- Zc sohc head onto d16 block
- Hi and power steering woes.
- D16z6 piston ring gap for boost
- B18B1 Swap
- Strut tower brace not lining up
- TPS voltage drop (D16y8)
- D16y8 to d16z6 swap preparation
- E-85 for a Jdm B20b ??
- 1997 Del Sol SI favorite Engines to swap
- Need help on cigarette lighter wires
- sway-bar/endlink/LCA Question
- Junkyard 'budget' turbo Civic
- H22 swap gear problems
- Oil residue on radiator cap.
- Keyless entry wont unlock but it does lock
- rpm hunt and idle little high
- Low MPG
- AC compressor works on and off
- Tach Bouncing not Dizzy. In desperate need of help.
- Radiator fan being weird
- 92 civic MAP conundrum
- Can I use an OBD2 EK ecu on an OBD1 wiring harness and engine?
- Need advice on stock engine harnesses
- Missing Wire?
- Car stolen/recovered - How'd they do it?
- Can’t Enter OBD2 Diagnostic Mode (Issue Shorting Pins 4 and 9)
- Potential bad ECT Gauge Sending Unit
- Does the pan from a seat determine the height?
- EG AND DEL SOL SEAT PAN THE SAME?
- Help with Del Sol VTEC specific interchangeable parts
- What is this thing called?
- 1999 Civic diagnostics
- 1995 Del Sol AC Static Low Pressure is High
- Broken nut inside frame for torque mount
- 1998 Honda Civic p1509 help
- my d16y8 blow... help
- iacv and tps code but really weird
- Fuel Injector help
- Radiator fan with ecu swap help
- Trims and seals for doors
- 13/14mm rear sway bar with no bar in the front
- 92 civic keeps randomly dieing
- R12 to R134a
- 94 Del Sol VTEC TPS and stutering issue
- Need help with break up issue
- 2000 civic d16y8 - oil pressure switch (location?)
- Oil & filter
- 99 civic no start
- D16Z6 intake + B16A2 TB on D15Z6.
- AWD Motor Build Choice Help
- AC Recharge issue - Civic 97
- Recommendation for brake upgrade on 98 ex?
- 1998 Civic Lx door unlocks then lock back up again
- Rear Engine Mount Misaligned?
- Weird Throttle body situation
- hey guys...new here..ive read some stuff...love any small.quick help/responses to thi
- Vague Shifter/gear engagement 94 EJ1
- [HELP] - No error code but CEL and No vtec
- Question
- running engines still available?
- Help Fixing SLAMMED Del Sol
- Car won't turn over....help?
- 93 civic access port
- 96 Honda Civic timing bell issues please help
- Car taking long crank and multiple cranks to start after connecting fuel pump relay
- PLEASE HELP (1999 civic coupe d16y8)
- Difficult-to-pinpoint Electrical Short Cigarette and/or Radio
- Soooo yeah...kinda need some help here.
- Help! Funky aftermarket distributor wiring
- weird misfire
- Brake caliper slide pins for 98 civic dx hatch
- 99/00 SI rear sway bar
- Electrical/ECU issues
- Shifter Bushings for '00 EL
- 3rd/4th gear grind after rebuild
- Cel code 15 any help boss
- B swap iv tried everything
- Idle surges in 2000 Civic
- Why does my engine sound sick !
- overheating issue
- Need suspension and steering advice
- B16a2 boosted running rich
- Exhaust leak
- Did I cause wear to my OEM Clutch? 98' D16 Civic
- ABS. Non ABS
- HELP BAD FRONT END SHAKE!!!!!
- My new project!!!
- 2000 Honda Civic EX Breather Pipe
- 1995 honda civic question about interchangable parts
- Wiring Diagram for 97 Sol Aux Light Switch
- B16A2 Rebuild - Initial break in
- Water Pipe Replacement
- OEM Keyless Entry for 97 del Sol
- Crank no start... here we go again....
- Curious about open plugs on B16a block.
- 92 Si Ignition problem
- Muffler help for 1999 EM1
- No green key code light
- Please help me solve p1259
- Code 9 OBD1 b18c1
- B18B1 98 EK Swap - speedo is tach?
- 06164-P2A-000 What size this injector is 240 or 190?
- 96 civic hatch with b18c5
- 97 front left lower motor mount
- 97 Vtec starter solenoid ?
- ZC engine rebuild help
- Del Sol S vs Del Sol Si transmissions
- where can I get the service manual for a 94 del sol Si?
- CEL Code 12 (ERG system) on 2000 Civic HX
- HELP FINDING NUT FOR SHOCK STURT TO CAMBER ARM IN REAR
- Making power with a 2000 honda civic dx
- elec windows stopped working
- 1998 Honda Civic LX
- EG6 Yellow Interior Check
- Loud tick then loss of engine power. Wont start
- Videos of leak in my 1999 Civic SiR. Recommended course of action?
- Vibration
- 2000 civic si b16a2 no spark! Tried everything....
- Code 22 vtec pressure switch
- 1995 del Sol - ABS Light Illuminated
- D16Z6 - Rear main seal bolt size
- Honda rods, what kind?
- Head Swap issue?
- So I am having this issue with my 1996 Honda Civic 1.4i...
- 2000 Honda Civic w/D16y7 engine, Manual Trans
- Subframe Part Help
- A/C Diagnostics - A Crash Course in Cooling Concepts
- Hydraulic to manual clutch conversion 96 civic ex
- Ac not blowing cold
- 94 civic ex coupe (ej1) quarter panels
- help identify noise!!!!
- Where can I find rubber engine mount replacements??
- No start
- D16y8 Whinning/whistling noises
- Mugen
- d16y8 very unusual idle problem
- Polyurethane Mounts B16,B18
- Caster issues after alignment
- 1999 Honda Civic rattling problem....need help.
- What material is door panel or how to paint it?
- Del Sol Exhaust question
- leaking engine coolant under the intake manifold
- Del sol , headlights Canada
- No Data link OBD2
- Wiring issue on my 98 Honda civic sedan
- D-Series Build - Too Many Options
- Newly bought 1999 Honda Civic HX coupe. Need help and thank you.
- Help with b18c1 swapped del sol , no crank condition
- Engine replacements
- Fuel gauge+Temp gauge not working after cluster swap
- LOOKING FOR A GOOD HEADER SETUP
- Del Sol Windows turn signals and cluster not working
- Are these stock b16 pr3 pistons?
- ej1 95 civic door lock issue
- Del Sol turns off when coming to stop
- COILOVERS UNEVEN! HELP
- 94 del sol rpm jumping like crazy help!!!!!
- I have a b16a2 swapped into my 98 ex but, it still has original ecu
- B18B3 hesitation at low throttle ONLY
- FYI: OEM Mass Airflow Sensors are made by Hitachi!
- Skunk2 spherical bushing noise maybe?
- Civic VI '96 D14A4 - "tune-up"?
- Low Idle when Return line changed.
- 2000 Civic Ex 2dr coupe
- Question about the Civic Ferio tall wing
- Spoiler on Civic coupe EJ1
- Autometer Wideband Datalogging
- ej9 can fit ek9 bumper?
- **HELP: Help identifying EH/EG chassis harness**
- K Swap a 1994 Honda Civic
- 98 Civic
- Del sol idle issues
- Brake light
- ECU preventative maintenance?
- 94 Del Sol SI Power Steering Rack Threads
- O2 sensor
- Help! 2000 Honda Civic left rear door stuck.
- 2000 civic ABS module replacement
- Ej9 vs em1
- What to look for when buying Eg hatch?
- Power steering pulley reomoval tool
- How does wheel speed sensor work on drum brakes
- 1994 civic dx D15B7 weird air sound from engine
- Edges of timing belt frayed - incorrect install?
- Inner tie rod boot/bellows removal
- Idle goes high when running while in neutral and goes back to normal rpm when stop
- Civic EK3 - D15Z6 Service Manual
- Seat Rails vs Seats (Honda/Acura)
- Broken Valve Cover Studs - How to Remove
- [99 Civic Si]Necessary mods for DC JDM 4-1 header on b20b block and b16 head
- Iso a radiator support for a 95 del sol
- Need help replacing the SRS bulb (1995 Sedan)
- 94 civic sedan rear speaker replacement
- [Build Thread] '99 Civic EK1 Barn rescue - From CVT to Manual turbo
- [Budget build thread] Daily driven Civic MB3 fastback - The little brit
- Upper Control Arms Rear and Front - Which other models fit a Del Sol's?
- Im in need of some help
- 2002 Civic SíR 2l clutch change
- 2000 Civic (VTEC) Manual trans on a '97 Civic (NONVTEC) Engine
- Suggestions
- B16b engine from hmo question
- Squealing noise
- Help 96 civic tail lights and blinkers quit
- 1993 Honda Del Sol ECU and CEL
- Caliper front left??
- 97 civic fuel pump won't stop priming or crank
- AMERICAN SUNROOF COMPANY EK HATCH SUNROOF
- What 14" tires should I buy?
- Ek3 Bswap Fuelling Issue
- Honda del sol hood
- Less harsh motor mount options for under 300whp.
- Help Identifying Bushings
- 98 Civic Hatchback B Series charge harness
- OBD 1 Issues
- Huge oil leak on back of b16a2
- Just Bought A 99 Civic and its a mess. HELP!!
- 97 HB Starts without Pressing Down Clutch
- Civic RPM drops when AC is on w/VIDEO!
- Need help from Honda gods! I’m going crazy
- Where does this wire lead to?
- Civic hatch rear crash bar on a Del Sol ?
- B18B1 swap with what I "think" is a phearable chipped ECU?
- Front Fender Rust Repairable ?
- Is it worth the $
- 95 civic window diagnostics
- external fuel pump
- Second Gear Not Always Engaging Properly
- HELP! 94 del sol idle jump fluctuation
- 95 Civic 2dr coupe, water in trunk
- Gauge cluster
- Driver Side Window with roof on sounds like it is strained - 1993 Del Sol
- D16Y7 Timing belt set
- Will EG AC fit Del Sol?
- Did I fuck up my gauges?
- Wipers Won't Shut Off
- OE Oxygen sensor
- P28 unknown wires
- 99 civic no power to cks
- No-start Condition - Ignition Coil Possible
- Vtec engagement issues
- 98 civic obd1 b18b1 swap help
- How to clear fuel from engine after spark diagnostics
- Ek4 armrest in ej6 coupe? Will it fit
- Weird issues - 95 Civic dx d15b7
- building a d16 with time and tons of research.
- fuel and temp gauge not working after tinkering with them
- GReddy Water temp sending unit
- Ignition problem
- Seats in del sol
