View Full Version : Honda Civic / Del Sol (1992 - 2000)
- hidden/tucked muffler
- My 93 eg issue
- Wierd Problem
- Injectors w/Resistor Box vs. Stock ???
- Magna Flow High Flow Cat Fitment
- help finding out what kinda turbonetics turbo charger do i have
- d16y7 97 EK running to lean? HELP!!
- horsepower?
- new to the forum, need some advice on a project
- my 94 delsol 1.8 dohc
- 1995 honda civic AC problems
- ignition problems
- Removing aftermarket headunit
- question vetc and hp
- ej1 axles?
- 98 honda hx squeaking noise
- help me ERrror code 15 ot switch and Started engine
- Ignition coil question..
- Quick question on Fuel leak
- head gasket leak after new one installed
- Anyone installed a 02-05 civic si deck in a 99 ek?
- EJ9 number plate rear recess removal help
- QUICK question!!
- LSVtec timing belt cover?
- gsr oil pan leaking
- smog failed
- NEED TO KNOW THE DIFF ON ECU'S.....
- running without brake backing plate?
- 195 vs 205
- Exhaust Size (1998 EX)
- D16y7 Torque Specs?! Please help!!
- NEED HELP FINDING A PAINT CODE!!!
- Suddenly Squishy Clutch Pedal
- 1997 hx manual trans.
- need help with resetting Clifford alarm/Change password.
- lips for del sol
- ac compressor
- ek dash in a eg
- Emissions issue.... Researched and dumped to much money.... Need help.
- surging idle and high pitch whistle/whine?
- 96-00 Firewall Plugs, OEM full Rubber plugs
- New guy with some questions
- k swap info
- sunroof
- [Pics Inside]Timing Is Correct, But Car wont start?
- help on vss
- Recommendations for Transmission?
- noise coming from the rear end of car
- motor mount removal
- Catalytic Converter for ITR Swap into EJ1
- RHD SHELL
- Having trouble with passenger side power locks/windows...
- 96 EX Sedan: Wiring between Driver's Door...
- how to remove driver side engine mount easier?
- wats this called
- civic a/c problems
- 96-2000 trans into 01 civic?????
- car idles cant give it gas...?
- What's the best turbo kit for my setup?
- help converting my auto to stick question?
- ej8 braking problems
- Need some advice on some new wheels
- Help wiring Z6 dizzy ignitor unit
- Quck question about ABS
- T-Bracket question
- Inconsistent Oil Dipstick Readings???
- ctr pistons
- o2 sensor?
- LS-V swap to ej6 help
- First Car EJ6
- 93 ej2 with 94 ls swap, do I need civic or integra clutch master cylinder? Slave too
- overheat wats the deal
- will a integra master cylinder fit a ek civic
- are steering columns from civic 92-2000 interchangable?
- Auto trans V.S. manual trans
- AXLE HELP. EJ W/ 2ND GEN JDM B16...
- will ef ground control sleeves work on a eg?
- raging like a mofo:trailing arm bushings
- d15 oil jet
- Where does this line go?
- have random misfire on d16y7
- should i stay with my b16a2 or go b20V
- Unique problem while starting up
- 94 civic z6 vtec sputtering under load
- HELP: JDM D15B VTEC - Loud motor?
- AC pulley bracket interchangeable?
- brake booster vac pipe tuck
- HELP: solid CEL and blinking SRS Light
- eBay knock sensor
- Disc Brake swap questions
- Bogging issue
- gears wont go in when in high rpms???
- coolant out fast plus overheat?
- 02 sensor not working?
- '99 Civic Si A/C HELP!!
- b16 very rough idle! help!
- rev limit at 5k rpms?
- Shift linkage
- vtec controller help
- 2000 civic gsr boosting question HELP!
- How to make my stock b18c accelerate faster
- HELP!!! B16 HIGH IDLE, THROWING CODES ALSO...PLEASE READ
- GSR VS B20V
- ABS plugin behind cluster
- hood latch
- Misfire at 5000 rpm
- title
- tein edfc + coil overs
- weird ringing sound..
- How to make timing marks on an aftermarket pully???
- upgrades?
- Car Wont Start PLEASE HELP!!!
- starting system question
- Crossed tps wires
- DOHC VTEC decal question
- 1992 Honda Civic Hatchback Si - Journal
- Failed BAR, need help elucidating some things
- New suspension vs new turbo kit
- Thinking about building up my LS
- b16 vtec engage p30
- can some one verify?
- New EK Owner - Mod Bug
- Check engine light
- exhaust manifold for swapped civic
- Car Insurance for restored cars?
- automatic transmisson problems
- y8 into 96dx swap troubles
- opinions
- 95 Dash swap
- WHERE TO GET BOTTOM MOUNT LOW SEAT RAILS FOR EK????!!!!!
- fuel tank
- vtec gasket?
- vx to d16z6, need o2 help!
- HELP! IAC AND TPS CODES....OBD1 B16
- witch of these camber adjustments ??
- Muffler Sputter
- automatic trans problems
- Ebrake light always on WTH?
- Does the magnaflow model 14832 sound good on a civic with 2 1/4 piping.
- vtec cleaning?
- 93 dx coupe help(overheating and loosing oil)
- cold air intake question
- auto To- 5speed To- B series * questions *
- Need Help With Swapping Auto Tranny To 5 spd
- a quick "wire tuck" question..
- jackson supercharger on a d16z6
- Problem with transmission
- Shift linkage for GSR
- Noob Exhaust Question
- d16y8 rebuild or b18b ls swap??
- D16y7 seperating auto tranny from block
- Civic steering wheel compatibility
- INTAKE PART UNKNOWN
- Vtec Problems!!!!!!!!!
- rear brake issue in 97 civic
- Wiring Harness Diagram
- Stock fuel pressure
- headlight problem in eg hatch (help)
- Timing issues and cam installation...
- Need Turbo Help b18c1 swap
- gas in radiator....why
- Single cam v tec solenoid work on a b16?
- Whats a good security system for a honda civic?
- yet another CEL problem thread
- 2000 civic si ideas??
- Swap opinion
- Ej8 should I sell or keep??
- b18 eg failed smog test results
- car is blogging in low RPM
- Helping A Friend. Need Torque Spec!!!
- tach signal ?
- B20 non-vtec nitrous build
- Civic Intake
- Engine Swap - Question
- VTEC ISSUE please help
- delsol b series
- Can't find an EK lip
- mini-me vtec not kickin in!
- need help cel code 43
- Temp Guage goes up when at a stop only.
- interchangeable seats
- Coupe seats in a Hatch.. Info
- b20 vtec turbo compression ?
- Oil light question
- 93 civic dx starting issues
- No Start...Intermittent Power...Ecu? Grinding Noise HELP!
- third brake light ?
- What to expect from a K Swap in a 1993 Four Door
- Rear toe camber bolt threaded.
- HELP!!! no power to injectors
- Trying to B.A.R. my car*advice needed
- Help, 96-98 Lower Bumper Grill?
- Quick question about taking off power sterring components.
- Radiator pressure.
- Need Help Deciding My Swap
- No power to power mirrors
- Non-Vtec D15b Crank
- 2000 civic si help me!!
- Head Trouble
- Starting Issue???
- IACV Question
- A/C problem..blows cold then warm. Help..
- Car vibrates a lot after swap
- VTEC pressure sensor setting check engine light
- Questions About B18c Swap in 2000 civic si
- Mini-swap (y7 block y8 head) will not rev past 5000 rpms
- Is this possible??
- injector wiring issue
- correct rotation of condenser?
- Muffler Questions
- A few problems on a '93 Hatch/ coolant leak inside cabin
- need torque for steering bolt
- Fresh rebuild, wont start. cranks, and sometimes sputters but wont stay started
- LOSING POWER ON TYPE R SWAP!! HELP
- how much is this car worth?
- 95 Del Sol is suppose to have a 1.6L vtec motor, Is this the right head?
- b18 motor is this worth 1200?
- axel seal replacment
- Tokico Bumpstop Facepalm
- Low idle after warmed up
- IACV on D16Y8
- 97 acura el b16 injector issue
- Engine problems after swap?
- ____D16Z6 INLET onto D14 Help!____
- 1993 Del sol S D15B7 tranny/axle problem
- looking for some gold rota slips
- Does anyone else's rear washer leak under hard acceleration in their EG?
- what size gauge for pos. battery wire...
- EG to EK Wiring Harness
- Leak down test help
- Totally new and need some help
- CEL Code P0141?
- SI check engine light
- Threw a rod.. Can i still run the car safely on 3 Pistons?
- 99-00 rear bench seats wont fit in 96-98 coupe
- Exhaust for a B16a2
- intake manifold differences d16y8
- Thought it was a simple map sensor
- 90-93 aaccord axles for a h22a eg swap
- VX to Ej1 swap help
- NEED HELP WITH SMOG
- K20A eg DTC help
- Cable Tranny Clutch Q?
- Deal Seems Really Good?
- adding a car to my garage??
- eg/gsr CAT and header combo for passing CA SMOG question
- ***official rsx type s muffler fitment thread***
- lagging acceleration/idle dropping
- good trade?
