View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Axle nut loose?
- quick mount question
- vibration due to bump on a tire, bad strut?
- D16z6 vs. D16y8
- help me please
- What's the sympton of bad hub bearings on a 92-95 civic hatchback???
- What are the street prices for a 1992 Si hatch
- 92-95 civic ebrake install
- engine wire harness auto vs. manual
- map sensor wires...where do they go?
- Osaka Motors
- F20B homework
- 99-00 Lip on 96-98 EK hatch?
- a small bit of FYI on the edlebrock D series IM manifold and triangulated strut bar
- how to make fit on a ek crv five lug?? can i put on an ek???
- indepently wiring a speed sensor
- CAR WONT START!!! PLEASE HELP!!! (already searched)
- so excited i had to tell everyone
- 2.25 or 2.5" for single cam boosting later
- Please check out my camshafts pics
- d15b7 ignition coil and box?
- polishing valve cover
- Civic 97, Inside Door handle broken, Rod slippage?
- jdm eg6 rear seats reupholstered?
- b16 fuel injectors
- civic hx overheating
- 96-98 vs 99-00 front end
- Just curious will a nissan shift knob fit a honda???
- Heat and Idle issue
- Stock radio fitment questions...
- Good spring rates for 94 civic lx...
- brake trouble..
- good deal?
- Just got back from a long trip...
- 99-00 or ek9 tail lights????
- Will an '01 cluster fit in my eg? HELP !!!!!!!!!!!!
- Electrical problems
- i just got my clutch put in . . .
- car shakes in morning in low gears
- b16 swap into 94 sol - need knock sensor plug (searched)
- Adjusting clutch biting point?
- Newbie Question- My honda is clicking after I turn it off??
- pulley belt
- Where can I buy a gasket kit online? (searched)
- QUESTION: Clutch Problem, Slipping, High Biting Point
- GReddy front lip...
- Whats up y0!
- Pulley Question, answer fast please
- Changing A/C belt, little help please
- h22 swap pricing
- Stock civic radiator
- Compression Ratio Question for EX
- camber question
- CX tranny?
- UNDER DASH FUSE BOX LABEL
- Strange click/clunk
- new axles ?
- brake calipers ?
- Identifying OBD Type ?
- what is different between those o2 sensor?
- Fuel Sending Unit for 1993 Civic
- h22 or h23
- Just bought a 96 Civic DX hatch
- need help
- Wheel bearing symptoms??? Or so I think......
- Rear LCA on a 98 sedan
- Estimated Quarter Mile Times for my Car. Any Ideas???????????????
- WHAT IS THE BEST?
- Update* How to pass Chicago emissions (OBD2)
- Turn signal
- *searched* tranny weird stuff.
- HEADLIGHT TROUBLE!! plz help!
- Lug Pattern
- LUG PATTERN
- 93 Civic EX - High Idle, TACH, OVERHEATING, etc
- I joined "Honda Family"
- mounting problem with ek swap
- My radiator took a dump on me... :thumbdown: Need a new one...HELP...
- ctr compression check?
- How close is milano red to roma red?
- need some ideas on performance ofr a civic hatch
- IS IT GOOD TO PAINT?
- Wobbly Front End
- 96-00 Camber kit on a Del Sol.
- 92 - 95 Del Sol S - Overheating/Erratic Idle
- Civic Models Question
- jdm tailights
- Civic Conversion kit in a Delsol
- Painting Honda Valve Cover... Need Suggestions
- D16Y head swap
- brake pads replace.
- No spark or fuel in h22 eg
- Single cam swap(lol)
- Short Shifters??
- NOOB ? _VALVE COVER REMOVAL_SOHC
- i saw this thing on tv..
- tranny question
- Del Sol Owners - Need measurements for AC/heater control unit
- how do I? dsm injector wire up on obd2 96 civic for turbo
- 2002 civic ex 2 door i cant find performance parts.
- Restricted trial User info
- SI calipers on my HB???
- Adjusting Timing - Need info from VECI label
- EG tranny/engine swap question from newb (Im a Lude guy)
- Ok so i finished changing my oil..
- EG suspension same as DC teg suspension?
- Help: How to Change Antenna on Civic 97
- Acura/Honda OEM Online-Seller/Dealer Links
- 98 civic ex parts
- PIC REQUEST: Modded White 92-95 EX sedan
- Is this right? Weight question.
- rear hub to disc conversion ( have a del sol and the civic)
- 00' B18C5 INTO A 94 CX HATCH (4 ?'S)
- 99-00 Civic front support bar the same for 2dr and 4dr?
- PLZ HELP! (oil filter)
- OHHH NOEEEES!!!!!!!!!!!!!!!!!!!!!!! *bumper question*
- RIP My 95 Civic..
- Swapping Trannies
- h22 injector resistor
- Yet another tachometer wiring question... HELP PLEASE!
- b20vtec overheating
- SERIOUS valve cover problems ... help plz
- megan racing muffler (sound good?)
- 92 CX tranny onto a 96 d16y8?
- Katman's Obd2-2 to obd1 conversion
- difference between d-series and b-series flywheel?
- EJ/EK with König Heliums or Rota Circuit 8
- Oil Question: (will synthetic work for me?)
- florida exhaust tickets
- rims on ekhatch
- just picked up itr sway bar + beaks kit, waves near bushing..normal?
- N2o B20 w/ 203 whp & 384 ftlbs (New Dyno #'s)
- Excessive heat? Please help.
- Brake problem
- Primary o2 = male to male on harness?? HELP!?!
- Magnaflow Rattle
- squeeling noise... coming from wheel area
- oil change dun rite
- H22 shift linkage and axle
- What to do next
- think i just blew my motor-------------------------------------
- !|[Panasports]|! ....a question 'bout 'em....
- motor serial number...
- Spoiler light help!
- jdm itr CLUSTER QUESTION
- Intermediate shaft bolts
- need help, where to get "X" brace for 92-95 hatch
- Melted 5th gear. haha
- How do I take off the brake lines? (pics included)
- Del Sol rear disk brakes fit a 96 ex ?
- Here's a question - will US odometer swap into JDM cluster?
- How do I know if I have a r134a or R12 AC system?
- A little help please
- Help i disconnected my heater in my 97 Civic LX
- I would like some advice on which civic to buy(insert of civic ads(no pics just discriptions) i have
- VTEC Question
- Lost Part of the wiring for my stock fogs, Can i use Cruise control wiring to make them work..
- Is There anyway to change the Bulb color of the climate control Buttons
- Cylinder head torque???
- got question on cusco 4pt. roll bar on ek coupe
- 2.5" exhaust on my y7
- b16 quarter times...wutcha think about this setup?
- siR 1 vs. siR 2?
- LSi
- please help !!! where can i find a 99-00 civic front end???
- e-brake cable question , please help!!!! thanks
- Center Vent Removal
- What are the weight differences between hatches please! CX VX DX SI
- Just installed Skunk2 Stage 1 SOHC Cam ...Wow!!!
- Sqeaking Problem.
- Engine removal and install without release AC pressure?
- needed: how to install Cruise system on 92 Civic (D15B3 carb engin)
- Getting closer to my goal, B20 hatch Track Times
- 99-00 si seats question.
- HELP Decide Cusco Zero-1 VS omnipower coilovers
- Will 16x7 40mm offset Rota GT3's RUB
- tried 4 ecu chips and still.....
- Should i trade my dc4 + cash for this eg6?
- is this oem or aftermarket shift knob?
- Ran the turbo D16z6 del sol on 9.5psi......
- Installing halo lights
- Fuse problems - Doors won't open.
- Cracked block??.....valves???...what could it be?
- HELP! car bogging/sputtering/hesitating *did search*
- Honda song..re post possibly
- b series swap in a 5th gen
- how do i fit gsr seats in my del sol???
- no vtec oil pressure? please help
- oxygen sensor connector
- GSR HG on an LS??
- integ exhaust into eg
- HELP! 1995 Civic EX Vtec cylinder head bolt torque specs???
- help car wont start , throwing code 22??
- srs question
- will fuel pressure push fuel past the injectors??
- motor types ??
- EK EX CAT LENGTH
- Tein SS Coilovers
- Dirty D-series help
- Sorry, Newbie question
- Help!!! 00 civic foglight install question?????
- civic ex overheating
- Throttle cable keeps on sticking after hard drive.... fixes???
- projector headlights?
- 99-00 SI B16a2 problem.
- Frame Locks
- go or no on any neons?
- should i trade
- WHERE EXACTLY IS MY IAT SENSOR ON MY 94 VTEC SOL???!!!!!
- How much does this hood weigh?
- civic cx hatchback rear suspension
- Vtec solenoid problem
- Del Sol Gauge Cluster Wiring Question
- p06 ecu ?
- VX Power Steering
- ACG-IG KEEPS BLOWIN OUT!! wtf???
- honda data
- why when i......vtec
- Power window problem urgent
- Water Bypass Valves
- Custom Short Ram EG designs....Submit them.....
- Another offset question, searched....
- Irractic idle and wont rev past 4500 rpm
- Del Sol Projectors, how many of you are interested in a set?
- Does a (US) 99-00 Si and (US) 96-00 DX/LX use the same MC and BB??
- Someone .. Anyone!? help me
- Anyone use the Neuspeed 4pt Strut brace?
- short shifter
- heater problem...in the summer time
- Remove sticky shit from gutted hatch....
- leaning seats
- look at my civic (just got into an accident) pics
- Fixing a wrecked HB
- what are good settings for VFAC (Vtec Controller) for b16A1
- are all civic top hats the same??
- Anybody have the "new" TYC Projector lights for EG?
- Info on Moding 94 Civic LX???? in desprete need!!
- Intakes - Short Ram vs. Cold Air
- pic install of a master and slave cylinder on a civic
- i need help!!!
- FRAME Damage, causing tire to rub. PICS!
- AC compressor install on 2001 EX Civic?
- question... attn.. eg guru
- price for z6 IM?
- turbo engine question
- dallas and ft worth people
- tranny questionq
- Cluster install(I searched)
- HVAC controls swap
- motor bogs BAD
