View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Really Really Bad news
- Tilt Wheel in a CX question
- 00 si grill question, and back lip
- anyone got any good eg pics from yesterdays h-t meet?
- HELP, racing seats install....
- Ek dash removal and adding options questions
- ls head package suggestions
- What cord do I need to get Videos on to my computer?
- hard wiring a horn?
- should i buy 40 dollar hatch?
- help! no brake pedal pressure after installing new pads/rotors!
- Low Fuel Warning on 98 EX Coupe??
- flywheel question...
- My lights stopped working!! WHY!?!?!
- temp gauge problems?
- Climate Control Venting Problems
- "crashed" my baby today :-(
- which front lip for my eg6?
- shocks for 2k civic
- is removeing cat on my civic vti a good idea?
- EG - A/C Lines...removal?
- New Pistons and Rings Ques **techys only!**
- New pics and video of my hatch...
- Dyno results... Need some input...
- Right hand drive, where to get one?
- do they make aftermarket headlights for a 93 del sol?
- How low should I go.......?
- planning on going turbo.......soooo
- e Fuel injectors?
- EG/EJ Mugen "style" ABS lip??
- what you you think of drop zone springs
- widest tire
- Retrofit front speakers on 7th gen coupe
- opinions on b18b's
- What can I do take make my 92 si faster using stock engine
- 6G forum?
- Quick question about SRS light
- . whats a ctr
- Got some new shoes.
- will a CX block with a DX head take the rev limit of a DX without damage?
- d series head swap problems...help fast
- This is annoying the hell out of me, HELP!!
- GSR,B16A2,or turbo out SOHC????
- B18c1 swap?
- 1.75" drop to much on tokico blues?
- Project EK's New Mods!!
- Offset
- H22 question (Might be a repost sorry )
- "Old School" 14x6 Enkei wheels - strange question!
- 15's or 16's
- heeeelp me
- kyb AGX's and skunk2's
- My EK, how much? 56k pull up a chair
- wiring for 95 civic hb cx
- pics ek
- What fuel pump are you using?
- To those that have swapped in sunroofs......
- EP3 Formula 3000 Civic SI
- Fuel and NA
- ok where can i get the "pill" for my autometer tach at?
- Please!!!!!!! someone post their opinion:)
- SRS Light comes on when dash lights on? SiR cluster 92 Si
- Anybody have pics from todays Fuddruckers Meet??
- Looking for an EG in the Miami area
- S2000 Cluster in EG
- 95 Civic (EG) stuttering =(
- 1995 Civic Si (Canadian)
- SLAMMER ATTACK... in case you were wondering why Honda-Tech is so SLOW...
- should i keep 2.25 or 2.5 exhaust?
- eg with gsr motor w/cams idle?
- whats this mean?
- wiring sohc vtec head
- del sol headlights
- another ghey exhaust poll
- 99-00 foglights with a 98 civic???
- *****NEED Pin Number and Location for a B16 ECU ASAP*****
- Coming Soon to a CiViC near you...
- h22a labor rates?
- maintenance light schedule?
- im bored.. took some pics of my project
- reanother dumb question
- Back from the track......
- 98 civic lx front lower tie bar install?
- white face gauges
- tried searching. too many pages. what cai for b18c5 hatch si???
- 92-95 civic, 94-00 integra skunk2 springs, Brand new*FS*
- Headlight Question
- i need weights for 99-00 civic si
- Del Sol Gauge Guard
- anyone know how to take off the dash?
- SirII tranny
- Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors?
- Is it possible to pass emission without catalytic converter?
- exhaust problem.. extracting broken bolts from B-pipe flange
- Changed Alternator Now Low Voltage Light Won't Go Off
- changing distributor cap and rotor...dumb question
- what parts should i use?
- Damn i bent my Spoon front lower tie
- Removing Bumper
- 94 Civic Hatch Motor swap
- Civic headlights with black housing.
- aiming headlights
- Mugen front strut tower bars
- The chassis code for my car.
- Will this mugen lip fit?
- quick question..???
- HELP! Seatbelt stuck!
- 99 si exhaust on to a 99 ex?
- FINALLY pics of EH2!!
- Brakes...
- A'PEXi vtec AFC
- any tutorials/pics on installing front SI sway bar?
- valve adjustment specs or d16z6
- Do turbos run out?
- specs and times
- the Fast and the Furious Flame away
- Has this been done...
- my timing is right but my car stumbles on accelleration and the idle goes up and down? why
- h22 turbo
- Where's the 1-piece headlights?
- what is faster lsvtec or b18c5
- d16a6
- ES OVAL universal mufflers *pic*
- Testing waters, anyone interested?
- suspension FAQ
- does anybody know of problems with ls/vtec bogging
- 1992 civic vx owner needs help
- WHere can i get TAChOMETER?
- Hybrid T-Belt Cover Q, need awnser QUICK
- Vortech in sol?
- Which paint to use when painting side skirt?
- Price you paid for your complete B18B1 swap?
- the term "newbie" really means....
- UPS man put yesterday! (Mugen TL)
- Oxygen Sensor?
- Autodynamic front and back lip fitment?
- b16a3 and ls block
- Mini me swap for D16y7
- 00 b16a2 swap into 98 civic dx
- APexi exhaust on a ek
- My Si got broken into :(
- Instalation of Integra Type-R intake manifold on B16...
- Who makes ES Tuning mufflers?
- do they make a QUAD gauge pod for 92-95 Civic?
- home depot lip help
- 92-95 civic EG's colors??????????????
- what does the msd 6Al do??
- JDM One Piece Del Sol Headlights.
- fender/hood gap
- little bit of something... 56k?? dream on!
- Will these add horse power?
- GAB Revo II coilovers?
- JDM Engines?
- Port and Polish??
- Coilovers?
- Rear speaker panel question?
- Can someone run carfax for me please?
- a Good deal?
- question on the seals for a del sol
- Has anyone used jdmhondaparts.com???
- Carfax...
- Welding????
- MUST READ - Ontario Bill 241
- Vibrating... help?
- Integra catback on a civic hatch
- would a 1.5 inch drop mess up my camber?
- where can i get 96-98 fogs
- What would win..
- what wire is the tach hookup wire in a CX wiring harness behind the gauge cluster (1993 cx)
- Noise from back driver side wheel
- M3 Sides on 2000 Civic Si
- 5 degrees and my car is over heating ?!?!
- Who has the least money spent and faster....
- How much does a second hand 2000 EK go for?
- Idel Problems
- 3.0 VTEC V6 in a Civic.
- where can i find a b16A1 motor online?
- halo projector lights install on 02 civic help
- Will a Del Sol VTEC intake tube match to an LS throttle body?
- Is it possible to legally smog a LSVtec
- Free AEM V2 Intakes
- Idle when decelerating???
- high pitched squealing noise from engine bay (worse when cold)
- Where to buy?
- GSR block vs LS block (LS/VTEC)
- EG Hatchback Pics
- need help!
- thieves...are they tryin to get me????
- b16a2 for 1200 complete swap ?
- turbo, surpercharger, or N/A on my Dohc Vtec Del Sol?!
- 16.9 HP and 14 lb-ft of torque from AEM CAI V2!!??
- Would a cat off a 92 si hatch fit on a 88-91 CRX??
- anyone know the cheapest place for koni yellows?
- North Carolina Snow Pics (kinda 56k beware)
- :::: 99-00 Bumper for sale EBP ::::
- the baddest delsol
- :::: 99-00 Si OEM Front Strut Tower Bar For Sale ::::
- ::B16A2 For Sale::
- Looking For A Honda Civic Hatchback
- PARTING out a 92 Hatch!
- little off topic... but needs to be adressed
- New Mugen lip
- jdm auto folding mirror how can i tell if they are the auto ones or manuel ones
- gauge cluster bulbs?
- my next project
- Fuel pressure regulater install
- My projectors use H3 bulbs but is it possible to put H7 bulbs instead??
- Need some advice on tire size and offset
- melted my stanley corners!!!
- nerdsports DIY catch can...
- hybrid motor
- For my brothas with a carfax acct.
- Greddy EVO Video
- how to tell that rear end suspension/brakes are si?
- Engineering Schematic...???
- Cold weather problems
- Kind of a non-tech question
- How do i take this pin out?
- will the wheels fit my car?
- distributor went out, took my torque with it...
- kyb agx's
- CEL problem, and a few other problems after swap.
- 99-00 Radio Console Retrofix Question for the EK
- 92-95 civic 4 door interior?
- Whats you tranny fluid do you like best
- LS/Vtec???????Wats you time or HP to the wheels
- jdm/usdm hybrid cluster
- mostly for the AZ peeps, and its not a civic question... I have a few though.. SWAP question.
- 2 questions about an JDM ITR rear sway bar.
- Good idea or bad?
- Tech question: stroking B16B
- Was this a bad setup?
- Removing Stock Seatbelts
- i have a weird problem...help needed.
- notching block with eagle rods
- eclutchmasters? Has anyone heard of this brand?
- HorsePower Question
- bout to order my new rims and tires...
- OT - Free Pics and Video of our last show
- Vehicle Value - Project Car
- Changing rotors on a EG hatch
- Del Sol Fog Lights
- Cams Questions??????
- damn the distributor... damn it to hell!!!
- what model hatch's come with tach??
- Can someone post yellow 96-98 Civic coupe with a black housing headlights
- SOHC questions
- best struts for 5g hatch
- SRR SOHC Final Drive. EG/EK suspension
- Update pic of my new EH2 project.
