View Full Version : Honda Civic / Del Sol (1992 - 2000)
- rear disk for a 97 civic ex parts?
- On going battle with P0505 idle malfunction. Now with video.
- Wiring Harness
- Can I convert my EGs manual steering to power?
- fuel pump not turning on?
- D16Z6 VS D16Y8
- What colored Rims go with a Dark Green Honda Civic??
- STOLEN 97 CIV HB FROM CHILLIWACK HELP!
- 97 Civic sputters at 2-3K rpms
- Fuel problem???
- Is there a way to delete evap canister on 0bd2b without throwing codes
- Valve adjustment info help?
- Rear bumper lip.
- B16A3 knock
- Honda civic gsr swap p28 ecu running lean
- qeustion about VIN tag.
- Civic 1992 Battery or wiring Problem
- Where did u order your oxygen sensors?
- Mini-Me Swap + E85 = Fuel $ Saving?
- removing auto cruise, 2000 ex coupe
- Where can I buy back seat locks for my 93 eg?
- 98HONDA CIVIC DX
- Should I invest $20K dollars in a Civic SE worth $3K?
- Need a wire-harness!
- 1992 honda civic si, left front caliper frozen
- 1994 Civic cranks but won't start
- '97 Civic vs. Concrete Pillar ***image heavy***
- brake pedal goes too far down before braking
- ground control sleeves on skunk 2 struts?
- 95 civic automatic transmission problem
- b16 swap EG6 main relay not kicking on???
- 1994 civic ex cam shavings?
- 98 Civic LX - Cylinders misfiring as well as P1399 code.. Need HELP ASAP
- ATTN: MISTABONE
- Ek cluster swap
- Type-R, Good buy?
- A/C not cooling
- Hose off
- dash lights dim
- D16Z6 Miss fire at idle.
- Whats The Easiest Way To Install a Clutch Master Cylinder On a 93 si d16?
- D15B 3 stage Vtec..what should I do?
- vtec? em1
- My car wont start lol
- low beams didn't work, then worked
- Need help Id-ing some parts
- What plug is this
- 97 Civic 2DR EX Auto PCM
- Honda Fit front lip on EK/EM1
- 95 civic ex engine pull
- AC/PS in del Sol with B18C1 GSR
- Need diagram to remove delsol wire harness
- Bad Gas mileage!!
- Front passenger squeek help cant figure it out
- motor mount studs too short on drivers side; B20 swap with avid mounts
- civic with ITR engine question
- 94 hatch shifting issues
- 1998 Catalytic Converter to B16a2
- 1998 Radiator for a b16a2 engine!
- Axle problem
- 3 questions about the B18C1.
- Help...CEL code 6, 7, 10, 41 fresh y8 swap in EG
- 96 EX, wanting to H2b
- del sol front windshield
- Air Conditioning Questions
- Gauge Cluster Differences
- HELP! BEARINGS!! B16a
- HELP!!!! Can I put a OBD0 B16 into a 92-95 civic
- b18b1 automatic and manual throttlebody difference?
- old noob here. 97 civic sunroof and other electrical problem need help
- 93 eg b16 Turbo setup help!!!
- Dseries to Bseries swap 96 dx
- AC Bracket help
- still overheating
- which wire harness do i use for my b16?
- 99 Civic DX - headlight and tach questions
- It's been awhile.....lol
- car shaking issue help plz
- Single Vtec Camshaft Identification issue
- 99 Civic EX - loud hissing noise, sounds like a baby rattle with sand in it
- help
- o2 sensor help and i.d.
- Sudden Death after washing B16a engine
- fuel sending unit or fuel pump itself? d16z6
- GREDDY MUFFLER HELP!!
- gx suitable donor for my dx?
- 4 wire 02 conversion on D16Y8 HELP!!!
- 97 civic foglight installation help
- White Smoke Pouring Out Of Exhaust, Sluggish, Hesitant
- How to clean iab (intake air bypass)?
- full size radiator in a del sol
- civic coupe suspension question
- built turbo em1......need advice
- EX vs SI seats
- Mugen Lips?! How many are there?
- Engine swap
- Is this the right harness for window conversion?
- Fuel Pump Priming Delay
- F22B1 EG Will Not Start... PLEASE Help!!
- A removable steering wheel is not theft proof
- need some help for a b20b!
- WTB: 97 HX wiring harness
- Taillights
- 1995 Cx Hatch AC
- d15b vtec y8 manifold what gasket should i use???
- OBD's
- No start/ code 3
- mugen ecu chip on p28.. removal/help.
- Alternator on it's way out?
- Del Sol and Bass
- 1993 Honda Del Sol "S" clicking noise @ steering column
- anyone have a vacumm hose diagram for
- manual, obd2 to obd1?
- How to differentiate between a b16 / itr
- My EJ1 Build
- Which company makes a good black housing headlight set for 92-95 Civics?
- skunk2 cam(sohc) need tune? 92-00
- my MPG is off
- Good Price? $2k for a '99 LX Auto Sedan w/ 120k Miles... hail dmg slvg title
- Skunk 2 Coilover Sleeves fit Koni Yellows??
- **98 D16 Rebuild**
- Car died while driving.
- Need some advise I have a Civic EK
- Constant water dripping from exhaust/grayish smoke
- Parts recommendation for 99 sir
- 1995 Honda Civic LX help
- EJ6 water leak in trunk
- z6 missing under load
- GSR Rear Seats in EK Coupe-
- made an oopsy with the oil... wrong grade..
- h22 into ek dx wiring
- Fresh swap 98 d16y8 into 93 EG any info?
- New user needs some good new honda friends
- engine dies while in gear
- High mileage civic. Worth building?
- D16y8 Bogging problem
- Replaced drums and now parking brake's not working.
- ej1 leaking bad....
- obd2 to obd1???
- Is this car an EK?
- j's racing dc2 bumper air vent work on a 96-98 civic?
- Front Control Arm Bushings
- what makes y7 and y8 camshaft differ?
- 2000 civic wont fire after it rains
- help 97 civic d15b vtec
- idling problem!!
- CIVIC SOHC VTEC THROTTLE BODY INTAKE UPGRADE HELP
- CEL's reoccuring
- eg b18b1 ls swap. no fuel, no spark
- Reverse lights arent working..
- detonation causes
- B-series harness help!
- code 8, need help
- D16Y7 Valve Cover Paint Job
- JDM Power Folding Mirrors - SI
- Shift Linkage problems
- B18c5 bogging down!
- 1997 EK Hatch dr door doesn't unlock/open with key
- Installing Airbags on Civic 94/95
- Looking to do a SWAP
- Please post pictures of some clean 1996-2000 4 Door Civics
- del sol taillight problem tail light
- OEM Honda Civic Si Springs 99-00 need price
- Exhaust Tailpipe problem?
- Dorman Hood Release
- 97 ex tranny question
- Replacing Del Sol Antenna
- trying to grenade a motor...how to remove fuel cut?
- stripped thread for brake drums 95 dx
- Will a VTEC run ok in a non VTEC car?
- Picked up a 2000 Civic 4 Door - Need some Ideas
- Temperature gauge not working.
- Help figure out fuel pump prob. tried everything.
- d16 to d16z6 problems
- queston about eg with a b20v swap. what ps pump and bracket to use?
- Undo Integra Front end Conversion on 00 Civic Si
- 4.7 final drive?
- any opinions on a trade? z6 hatch for b16a hatch
- 95 civic dx radio stays on
- c327 skunk camshaft and camgear????
- bar question
- 00 front end conversion ebay
- 01 civic dash assy. in 96-00 civic
- 06-up seats?
- Odd connector on ECU of GSR EK *PIC*
- (95 Del Sol S) Oil On Top Of Plugs? What to Buy?
- Removing Del Sol Radio?!?!?!?!
- coilovers question
- how to darken purple spray paint
- 98 civic ex sedan door lock problem, also auto roll down problem
- What ECU for LS swap in '99 Civic?
- E-Brake button???
- Slim Fan mandatory?
- Another Suspension Poll
- B16A2 w/S4c opinions pls
- 95 dx brake question
- Only 96 spark plugs work in my 94 Civic
- jdm d15b vtec is safe to go turbo?
- On a budget.
- Does anyone remember this instrument cluster?
- Ok everyone i figured out the P0505 code
- Quick Exhaust question: flex section or not?
- Have you experience any issues with P0715 codes?
- 95 civic Slave cylinder push rod pop out
- Will a y7 engine harness work in an em1?
- Lowering springs in front only?
- issue with 2000 civic automashit
- Skunk 2 Coilovers? Thoughts?
- Removing the vinyl interior trim around trunk latch striker ('98 hatch)
- Tranny problems. ej8
- wHICH hYBRID BSERIES
- 92 Civic Hatchback
- Best exhaust for my b18b eg hatch?
- Si Head Rests
- what ecu do i need?
- Tach innacurate after tuning? Please help.
- eg suspension on an ek benefit?
- 96 dx sedan with stock moonroof?
- Slow gsr??
- Upgraded Brakes?
- Rear sway bar with Mugen Twin Loop questions
- Where to buy ek trunk lip?
- 96 hx b16a2 swap finally done!!!
- help with vacuum line problem, B18 into 2000 civic
- Stolen Del Sol: Chicago, keep on the lookout please!
- Hondata issue
- ej1 motor mounts h2b help!!
- Integra OEM dual bend shifter in 99 Civic Si without cutting or bending??
- whats this?
- d16z6 map sensor problems
- Tire Advice
- getting horrible gas mileage. plz help!!!
- Need help with tranny noise please
- 96-98 Auto Trans ?'s
- Ek roofrack?!
- code 14
- Ej1 LS-VTEC
- CAT help magnaflow
- 94 civic hatch dx d15b7
- 88-91 Prelude Brake master cylinder for disk conversion..?
- Camber on one wheel
- Back window/ passenger window won't roll down(no blow fuses!) what else could it be?
- F20 into 93 eg coupe..
- Rear main oil seal leaking on new jdm engine swap..
- De-Rice my Civic SI
- 1994 civic ex gauge cluster can't read it
- LS tranny problem
- Question on these wheels for del sol (please don't move), quick question
- 94 Del Sol - need input on headlight casings and other upgrades
- Radiator fan not coming on (Again!!)
