View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Clutch pedal back on the floor after bleed......
- Opinions on Cold Air Intakes
- Trouble starting
- 94 civic backup light trouble
- 98 civic dx intake manifold issue
- Oxygen Sensors
- Intake to bumper?
- Attempted theft damage
- 95 Sedan Power Lock Switch Will Unlock but Not Lock
- Why does my 1997 Honda Civic shut off when depressing the clutch while driving?
- Took distributor off 97 Honda Civic LX and put it back on, now it won't start.
- Best dizzy to use to make tach work?
- Del Sol Exhaust
- Fitting 16x9+20p rims with 1 inch spacers.
- 2 door vs 4 door window lift motor.
- 98 honda civic lx ac compressor noise
- Only 1 speaker works, wiring or aftermarket deck?
- 96 Civic temp gauge shoots up to hot
- High Idle in Stop and Go Traffic D16Y7
- B16A Swap Issues
- radio goes off and on when I push gas pedal
- Indicator not working, but not faulty bulb
- still fighting radiator hoses
- Need Help I Have a 94 Civic Dx Sedan
- ek4 vti srs problem
- battery issue
- 1998 civic ex NEED HELP PLEASE
- I have a 97 Honda with grinding sounds.
- Help
- EK 20 Second Idle then ecu cuts fuel :( Need some Honda boiz to help me on this one
- 95 civic Hood latch won't lock
- oil leak
- B16a cable to hydro Q
- 1993 Del Sol Gremlin
- clutch pedal switch pigtails
- Radiator fan issue, 98 civic lx.
- Another strange intermittent start issue....
- Have a 97 civic hatchback
- Brake rotor rubbing against my caliper bracket.
- em1 vs ek9 front lca
- 98 4 door with a d15by8 Need Engine harness!
- d15by8 mini me
- 1995 Civic EX Coupe Steering Rack Removal ?'s
- Ek/eg shock/struts
- 97 civic ex won't rev past 1000rpm, barely starts
- 99 civic ignition ignition kill switch
- Help me figure out what brand these control arms are?
- Chipped ecu off b20/ for d15b vtec
- Ek civic central locking problem
- New springs and struts? or something else.
- Strange intermittent no start?
- Assuming clutch hydraulics are leaky...
- Broken valve cover bolt
- Grinding Noise when Engine Braking or Accelerating
- Ac / Engine Vibrations
- does anyone know any online shop for 93' vti del sol inner fender s?
- Broken steering wheel?
- 99 civic clicking noise when driving
- My Piece of S**t Is Running like a Piece of S**t. HELP!
- 98 Civic DX - Motor Swap Smokes - JDM B20 motor w/ GSR head.
- Control arm fitment years.
- struts
- Looking for Ingition, Trunk, and Door Lock Set. Replacing Everything.
- 94 civic hatch won't start
- 93 del sol automatic trans shifter gremlin..suggestions?
- why did my engine bay fuse box wiring harness connectors melt in my 98 honda civic?
- car's not running right
- 3 years after joining, finally got a Civic.
- ignition coil replacement
- Misfiring and Egr codes
- Civic Lost All Electrical Power
- Civic EK Power Steering leak at the reservoir
- 95 Civic misfire or chug at driving speed.
- 98 civic ex hesitation and jumping?
- looking for 94-95 Del Sol turn signal switch
- PO300/1399 fix 2000 civic ex
- Silicone Caulk on windshield
- 93 del sol 98 b18c swap
- Civic question about seats
- 99 civic b18b battery light comes on intermittently
- exhaust size question
- honda civic 1998
- pull out hair definitive crank no start workup
- just a little more power would be nice
- engine fun
- leak in pass floor when rains - 92 Del Sol Si
- removing rear brake lines
- Adding Battery Backup 520T to...
- 99 civic si engine wire harness identification
- What engine do I have
- Radiator Over Flowing 99 Civic EX
- I finally got a sol! Engine swap questions.
- Daily D16Z6 Turbo- Have I done my research correctly?
- Heater/ac blower fan
- 99 Civic DX won't start
- Looking into an el with a b20 VTEC need help
- Oxygen and cat monitors
- 93 honda civic brake lock up
- p28 chipped ecu for a b16a3(p30)
- SLOW 99 DX build
- Civic Ignition Distributer Unit Replacement
- 94 Civic VX loses power and jerks when gas is low
- 94 Civic Si hatch wiring help!
- Battery Relocate question (fusebox)
- Got to do it
- Coolant system Burst after new radiator and bleed.
- 99 EX w/ B16 Swap Clutch Issues
- 99 EX Climate Control
- 96 Honda Civic DX M 5 Overheating after replacing nearly everything
- honda fan
- Misfire, rough idle.. electrical problem??
- Del Sol K20 swap?
- 97 civic ex automatic, drives forward in park, netrual, and reverse
- 2000 Honda Civic ex clutch fork question
- stalled manaul civic, wont restart
- single pop in front end (99 ex)
- why does this 99 EJ6 looks like 98 civic? weird
- civic MB2 D14 OBD1 SWAP
- Inquiry: Looking for Oversize Pulley for 1.6litre
- ebay bleeder screw size
- 2000 Honda Civic ex clutch fork help
- Help please 1993 1.6 d16z6 honda civic (ticking noise)
- powoner steering belt on 99 civic
- Del sol antenna delete
- D16y7 Timing Belt Squeek
- rear camber
- y8 head carbon build up
- B16A6 Idle
- Jdm obd2 d15b stage3 vtec figured out
- Manuel 98 civic Ex P0505 code and P1457
- 2000 Civic won't start
- Power steering/AC/alternator belt tension?
- New OEM Rear Upper Bumper Beam Doesn't fit
- Help Identifiying ICM (igniter) model
- I NEED AN EG ELECTRICAL GURU
- prepurchase advice/help on a 97 civic ex
- My em1
- 2000 EJ6 Hatchback B18c1
- Replace ECU 1998 Civic EX Coupe for P1457 Evap problem. Now Car will not start
- d15 to d16 swap harness and ecu
- Honda Del Sol Weird Problem.
- Mileage is a problem?
- Help
- key fob has no "option" button 1998 civic EX
- Quick question about header replacement
- D3 & D4 lights on and blinking at same time
- 99 civic ex MT - need help identifying engine noise - recording attached
- EK9 Civic Type R Track Specnon SRS steering wheel?
- No Spark/No prime
- 1993 Civic delSol S 15" Tires?
- Eg hatch exhaust fit a ek hatch?
- Honda Civic 1997 1.4i EJ9 Hatchback install airbags and OBD2
- Civic coupe 1995 Doubts about heads?
- Coolant temp sensor
- No start
- Super strange electrical issues???
- 92 eg passenger side firewall pad drenched
- OEM Honda/Acura B-Series Motor Mount Discussion
- 99-00 Civic Si limp mode
- Exhaust fitment issues on b18 swapped ej coupe
- Zc vs D16y8 dizzy Timing
- O'Reilly's Clutch Set
- Running poorly after dizzy install
- Radio loses power, shuts off at low rpms
- 99 Honda Civic Battery Light on
- car wont start after sensor mix up
- Do i need all the wires
- 2000 civic ex rear disc brake conversion?
- 94 HB map sensor/boost problem
- Sunroof won't close properly - 92 SI Hatch
- Problem Removing Nut on Lower Front Engine Mount
- B series build questions
- 2000 Civic help
- turn signal malfunction
- My DAP EK Hatch build!
- Things to consider before lowering your EK
- Set readiness monitors - Failing Smog - OBD2
- 97 ex coupe best swap?
- 1999 civic si rear bumper lip spoiler
- TPS Readings High
- 97 Civic Aftermarket Headlight Deteration.
- Bent trailing arm?
- Radiator Fan Test - '93 EX
- 98 civic drivers window
- Window 98 civic
- crack in rear subframe,pics attached
- keep burning up ecu
- 1997 civic cvt trans surges at idle
- Weird electrical gremlin '99 EX (Canadian)
- 97 honda civic ex
- Mini Me tuned - What what speed i should expect at 2500RPM
- EG hatch, D series engine swap to B series
- EG6 Transmission swap q's?
- Solved: 98 Civic LX misfire and rough idle / hesitation
- 92 civic CX engine dies at half throttle
- Subaru like sound during startup
- Thermostat reading question
- 1999 ek d16y8. Obd2(b) to ob1 problem
- 3rd gen prelude seats in eg
- bolts for engine on stand?
- Hondash Bluetooth Live Data Tool
- Need help! D15B7 Automatic to D15B2 Manual Full Swap (Solved)
- EG Kswap: P0336 + P0341
- Anyone Know How to Remove Recline/Height Adjustment Knobs on an EJ8 seat?
- Can Civic without ELD work well?
- Does not turn on the EK after restoration
- 98 Civic EX AT dipstick
- Swap engines
- 1993 Honda Delsol Transmission noise
- Intermittent hard start when engine warm. Then a cranking no-start. [Solved]
- 94 Civic EJ1 D16Z6
- Why won't it start
- AC Problem
- Kswap EG won't run, almost turns over.
- Clutch problem
- finishing up y7/y8 mini me - last questions
- 99 honda civic ex 4 dr sedan front sway bar
- SRS reset after pulling 7-2 / 7-3 codes
- Manual Transmission ecu in an Automatic Transmission
- B16A2 seized, what other engine can I swap
- 2000 honda civic low idle and accelarator lag
- 98 EX Distributer Cap - Thermactor?
- Shift Gear Stuck between Park and Neutral
- Coolant spray, possible head gasket problem?
- AC field coil interchangeability
- 99 Civic LX - P0420 code after most everything replaced.
- AWD CONVERT on 93 Civic Sedan??
- 97 Honda Civic LX
- Horn issues
- 96 Civic Coupe front sway link..
- Which head gasket
- Help with exhaust hanger rubber piece.
- Is this timing related?
- Need a professional opinion!
- New guy 93 Del Sol
- Help need a diagram
- lights dont work
- Which parts from Civic Sedan 6th gen are compatible with Hatchback
- OBD1 ENGINE SWAP TO ODB2 CAR PLEASE HELP.!!!!
- security alarm
- 99 civic dome light problems
- Why does my car turn off
- could use a bit of help/advice
- 1997 Del Sol JDM B18c Turbo options
- Need Denji Projector Headlights for my eg
- Iso help
- Obd2a to obd1 I got spark and I'm not hearing the fuel pump prime.
