View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Which linkage for a B-series swap on a Del Sol???
- what size?
- Time for a new Alternator....is DURALAST ok???
- eibach and intrax sway kits? anyone got this? good/bad?
- DC2 Springs fit on 92-95 4 door civic?
- where can i find EK rear bumper heat sheilds??
- projectors install
- Just did a b16a swap into my 99 civic ex..which AC belt
- Headlight question....
- what would you do/has this happend to you?
- What Alarm Is good???
- New wheels/tires, do I need a camber kit?
- rear ended someone ... front radiatior support problems
- ls rods in a d16a6
- milled head, timing off....
- passwordjdm intake manifold gasket?
- Motor mount ?
- Corner light bulb socket
- Crappy Dx
- rear hatch leaks
- Help!! NO fuse box cover!!!
- 93 Si brake job........?
- apexi ws muffler on ek?
- Side moldings on a Civic vx?
- d16z6 or d16y8
- gauge cluster indetification please
- B22?
- synthetic vs. conventional oil
- What size tires do you guys run on 16" in a EK?
- erratic tach!?
- SoCal: **~STOLLEN~** 98 Civic DX Hatchback (Santa Fe Springs area...562)
- Question about building a d16y7 with 190k
- Whats needed to do a rhd conversion
- 1st Post
- air bags in an eg
- O2 sensor
- Another LCA and Sway Bar ???
- Installed JDM D15 in to Eg sedan help?
- starting problems
- turbo timer help
- Mushy Clutch and Hard to Shift
- question on hondata and passing inspection
- Car Problems "Battery, alternator, or wire problems"
- What is the difference between USDM taillights and the JDM ones???
- Helllllp im having issues with reatteching wires on the big driver side motor plug
- Metal on Metal scraping near front wheels?
- Sagging VIS CF Hood
- Re-Use of a Head gasket (PLEASE ReAd)
- Griffin Radiators @ Jegs
- tip on buying an exhaust
- Anyone purchased from www.virtualbodyshop.com?
- Underhood fuse box, help.
- need engine help 95 civic lx 4dr sadan
- << EK9-owners: Germany needs your help!
- 4dr Sedan GX
- How much are regamasters?
- Do ek hx's have rear disc?
- Civics amperage usage?
- Rear and front Wiper wiring diagram???
- what should i expect, performance wise ?
- D15b problems once again
- EP3 seats in a 94 hatch????
- a/c not cold...help
- Need help! why my car doesn't start
- HX rims are 14 in. right?
- 99-00 rear bumper on a 4-door
- brand name sway/strut
- Throttle Position Sensor?(searched)
- bad ignitor
- Exhaust compatability
- gsr in 96 coupe question
- EK mirrors on an EH ?
- my RPMs keep dropping LOW...
- 97 4-door 5 Speed.... which seat rails
- Quick tire review...help me choose
- wheel wobbles
- Window won't go back up (94 del sol)
- b16 head/d16 block?
- itr quick release????????
- EK front LCA interchangable??
- Rotor keeps turning black
- rebuilding my engine need help
- Hmotorsonline
- Need some QUICK SWAP HELP, B16A into a 92' Civic CX.....
- need a good site for cf hood
- 310 cc injectors
- CTR LIP SHORT!!!
- GPS Navigation in EG....
- Vibrating problem with my car...
- My 92 hatch with b18B1 LS wont go over 115MPH
- turbocharging
- using jdm wiring harness..what to do with map sensor?
- EG Owners, post up your quick release wheel set ups.
- radio resetting?
- DIY: lightweight stock del sol hood
- which fuse is for the fuel pump?
- bbk intake manifold
- idle/clutch problem...
- LCA and ball joint won't fit back together?
- shifting problems???
- installing springs on a 05 civic...
- Rims i Need RIMS
- traction bars
- suspension question..
- DA brake swap onto 00 EX
- 96-00 Honda Civic FACTORY SERVICE MANUAL 2200+ pages....ALL MODELS..US and CANADA....PDf file
- will 88-91 springs and struts fit on a 92-95?
- PARTING OUT WHOLE SOL...
- Del sol owners: how to remove door panel?
- tranny noise
- Need help with parts
- What rear seats are available for my 97 civic sedan?
- O2 Sensor rattling on Shift Linkage.....
- Need Turbo install Help
- Need help with finding parts for my EK
- Will These Tires Fit
- anyone ever fix their car stuttering problems?
- Can anybody guess what this is?
- Idle Problems With My 96 Ek???????
- o2 Sensor question...
- FREE 40 point inspection from Honda dealership
- Problem with my EG6
- ITR Tranny vs B16 tranny
- temp gauge rising?
- Looking for a good pair of Del Sol seats...
- Synthetic Oil and Zex Cam
- Need help on motor mounts???
- can you use suspension from a 96 EK in a 90 integra?
- Issue trying to replace driver's side headlight bulb - '00 civic
- Rattle Noise DRIVING me crazy!?PLZ HELP
- any tips on how take out my eg2 delsol dash?
- removing shift boot?
- O2 Sensor Wiring Question, Help Please.....
- DOES ANY HAVE THE PIN OUTS TO A P28 ECU??????
- 15x7 40 offset or 35
- Cluster light / headlight problem
- Overheating!!... HELPPPPP
- D16z6 dying?*frustrated*
- Lsd install problems
- JDM Cluster with DX wiring..
- Barometiric Sensor Unit Problem..Help...
- help to think.. thanks
- Heart transplant!!
- 96 Civic EX and CX brakes the same?
- Changing CV joint, need any special tools?
- finally decided to post pics of my EJ1
- Nor Cal (bay area) my car stolen look out for it please
- i need some help, should be easy
- God damn Leaking hatchy
- rattling exhuast: hitting swaybar
- Specs of 96-00 EK9
- R134a AC conversion question
- Coupe compatible with Hatch?
- 1995 ex harness with a obd2 b series swap, what distributor to use
- ATTN: EK experts!!! SRS light is on how do I get rid of it?
- EG JDM Side Marker
- CTR intake cam on b16
- show off your eg 2dr here
- Why do i hear this noise?
- Wiring VAFC to ODB 2 car with ODB 1 motor, please help
- want to know if this is possible
- ECU P# for the b16a3
- 00 civic chassis electrical probs
- b16 losing coolant! from thermostat housing...thermostat?
- plz help asap
- 98 Ek. how low should i drop it?..
- engine serial # and VIN
- Trunk Keyhole rust issue.
- I need some quick response to my question ( suspension and tire...)
- Wierd simple GSR rear brake pad question...
- Is this ebay auction legit?
- Help with wipers!? 92 Si
- NEED HELP: how do i adjust lights on 97 ex coupe
- HELP NEEDED:WHAT COLOR PAINT TO USE FOR MY EG6 OEM STYLE FOG LIGHTS
- Stolen Foglight Cover
- Factory OEM Headlight and right fender for 00 Civic EX
- Skunk2 cam gear install question
- b16 tranny questions
- GSR SWAY on EK random issues
- wiring for power foldong mirrors(ran a search)
- WHEELS ETC
- Gas Mileage Improvements and suggestions please. 95 Civic
- tranny question
- clutch?
- Clifford Matrix in a del sol
- run at the track again today let me know what u think.
- Help needed... dumb question
- intrax rear/front sway any good?
- What ECU's needed for jdm d15 swap???
- socal// anyone that can install a y8 head on a d16y7 for me?
- drive side door won't lock from the inside
- 94 civic hatchback DX motor swap
- sway bar change... shock needed to be changed also?
- Eg civic Best hood pin location , searched but not satisfied
- temp going up at idle?
- type r springs on ek coupe?
- Need a Honda part # for 96-98 EK Radio Pocket
- don't know the name of this part
- Fuse Box layout
- AC bracket on a B16 swapped 93 coupe? 99-00 Si Bracket?
- Would this camshaft fit? please help im bidding on ebay
- Not a tech question........
- need help from d15b and z6 owners
- check engine light on a 99 ex
- p28 or p72 ecu for EG/ B18C1 swap
- b18cr in 92 si, tach not working
- y8 intake manifold on y7
- brake rotor suggestions?
- P72 GSR CEL HELP!!!!
- 92 civic dx: spark plug gap?
- swap or rebuild d16z6
- Idle rpm
- can a bad O2 sensor cause funny idles?
- Electric Problem :'(
- 96-98 99-00 A/C Kit
- SWAP OPTIONSSSSS
- tips for b20vtec?
- My engine came with a chipped ECU and I want something stock.
- I Need A Pin Out For 02 Civic Gauge Cluster
- 17s and Omnipower Sport, unbearable? (already tried suspension forum)
- Good Move, Or Bad Move?
- which honda
- what would cause my car not to turn on at all but brake lights work?
- 93 si throwing code 43 whats wrong
- CTR Valve Cover Part #?
- Low Voltage issue with my motor
- legend brake upgrade on 2000 civic ex
- Ls/Vtec vs poor man's type r
- Quick Fuel Pressure Reg. Question
- My WTF! car wont start Part 2.
- what do u guys put in your radiator over flow tank?
- Rebuilt motor got a few questions...
- On a budget.
- 93 del sol s
- 93 civic HB
- ebay eg6 foglights are they worth buying
- ES polyurethane suspension bushing
- Is my timing messed up??
- powder coating rims?
- 4th gen Civic/CRX springs fit on EG?
- Applying Dynamat or the like to outer door skins
- My ACCIDENT.
- Severe brake prob, please help.
- Installation help
- Rpms go up then drop realllllly slow when i shift
- Diffrence is CX, EX, LX, VX, DX, VX, Si-R
- Wiring Harness
- Can someone do me a favor and take a pic of...
- B16 or H22
- HEADLIGHT/DASH LIGHT ISSUES
