View Full Version : Honda Civic / Del Sol (1992 - 2000)
- si rear sway on ex, need help.
- erratic idle and vtec questions
- EK console in EJ, anyone have this
- need help with slave cylinder and clutch
- plz send me write up on the h22 goin in the civic.... and give feed back on how it turned out...
- Cant Start! D16z6
- Passenger Aibag + Quick Release = Headache.........
- nsx/prelude front brake conversion?
- upper driverside mount??
- heater bypass valve
- Struts needed for 99 ex...
- Keyless entry"magic box" where is it located? 97 civic EX
- d series throttle calbe with a b series engine...
- Car Turns Over Almost Starts but doesnt
- school me on the zc
- Disc Rotor dimensions
- eg power window help
- waterpump??
- timingbelt????
- EK interior Digi Clock
- HONDA CIVIC ION HEADLIGHT
- For all of you HX'ers
- EG vs. EK?
- what do i need to do the whole k20 swap in my 95 eg dx hatch
- How much do you think i can get for this?
- Did i Swap in a blown motor?!!!
- Lower balljoint nut???
- How can you tell if a catalytic converter is bad?
- WTF????
- LSD for Cable and HYDRO the same Diff??
- ecu
- which wire is positive?
- B series coming out of EF going into EG....mount questions
- 94 Brake Booster... for a eg hatch...
- ?'s on a integra cluster in my EG
- ek hatch w/ integra front brakes
- Piston movement in cylinder
- Engine Check: P1163 HO2S11 Slow Response (Bank 1 Sensor 1)?
- D15B 3 stage vtec
- To all the peeps that have put power windows into eg!
- Questins, about my JDM GSR swap?
- d15b vtec uses what alt & p/s & a/c belt?
- I'm new here.
- headroom with aftermarket seats
- pics of injectors/clips
- January Import Tuner Cover
- how much better is the y8 im than the y5?
- hid's on oem fog lighs
- d16y8 turbo setup
- Rear Seat block off cover thing.... ive searched but cant find it
- Cheap Eg Mod?
- LCA?
- electrical gurus i need your help
- prop valve leaking.
- rim wobble
- dont know how to disasseble drive axles
- gsr cluster into civic
- mini-me help ASAP!!!!!!
- Headlight...stability?
- racing seats in coupes!
- D16z6 Ign Coil Test
- getting an alarm but ran into a problem...
- problems with fast turbo oil line kit
- what do apexi exahusts sound like on an automatic?
- Eg Honda Emblems/Dome Light Help
- cam in my mini me
- 2 questions.... have searched SWAP dizzy Alternator
- oh shit new cleaning tool
- RHD combo switch HELP!
- 96-98 civics..manual to auto swap and auto to manual swap
- EM RACING C-PILLAR BAR FOR CIVIC Si ???
- rear suspension help...
- a6 into an EK, what do i do about the crank position sensor, and crank pulley?
- 96-00 EX knuckle caliper mounting point distances?
- Spring bolts on exhaust pipe
- Dremel bit to remove paint for touch up?
- need to know straight drop
- speedometer revs with my tachometer?
- WIRING HELP!
- I NEED A MOD'S HELP!?!?!?
- 99-00 Civic Si Dash Fuse Panel - SEARCHED
- Seafoam Question
- Grounds??????
- sway bars, and strut bars....
- 99-00 Si harness cut at ECU options?
- civic type r power folding mirror
- HELP Expectec B16a CR
- Clutch Cyclinder
- replacing gas tank.
- Help starting D16Y8
- Crank Position Sensor Code 4 HELP
- need help on what wire harmness I need
- changing from dc to EG got a question.
- ignitions f**k?
- OBD2b Wire Harness to OBD1?
- Christmas Budget
- 96 civic climate control on a 99
- Shifter Knob
- Climate control help, and a question about stripped tranny bolts.
- wtf happen to We-todd-did-racing.com
- box clever?
- car died last night and i cnt figure out why
- wire colors for TPS SENSOR, MAP SENSOR
- what can cause my idle rpm go up when i relese\press the brake pedal?
- D16 power steering pump hose connection, bolt spacing and arangement?
- what's better in my civic?
- NEED HELP ASAP! car is down and have a race in two days!
- pINK Hatch on PINKs right noww....
- '99 Civic Speakers (Searched)
- B16 For Cheap?????
- can i use it for my b20b? crvtec?
- b16 harness into stock 97 EK
- ITR sway bars
- what would be the best valves with my setup?
- fuel line + inline fuel filter (how much is needed)
- H22 EG Bottem end torque issue!
- help my car pulling right/left...
- adding tilt wheel to 93 Civic Cx
- i need help im having backfires!!!
- How do I fix my hand break light?
- car died!! help!!
- Help with mini me swap.
- drivers seat
- bad alignment = torn axle boot??????
- CEL 4 CPS
- bad camseal
- b16a2 Sensor help 2000 si in EK DX
- D16Z6 into 93 delsol S
- Free aerospeed coilovers worth it?
- Flickering lights
- Thinking About Getting a JDM EG6
- chipping p28
- accident question
- Just swapped LS in and running really weird
- CONFUSED.....TB question?
- It's been a while (since i've created a useless thread in this forum)
- Does anyone have Tein's on a del sol
- Heat or AC making a weird noise when running over pot holes
- 95 Civic front bumper question
- piping question
- Tdc help
- Help Cleaning transmission fluid from the firewall/dash??
- tires for ej1
- Valve Question ?
- CTR or ITR pistoNs!!!!!
- Will this fit...?
- HID install into EG fogs
- brakes for 5 lug 92 EG
- HELP oxygen sensor wiring b16a2
- del sol is an eg correct?
- 00 EK/JDM ITR Swap/Del Sol A/C Bracket/D-series Compressor/ What belt?
- Need some help: Gauge cluster stopped working...?
- another ek window track problem
- Auto B-Series into Auto 92-95 civic
- b16 head question?
- fabricating seat brackets?
- Thermostat problem...
- whats the best complete valve train for b-series/b16a2?
- engine problems stemming from radiator
- speedo jumps when i hit the brakes
- What ngk spark plugs are better iridium or platinum?
- no tach after b20 swap
- 99-00 Civic Climate control panel in a 96-98?
- Valve Cover problem
- ***Tranny Popping out of 5th and leaking tranny fluid***
- MAP sensor question
- B20 v tec ?'S
- It's good to be back!!!!
- Fog light install
- brake light
- building a motor for the first time.
- mini me
- d16
- car security
- Seat ajustment problem
- Quick injector question
- Need a rear bumper
- a6 ARP head studs....will they work with a y7?
- I NEED a QUALITY oem o2 sensor - where to get? for b16a2
- broken motor mounts in an EK...
- any body interested in getting a DYNO
- CEL 6 .... need help
- Need help first time swap problems
- quick confirmation, to make sure I'm right... upper control arms
- B20 swap into EK, will turn but not run!
- 2000 EX b16b swap
- Suspension Questions
- Would a 2006 k20a fit into a 95 del sol?
- Attempt it myself or have the dealership do it?
- Vi-RS I/H/E Questions...
- Help with throttle Body?
- are they going to rub?
- b18b or b18b1?? need help
- Need help picking a tire size for some 16s
- Question about seatbelt harnesses
- Will 02-05 civic exhaust fit 92-95 civic?
- TINT HELP!!!
- i found a few honda part websites, are there acura parts websites?
- F1spec seats?
- Intake manifolds which preforms the best.
- engine obd...? help
- lo jack in a honda?
- Another Catch Can Question (searched)
- Need Help with Gas Saver Swap [VX Swap]
- reading rims/tire? choosing the right tire to go with your rims?
- Is it true that black people..............
- pic request *cant post in app/cos*
- Quick Question
- 92-95 civic fog light lenses
- d15b7 with a jdm d15 head possible?
- swapped fuel injection feed hose question
- whats causing my o2 sensor to keep on goin out???
- Radiator choice
- will this fit?
- quick harness question
- Wheel Stud Issue
- Do I really need a spring compressor?
- Fuel Pump fuse?
- DX EK hatchback tranny.....
- 92-94 civic HATCH with abs
- AEM trutime cam gears - which is exhaust and intake side
- Extra Sensor, Extra vaccum
- exhaust q?
- mugen twin loop fitment
- throwing code 8 topd dead center sensor in my 94 cx hatch
- Which way does the cam gear key face
- D Series Crank???
- help me with my shifter
- how do i test a fuel pump? without taking it out
- need opinion on my idea obd1to obd2 conv plz
- o2 sensor gone bad
- i can get an ls engine for $300....
- Dizzy ~.~
- ej8 c pillar bar?
- Honda/Acura Speedo accuracy issues
- RPM at Highway speeds
- Si cd player question
- What engine harness do i need? HELP!!!!!
- EG
- Reinstalling cam caps...do i need liquid gasket?
- wat does 1996 honda civic hx have in the motor wise
- !! Black Friday=Car Theft Galore
- Plug needed?
- intake manifold to TB
- 95 DX Door Lock Swap?
- LS tranny woes
- GA exhaust laws...
- original key?
- HONDA sensors resistance chart. anyone has it?
- Gsr a/c Compressor? works? read here let me know
