View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1999 Si Headlight conversion on 92 Civic Hatch
- whats the 'best' supspension JIC makes?
- Pics of my Black2kcivic (56k needs to get some Astro Glide!!!!!!)
- has anybody needed extra parts from Honda when you dropped your car?
- ** URGENT! ECU code....please help! **
- Car won't crank over at all
- finally got my spoon lug nuts
- exhaust??
- how do i put teg mirrors on my ek
- 92-95 Civic Swaybar owners, take a look
- Project EK........RIP!!!
- ecu question
- Largest tire size on lowered hatch?
- Code 73 or 74
- 02' Si Front-end Noise
- D series nuts gotta problem 4 ya
- RS*R or SKUNK2 or Apexi N1
- Tranny problem?
- I need a test pipe in Orlando
- Need help opening the hood!!
- Tein problem Need help quick
- VSS wire question, can someone look it up in Helms for me.
- My engine size/code once and for all
- OBD 1 or 2???
- my ej needs brake help.
- KYB GR2 vs Tokico HP
- slotted and drilled rotors.......discussions here!
- B&M FPR and gauge install question
- P28 ecu ?
- Ball Joints and tie rods how much $ do I need OEM?
- Got a 14" tire lying around....anyone want it? FREE
- VAFC tuners....
- Y8 Turbo in a Porky 94' E Coupe
- b18b...is it salvagable???
- Progress 22mm rear swaybar?
- GSR front sway bar on 93 del sol.... progress adapter kit?
- Anyone order from rpmmotoring.com?
- Turbo on ebay
- can anyone help.......radar detector??
- Slotted Brembos(stock size) or OEM SI( 99) discs brakes on 92 Hatch??
- obd 2 wire harness onto obd1 motor.....HELP!!!
- spring ? integra or civic?
- Tech for the Day W/Pics : Resurection (56k beware)
- obd1 distributor ?? what replacement
- 18's Rubbing
- Anyone else dealing with MotorVation Performanace, Inc., NM
- SI(99) discs + Teg RS(94-99) galiper...does it fit??
- Motegi rims. quality?
- body and paint shop in so cal
- Who has a GSR or ITR front lower tie bar on their EG/EH????
- idle problem
- Do these prices sound right for bump stops for a 6 Gen coupe?
- rates at machine shops
- Spoon Sports Ventuli Plate. Just wanted some opinions.
- tire size
- Can someone run a Carfax for me?
- Help! Wiring Question
- Power Plug help needed (99 civic)
- tech: Swapping B16A2 into EG
- anyone got a pic of Mugen front strut bar in a eg??
- tranny mount question: b18c into 93 si hatch
- BIG Brake Upgradez * anything other Than AEM-- any suggestions?
- What do you guys think of the neuspeed sport spring and kyb gr2 suspension combo offered at inline f
- Need Someone In San Diego To Help Me Out
- you won!
- i need part number
- Anyone with B18C5 torque specs!?!?
- dropping weight.. no ac, striped interior.. how much will i save
- Pics of my shaved 2000 coupe
- 7th gen 01+ civic turbo kits manifolds etc?!
- 15's or 16's on an EK
- Got couple of parts.
- new EG member need help!!! does del sol seats fit in my EG HB???
- Need infor on gsr cluster wiring for EG civic
- Need some info about piston swap in d16z6
- 17" rims and tires
- Cam seals
- How to install the main relay for 93 Civic Coupe DX? Engine Swap also...
- Have you dealt with them?
- why is my speedo of by 15mph?
- how much for???
- Overtorqued Bolt that goes into Transmission
- Thought i share this and get some ideas on what to do mostly on my 93 cx
- Shocks and Winter
- Autometer Gauge Pod?
- my new hybrid
- Does certifit ship parts
- Headgasket Change
- Teins....
- Exhaust resonator burning out?
- 1/4 mile time for b16a eg6????
- Center Console in hatch
- b16b in EK Coupe - World Sport Model Number to order?
- Question about exhaust
- How Much shoud....?
- How do I adjust Timing on an Unorthodox racing crank pulley?
- Question about o2 sensor
- apexi N1
- del sol seats in an EK question help
- im not happy with the EG headliner, any ideas?
- Clutch Rattle?
- Cant get bumper beam mounting bolts back in!!!
- stripped shock tower bolt help me out
- After months of waiting. They came today *PiX
- what kind of strut bar is this?
- Is electrical tape enough insulation for the Engine Wireing harness?
- n00b question: when buying a used muffler..............
- how much gain?
- Power Winows
- the crossroads have arrived, spill my guts
- Anyone hear of Cwest coilovers?
- car wont start.. :(
- 7th gen. seat swap
- engine weight
- spedo speedo
- ECU Swap
- Fast idle after starting, around 3000 rpm?
- What to so with stock parts?
- what are the hp gains of pulleys?
- Installing EG6 cluster....where the hell do the indicators plug into??
- 92-95 civic hatch manual or...
- 93 cx latch
- stupid imitation amber corners
- Price for a y8 intake manifold?
- what is the best oem cat? for a eg?
- civic audio console?
- is 91 octane ok?
- D Series Tranny codes...
- Where to Buy a CF Hood?
- Hankook tires any good??
- 92 VX factor ECU? Is it a p28??
- can't start car in warm weather
- Tein or Zeail coilovers which should i get?
- Some Questions About Tein Coilovers???
- o2 sensor help asap!!!!
- running a chipped p28 by kenji
- Exhaust compatibility Q's EK hatch/SI coupe
- 92-95 Civic LX/DX compression check
- homemade turbo kits
- b16 & LS
- C&R radiator ?
- obd 1 vs. obd 11
- need a brake diagnosis
- Thowin code 83 or 73 cant tell.
- rust repair - where to find replacement panels?
- 94 Sol Motor?
- frustrating fuel problem
- s-florida dent removal
- power to manual steering
- My dads DX Trany is gone.
- D series question
- batterys for eg........look
- Brake Rotors???
- Powdercoating or Painting wheels?
- picture request
- Gear ratios??? H22... H23...
- Distributer ?
- plate holes on front bumper
- ctr steering wheel Q
- upgrade my del sol cooling!!
- 2dr civic Pics please...
- Timing Question
- H22, a/c in eg question?
- how much should i be paying ?
- Throttle body problems
- do OEM ITR catbacks fit 5th gen civic coupes?
- B18c5 in a Del Sol...
- Anyone got pics of 96-98 4 Door civics?
- Type R rear seats in EK
- In a Hatch, down by the river! (pics of my car)
- OEM windshield nozzles
- Size of piping on a 00 si
- WTB: Del Sol VTEC A/C Bracket ASAP
- Which Rails for the Momo seats Anatomic????
- Questions on the G Tech Pro Competition computer for racing
- What exactly is unsprung weight?
- ek stanley sidemarker installation...
- Tachometer Problem
- My EJ8 B18c1
- Q: 5g engine swaps
- Tires rubbing in rear
- ApexI Dunk cat back for eh2?
- FS: 92 Civic Hybrid Sorry for this forum post but reach alot of peeps here
- Del Sol Headlights
- Help request: About my weird fuel indicator (needle)
- problems??
- Hondabond
- RS emblem?
- One Last Question About Painting My Car
- Are there no perfect front camber kits for a 2000 Civic???
- Need a Front camber kit
- what difference between canadien and japanese built EG's??
- superglue on dash!!! need off!! HELP!!
- space between hood and bumper on 93 EG??
- 2000 civic si
- question about dings and dents?
- question about rear disc
- in desperate need of pinout info and pics
- Cnc Ported head dyno graph for H22a and F20B!!!
- Anyone heard of a kamikaze header?
- Tell me what you think about this swap...
- 1.5" Or 2" Drop For A Del Sol Show Pics Please
- AEM CAI or cheap ebay CAI???
- how hard is it to replace oem honda release and pilot bearings?
- Q those who have venom400..
- 94 Hb W/ 94 F22 Swap, Help Plz!
- How to take out starter?
- Brake Upgrade question
- Need your help. PLEASE read this.
- water temp problems with A/C on
- getting picked on..........
- neuspeed springs
- Ford Mustang Saleen V8 Turbo goin into a 94 Honda Civic. !LOOK!
- Which is better????????????
- B18b.....
- quick del sol p/s question
- mini-me swap
- Painting My PY How Much Do I Need
- DC Sport 4-2-1 Header, what gasket to use?
- Rim decision thread.....
- Any tips on removing coilover sleeves from a shock/strut?
- Ricer question
- Rough idle problems
- Removing trunk lid of 96-00 coupes
- ...just bought a 93 cx hatch....and gots some ?'s
- Windshield squirts.....
- Who here has done the Prep Urself Maaco trick?
- b16 sir II with a type r block?
- Need a driver side Depo Foglight cover.
- Clutch problem please help.
- Who sells OBD1 P28 ecu's, both stock and/or modified???
- what rad with b18c in 5th gen?
- jdm ITR CAT gasket ring???
- 2002 Civic EX Hi Flow Cat
- Will a jdm engine harness work with a USDM swap
- Please Help!!! WHat are the signs of a D-16 Distributor going bad??
- RS*R cat back
- any ideas for a newbie
- harnesses Installation
- Gutting your cat (WARNING - GRAPHIC - and 56k unlikely)
- FS: SRR LCAs, SIR cluster, Rotors, CD Deck, Sub amp, Lip, etc.....
- ECU Code 36 (wtf?)
- Got a rattle in my exuast any ideas?
- Worse day of my life....
- Sway bars on 92-95 EG.?
- what Pin is the HO2 sensor in the ECM
- piston confusion
- apexi rev/speed meter
- Transmisson question
- oil pressure sending unit
