View Full Version : Honda Civic / Del Sol (1992 - 2000)
- LEAK IN TRUNK/RUST -- PICTURES need some advice.
- help with noise
- low compression in one cylinder piston rings?
- help with crazy speed neddle
- b16's barely staying alive
- starting issues need help!
- Need Help!! EG Hatch Power Windows/Locks
- Need Help With My 92-95 Civic Hatchback Build.
- Insurance tryna low ball me, whats new?(Allstate)
- Distributor question
- when i give it gas nothing happens any ideas?
- Left headlight grounding problem 96 civic sedan
- picture of the engine for a 1992-1995
- Wrapping my seats...
- How can i convert a 96 civic dx to all power interior features??
- Omni LCA's on EJ6 won't take ITR rear sway??
- Calling all K swap geniuses...............
- p28 on a d15b?
- 2-step
- 2000 Honda Civic - Collant Empty after new water pump installed...car overheating when sitting
- Code 41
- help!! i want to make my b20 a little more reliable
- Honda Civic 96-00 service manual
- question on tranny swap
- Drive Master Cylinder Stopper in a 1997 Euro Civic VTi
- are all D-series fuel rail the same?
- Boosted H2B swap in an ek Opions?
- Seat Swap
- pound for pound
- B series axle splines not lining correctly
- Just Bought Rear Disk breaks for My 94 Civic Coupe will I need new E-Break Cables and Break Lines???
- rear lights and turning indicator problems
- Eneos oil?
- 81 mm refers to?
- More ECU questions.
- ***Random Lighting Problem PLEASE HELP!!!***
- Rear disk conversion- need some advice
- NEED HELP W/MY H22A Civic!!!!
- 96 civic hx, wanting to use 99 si stock intake, and header???
- What is the best transmission for a b18a1 LS Vtec swap?
- turbo/nitrous
- B-series plus manual swap
- del sol tranny
- out of the game *edited*
- Homies car got boosted last nite and bad news for they bad guy
- click/clunk axles ?
- code 17 VSS
- secondary o2
- 97 Civic A/C help!!!!!!!!
- need help finding sensor
- Clutch
- OBD1 into EK
- car sputtering when accelerate 01 turbo ls
- Frozen Brakes. Where to start.
- B18c1 into EK wiring question
- Cable b16 clutch kit?? where to get one?
- what kind of honda seats fit 95 del sol...
- SOHC or DOHC?
- Rota's
- Springs
- Major help!!!!! this is for the honda gods out there to help with!!!!!!!!
- i need help with v-tec
- NEW!
- broken trans mount need advice..
- Having trouble getting into gear.
- Hi new here
- wire harnesst question
- Anyone ordered/hear from Jazz Pro Parts recently?
- Will D16a6 internals fit in a D16y8 block?
- electrical charging problem
- Valve calibration question?
- Disc brake question...
- VW GTI to Honda Civic
- h22 eg
- Simple Question??
- Pics of a 99-00 Civic Hatch with Eibach Prokit springs?
- Suspension Question
- where to buy usdm type R?
- unburnt fuel coming out my exhaust? [pics inside]
- 95 civic blowing white smoke...
- i need help polishing gsr fat five rims
- help big problems with the ITR swap
- obd2 to obd1 conversion problems
- Someone tried to steal my civic and necked the hell out of it...
- LS IM/TB on D16Y7
- power windows dont work but power locks work. need help.
- Is it Possible to use a 225/50 r15 Kuhmo Ast Tire on a si or gsr blade rim?
- my del sol vtec.... help
- Tranny problem, please help
- Y21 gearbox reverse switch
- 1997 civic hx fluctuating rpms
- EG w/ D15B7 needs a swap
- Lowering my GC coilovers??...
- Compression/Gas?
- Windshield Replacement.
- another rear camber question
- having trouble shifting into gear
- Del sol wire harness questions.
- How much it worth?
- non VTEC to VTEC ECU conversion/ question about p06 and p2e
- inertia switch on a 93 eg hatch
- My tranny has no vin Plate?
- power door locks only???
- 92 civic [ VX ] interchangeable with [ALL] sohc oem headers?
- fake tail light?
- p08 chip for p28 ecu?
- 99 civic ex question please help
- made a mistake, help
- Buddy Club Vtec Controller
- i need some help please
- gsr into 96 ek. quick wiring q's.
- quick question
- question on tuning
- Seat Height : Sedan vs coupe/hatch????
- Factory Options for 92-95 EG hatchbacks??
- Interchangeable IACV?
- STOLEN EG / Bay Area / Outkast / Alameda / Oakland
- STOLEN EG BAY AREA / OAKLAND /ALAMEDA - PLEASE BUMP
- 22mm rear ITR ARB to EG chassis
- LS swap not starting???
- ATF in gastank
- If any of you know who has a EK hatch for sale preferably with a b18 in it already let me know
- Relay problems, pls help.
- Using 89 octane on a b16a2?
- I want to Do a Build Thread but have some Random questions first.
- MAP sensor diagram on 2000 civic EX d16y8
- DC header, D or B series?
- how to check map sensor???
- B18C1 into EK shift linkage question
- Will 96+ Civic side mirrors fit a 93?
- need some port work done! DFW area!
- Any Honda people out there from BUFFALO NY area?! Need local help!
- how much is this worth>?
- burning oil
- HELP with emissions!!
- transmission problem ... help!
- H4H HIDs
- trunk light indicator flashes ONLY when stereo is on...
- 1999 Honda Civic LX Won't Start
- Ek coupe in this song lol
- idk whats up
- interior
- Ticking noise(b18c1)
- Problem with my car...something involving my battery and clicking noises
- something wrong with my engine?
- clock light dim when lights on?
- Converting 1998 Civic ex to 2000 Civic Si
- civic d16z6 k26 turbocharge smoke???????????
- 1998 Civic Ex converting to 2000 civic Si
- ready to buy a civic, want to convert parts from my totaled teg, any tips?
- auto to manual eg question
- 205 50 14 tires on my 185 60 14 stock wheel
- which year is my gsr head?
- i need the pinout to the ecu wires for IAT sensor
- How to? Viper Alarm 791XV
- 97 Civic SI Overheating....
- What axle fits gsr tranny with quiafe
- y EG won't start
- Car bogs for a few minutes after startup? Help.
- brake fade problems
- It really must be my lucky day, first over heating problems, now the damn thing won't start...
- need help putting a k series in my eg coupe!
- pulls till 4g
- New FAQ's please
- It (STILL) never ends... Cooling problem now, WTF?
- code 24 wtf?
- B16 fuel pump
- Will an Automatic cluster work with Manual Transmission?
- NEED HELP
- AC question.
- do i Need a Proportion Valve of I want to upgrade from Drums breaks to Disk Breaks ??? Need Help
- Can a CtR E-Break handle be installed on a EG or EJ Coupe ??
- prelude vs civic
- P28 on b18c1
- How to Bar' Automatic JDM B16a2?
- ECU Throwing Code 19: Automatic transmission lockup control valve
- Problem With Cluster And light switch
- HELP. electrical prob maybe related to alarm 99 civic EX
- chrome tuned issue leans out at 5psi regardless of rpm
- What should i do Next??? B18c swap ..I NEED WARP SPEED SCOTTY !!!!
- might build my own engine
- What kind of head gasket should I buy?
- Del Sol transmission compatibilty
- want to trade 97 civic for 03 tl tranny
- cluster questions
- 93 civic hatch overheating issue, bad headgasket maybe? thanks
- would u do a trade????
- Del Sol gauge cluster clock doesnt work
- Problem starting
- ls vtec swap
- what gas to use in d16z6?
- SiR Cluster installed, now dimmer won't work.
- Will eg front camber kit fit on ej?
- 1992 civic heater core question
- jdm gsr
- dsm piping
- Skunk2 Pro s Coilover question!
- how much would u pay for.........
- all in favor say I n/a or turbo
- Problem Starting Car! (94' Honda Civic EX)
- Best D series ever!!
- b 18 swap
- HOW TO: S2K Seat Pan Swap into EG/Del Sol/EK
- 97 civic replacing air bags AND.....? NO BS
- what hatch?
- i was board so i did this
- First Vtec Motor, Not Sure If It Is Engaging
- U guys ever tried this ?????????????????
- b20 bottom end specs
- mini me swap
- D15 to D16 questions.
- vtec
- 96 Del Sol VTEC sounds like a Subaru..... :(
- 1994 delsol si trouble
- Your opinions on polyurethane bushings...
- Fake Ctr lip mounting hardware
- 93 civic auto trans
- Anybody have pictures of a civic in rosewood brown?
- does anyone know what recalls were for 92 eg sedan?
- The dual bend d-series shifter answer (skunk2)!!!!!
- 99 Civic DX idle question
- RSX mud/splash guards??...
- 96 civic lx auto transmission problem...Any help is good help
- 94 Del Sol Transmission problems - Won't change into 3rd or 4th
- Thermostat housing/waterpipe assembly URGENT!
- Engine swap question?
- gsr rear seats
- Quick headlight question
- starter will not crank
- Speed Sensor
- Traded my 91 DA for a 93 hatchback
- building my own engine
- any1 with 96-00 oem side skirts 4sale?
- Caliper replacement question....
- use stock shocks/springs on my civic with a gsr motor swap?
- Which Coilover set is better for a 2000 Civic? FunctionForm or GC+Koni
- Aftermarket timing belt, which is better, what do should I get
- Trouble finding bolt
- car starting problem
- b20b on an 97 ex coupe
- Need info on power steering with B18B1 in 95 EX
- WTB : 99 - 00 dirver door harness and power door regulator ASAP!!!
- didnt pass smog(new cat)
- crank swap
- Can I just swap rotors for type r rims?
- auto motor
- Hi, I'm new.
- help
- Question about throttle cable!!!
- a/c doesnt work and its hot out!!!
