
- D15B VTEC Parts List
- Anyone with pics of an ES N1 on an EK?
- wiring harness for a d16y8 anyone?
- Need Susp. Help...
- $1.99 cleaner works wonders...WoW!
- Suspension Question. Help Please.
- whats the quietest performance exhaust for a 97 ex?
- what is this gray plug? please help!
- hp stock?
- WTB 92-95 HATCH
- FIRST TIME SWAPPER!!! NEED HELP WITH ECU FOR MY EG...
- prelude clock into civic
- getting ready to do my first suspension................
- clutch problem?
- eg spoon/replica c/f lip durability
- 98 Honda Civic CX hatchback
- Any one selling anything for a 96-98 civic i.e. bumper, stock silver parts,
- Hatch Lifts supports EG
- Removing long block while leaving tranny in engine bay
- A Mutt DOHC Vtec???
- 1992 Civic hatchback teal green. what mods??
- spoiler from 2dr to a 4dr
- SRS Codes
- JDM B16A w/ JRSC & Boost Upgrade?????
- Need help - Crank bolt
- d16y8 IM + b series throttle body + d16z6 = throwing codes??
- how much are motor mount inserts
- phantom grip lsd or CTR helical LSD?
- help! 98 ex or 97 lx?
- Using APEXi VAFC in D16Z6 stock engine
- Stainless steel catback piping pre-bent?
- ok clutch is scary....
- head question
- I cant find a ITR block.. HELP
- Will a EG bonnet fit inthe back of a EG?
- hard to shift into gear...help
- b16a1 motor swap probs
- Need Help! Car is thorwing code 91?????
- Urgent Swap intake question!!!!
- what d series in 93 si??? plz help
- Just got 1993 Del Sol and I want to Pimp it out, need some help on what to get
- how to remove long bolts in headlight bracket
- clicking from my steering column
- Air conditioning queries
- Loud clicking noises when I brake.
- JDM Sidemarkers for EK which plug to use?
- where to find a P07 ecu racing chip
- VTEC Malfunction
- RANT: "EK" Coupe and Sedan Exhausts Are the SAME!
- Shakeyness
- How much do eg hatchs go for?
- Type-r strut bar onto 96 hatchback
- what do i need to put injectors from a obd2 h23 prelude in a obd1 z6 swap
- Engine swap
- Need to find something! HELP
- What color is my car
- ok so im gettin my mini me swap done
- Rim size question
- Brake conversions
- HELP MAP SENSOR IS A BIATCH
- >>>Quick Honda RPM reading<<<
- VAFC-II..i need a little bit of a favor
- Quick Question
- OBX Exhaust System?
- Clutch Pedal ?
- camber kit question
- Oil aditives
- distributor wiring for crx
- clutch delema
- Light crank pulley with turbo.
- Need Help
- GT Radial tires
- Where to find USDM audio console.
- Newbie heir to 97 civic dx but NO TACH! How to get one?
- IM need some help on coverting my 92 headlights into 00 skyline lights
- interior dash panel?!?!?! ARGH!! Hit this up peepo!
- whats better 15's or 16's Rota on del?
- skunk2 stage 1 cam timing
- Cold Air Intake Tutorial?
- Removing/installing clutch w/out alignment tool???
- How do I pre-determine a certain offset will clear my calipers before purchasing them?
- what other option do i have for the drivers side motor mount??
- need oil pan gasket part number for civic si 99-00
- filling in stock spoiler holes
- DC Sports Exhuast System?? Or Skunk2 exhuast System?? Anyone selling or something??
- Hood Pins vs. Hood Locks
- Sites?
- Just installed at AEM Cold air intake (D-Series) into my civic. I Got a question!!!!!
- specific brake swap help (ive searched already...)
- Running open exhaust?
- JDM fogs, do it yourself
- power windows not working, 93 EX coupe
- How long a stock Engine will last?
- my eg is running slow?
- PB Blaster
- I need to re-upholster my headliner...help!
- exahuat/muffler advice ASAP please peeps!!!
- Speedo question...
- REALLY Loud high pitched whine when I start engine
- low level shutoff
- Mini Me (whast it worth to you?)
- Show your sympathy for this forum by doing something fun!
- starting problems
- Upper Radiator Support
- Rear brakes problem
- how to leather wrap seats??
- did you think that honda was planing on all the motors swaps?? like the gsr in the eg hatch plug n p
- B16a2 engine questions
- quick question?
- 92 EG si rack and pinion in a 92 cx??????
- what kind of sander/ prepping
- seatbelt problem
- Canadian Acura 1.6 EL is 6th gen civics twin
- JDM mirrors on eg??????
- SEARCHED....what to do next?
- weight of steelies?
- Harsh ride..ass bruiser!!
- questions on civic turbo
- smell clutch?
- lug nut stud..
- prothane or energy suspension motor mount insert kits? which brand?
- Is this a JDM EG Civic console or something????
- 98 honda civic question about how much i should sell?
- ANY GOOD SHOPS FOR BODY WORK IN NYC AREA??????????
- This is in reguards to the 2004 honda civics...
- Taking my B18C1 Hatch to the smog ref... will having a switch for the radiator fan be a prob?
- crashed my ek...check it out....need help
- Hollow out my cat! I need help....
- tb and intake mani??
- Spoon side mirror question
- Clanging/ticking noise?
- Adding exhaust resonator
- MY CIVIC HAS VALVE TAP!
- Alignment Shop NYC Area
- WTB!! Wide body Fenders for a 00 Civic Si 2 door!
- hatch struts, which are highest quality?
- Rattling Hood
- hey
- Turbo Install EG PICS!!!!!!
- I need some information about my swap?
- HELP!!! getting tranny off, stuck at last step....
- need help with 92 hb CX .............
- LS disc brakes vs. GSR disc brakes, are they the same?
- Help pulling out engine!!!!!!!!!!!!!!!!! (n00b)
- Bay Area
- Full cold air ntake on my gsr swapped EK sedan?
- Best place to buy a JDM Engine
- Need help on rear seats... GSR CONVERSION
- Hello
- Bolt ons and horsepower gains
- Clip broken on wiring harness
- anybody kno where to find omni coilovers (sleeves not full kit)
- Noises when i brake...help needed
- ayy!
- Sideskirt question 99-00 civic
- what seats fit in a 99-00 coupe?
- Sensor relocation on Skunk 2 Manifold on b16A2 Swap
- How much can I get for my Si EG?
- b16a out of a del sol info
- Blow Off Valve Piping
- wiring a OBD2->OBD1 DIZZY
- codes 3,10,41 and won't rev past about 2500, help!
- OBD II B wiring pin outs?????
- Question from a n00b
- Where is the best place to mount my PS2?
- Wiring Question: Rear Wiper, need to know voltage and wire colours!!
- Sagging civ
- Throwing CEL
- vtec solenoid?
- Dent Oil Pan
- Type r brake question
- anyone have parts for d16y5 (civic hx)
- 00 Civic owners: How do i remove my door panel?
- how to: timing light
- 96-98 to 99-00 Civic HB conversion
- 97 civic.....problem in 1st gear
- Warrenty about to run out on my Si, what to check?
- ek exhaust (2dr and 4dr)
- line on crankshaft pulley
- ***High Flow CAT turns CHECK ENGINE LIGHT ON?***!!!
- Honda Oil Filter. Some questions.
- two problems---runnin hot, burning oil
- EK9 PARTS
- springs and bolts for ITR headers
- KYB AGX questions
- 96-00 civic sohc manifold
- type of honda/acura?
- I Need A B16 tRANNY !!!!!!!! sOMEONE sELL ME one
- Wheel Bearing Question
- Causes of overheating?
