View Full Version : Honda Civic / Del Sol (1992 - 2000)
- pink slip/car title
- B16B TYPE-R into a 1998 Civic LX
- Looking for a steel braided fuel line.
- What kind of wiring harness do i have?
- Lookin for replacement parts 00 Civic ex
- One brake light out... can't find the problem
- Momo horn & NRG plate
- code 6.....ect sensor
- ROACHES in my car!!! HELP!!!
- EG Coupe Color
- removing a civic dash... *95 coupe
- 94 honda civic ex gsr b16 many jdm parts
- 93 Civic Temperature Gauge
- oem fog lights not working
- tranny final drive????
- drum to disc conversion
- 96 Civic DX HB........Yay or Nay?
- CTR vs ITR vs Stage 2 cams?!?
- EG-B18C1 eager to hit 200+ hp?!?
- Windsheild washer switch ?????????
- turbo ek Oil?
- apex'i VAFC uninstallation
- QUick question about Coolant Gauge in your car CLuster... WHere does it sit when you reach operating
- Megan racing vs DCsport vs Toda racing headers?!?
- Type R 4.785 Final drive
- Gauge Cluster Lights HELP!!!
- junk yard
- looping eg power steering
- white ek hb
- Tein super street suspention
- How To Wire A Horn Switch To An Aftermarket Steering Wheel!
- Lowered Sedan
- Just curious if no oil pressure sending unit affects anything...
- Paint cracking on new shocks when installed
- Differences in the z6 block vs. y8 block?
- more power.
- Quick Questions On Seats???
- Honda Civic Cx H/b
- ok toss me ideas....car cranks "when it wants to"
- 02 sensor question
- Huge Civic Problem!!!! Mechanics Wanted!!!!
- B18C swap
- EG 92-95 civic coupe INT. what can swap!?
- Serious Issues
- Milage Questions
- question on building this motor
- Anyone cover the trunk cover in suede?
- another b16 question
- 98 civic turn signal bulbs
- Could a bad rubber dampner be causing my speed based viabration?
- b16 swap question?
- b16 swap 93 civic
- EG door panel question....
- what control cold fast idle on 00 civic SI?
- Another car bogging out thread.
- mis firing help
- how muh
- Update to Koni Yellows for Ground Control Q?
- 92 cx, sway bars?
- Z6 head onto d15b?
- Del sol W/ B series...Which Rear Motor Mount Bracket??
- Mallory ignition Hyfire 3 RLi part no 651,,,,,, need help finding install direction!!!!!!
- My radio says code !?!?
- What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other?
- Going to buy 1992 CIVIC HATCH WORTH IT?
- FS: Type R ecu(P73)+OBD2 to OBD1 jumper `FOR SALE $120
- D-serise autometer oil pressure gauge installtion q.
- brakes, where to buy?
- GSR leathers into an EK... (searched)
- just need some help quick, on my y8 manifold onto my y7
- GSR rear seats?
- MSD
- FOGLIGHTS , HELP PLEASE
- Annoying vibrating noise, high rpm's
- OEM EG EX/SiR lip still available?
- Smoked Ambers
- DSM 450cc injectors
- car wont start need help
- Lug Nuts
- rear disc swap on my 94 CX hatch
- 195/55/15 or 195/50/15 falken ziex
- SRS Light Flashes When Checking For Codes
- Legalizing exhaust in CA. I need help on the phone number
- engine oil for d16z6 motor?
- found a good civic, go for it?
- help with oil leak/burn
- 98' 4dr Front end and 00' 2dr front end
- Black Interior
- 95 civic converted from LHD to RHD
- car hard to start and stay on when it cools down after 2hrs.help
- 1999 civic hx, what kinda maitnence should I do on it?
- PIC REQUEST:
- Out of ideas (VTEC and VSS CELs)
- 92 Civic Denji Projectors with OEM Glass Cover?? anyone done it??
- more info about this b-series transmission?
- trailing arm torx bolts
- Alot of Del sol goodies for sale
- Muffler?
- What Does A JDM D15B Motor Normally Rev. To, And Is 8K Safe?
- Air conditioning question
- how to identify a JDM DOHC ZC tranny
- another "MY VTEC DONT WORK" thread
- tie-rod replacement part question!
- Sad in Oz - Fresh replacement engine , installed, timing belt slips on start up and valve noise ?
- This isn't a good deal right? - Suspension related
- Civic Swap
- Steering Wheel Material
- help asap alarm issue! matrix 3.5 with my si
- High Milage+Investment
- Underdrive pulley question.
- e-brake light on...
- Best Intake for b18c swapped EK ?
- P08 or P28 !!!!!!!!!!!!!!!!!!!!!!!!!!
- Loooking for photos of RHD engine bay.
- Will the stock front upper strut bar on my dad's 97 integra gsr fit my 95 civic coupe?
- Hey, lookin for 99-00 fog light mounting brackets.
- Door lock modual wiring pin out - Help needed to indentify wires
- 96 hatch has no sway bars
- need eg ignition wiring diagram
- jdm cluster
- japanese licence plates!?
- Help..need info in swaping b18b1
- HELP!! Electrical Problems in a 92 Civic
- 1.5 inch exhaust VS. 2.5 inch exhaust
- ? about $ for a full d15 non vtec swap???
- which build should i do
- exhaust smoke. i know whats most likely wrong, just want opinions...
- Fake Js intak...filter question?
- Question about hoods on a 99 civic hatchback
- ecu problem? help
- Will a 94 DX Door fit onto a 92 honda civic DX hatch back ??
- Tsudo RSR style muffler any input?
- Valve Seals?
- Hitting Red Line?
- Ek headlight help
- SRS
- #'s for Ls/Vtec @10psi???
- o2 sensor
- Spring rates??? Differences between 92 95 and 88 91?
- HELP MSD.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
- failed emissions in az, NOX a bit high
- Swap Tranny
- LX/EX cluster VS SI cluster in EJ6
- EG owners with aftermarket LCA's, step inside
- Heat Not Working
- RSX seats in a EK
- Mysteriously the car turns off sometimes, and Clutch is too stiff
- I accidentally ripped the black rubber thing around the headlight bulb...
- Header just a weeee short. Quick Fixes or Muffler Shop
- tein SR
- ebay projectors, anybody have experience?
- Help: Broke piece of headlight bulb/plug
- Where to get a passenger side fender liner!
- Changing Fuel Injectors
- What size bolts for sparco seat mounting?
- eg6 rear seats help
- radio console
- rear brake drum conversion . . . NEED HELP ASAP....
- wow..Really wierd electric problem...No key...fuel pump primes...dash lights on?
- swap question
- Review: Omnipower Clutch Master Cylinder
- clutch problem...help.
- Hatch wont rev past 2K
- AKMEE d16z6 valve train dyno result
- car doesnt start need suggestionss
- EK wiring for turn signal / city light / side marker
- steering
- pistons rings!!!
- question on exhuast
- Puttinq a LS Swap from a 91 inteqra into a 93 EG Hatch. Whats all needed to do swap.
- Where to find info on JDM EG Civic models
- Wiring Question..
- b16a2 lower main bearings
- Blower motor works sporadically
- FOR SALE OR TRADE: COPPER EJ8 $7,000
- Is this normal?
- Civic Ignitor Reliability
- Removing Muffler from Pipe?
- Does anybody remember ,
- the desig
- Where can I order the blue Volk lug nuts?
- anyone ever see these fogs before?
- question about b16a2 head...
- Bypassing 96 CIVIC COUPE ENGINE IMMOBILIZER SYSTEM/purchasing new kit.
- Suspension on EG.. Eg owners help out
- wheel rub
- clicking noise when turning left, not cv joint/boot
- Turn signal issues
- Mini me vs D16z6 Swap
- Strong winding sound...
- Ek gage cluster
- How to tell differences in y7 and y8 parts
- 13" steelie fit on '99 Si rear wheel?
- JDM D15B V-TEC PROBLEMS!!!
- Brake conversion '99 Civic Lx
- What year civic mounts to use on ek. Whats all compatible MOunts ect
- Why would an auto ecu work but not a manual
- ~~~My Timming Jumped~~~
- Car hesitates when you first start off. Need help.
- oil leak
- help needed car doesn't start
- Need a Little Help with D15B
- brighter corner bulbs..
- Break Light coming on while driving..
- Hasport... Confused! FULL-RACE Motorsports help?!
- Another stolen civic
- d16z6 plugs?
- EK swap ??? need help
- i want
- 96 civic hatch rear seat
- Good price on a 99 Si w/100K
- b16 problems
- Fuel pressure
- Which brake lines to use after big brake install?
- some help
- OEM to DC Header, problems...
- what rims will fit my eg? *searched*
- 1993 Honda Del Sol SI SOHC VTEC Installing Clifford Arrow 3 G4.?
- Clifford Arrow 3 G4 Installation problem> Please help?
- GAS PROBLEM!!!
- rear strut bolts
- Help My h22 4 door civic loose weight.
- Quick muffler q...
- For All Those Who Are Using a Motorola 2.5 BAR MAP Sensor
- gsr eg rod bearing question????
- LS Swap in hatch
- Ahh clutch is on the floor
- h22 eg radiator fan fitment
- Where is the jack in a '99-'00 civic coupe?
- quick d series question
- b16 vs ls vtec
- hey everybody this is a good one . . . 7:24:26 pm
- installing NRG bushings cost ?
- need some mini me advice
- Gsr swap idle issue, help me pass emissions!
- need help removing my 98 civic front bumber
- Looking For S2000 Seats
- o2 problem, how do i do this?
- throttle body swap
- Help the new guy
- noise coming from exhaust?
- overhauling my rear disk brakes...
- DOHC ZC Swap
- swapping an hx for ex
- Relay? problem
- OBD2 to OBD0 Wiring Harness
- CEL on '00 Civic w/GSR
- gsr swap
- DOES ANYONE SELL CARBON KEVLAR LIPS?
- Rear Quarter panel rust, price?
