View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Intake and Exhasut valve guides
- NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE
- Are my motor mounts from a 95 GSR complete for JDM B16a Sir2 swap?
- CARB problems-check it out
- Weird Intermittent Problem-please help
- A/C question. please help, it's hot here
- apexi N1 catback piping diameter
- Quick CTR 5-lug quesion
- Specification of Del Sol's, which ones were the DOHC VTEC models?
- zeal or jic coilovers
- 98 CX with PS/AC Worth?
- Del Sol Keyless Entry
- Squeaky Cat
- ITR valve springs and skunk2 stage 1 cams
- HAYAME FULL Coilovers
- Comptech sway-tie bar?
- Y8 into 92 CX
- well me first, but then him right afterSurprise! Surprise!
- about this swap
- Jegs E-Cutout??
- ITR Fuel Pump vs DX Fuel Pump
- del sol with front conversion
- engine problems
- comp cams 59300 vs crower cams stage 2/3
- 92 civic b16a engine swap help tranny oil ecu wiring
- Attn slammed guys, lift ramps
- Anyone with skunk coilovers, what do you have them set at ?
- another exhaust question...?
- Slicks are f-ing cool!!!
- Seattle Area:Auto to manual help
- Suspension Question? Please Help!
- home made ground kit....
- How to remove ebrake plastics???
- SOHC (D16Y7) FIRING ORDER .. PLEASE HELP!
- What a day for me and the hatch... *PICS*
- max wheel width on a 00' Si??
- gsr springs+shocks in an EG
- AEM Cam Gears stripping - need info
- taking out heater core tube. will anything leak from the tube?
- Comptech header problems.
- VAFC Question....HVt
- AICV, FITV need help
- Am i being scammes??????????????????????
- quick question
- will struts from 96+ civics fit on 92-95 ??
- 2001 Civic EX problem
- QUICK AXLE SEAL QUESTION!!!! NEED HELP
- E_break problem
- is this legit?
- coil spacers
- can u tell me where my stock ecu chip is
- Bout to do a Engine swap (1.6 Liter DOHC Vtech with turbo)
- JDM EG6 Muffler? Effective?
- Axel Question
- best d series r/s ratio for boost? why is vx best r/s ratio?
- And you thought you had a sweet swap!
- Help with Stock Alarm
- Cruise Control Button Removal
- attention moderators
- CEL 3, 5 map, 93 ls tb on 01 ls imtake manifold. searched
- Which head gasket to use?
- Going Junkyarding, need some help.
- Blower Motor Trouble
- What do you guys think about this idea
- Using the y8 head gasket on a d15b?
- Wasted $$$, so what's next!!!
- 1996 Civic Sedan Wont Start In the Heat
- building head from scratch dont have any bolts... PLZ HLP!
- Valves? which one is which?
- Greddy SPII exhaust opinions
- Engine overheats while driving but not at idle??
- D15B info nedded
- 92 civic head gasket
- Running Rich
- Certifit (Certi-fit) Radiator Core Support
- question: 98 accord 4 door seats in a 96 civic coupe?
- EP3 exhaust on a EG?
- Springs?
- no spark
- Clutch Question - Y/N Answer
- Brake upgrade project
- Real world CV joints
- cali smog help
- How to Removing EG Door panel?? I searched ! pics!!
- gsr lca on eg hatch question
- What A/T tranny would fit on a 95 Civic EX?
- Lip Info
- can i put a fmic on my car......
- NEED HELP w/rear sway install...
- Meet my new Toy
- 94 and up Integra dash in a Del Sol
- 16 inch bronze 5zigen FN01R-C wheels with falken ziex tires
- who would be interested in 92-00 civic traction bar/crossmember bar for cheap!
- TO ALL YOU 92-95 CIVIC OWNERS!!! POST UP
- Cam Gear for a D15B7/D16Y8 Mini Me???
- dohc vtec solenoid. any way to convert JDM one to 2 wire?
- New here
- Super Clean EG, Near Impossible?
- Injectors cheap/not so cheap increase
- Is this a 1" MC? Picture.
- Door panel question
- B&M Short Shifter
- posting in classifieds
- RPMS
- Side View
- Cleaning the intake/throttle bodies
- Sticker
- Oil leak at the tip of the head?
- What ECU do I have????
- Skunk2 Short Shifter: Single vs Dual bend
- Help with a CEL code
- Parts for b16 swap
- 2000 Si Dizzy
- Prelude 2.2 v-tec into a Civic eg
- exhaust or suspension?
- Just bought a P28 missing chips?!?!?!
- Keep getting CEL code 3 MAP short/bad MAP?!?! WTF?!?!
- question about highway cruisin
- mMmM I need this cluster what about price?
- ECU codes, easy way to check
- Difference between Hydro and Cable Tranny?
- I need your help guys...
- how boostworthy is a gsr engine?
- 2.5 b-pipe, 2in muffler?
- DH-racing heads...
- Ok guys, I need your help!!
- B16B Parts..only if you know please
- B16A vs B16B
- CV boot tear....cv joint bad? HELP!!!! Please!!! Any help is appreciated thanks
- Sway Bars...
- Can you put a B16 LSD in a USDM LS tranny?
- ahhh quick question. coilover problem..!!
- help with ground wiring???!!!???
- Noises from suspension i think.... SOMEBODY HELP ME!!!!
- help?!?!?!?!
- na program ?'s
- Verify Tranny vin
- where to download helms?
- which rims is good for a civic
- Type r block?
- Apex n1 vs Greddy evo2
- got my 99 GSR!!!!!!!=)
- my way- ls/vtec/turbo...
- exhaust on my 97 civic dx
- My new sir seats
- help! too low now
- Project in the works
- Are 92-95 rear toe arms the same as 94-01 Integras? (did a search)
- 92 civic hb w/ jdm h22-"FIDANZA OR ACT FLYWHEEL"
- will any other key fit kyokugens????
- would a rsx gauge cluster fit my 96 dx?
- cluster and tail lights blew!?!!!
- Fluctuating Gas Gauge???
- TypeR cams and piston in b16. How much gains?
- Code 14 on 95 ex coupe
- Brakes Sinking @ stop? possible line leak or bad MC?? Help please.
- Does the rear come lower than the front end on a 200 si stock?
- TeinSS install question...
- car starts then dies...code 7
- NEED HELP QUICK.... WHAT PAGE IN HELMS...
- Hondata Heatshield Gasket... It's just a $60 piece of plastic?
- where can i buy civic's k20a engine?
- is CTR 5lug same as USDM ITR 5lug???
- EG Civic / ITR Master Brake Cylinder (Yes, Again...But different question)
- Size of Brake Booster
- What E-Brake cable on eg hb with del sol disk brakes???
- Do swaps really have 30k miles ....
- ATTENTION: ANYONE WITH A WHITE EK THAT WAS RECENTLY STOLEN WITH CTR.
- Sorry I made a mistake
- F/S:sellin my civic type r swap
- Low idle, really sluggish...
- Need V-AFC settings Help
- whats the best tranny for this swap?!
- FOR SALE 1991 CIVIC HATCHBACK!!!!!!!
- Gas pedal sticks to the ground. WTF?
- HELP: Tranny fluid is leaking through Half-shaft
- Problem mainting pressure while turning
- Clutch Slipping - advice on replacement?
- IAT location?????
- swaping a ls into EG
- y8 trans keeps popping out of 2nd gear
- Clutch slipping after slave cylinder install... PLEASE HELP
- Run Channel Installation on 95 Civic??
- what size bulb?
- problems with tokico blues and H&R sports
- rear suspension question
- Gassy assy smell at idle...
- post pics of 96-98 coupes
- anyone have jrsc on d16z6 and installed him/herself??
- Will coilovers/struts from an 88-91 CRX fit into an EG hatch?
- Clutch question ???
- installed gsr dash now blinkers dont work
- Does anyone know any good websites, where you can buy highflow cats, or mufflers..
- Car got stolen, problems with lights and washer nozzles
- Porterfield shoes + Hawk HPS pads = good thing?
- Which oil in D16Y7???
- Question about AGX rear bumpstops.....96 hatchback...
- Went to the track last night.......
- J's Racing GT Wing
- B20 VTEC...Direct bolt on swap?
- do 2001 gsr seats bolt in to ek?
- Spring from 95 ex to 99 cx
- My gift from H-T :-)
- what are the stock Civic fuel pump ratings (pound/hr) and how much HP can they handle?
- What will I need to change to fit tein coilovers on a 98 cx hatchback?
- problems with my 00 turbo SI
- Dual Core All metal radiators in So Cal 109.99!!
- What size Piping for my exhaust?
- Will integra rear top strut bars fit EK's??
- need to find this axle, please help, 2000 civic si
- Need Help Car Died Last Night.
- Just swapped b18 b into EG6 and ran 16's.
- delsol pedals same as 92-95 civic
- HELP Virginia Emissions, what do i need to pass? look at results..
- Need a quick advice on Coilovers....
- Help Me!`
- Just a heads up for you guys Buddy Club seats NEW
- Anyone want to do a DIY short shifter segment?
- Is there a conversion for this?
- alt and starter? problems.. help a.s.a.p
- [FAQ] The Official Exhaust Thread
- Price for manual conversion?
- Just wondering who has a b20 not b20vtec
- question about Beaks and ST sway-
- Rear sway bar question
- About to buy ECU Upgrade.
- help
- Anybody with pics of an Eibach prokit on their civic?
- what makes the stick feel sloppy?
- SPRINGS - any pics with eibach sportline or prokit springs
- squeek-a-leek
- 00 si... painting stock sway bar
- wut clutch should i get?
- problems with short shifters
- civic eg4 lsi
- Need definitive answers on D15b swap in 92 DX hatch!!
- Who should I get my LCAs from? SRR, Function7 or SPC???
- EK hatch with edelbrock turbo kit... whats next?
- OBD1 Harness..b16/? d16z6? what?
- engine starts revving
- How to get hood open? Hood latch broken!
- blinker wont work with my lights on...
- Del Sol VTEC axle back on EG w/ B16A
- Inpound, RHD question...
- obd 1 - obd 2 TRANNY DIFFERENCE?
- TRAIL USER? HOW TO BECOME A NORMAL USER?
- B18c1 sol TPS help.
- d16 clutch
- Where can I download SPOON MUGEN bin file ?
- where can i get this OEM bumper?
