View Full Version : Honda Civic / Del Sol (1992 - 2000)
- w00t I BOUGHT a DEL SOL!!!!
- is EG1800cc legit???
- helP! which hoodpins aren't rice?
- Would just Integra front brakes help out my hybrid CX?
- who's got Arospeed seats? what'd you do for brackets!??
- type-r port n polish?
- Is $600 a good price for usdm civic SI tranny?
- JUST to LET YOU KNOW
- real jdm type-r motor?
- gas tank size
- mini-me on ek details
- Need CTR pic for wallpaper!
- Rattling heat shield.. Can I just remove it?
- Where to get yellowish Ion coloured H4 bulbs?
- Anyone using 100/130 watt bulbs??
- swapping auto ek to manuel b18c1
- I've been hit.....fucking punk ass theives!!!!!
- what tires you runnin?
- Los Angeles Area, good quality paint job for $1000-2000?
- 16x7 +40mm offset... rubbing?
- Writing an essay for class...Give me some info on JDM, etc...
- Suspension Set Up!!!! Need some dealz!!
- What size Paxton Fuel Pump on CRVtec?
- Need help aiming OEM foglights!
- turbo a crv-tec?
- critical info:need to know on fifth gen/3rd gen civic/integ.
- Software from Honda
- i have a problem with my header!
- Racing Wheels
- FIBER IMAGE HOODS???
- Anyone with a CARFAX account????
- ive got cash what should i buy
- ENGINE Problem
- b16 vs b18 nonvtec
- Crower Stroker Kit...
- catbacks that go under the rear LCA's on EG's????
- where to buy new factory carpet mats for a 92 dx??
- what can i expect with my apexi n1?
- Finaly some pics of my ride .......sucks to be u if u have 56k
- help, My friend just got a 95 civic cx
- Help removing axle on 98 ex
- JDM DC 4-1 header and which test pipe?
- My Si
- motor mount mod question
- inciviccord
- Need help finishing up gsr dash
- Stupid rock chips!! Would mud guards look to silly on a del Sol???
- Neuspeed Strut bar fit 4 doors???
- Exhaust problem on EG with WW RS KIT
- Help me to all NJ ppl!
- Fuse Question
- Who here knows what a Real Civic Type R front strut bar looks like.............
- My Investment :Pictures:
- gasoline never reads full on eg....?????
- DOT 5 Brake Fluid: Pros and Possible Cons?
- si,vtec?
- Skunk2 short shifter question
- Help please... VTEC head swap on a dx engine??
- another hatchback paint
- P84 ecu, from what car?
- wheres the fuel pump fuse?
- Dumbass question of the day.
- 92 hatch Cx and 94 hatch CX
- How do you roll back miles on new cluster???
- my EG died!!!
- RHD Registration?
- Guys is it really that easy
- Is this car worth buying ?
- ls eg conversion
- Road Paint on car
- Searching topics...Does it work?... Suck?...or am I an above average Idiot?
- Custom Upper Grill - Front H Removal Technique
- Civic rims...
- help with a 5 lug conversion!!!!!!!!!!!!1
- intake manifold question
- camshaft info
- camber correction help......
- carbon fiber hood for a del sol
- HELP! BRAND NEW CIVIC SI
- Installing an APEXi Turbo timer on 95 Civic EX
- Just installed NEW BREMBO brakes!!!
- bog @low RPM w/ BBK throttle
- turbo or swap
- HELP! Bolt sticking out of engine block!!
- Ever consider a "vehicle repair loan" for mods???
- Here it is before its sold (2000 CX/B16B)
- Need 96-98 Civic Healights!
- HELP!! - 97 ITR Shifter WILL NOT bolt on to my 99 SI Shift Linkage -- Any HELP???
- Intake question for a swap
- Hot Import Nights @ Seattle
- EK and EG pic request
- wut is a P07 ecu???
- Opinions on GSR suspension...
- are 92-95 SOHC VTEC injectors same CC size as 94-95 GSR injectors?
- Car going to be painted tomorrow (Championship White)
- i am new =)
- Injen intakes?
- heat up my car?
- what lips are available for del sols?
- Factory axle back with aftermarket B pipe?
- Roll Cage for 00 HB.....
- how much is a RHD hatch SI?
- EG lovers dream!! Check it!
- Lowered EK tire rubbing solutions?
- what kind of times should i expect from.........
- mugen pedals
- WHat oil for my EG? and quarts?
- Want EG taillights...SUmthin not ricey???
- WTB: Black 92-95 civic dash.
- how much for my motor?
- gsr hoses question
- PICS Of 97 CIVIK (hatch)
- shiftlinkage question!!! Pics would help
- New Pixs of my civic =)
- 92-95 jdm 4-door stanley corners..
- Girlfriends new car, having some lighting problems...
- Block question
- Parts for a b18c swap?
- exhausts...
- CF chin spoiler for 92 hatch?
- where'd you get your red/clear EG tails?
- engine swap in cali
- Running on Snow
- * Got a problem with my Engine **
- EG FRONT END QUESTION....
- Brake light?
- US, Europe, JAPAN swaps
- Question about auto tranny to auto tranny swap
- dx header swap
- B16 Cable????
- ignition timing
- vtec engages in what rpm on 92 EG SI?
- full set of 00 Si seats going into a 92-95 hatchback, MODIFICATIONS?
- One more question on trannys . . ..
- Anyone knows the number for American Honda Finance Company?
- anyone selling 97-01 lude rims/tires?
- Transmission quesiton..........
- Adding to the CX projects. Here is my car.
- 2000 ex valve clearances
- How much Should I lower my car??
- anyone riding on groundcontrol adjustable springs?
- JDM civic USDM civic?????????
- Best affordable big brake kit
- will dohc ecu run a sohc?
- How to test Main relay for a 92 civic??
- 92 up SiRII and 97 EX wire harness
- B18C5 in an 2000 LX?
- whats a good AUTOMATIC tranny to run turbo on?
- How do u install an Ignited starter?...
- what does a transmission cooler do(auto tranny)?
- exhaust melting rear bumper
- For those who seen the 2002 SIR in person, what do you think of it?
- APRIL 13TH MEET PICTURESSS!!!!!!!!!
- anybody know where it went?
- projector headlights
- Exhaust system's for 94 Civic Hb..... hybrid suggestions
- anyone here want a b16 ef? i want an eg.. lets trade....!
- Rubbing??????
- gumball rally 3000
- front bumper adjustment??
- Exhaust system's for EK hybrid suggestions
- how much drop?
- tires? scraping?
- Lowered and rubbing problem
- The Benen car
- anyone here got pix of the wingswest rear lip for eg?
- spring issues
- Which pistons and rods
- Questions about Spark plug wire applications...
- tranny question
- Prelude spindels on a 99 civic hatch
- Crower 63401's...
- help!!!!!!!!!
- 92 hatch
- A ? about a 2000 Si
- 92 civic hatch gsr or 90 crx?
- what kinda paint job would u all like to see on my civic hatch?
- JDM eg headlight question
- b16 engines...
- air pressure
- quick question on RIMs for my 2002
- JDM LOVERS!
- which tires with 15" wheels?
- Does anyone have......
- Rack and Pinion
- Rota Subzeros
- Which camber correction bolts? PICS inside!!
- Pics of my new Exhaust
- Who has ever heard of the follwoing polyurethane products....
- EK c/f wings
- i need parts...
- What's the weight of these motors?
- 96-98 SiR Front Lip
- new mod and new pics
- 92-95 EG colors??
- what exactly should be built up when planning on installing a turbo??
- Which Coil Overs?
- Del Sol dudes: Leaky roof! help......
- any sites or place to buy a engine rebuildkit?
- Engine building question
- Del sol headlight conversion.....
- shocks for 97 civic coupe?
- A newbie NEEDS YOUR HELP TURBO/SUPERCHARGE 02 CIVIC?
- This look right?
- what clutch? how to install clutch?
- 93 CIVIC HB swap info....
- getting a new car, need opinions..........
- alright... I have a question about 99 vtech head on 94 vtec
- Anyone installed AEM pulleys on their ek??
- Aftermarket Steering Wheel w/ Cruise?
- kinda funny
- Spoon Sports Non-adjustable damper kit vs Mugen Sports Lowdown?
- My new Panasport wheels
- Anyone know?
- Apexi World Sport
- 2000 Civic Si Tranny
- Any websites that sell engines? preferabbly b18c1?
- Hybrid guys: what radiator setups you runnin in your EG's?
- automatic Bseries
- need vtec help! ASAP!
- Where to get a b18c1?
- B16 Final Drive = Type R Final Drive ???
- where to buy a b18c1?
- Engine swap
- rota slipstream?
- Wiring Amp for '97 del sol
- Size of Si wheels?
- Just crashed my 2000 prelude!
- time for a new clutch
- what's the best road course set up?
- What are better rotors for the price
- dumb question ?
- Should I be taken out and shot?????
- How much Horse Power does a del sol have??
- 15's or 16's on hatch? rims
- Type R engine
- Good friday...
- Help with broken door handle
- interior
- spoon/spoon style CF EG wing. do you lose 3rd brake light?
- Why not a b16 instead of a b18
- jdm steering wheel . can u make the HORN work on a jdm wheel?
- do any of you guys have a jackson racing charger?
- b16a2 short block for $250 good?
- Who here has a 92-95 Civic hatch with a H22a? I need some real answers!
- Skunk2 Wheel Studs - Good or Bad?
- anyone using these HID's in 92-95 civics?
- info on doin' a hybrid ?
- Where to buy Skunk2 Stage 2 cams cheap? =)
- 93-94 civic ex question
