View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Heat not working; 99 Honda Civic DX
- Need Info On OBD2 H22
- Anyone know what brakes fit a 92 Civic SiR?
- fludded motor
- need help with aem standalone
- ek yellow square fog lights on 92-95 civic
- need help with my aem ecu!!!
- Body kit help
- 94 civic dx tranny (cable or hydro) K20a2 swap winter project
- Thermostats should open... even in cold weather right?
- Where can i get my Motor bar'd? HELP
- will a 99-00 tail light fit on my 97 dx coupe?
- 97 Civic New Clutch & Axles...now won't start?
- 1998 Civic Door Locks Stopped Working
- pic request!
- carb conversion help?
- eg rear seat ???
- HELP ME HATCH
- ok signal lights dont work bulbs are good
- eg esi doesnt start..???? battery seems ok
- Shocks and Struts
- Yonaka coilovers?
- CLUTCH ISSUES!!!
- apexi n1 or hks hi power
- 94 civic EX COUPE D16z6 FUEL FILTER install question HELP
- Unknown CEL, High idle, RICH, help!
- Shift Linkage Question?
- which IM is better?? y8 or z6???
- help please
- TPS question
- air filter making wooo wooo woo sound
- B16 or GSR Swap
- fuel rail oxidation???
- headers on ls/vtec
- windshield washer bottle question
- Lighting problem 94 EX
- Axle and Suspension Question
- Would this tranny work?
- Fuel pump question
- Slightly ripped CV boot, can I fix?
- rear sway bar on a 94 sedan
- Diagnosing rough idle...
- CA Smog!
- D16z6 swap in to a 96 civic ex. HOW HARD?
- harness bars żżż
- D16z6 swap into 96 civic ex. HOW HARD?
- Time Belt Differences??
- stock motor mounts!
- 96 CONVERTED TO 99SI
- car having trouble starting
- How to check CEL code on '00 Civic
- EG with H22 Swap
- Help!!
- My car is sputtering
- windshield washer disconnected
- cam an came gear help plz
- 94-95 srs control unit help!
- 97 hatch speaker rattle
- da for eg?
- Smoke on deceleration still..
- Gas gauge no longer works?
- OK MY CAR IS NOW SPUTTRING
- (Shock fitment??) 94-01 Shocks on 96-00 civic
- valve tap
- D16z6 sputtered and won't start
- Tips for frozen door lock...
- Clock?
- No heater in my beater...
- EM1 Respray color!!?
- help window regulator
- rocker replaceable?
- Questions about removing the tape player on 92-95 civic HB
- Please post pictures of PASSWORDJDM back lip on your ek.....my bad experiance
- Adjustable coilovers
- compression ?
- Heater Problem
- heater problem
- what would u chose?
- 4-1 headers/4-2-1 headers.. GROUND CLEARANCE!!!!
- Coilover recomendation for 2000 SI??
- Fuel System for 2000 SI with Vortech?
- D15B7 block Z6 head. information needed.
- what do you think
- how do i replace my 97 dx doors with ex doors?
- b18a1 swap trouble
- A/C evaporator gone... what about heater???
- b16b + n2o
- Trying to check CEL in ITR swapped eg?
- Del Sol Si upgrade...
- stiff e brake that won't go up after brake job
- Need to know what parts for pwer door conversion
- msd ignition
- 2000 Civic SI Wheeles
- Wiper switch from 94 civic into a 99 civic?
- Ecu trouble code diagnostic confusion
- heater doesnt work.
- car randomly shuts of while driving???
- brake problem
- brake fluid leaking help
- KMS Valve Train
- motor mount question
- How much km or miles do you get from 1 tank of gas from your civics??
- low idle need help
- d16z6 really low rev
- '96 Civic HX engine/ CVT trans question
- 99 Civic EX considering trade
- need help wit my fog light???
- Will DC2 rear seats fit in my EG sedan?
- Looking for opinions on my oil issue.
- Blowing Fuses
- Racing seats
- Authentic????
- 00 Si Exhaust Quick Question
- b series starter
- AC not blowing from center vents????
- Problems after wiring fog lights
- buying a body part.
- cluster problem.
- Nasty squeaking when reversing
- srs airbag light
- Main Relay question
- 93 civic hatchback has jerk when turning
- HELP!!! [leaking power steering fluid]
- b18b1 into EK civic
- 92 hatch cutting out problem
- d16z6 swap on a 93 civic dx
- HEY NITROUSE HELP
- How do I change the mileage on my EM1 cluster? (it's legit)
- Wires cought on fire - need to know where it goes
- b18b1 swap into ej8...axle fitment question.
- 94 Civic Ex coupe d16z6 slight faint smoke coming from engine area
- New here, my b18 Ek
- Buying OEM paint. Where?
- H22 Idle Problem
- what are signs of clutch slipping
- should i trade?
- FAQ: How to Install JDM EG Rear Interior - Pic Intensive
- p28 on d16z6
- '00 Civic Springs fit '92 Civic Coupe?
- Help Needed ASAP!!! Car wont start
- dual double head vtec???
- Cruise Control Adding to a DX '96-00
- need a part number
- how to bypass the neutral safety switch.
- motor shake!
- Need help in putting sunroof in car or to get it done
- Resonated test pipe : 2.5in to 2.25out
- d series axles
- 94 dx obd1 ls swap NEED HELLP 4REAL
- need info on b16 motor
- clutch not disengaging??? help
- lowering a 94 eg
- 99-00 Si Center caps in GSR Fat fives? *pics*
- help with wiring
- what to do build hatch or my si
- 99civicftw's *OFFICIAL* project thread
- Help!
- K20a with $8,000 what would you do???
- GSR leather seat into my 94 EX coupe
- no CTR section, think some one here would know
- H22?
- New here
- 95 ls oil pan bolts
- B16b engine Options with $10,000?
- gsr wont start
- Low idle around 400 RPM,
- vafc-1 hack... help meh
- i have a couple problems
- Sir Doors on Ek Hatch
- Knock Sensor for B & D series
- what company steering rack should i go with?
- What heads came on d15b8 blocks??
- TPS and MAP sensor issue PLEASE HELP
- running without a fuel filter?
- Performing cooling system service, suggestions?
- New to honda-tech, My eg
- Power Lock problem
- 98 Civic EX Coupe.:.Tire Stretch
- shifter moves
- obd11a motor in obd11b auto help
- PLEASE HELP wont start?!?!? Fuel Pump? Video Inside
- Clash Of The Civics - Battle At Sepang
- coilover install gone wrong!!!help!!!
- H22a 93 civic hatch ~ use integra axle?
- 98 civic ex..98 civic cx hatchback
- Car never warms up...
- Question about which brake lines to buy on my 98 coupe
- 95 Civic EX wiring diagram
- How to Do a si conversion on del sol.
- ENGINE TICK! vavle tick? please help!
- my car when i was in highschool
- 2000 Civic Si startin Problems
- anyone seen this car before?
- s2000 cluster still possible?
- 96-98 AC Conversion to 99-00
- New EM1 OEM Lip fitment
- is there suppose to be a clutch resivor on my 5spd
- Headlight bulbs
- Car sounds like a Subaru...not headgasket.
- I have a problem with my tokico Illuminas, plz help
- eg8 idle problem
- stock injector size
- 2 issues- egr cover plate? sending unit and fuel pump?
- PLZ Help identifying tranny parts * Diagram provided*
- Taking more time then thought
- Quick Civic Front Bumper Question
- aem programmable engine management system
- Problems with 2000 civic ex NEED HELP?
- Website with best complete swap prices
- location of the 2nd o2 sensor outlet?
- Idle problem after motor swap? help please!
- How do i know when my shocks are bad?
- eg6 question
- B18b1 Help...
- intake hose ?
- Rear window defroster..
- 93 hatch ISSUES!!!
- DEL SOL HELP..
- Swapping door skin? or just arm rest?
- Power door lock problem 1998 acura 1.6 el
- Timing question... retarding a tooth?
- transmission ground loose
- setting timing
- pinpointing the problem?
- Rear bumper vents
- ---->Y8 head on Z6 block<----***FIXED***mods could you add this to the faq's thread
- Trunk release?
- roll cage? (cusco, auto power)?
- what ecu should i use?
- Help please. 98 Civic Door panel removal.
- car bogging/stuttering @ low rpms
- quick trany question
- stumped no spark....
- i have a '97 civic hatch
- Back seat swap both are so seats
- what kind of wheels are these??
- eg b series swap and now exhaust problems
- Del Sol dash Harness help
- 6th honda civic gsr swap
- Air Ride Suspension
- vss question
- EK Power Door Conversion
- constant smoking under the hood...
- rear lower control arms question
- remove 2 layers and keep 1 in the head gasket ??
- d15b/d16z6?
- OBD1 LS ECU Problem...
- HELP need IACV hose locations please!
