View Full Version : Honda Civic / Del Sol (1992 - 2000)
- can anybody help me identify this wire????
- honda civic eg im thinking about buying
- Do I have a bogging problem?
- CEL 65 Secondary oxygen sensor heater wire
- Cel
- tell me about the civic ex-s
- Im looking for a collant line part
- b20 vtec ?
- lenso vpd skinnies need help on size for my b20 civic hb eg
- Need Help identifying some plugs
- Questions about coolant/oil.
- another motor swap HELP PLEASE!?!?!!??
- How much would you ask for it?
- Question about extended emissions warranty
- Slid into kerb yo, help me out
- FS!! Stock 95 Honda Civic Tail Lights.
- having trouble with a 2000 civic si engine
- dizzy?
- No power until 2k, 93 Civic 1.5L no CEL
- Axles nut!
- I have 2 quick questions!!
- wind deflector instllation guide
- Vacuum lines on my ls motor
- Where can i get some Eg mud flaps??
- GSR Fuel Problems (I think)
- will apexi power fc work with +98 b18c-r in a 95 eg
- Swap please help me!!!
- Will ECU Harness from 96 LX 4dr work in 97 EX 2dr w/ B18b1??
- HELP!!!???
- Interga (or some other) brake rotors to Del Sol VTi
- completley StUMPED. any one in md,, pa or wv wanna help. my car wont start ill pay 50 cash
- Some fresh perspectives please
- White Smoke from B20 Swap? Rings? Coolant Burning?
- gsr cluster
- HELP...
- OBD2- OBD1 conversion harness question
- How to replace 99 4D grill? I have work in 1HR.
- How can you identify which fuel injector is which?
- Identify block (b18cR)
- ebay hytech replica header?
- del sol parts vs eg parts vs ek parts
- ls/vtec turbo question
- Replaced Axle Now Crazy Torque Steer 90 Degrees? HELP!
- Several problems with my '97 EJ coupe.
- 96 honda civic ex swap h2B
- ek hatchback sun roof
- Oil Light Flashing and Headlights Went Out
- obx twin loop or es tuning???
- question about aftermarket steering wheel?
- Replacing an o2 sensor.
- OBX front o2 sensor?
- How to check o2 sensor?
- Turn signals both blink when headlights are on-HELP!
- Help! Trunk Problem.
- im not to sure about this one.. help?
- D15B7 Pistons
- my new project.. eg6 build
- head lights take forever
- Missing Hose Connection and O2 Sensor Wires ?
- suspension question
- car cranks over and fires but doesn't say running
- radiator fluid spilled everywhere. whats going on?
- 1999 Civic Si CEL code questions?
- Del Sol just stoped boosting
- stripped t-stat housing wire
- Fuel filter
- BOV???
- Civic turbo exhaust
- Annoying problem.
- 93 eg stalled n back fired heip
- 99 SI with GSR questions.
- VSS issue..
- ecu upgrade
- d16z6 alternator belt???
- Soft Gas Pedal w/ Aftermarket Cruise Control?
- motor swap questions
- Del Sol Auxilary Light Problem
- mud guards?
- Question about heater core unit.
- Why so many engine swaps on normal civics?
- switch cut-outs behind seats in personal compart in a delsol
- power steering pump ID?
- replacing 3rd brake light
- here's my trick slut
- Replaced 1997 Blower Fan Burning smell on top two speeds
- hey need input
- idle problem
- EJ7 sideskirts will they fit my EJ1?
- rear main seal removal.
- Koni GC or Tein Flex?
- How much should I pay for 99 si?
- Tranny support mount
- Cooling fan switch replacement
- help looking for part number or something
- Civic SI Intake Fit into Civic HX?
- my EG, pics... and question
- itr rear control arm
- ebay vitara pistons good?
- how the hell do i work with si front endlinks??
- state ref question
- EG FOG LIGHTS
- Shift Boot Retainer WANTED
- d16y8 head on a on a b15b8 bottom end what would i need
- fuel problem on 93 civic need help
- eg6 cluster bulbs
- Can a 99-00 front bumper go on 96-98 civic?
- Anyone installed a HKS type 1 turbo timer on a EG
- will a EG door hinge work on a del sol?
- Es Tuning Muffler
- need help with temp gauge.
- ek rear shock/lca question.
- Plug wire resistance
- got a fix for this???
- VSS same between all the Civics?
- Will 6th gen rear brake calipers fit a 5th gen trailing arm?
- need help pls. edelbrock intake manifold and TB installed on my gsr
- EG light problems??
- wiring diagram
- JDM OBD1 P30 ECU Specs
- Thinking about getting another Honda. A little insight, please?
- camber help
- p&p hid kit = backward beams
- axle broke...
- ecu question
- 95 civic ex head
- ITR brake question
- fuel pressure regulator, gauge, and o2 sensor, more $ really matters?
- Del Sol Wont Start (searched)
- Ksport suspension for EK
- OBC code fault p0703 on Civic cx 98
- help to remove a tranny
- Trying to find a set of Eibach Pro-Kit springs.
- sunroof maintenance
- gsr swapped civic acceleration not smooth
- Parking light wont go off
- h22 eg coil install HELP!!!
- obd1 B16 fault 13 Baro sensor
- Bulb Glued in Headlight
- Hard Idling when stopped?
- would a 95 dc2 cluster fit a 94 eg hatch??????
- 98 Civic bad smell from air
- WARNING!!!! very noobish question...just thought about it and got curious.
- whats a fair price for this?
- 93 dx w/ JDM B18C swap... Qs about upgrades
- Blue w/ Red Stripe wire unplugged from under-dash fuse box? where to plug????
- auto engine work with standard tranny?
- Want to buy an EK(96-00)
- Civic Weird Overheating Problem Head Gasket? Need to fix before winter!!! :o HELP!
- Messed up antenna on EG civic.
- Auto Window switch
- not exactly new but since i have never technically introduced myself here...
- which header can I use?
- K Swap prep for build
- Hydro trans to cable car?
- Burnt Valves?
- ~@~~Clutch or Axle problem? Help!
- head gasket blown from wrong firing order? opinions please
- failing emissions question
- my hatchback
- Someone verify this information regarding a heater...
- 00 civic cel ?
- sohc vtec question?
- planning on wiretucking a 00 si.
- 95 civic frt/rear shocks fit 99-00 civic?
- Failed state ref. experts needed.
- Mini Me question. For real.
- correct ECM for Y8
- JDM EG HEADLIGHT PROBLEM
- Brake light Question
- 99-00 front end swap on a 97 hatch
- rear camber washer trick
- horn clicks?
- Need help....what's wrong wtih my tail lights??????????????
- water temp. help plz
- EG Offset/Tire Rubbing Q's and ITR 4x114.3 Q's
- please show me a diagram
- Super low RPM reading. Cluster swap help.
- obd2a to obd2b harness conversion HELP
- Tranny fitment..
- obd2b to obd1 distributor wiring help???plz
- oil type
- Why am I losing power on a 2.5 piping with 4-1 header?
- OEM FOG LIGHT FRUSTRATION!!! PLEASE HELP!!!
- Help! Tach and Speedo off in 93 DX.
- Dash bulb burned out. A few questions
- sidemolding removal?
- Clean B16 Head how much is it worth?
- gsr smokes
- Replacing ball joint on 93 Honda Civic
- Unsure of what i need to do to fix 95 civic ex.
- mini me questions
- What is ur favorite color of civic's...
- Need help! No power, Im desperate!
- QUICK ? Head will not come off the block no clue ??
- how to convert to power folding mirro
- 5-lug brake question
- Power Steering removal
- I love cops :)
- RSX Seats
- help???
- Rebuilding my B18b, got a few questions?
- New Springs installed, now a suspension knock. Need Help.
- Keyless entry not working after installing aftermarket radio?
- CTR carpet, how hard to fit on EJ6?
- paint jobs places in st.paul minnesota for good price
- Buying new door lock and ignition cylinders
- Jumper harnesses HELP!
- vtec not workin...!! serious help.
- b16a2=obd?
- z6 oil pump y8 engine
- Rear Seats in Eg Hatch
- Where to get Timing belt / water pump kit online?
- Distributor wire color help <---------------------------------------
- obd1 b16a2 swap into a 94 del sol si
- new from south dakota
- Nagasaki JDM Motors
- coolant mixing with engine oil
- Speed sensor question
- gsr swap radiator pressure
- FIY article
- Sort of new..hello all!
- New Guy
- o2 sensor ?
- CEL 9 CYP - cylinder sensor
- whats wrong with my car? something elecrical...?
- weird heater problem..
- im not getting any compression! help please
- mini me swab questions
- a cat questions on a eg civic
- RSX seats in Eg?
- exhaust for 94 coupe
- HELP!!!! 2000 HONDA CIVIC SI ; ENGINE LIGHT FLASHING; CHOKING
- 96-00 Civic Dx ?/ Can I use d16y8 intake manifold on my d16y7 motor?
- best cam for boost set up
- head gasket placement
- D16Z6 Head on D16Y7 Block
- Need Help! b18c1 swap troubles.
- Rattling noise at high RPM's
- H3 3000K foglights acting up
- TPS removal?? how to?
- headers o2 sensor bung question
- driver side motor mount
- Swap Pedal Assemblies, Chassis ED to EG?
- questions on purchasing a EK coupe
- Coolant Temperature Help!
- rear strut bar for ek sedan help
- introduction from Australia
- s2000 Radio into EK
- I need help...
- Column BRACE LOCK
