View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Rattling noise when Vtec?
- 6th gen front LCA on 5th gen??
- What parts from other cars are compaitble with a 93 hatch cx
- fitting stock itr airbox onto ek4 ?
- teg seats
- b16a2 into 98 ex 3dr
- B series throttle body on a D series motor
- IACV symptoms? mine jerks when i give it gas at low RPM
- How much should I sell my hatch for?
- good and bad news
- Another: Cltuch/tranny noise problem
- okay to advance timing for stock civic?
- vtec pressure valve?
- radiator and fan fitment question
- is there cutting involved with a auto to manual swap
- Help me fix my exhaust problem please!
- head bolt problem...need advice please help
- Where can you get black leather wrap for a 96-00 Civic steering wheel?
- will ej8 side skirts fit on a ek hatch
- are obd2b injectors different?
- p08 p06 p something for my d15b7
- 97 Civic A/C Problems
- b16a2 into si eg..
- oil needed for d16y5
- help please?
- quick question
- engine will not run
- engine swap
- Jacer63's turbo build B16 civic hb
- OIL PAN! in need of help!
- can i swap on driver side fender, headlight and bumper from 99 to a 96 without changing everything?
- HELP - itr header on b16a
- Opinions Needed!
- advice for a 98 civic dx
- Help...OBD II Code Question?
- smog gsr hatch
- Battery issues again...
- car bucks like jerks back and forth....COULD the clutch cause this, only when its cold
- High Comp motor
- TPS/IAT switched, ECU smoked, Car wont start, Ostrich may be damaged.
- tensioner difference?
- H&R Springs
- b18 into eg
- car is runnin hotter than normal
- P1607-PCM internal circuit failure
- should i pay $2K for............ i searched but still confused
- anyone got a/c line diagram handy?
- d15b8
- NEED HELP ASP ON HOW TO HOOK UP A S-AFC For a 96 civic dx
- D15B vtec help
- rear disc swap
- cam and crank oil seal replacememnt, need help asap!
- decent clutch for d series?? (for y7/y8 mini me over summer)
- energy suspension bushings
- crashed my car, air bags went off
- Which Zc?
- b20 blox manifold & dc header going to type r motor??
- EK 4dr rear seats
- How to put ep3 seats in my EK coupe
- difference between 99-00 si and 99-00 ex engine harness?
- Zex Kit
- car blows smoke but the compression is still good..big story
- JDM B16 in a four door?
- i need help cuz something is wrong w my ecu i think?
- New as Hell, Late as Hell, Looking for Answers.
- wiring problems
- 95 LS redline
- Apexi auto timer A/F feature question
- jdm sirII guage cluster had burnt out bulbs, send it back?
- piston not pumping
- EP3 steering wheel in eg
- cant start
- CEL code 74
- How to read code error on p28?
- Wire tuck? info? pics?
- Any damage done to the car???
- Might be a stupid question..
- Questions about Grounding wire?
- exhaust size.....?
- question about twm 50mm itb's
- Stock grille
- smog b20 ecu swap to pass!! possible
- Need help guys, searched and found nothing...
- radiator cap for koyo radiator? wtf...
- Question about an O2 sensor on a 97 civic ex
- dx blades
- I have a check engine light!!! HELP!!!!!
- 93 EX Cruise Control Question
- how to identify cams
- fuel pump question
- power window help
- wheels weight
- NEED HELP!!!! H22 engine will not sart.
- outboard cv joint
- integra radiator in 96 civic ex
- ABS bleeding
- fixed car, new problem B16
- b16 a sir1 obd0 timing question
- del sol e brake cables in a 96 ex civic
- torque damper question
- MY BRAKES!!! I NEED HELP !!!
- mini me smoking
- 96 Civic safe to turbo?
- steering column cover question ?
- Need help on Right Hand Drive conversion!
- need help converting manual steering to power steering for my EK
- 96 HONDA CIVIC WITH A 99 SI B16 ENGINE? i need help plz.
- where to start with turbo
- installing a torque damper
- What do i use to clean up the inner oil pan ?
- tailgate stay question.....
- 92-95 4-door rear console?
- boosting a b18cr
- ITR Motor in civ. hatch, Axle question
- h2b?
- hot weather start-up D16
- Help with power door lock
- Rota Slipstream or Nippon F-2? Difference?
- Megan Headers
- Power Folding mirrors on em1/ek
- idle problem need help fast!
- check engine light
- oem stock exhaust,too long?
- best thing ever in life!!!!
- 92 EG HELLLLLLLLLLLLLLPPPPPPPPPPP
- b18b swap 92 hatch
- very strange issue, please read
- eg hatch pics...
- manual conversion
- Window Regulator
- Rack and Pinion Steering
- Exhaust trouble
- Right brake light not working!!
- If you had 4k and a stock ek hatch to work with what would you build?
- help!!!!!!!!!!!!!!!
- mini me swap question...
- swap question
- Mini Me Help?
- Fake or real video of civic acceleration??
- y8 tranny swap? quick question..
- EK4/9 GruppeM intake anyone know's it?
- prelude cluster in an ek?
- Electric Problem
- Honda cartoons cars? HOW!
- K im sure its done but Ima ask anyways! Help!
- CIVIC sohcVTEC decals
- trunk lids
- My EX Cluster fuel gauge
- how much is a hydrolocked b18c worth?
- Which lip should i use?
- Bypassed Fast Idler Vavle
- Door ringer
- Quick Q??
- turbo or swap
- how can i put 2 sirens on my car?
- 98 ls swap in to my 96 civic
- smoked tails...
- how much does an oem si front strut bar usally go for?
- Omni vs. Tein
- Ground Q
- what cat converter do i need for a 99si in a ek with a exhaust
- CR-V 4wd swap?
- SIR 11 cluster says idle is 2k?
- Install Power Steering?
- wonder if this gauge is worth it or not.
- ASR subframe install on EK, one question?
- need help with my speedomete
- what do u think is it even
- side by side comparison of short shifter
- tensioner pulley
- Awesome! At idle, I have a blue smoke show from my exhaust. Help/.
- Need help wiring City Lights and Sidemarkers on a EG..
- starter cranks but no start
- swap problem
- b16 vs b18b dipstick tube length
- FAZE gauge
- Joined EG hatch crew today...advice on fixing front end damage please
- Type R lip on a Del Sol Installation?
- ej8 overheating..help please.
- Surging idle on 96 gsr in ek
- pwjdm fogs
- 92-95 civic part out
- HID Reverse Lights??
- wheel spacers
- 92 integra rear disc onto 95 civic ex
- energy suspension trailing arm bushings
- Will Type R rims fit on a Civic?
- so my spark plugs went out...
- New suspension
- turbo gsr
- GSR PROBLEMS...............
- Info on a Certain problem
- Exhaust fumes.
- 92 civic d16y8 swap several problems
- b18 swap
- check engine light.
- difference's between 2000 civic dx and ex
- Rear Drum
- intake
- V.S what???
- help!!!!
- speed sensor ????
- ecu
- oem cd player fit into 2000 civic?
- converting to obd1
- how much would you pay for my b series ek hatch? serious please
- tach wire on 2000 d16y7 distributor?
- OMG the vibrations! avid racing torque mounts
- my d16z6
- NA newbie build question about the crank....
- Broken LCA bolts
- Does amount of cranks effect compression tests?
- dynoed at evans, bone stock obd2 jdm gsr w/ header, intake and exhaust
- bolt size for license plate?
- transmission gearing ratios already searched 95 civic cx and 95 civic si transmission gearing ratio
- just got a del sol
- centering steering wheel ?
- Jumper Harness
- 1992 Civic VX a good swap candidate?
- wtb b series hydro tranny
- looking for an eg to purshase! anyone got 1 for sale..or wanna trade
- 240 guys are funny!!!!
- need help with radio code?
- No Spark Help
- EG/EK exhaust
- Help: Odometer stopped reading.
- whats up with this shift knob?
- 92 civic hatchy b16 4 sale in southern oregon
- D16y8 harness plug questions
- mini me vtec o2 sensor question
- WTB b16 shortblock or longblock
- ECU.. for a swap..
- Anybody know the bolt size for a 92-95 front bumper..
- Engine shuts off when clutch is engaged
- A complete newbiequestion....
- hey guys - i only want to introduce myselfe...
- How do i install aeromotive frp?
- Best Intake?
- Steering wheel fitment question.
- Air oil seperator
- B16 swap $$$ question
- Hey Guys I need Help!!!
- need to find a engine auto shop
- 96 civic AT slipping Help?
- D15B7 with jackson?
- whats a best way to store a engine?
- 2000 Hatch, 120k, 2500 bucks?
- car won't start
- need help in wiring
- 92 CX With Rear Disc Problem
