View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Clutch stuck. Help Please
- best option for black floor mats(98 civic coupe)
- OMG I hate my Sol
- 92 Civic VX cranks but won't start after sitting 8 months??
- Timing Belt Changed - Check Engine Light
- Steps to register an EK9
- idle problem when engine is cool
- using integra sway bars
- all you wire tuckin fellers!!
- CEL Help on a 95 CX hatch
- EF Full core Radiator into 99-00 EK?
- A/C Help
- please help!
- "Only in the mornings" Temp gauge question./ISSUE RESOLVED
- Help axle stuck !!
- B16a throttlebody gasket
- Jdm ek (96-98) clock wiring question???
- 00 civic ex o2 wiring need help asap !!!!
- 2000 civic ex o2 Wiring??? Neep Help !!
- Help with motor not starting.
- question for eg back seats
- EG Doors vs. EK Doors
- motor mounts?
- is my 93 canadian hatch....
- Stumped on a d16z6 overheat
- Speedometer & Odometer don't work
- 00 Civic Dx Hatchback Misfiring
- Install 99-00 OEM raybrig fogs
- 92 hatch swap
- Engine swap info please
- GSR Knuckles on EK
- Help with brakes?
- 99 si tires
- Ebay Motors??any good!!!
- Clutch keeps on sticking. leak somewhere?
- Need help on rods size D16Z6
- Something stuck in spark plug hole?
- rev limit
- How Much do VX wheels usually go for?
- Climate control backlighting issues
- Newbies new project now won't start..what did I do?
- IACV o-ring gasket question
- cel 73 on a 00 si
- Will EG shock tops fit on EK ?
- buying new tires not sure which ones to get
- Bleeding the Clutch
- Momo type r steering wheel 4 sale only!
- :) Maybe..
- Intermitten No-start problem - No fuel
- Check Engine Flash
- size of apexi gt header flange.
- help!!! vtec breaking up.. Nothing seems to fix it!!
- Different bumpers question
- Final Drive of Si-R transmission ?
- BAR'd b20b?
- How can i improve my steering??
- where to get dowel pins?
- type-r (98 spec) final drive in b16a2
- Power Steering install on a 97 EK Hatch?
- gsr head
- Side skirts interchange?????Need Help?????
- b18a1 wiring issues
- Paint Codes
- z6 cam in a y8 head
- EG6 with Prelude Suspension
- Looking for good info into swapping a B18C5 into an EJ6
- a0 p73 piston in my stock usdm gsr block
- EG hatch o2 sensor question
- my rebult mini me swap, wit pics
- Ideas for Project Civic Come Alive
- just sold my built turbo ej1. looking into buying a vx :)
- EG civic hatch with ls vtec swap
- 97 HX engine sputter?
- j30 swap eg
- eibachs or teins?!
- Smog Help
- 2.75 Piping on a 00 em1??
- Step by step h22 rebuild
- clutch squeaky noise?
- Battery relocation
- 00 civic si b18c5 swap code p0171
- .58 TPS VOLTAGE closed.
- info about a p28
- won't start but all elements are there, also air in coolant
- EG Tranny into Ek
- clutch problems...
- D16z6 turbo first start idle pegs at 5000 RPM WHY!!!
- Re-pinning ls harness for vtec
- gas mileage!!!!!!!
- Exhaust issues/
- help with surging at idle 96 civic ex
- Is there such a thing as an ek4?
- Ct engineering
- Cusco cage
- What caliper did I get?
- What is the proper way to break in a new engine????
- need the axle nut size!!
- h22a8 build
- Bumper Cover and Fender Replacement
- check engine light on 99em1
- obd2 to obd1 dizzy
- ZC question about specs,hp, tq, and redline
- 97 cx b16a2 swap wiring help
- Rear wheel bearing service?
- Del sol tranny swap
- oil leak issue....
- EM1 cel code 9, 76, & 90
- how to remove climate control?
- so much smoke
- Delsol's suck
- AT-MT converson harness
- loss of power an pining while accelerating and up hill
- crv i-vtech awd swap
- Making an adjustable hinge for my CTR wing
- Black Steering Wheels?
- weight of 95 DX COUPE
- question
- What is a dizzy?
- z6 help for my sol
- 94 sedan or 93 hatch?
- full throttle lags
- best spark plug wires
- slugish mini me
- Need to know, k20?
- B20 Fuel help
- Need help identifying a dizzy
- ac questions about my 93 si civic hatch.
- Hi
- 95 Civic DX, need advice for swap
- cel code numb.43
- Question on Raceseat base mount in my 92 hatch
- Have Mugen axle-back, need to complete exhaust
- H22 in EG Question...
- TPS - Throttle positioning sensor problem.
- what wrong with this picture
- TB butterfly stop screw adjustment
- dc5 vs dc2 recaros
- HELP car idles at 5k!!!
- How to for T-belt/Water pump?
- 93 honda civic starting problem
- 95 2dr coupe, bump steer kit recommendations?
- Need help identifying this part - 1997 Civic EX
- Replace steering rack question? NOT A POWER TO MANUAL THREAD!!
- coolant fluid mixture of how much?
- how do i chip my ecu?
- b20vsb18
- stripped a valvecover stud what to do
- My car is dead. Help: Engine Swap Question
- need help with springs and shocks!!
- need help with getting a b16 bar'd
- valve lash adjust question
- HELP! New Ca Smog LAW. No aftermarket CATS? need to pass Bar
- 96 rear lip and 99 rear lip
- Is Radiator Different in Auto Than Stick
- Couple questions..
- fully built b16a?
- Any NICE 96-00 Civic PROJECTORS out there???!!
- jdm audio console
- need help: when i gas there is a huge rattle
- right headlight only works when brights are on
- Need help/Advice with B18 swap
- obd2A p72 or obd2b pt2
- Re-Torque Headstuds
- eg foglight harness diagram
- 95 civic tranny
- Can you use the same transmission?
- B series questions.
- 16x8 on civic coupe?
- map sensor help
- Help pass emission!!
- My 1st actual swap Pics!
- how to check ball joints
- OBD2A to OBD2B or OBD1 question
- jdm d15b running like crap
- Idle Problem, clean IACV, adjusted Idle set screw
- v-tec dummy Question
- how many MPG does your D16 get?
- d16y8 with p28 ecu issue
- What acctually grounds out at thermostat?
- gutting a car
- 97 EX Throttle Body Diameter
- car clicks and dies, any ideas?
- Not the same old power folding mirror question
- Engine swap poll
- fuel line pinched?
- a few questions about california state ref.. b16a3
- vtec problem(please help)
- OBD2A car OBD2B engine
- Eg hatch dies once started unless revved
- question about vtec head/s and d16y7
- Quick questions (trailing arm)
- Steering...crooked.
- distributor wiring help
- Civic will not run
- Battery relocation..
- 1996 Civic CX No Start Help
- Buddy Club SPECII will it fit my 94 coupe?
- the difference between automatic and manual cams?
- need some help with paint color name/codes
- experiance with ek wheel bearing replacement?
- roof rack
- To buy or not to buy... 2000 MR Civic Si?
- y7 exhaust manifold into a d16z6 would i pass smog?
- then and now
- delete
- Ok WTF NOW!! New Problem!
- EG wiring question
- Idol problems
- h22 in civic
- sway bars on my 92 vx
- CEL 22 VTEC working, but falls out
- b16a running rough in 92 vx
- Iacv? help please
- 93 civic died
- b16 revlimit setup
- how much do you think this car is worth?
- License Plate Question
- p06 ecu
- B16a engine or a full rebuild what do use think?
- engine question
- Engine swap 2000 to 96
- maitnance light ?
- DA intake mani
- Rough Start, Sputtering Low RPM Accell
- Tried to Bleed my coolant, none coming out...
- 97 DX needs a starter, choices?
- Need a coilover (key)/unless there's a trick?
- JDM leather seats for 96-00
- exhaust question - b16a to ek swap
- What are some NICE JDM rims for egs?
- wire color
- Wut is better plz help
- Just bought my first Honda.
- what the difference?
- check engine light problems.....
- Individual/one set suspension?
- 95 integra t bracket into eg..help
- Info on Jdm type r tranny and what to look for?
- help on buying a del sol
- Quick ecu question.
- Possible Instrument Cluster swaps for my EG
- Gsr swap into 94 hatch.(Wiring) ???
- ctr vs itr tranny
- Eg suspension?
- 92-95 Civic EX coupe engine swap?
- skunk2 Intake manifold Question
- 93 del sol running rich at idle and lean at WOT
- 94 gsr
- huge problem with b16, no vtec, bad idle, etc
- Car cuts off at idle
