- Civic Dilema. Need Opinons
- EG Seats in Del Sol? Help!
- tach help
- CLutch help
- crank pulley problems
- What gasket ? header/exhaust manifold gasket ?
- 6 speakers?
- Monster Help Needed Please
- a weird problem
- 95 honda civic ex cluster problems
- AC help in EK GSR Swap
- 1.3L head swap
- Help, weird issues in cold weather with throttle/braking
- Running on two cylinders
- will a 94 integra gas tank fit in a 92 hatch
- timing belt cover
- which header would be best for stock b16
- stripped camber bolts?
- Engine out, clean engine bay what can i do ?
- Need help with paint streaks
- cluster needles
- Smoke from Tailpipe
- 94 civic door lock
- What is this called???
- People with greddy sp2 please read
- What are these loose plugs in my bay for?
- Help! B16a2 ecu problems in a eg...
- 00 si motor swap to 96 ek hatch HELP!!
- CTR reverse gear issue
- Can you verify this setup H22a civic masters
- Eg Hatch Si Rear Seats In To An Eg Coupe Question?
- 98 to 00 climate control questions please please help.
- New axle makes thump noise
- need an answer
- Signal wire color on 02 sensor connector
- Bar help!
- connector?? pic inside
- EG Spedo wont work Already changed Spedo and VSS
- 97 Civic Door Lock
- wire harness connectors...where can i get?
- wow
- axle question
- ok this is killing me
- gsr frankien stien boost help
- b16 go boom
- Hi I am new here
- Greddy sp2 exhaust
- D15B7 using JDM D15B vtec cam.
- People with 92-95 coupes or hatch can you measure a door gap for me )
- Del Sol Shift lincages fitment?
- AEM fuel pressure regulator
- Greddy sp2........pics inside
- lca broken bolt
- DOHC Vs. SHOC?
- car smokingg
- b18c cams in a b16a?
- Main Relay Problem
- Del Sol S2K swap??
- no spark
- Calling out the best of HT...need advice(LONG)- Drivetrain Related
- Key won't budge!
- 94 Civic EX d16z6 stock Rough start, quick hesitation.
- failed theft attempt x2---need some advice
- EG to EK front suspension question
- Cold engine questions????
- rod bolts??
- ek seats?
- greddy sp2 exhaust
- Problem with greddy sp2 on eg hatch
- which prop valve/master?
- transmission code 4 my d16y7
- Help! Shaking while under accelleration
- Somethings Wrong
- NEED HELP! problem with my civic
- Would you trade... Si for ek?
- Windshield Washer fluid pump(motor)
- Del Sol Steering Problem (clunking)
- Interchangable sway bars....
- Just bought a RHD jdm style (conversion) questions..
- Intake
- Stripped Oil Pan bolt
- Need help Tuning my vafc
- Rim and tire size fitment for 97 Hx
- just bought a B20B
- CV shaft from a del sol to a civic
- Dash Removal 00 EM1
- wire tuck wire?
- Rear Disc Conversion Not working
- dyi on a roof rack for a eg6????
- It "fits"...
- k series Q's
- Honda Vin Number Sticker Help
- car starts and turns off when it wants
- questions on a 95 dx
- ls boost or gsr all motor
- MY interior light is dead
- got a Q on body repair for my si hatch
- Ford taurus cup holder install help in 94 civic ex coupe (pic)
- 99 Si Doors conversion help.
- B16 head on B18 block
- jdm 1.3 help plz!
- ek sir bumpers ( aftermarket )
- obd1 sensor HELP
- hid in foglight
- where can i find a D16Z6 vtec head
- SMOG! High HC at idle on stock JDM B16A
- Question about obd on ls swap into eg
- Questions about installing locking hood pins...
- (CEL 1 & 21) B-motor 2.0L vtec
- D15B swap into EJ2, P08 or P28 ECU?
- Suspention creeky
- Help!!changing timing belt on LS??
- ****please help i need help installing a waterpump on a stock 92 ex civic n timing***
- Ebay Distributors
- weird electrical issues with 99 honda Civic
- Water / Moisture in Passenger Footwell
- 88-91 suspension fit on a 92 Sedan?
- New here Need help with d15b sohc vtec in 91 civic sedan
- Reconstruction of my B16a2
- Water Leaking!!!
- Steering unstable at freeway speeds
- Which D16 (for EK) ebay header can be used with stock spring bolts?
- Wiring problems, please help
- cold air intake + water = :(
- need help figuring out numbers on motor
- Running new speaker cable to the doors
- Civic EG hatch Spoon Wing with Tail light
- Exhaust Manifold Gasket and Copper Spray
- Help no start... 98 civic cx with gsr swap
- brake lights
- need confirmation
- D series Oil pan Question
- Pullin the b16 tomorrow!!!!!!!!!
- CTR power to folding mirror
- Vtec switch
- 96 Civic Timing
- Where can i find Bronze Rota Torques to buy?!
- possible trans leak?
- Tail lights
- sluggish
- Car feels like its gonna die, sputters....
- fram fuel filter install?
- 92 civic... need help to figure out wiring up the IAB's on a GSR swap
- New Clutch..
- D16y8 head on a D16y7?
- Fuel Pump Flow Rates?
- Need help asap
- <><><>pix post<><><>
- Coupe front end...on four door...the right way?
- heater coolent is in my car!!!! need help asap
- No check engine light ~ why?
- What kind of manual tranny oil do u use ?
- Oil leak from head gasket???
- i need help to by pass for wireing
- Engine Problem
- Help me update my priority list. [Y8 swap]
- subs/ locks/ windows.
- Is external coil legal in Cali
- New task: Chaning Head Gasket on D15B7 motor.
- GENUINE Honda MTF vs. Conventional oil vs. Synthetic oil vs. ATF
- how to stop your window from hitting blow out clip
- B20 or B16B
- Any Pics: 15x7 w/ 40mm offset on eg
- Coolant and FITV
- Help! No heat/ overheat!
- RIP Master Cylinder - Suggestions on Replacement part?
- which cams do you think are best for my b18b1?
- no power at all......
- Del Sol Drag Project
- Do power mirrors have to be power mirrors?
- tps wierd volt readings
- how can i find out if i have an obd1 or obd2 delsol?
- JDM GSR into EG
- gas mileage and heater circuit malfunction
- Need new Driveshaft?
- i have d16z6 engine my car won't start bec of the ecu
- I spilled windshield washer fluid in the engine compartment
- civic 1.4i exhaust
- 98-Civic-CX Air Compressor Dosen't Activate???
- speedo and tach problem
- Need help finding a shop that can do b-serie's swaps please i'm in a bind...
- MSD 2 step w/o msd 6al... Smoking from Valve Breather??? help!
- MSD Blaster 2 coil
- Si Lip ripped off
- conversion harness for b16a
- Window issue
- B16a2 swap question
- OBD2 ECU with pins in all 4 plugs?
- Rear disc brake convertion?
- 95 civic hazard button light
- Swap help?!!
- Someone adjusted valves on my car and its missing?
- edm Rear fog light 92-95 civic Coupe
- 1999 ex rubbing fender
- Head questionssssss....
- Fuel Pump Problem
- Damn ball-joint nut!!!!!
- head gasket question
- What are some good quiet aftermarket exhausts?(D16Z6)
- 99 Civic EX starting issues. Please Help!!
- swapin' a jdm b18c type r in a 99-00 civic si
- Will a B series slave cylinder work on a D series ?
- another redline problem
- do JDM RECARO's fit 00 Civic?
- 92 ls block oil pump question??
- Seats and bracket question
- Ls vtec wireing
- VTEC wont engage
- Wrong Octane - 99 SiR
- Low compression. Speed only reaches 40MPH
- anyone in the tampa/st pete area...
- airbag question
- 1994 dx coupe - Rim n suspension questions
- taillight hatch converted to 99-00
- speedometer question
- Changing locks question
- Honda Access Visors on a EG
- Header help PLEASE
- b18b into 1995 civic ex(vtec) question...help!
- D16Z6 Rebuild Question..
- question about h22/f23 = G23 vtec
- D series shifter on B series linkage
- How to get my cluster out?!?!
- simple spring question for my 94ej
- Civic wiring to b series
- Rear seats for ek hatch
- question regarding about center console
- Where can i buy cheep Rota wheels ? ??
- OBD1 B16 Into Ej8
- Exchangeable Parts from Eg - Ej?
- car won't start..
- Best place to get eg6 corners/spoon rep mirrors etc.
- Itr front end...
- help on my 98 civic
- Rough Idle
- Horse power help!!
- 97 civic muffler
- which d16 fuel rail has the FPR at the end if it?
- rev limit problem please help
- 99-00 b16 starter in a 94 ls
- Need help....CEL #73
- best shocks for 98 hatchback
- What would you do first
- ecu for d16z6
- JDM vtec vs stock vtec
- B20 swap in 95 civic dx.....need a little help
- Del Sol Seat Covers - Dirty Stains
- Signal light wont turn off after turn
- What is the size of a stock b16 throttle body in millimeters?
