View Full Version : Honda Civic / Del Sol (1992 - 2000)
- civic type r with a h22 bottom end????
- need help on connecting my xetronic hids
- !!!!!!!need help now!!!!!!!!!
- will the 99 integra armrest fit my EG Hatchback.
- car smokes
- Coilover?
- need help w/ pro 1 cams valve spring setting at tdc.
- Both Radiator hose tight could it be a water pump title plead read! Or something esle.
- power?
- Super Steep Hills
- D15B8 and D15B7 Valves the Same?
- Just finished swap and Question about EVAP purge solenoid
- CEL when accelerating 96 civic b16a2 swap
- Alternator Problem
- injectors
- d16z6 or d16y8
- WHat are the compression #s for a B16a2
- eg fog light question
- Traction Bars
- Car won't go into gear!!!
- civic si brake mounts?
- b20b
- turbo exhaust options (question)
- Whats the compression on a...
- my old coupe
- do ef spring work on eg's?
- bumber and side skirt question.
- clutch pedal help
- GSR Rear Seats
- 1997 ek9 suspension issues
- what cmp to use for best mpg?
- blowing fuses?
- fogs lights for 00 si
- angled exhausts
- ANOTHER A/C QUESTION!!!!
- How much is a D15Z1 or D15B8 worth to a normal person?
- Clock is dim and no radio in EG
- exhaust?
- Drop in MPG going from the dx tranny to the si tranny? also switching to a mini me head
- duel hood props
- cx or vx
- does 92-95 front seats fit 96-98 ?
- JDM Foglights onto a non JDM bumper, will this work? (pic provided)
- Top Dead center sensor and Vtec pressure valve?
- brake upgrade
- stock ek hatch code 45 please help
- 97 EK hatch to 00 civic si question
- Air Conditioning doesn't work when in direct sunlight....
- which takata harness fits delsol?
- angel eyes installation fiasco
- z6 in a 97 ek coupe ,engine turns over but no spark,hep!!!!!!!!!!
- 96-00 Exhaust B Pipe
- Quick Question Concerning Exhaust
- Recently installed new distributor. Car won't start.
- what can i use from a da on my eg hatch
- A picture of my eg all pulled apart...
- 99 ecu in a 98?
- car 95 cx obd1, motor 96 d16y7 obd2
- turbos
- air conditioning not blowing cold
- Maintanance Schedule for 1999 EX?
- Eg Foglight relay.... QUESTIONS ABOUT IT
- really fast question! please help
- EcU pin extracting
- City Lights?
- removing front seats
- Import
- Serious answers needed.
- HELP!
- Honda Top End Engine Cleaner??
- 92 coupe side skirt are 1 3/4 inch smaller then 94 coupe
- B16 throwin out black smoke only when warm????
- ** WILL TRANS AND CLUTCH FROM A 92-CIVIC CX FIT ON A 1997 CIVICI DX**
- Car sounds shitty
- help HELP HELP!!!!
- brake booster help...?!?
- coolant / heater problems
- front end shaking, HELP!
- help help sorry for the stupid question
- b16a and h22a
- Need help - LS swapped Civic guzzling gas, map sensor problem?
- **Pic Request**
- 99-00 civic si
- Going to do swap but need help!!!!!
- Bad vibrations..
- anyone done colored LED intrument panel swap?
- helpless since my honda dont go reverse..urgent help needed..gearbox problem
- solid cel no fuel turbo b18c
- Another IAB wiring question the real way!
- I am too tall for my seat... seat suggestions for an EJ8
- Sorry, very new to all this, need help on EK RHD conversion, thanks to everyone
- Car turns off
- need help finding a keyless entry remote for 94 civic (factory oem honda)..
- JDM vin tag fitment (EG)
- Question about 93 Civic EX 4dr w/ABS Brake Master Cylinder
- Del Sol QUESTION! Rim fittment
- Need motor
- Buddyclub Exhaust????
- d16 turbo project -- need help
- A little help would be great.
- rear disk
- CAN YOU GET A S2000 CLUSTER TO FIT IN A EK HATCH.
- SI Rim question
- slight popping from exhaust
- 99-00 Front end on 93 Coupe
- Gauge Cluster problem
- how can i check if a engine is legit?
- help !
- K20A in Civic EG
- Help!!!
- Undecided future
- head options d16y7?
- Why is my short shiftr and trans is acttin wierd
- Will a axle back from a Del Sol fit a 00 Si?
- why the hell isnt this stickied. i looked for it for 3 hours scince noone will answer my question
- EK dx models don't come w/ stock Front Sway Bar?
- comments/suggestions
- Check Light Problem
- 99-00 Si Greddy Turbo Kit.. E-Manage?
- B18A1 into EG question.
- CX ECU VTEC ready?
- 92-95 audio console
- 92-95 EX heater control vavle
- Where is the radiator ground wire on a 92-95 dx??
- Eg coupe bumper on a sedan
- Civic 92-95 Passenger seat - HELP PLEASE!!!!!!!!
- Civic 92-95 REVERSE LIGHT HELP PLEASE!!!!!!!!
- 99 civic si fuse box
- mugen ecu
- eg passenger mirrors
- d15b7 overheating, need help please!!
- Quick help
- Help!
- Will eg clutch master cylinder fit ek?
- newbie
- Engine Temp needle jumping (to hot?)
- need help with b18 swap
- Si Wheels
- Need help axle problem.
- really loud and annoying noise
- 95 b16 coupe quarter mile
- rattle noise from engine bay ONLY ON ACCELERATION!
- link to pix, how much to repair?
- EG Interior ?
- overheating civic coupe
- B18c swap problem? maybe
- Name the problem PLEASE
- Slow/weak cranking after clutch change. What's the culprit?
- bad driveline noise
- fuel problem?
- Choose 1 eg
- Idle,MPG,rich, cel problem.
- Stock wheel size on my DX?
- EK hatch weight
- civic not starting after cap and rotor was installed
- WHAT IS YOUR EM1 MPG?!?!?
- ecu fuse?
- Losing oil. But cant figure out where its going.
- does anyone know witch way the check valve goes, witch way it alowys the vacume to flow - see pics
- Having an issue getting into 1st gear. PLZ Help
- Whining/squeeling noise while idling
- EG fan relay ??? :D
- bouncy and high idle
- loud clicking..
- Oil Drain Plug
- buddy club seats!
- Putting a GSR into a Civic si?
- auto to manual conversion questions
- Can anyone explain this wierd belt wear?
- ground control coilover question???
- Blinker Question...
- 2.5 exhaust on stock VX? lookin for opinions
- What is the compression ratio of a stock d16y8?
- HIMOTO(TENRAI) catback any good?
- MY gathers/maplight installed.
- what does the bolt on fuel rail do
- head question
- 94 eg JDM D15 swap coolant WHA???
- Plug to Fog light switch?
- pics of eg hatch completely disassembled.
- b16a2 swap in 96 EK, can i reuse y7 or y8 oxygen sensor???
- cd player
- light weight flywheel mpg?
- jdm d15b exhaust manifold o2 sensor threads size
- Megan GSR 4-1 on B16
- <<<<Car Runs Fine, Check Engine Light is ON! wtf>>>>
- Will this DC Sport header fit my car?
- Rear Speaker wire, prerun or not.
- Alright guys, i need help pricing some stuff im selling, need opinions!
- white smoke?
- STOOPID IS AS STOOPID DOES!
- p06 ecu in a obd1 ZC
- Question about this forum...
- What parts do I need?
- iacv help
- Meziere Water Pump
- Power windows & door locks
- Cluster swap
- just got a 2000 ek but has diffrent intake mani?
- fans not working
- 92 EG SI PRICE RANGE
- Where to buy Head bolts
- looking to buy an EK hatch with a swap, what should I look out for?
- We've been out of the game for awhile and need info please
- tighter manual steering?
- which head do i use for a mini-me swap?
- amp gauge??
- SQUEAKY suspension!!!
- brake cylinder cap?????
- suspension question
- NEED power window help!!!
- h22 in civic wont rev
- need help overheating
- I found a piece of vaccum tubing in my timing belt area.
- Where is the intermittent control unit located.
- someon please help on si rear disc problem (stock 93 si)
- should i trade a 97 ek for a 99 si?
- RS*R ExMag
- Air/Fuel Ratio Gauge Install Question
- starter spins, but no start, need help.
- DOES ANYONE KNOW WHAT FOG LIGHTS THESE ARE?? FOR DEL SOL
- 94 Civic Dx...No Rpm Gauge!!!
- 93 b16a in 96 hatch wont start
- sound deadening removal = rust?
- Windshield mirror...
- Cool - Free prepaid gas card - several options!
- Header Fitment Question
- Manual Swap---92-95 EG HATCH
- FLAME ON - Vtec Light, pros/cons make use of an LED
- Parts to Help Clean Up Bay'...
- my car has been jacked please be on the look out.
- what ecu can i use to pass smog ?
- Which Headgasket to use?
- Throttle noise???
- Shop manual
- BAR LEGAL SWAPS
- hood pins
- timing mark question....read PLEASE!
- DA=EG ( springs) ??
- VTEC question
- need help
- EDM vs JDM vs USDM, help us out please!
- is it worth it? totaled my civic what next???
- Quick question=Quick answer!
- eg with a gsr trany problem...... help please
- OBD1 gsr into 94civic ex
- 96civic sedan trunk wont shut all the way
- how safe is this?
- distributor D16y7 question
- throttlebody questions
