View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Proper way to bypass heater
- COMPRESSION TEST DONE; HAVE QUESTIONS??
- Fuel Pump Problems
- Getting codes 20 and 23, HELP
- p75 questions
- 96-00 ek 2001ls seats
- hp question for d16y8
- JDM Cluster Question
- Need some help, in the middle of doing my swap.
- shift light without a tach???
- need some help with starting my car
- Question about engine?
- What parts do I need for a rear disc conversion?
- Who sells Raybrig light bulbs?
- is this possible??
- !!!!!!!!!!!!!!!!!!!! PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!
- I need help ! swap problem....
- d16z6 into 92 civic VX?
- Y8 manifold onto y7 swap, HELP!! (pics)
- HELP ASAP - Car turns ver fine, Wont start, backfires -bad-
- blew up turboed GSR in del sol...
- water line and hoses
- radiators???
- Help
- WTF is that knocking.. wheel bearing?
- Questions about tranny: doing an ls/vtec swap soon
- SO CAL*****WTB: dual core radiator
- problems with my tranny
- help w/ apex'i turbo timer, wires=
- 97 si delsol upgrades?
- ebay shorthrow
- HELP! Boosted Throwin a CEL #1 or #10
- will a 97 dx hatch stock exhaust fit a 95 ex coupe? <search was no help>
- Need help locating horn wire harness, SRS unit GONE...
- VTEC
- real or not civic type r
- door panel fitting
- installing my egay catch can,, just one thing though...
- 37820-PR4-A11 for my b18b?
- spring problem!!!!!!!!
- ebay fogs
- Clutch question....
- Finally got a p08 for my d15b
- Questions about my 95 Civic Dx Sedan
- Got 5 speed cams, should I use the exhaust one too, or just intake? More?
- dc2 recaro seats
- y7 to y8 manifold swap (quick question)
- HELP.... I need the socket size of civic knock sensor?
- 99-00 ek bumper conversion
- knock sensor size???
- 92 D15b performance mods
- 2000 4dr civic exhaust question
- speed sensor
- tire question
- Purge solenoid..?
- so im a vw kid thats thinking about getting a honda
- Will power steering pump and bracket from 93 d16z6 work with a 94 b18c1?
- Alternator question
- Need help finding new taillights......
- Help please!!!!!
- another header question
- Need help with wiring for my b16a sir II.
- clutch problem?
- Del Civic
- squeaking noise everytime i step on the clutch?
- Si 2000 Speed Sensor problem
- What Headgasket to use?
- Compression loss from port and polish?
- My exhaust rattles like crazy between 2000 and 4500 rpm
- ok so im a noob, need brake help, like NOW please
- power streeting in eg swaps
- Forum Going down the crapper
- d15b VTEC versus stock HF motor, fuel efficiency
- Where would one find these parts?
- .::New pics of the Hatch::.
- EG Stolen - SLC UT - West Jordan - HELP
- keyless entry
- Need Help with Ground Wires-93 Civic EX
- Need Help with Check Engine Light / VTEC
- koyo aluminum radiator,....no cap???
- b16 mess HELP
- Whining noise from engine bay... not PS pump
- Skunk2 Short shifter installed
- Considering someone else's trade...
- 99 civic dx to mini me vtec help!!
- b16 tb on stock z6 intake mani
- Genuine Spoon?
- new clutch
- d16 good enough swap for my needs?
- Will HX wheels fit 1995 Civic Coupe EX?
- itr rear lca's on an ek?
- bushings...
- HONDA CIVIC RIGGED? YES OR NO
- how do you install a GSR radtior into a civic 92-95 hatch??????
- how to NOT wear out a clutch
- Looking at a B18C5 Civic...what codes to look for..?
- kyb agx/sportlines: Opinions?
- Type R head a good upgrade??
- yet another car with wierd idle ... help plz
- need some quick help..
- Looking for b16a2 tranny
- Bunch of car problems. Please help!
- Some pics of my 92 Hatch W/ JDM H22
- Weird whitish sludge in the radiator cap area.
- k20 del sol info...
- Installing AC.
- some newb questions............
- Post excuse
- too much milling maybe
- mini me swap gurus! I need your help!
- Adjustable shift knob?
- Sideskirt removal help!!
- link or help on installing jdm eg sidemarkers
- 1/4 mile time for a h22 eg hatch
- ITR Spoiler fit on a 96 Civic Coupe
- EK Steering Wheel
- Is this an OEM 2 Piece grill for EKs?
- Thinking about getting some 16s
- New radiator, old and new *pics*
- Oil pump gasket?
- Will this fit in ?
- Where can I find a b16 differential??
- Ignition Issues
- noob question
- Question about JDM Intake Manifolds
- k20a on Delsol
- OBD1 Oxygen sensor wiring CHECK.
- JDM power folding mirrors
- where to get obd2a to obd2b harness
- ignition switch?
- A/C Mount and Bracket **please help**
- QUESTION ABOUT D16Y8 ENGINES
- 00 civic ex stumped which engine?????
- Speedometer Going Nuts!
- h22 swap question...
- Totalled GSR for stripping
- car running like shit with skunk 2 manifold
- B16a2, Compression after milling and 2 resurfaces? Clearance issue?
- :more damned coolant issues:!! HELP
- Is it hard to install air conditioning in a car that had it but was removed? also, RHD LHD same?
- Confused about OBD wirings.. HELP!!
- worth it ? not worth it
- please help with my check engine light
- BULLFROG Hood...Anybody still sport these...?
- 2000 type r motor swap obd2
- obd-1 civic and obd-1 integra distributor ignitors the same?
- ex and si cluster
- exhuast mani for D16Z6 ??
- **HELP. AT WORK AND EG WON'T START"
- questions about installing stock radio in my hatch
- Detonation
- JDM Stanley city light bulb identification
- Need Help with Omnipower Coilovers!
- 94 Coupe VS. 96 240
- 16 valve zc motor
- running like crap
- some brake questions...
- What Short Shifter do I have?
- how do you take out the climate control from the eks?
- ls head on d15?
- a/c compressor question
- headers for my sohc
- DC 1 Piece Header on D16y7
- Hydrolocked my engine a little bit.
- CEL code 48
- All B series Vtec Axles the same?
- Parts Needed bad!!
- Power antenna for HB
- VTEC VX
- Parts list for power steering and other options.
- ARP EXTENDED WHEEL STUDS
- QUSTON EG B18C WITH P28 >???
- gas question
- 92 eg redline?
- throttle body swap?
- 99 civic alternator fit a 98 civic?
- ractive vs. dropzone
- Fitament: GSR Rear Seats in Civic Sedan?
- HELP!!!! CLUTCH PROBLEMS
- Need help with rear disc brakes for my 93 hatch
- civic type r valve cover
- Inexpensive speed upgrades.
- 92-95 "Racing" Console
- gutting the cat...?
- Need some ideas for swap in my 97 Civic
- d15b jspec high boost!
- y8 header on b7?
- Honda optional audio console for 92-95 civic
- b16a2 engine is from EG or EK Si?
- Will a '00 Si exhaust fit a '00 Hatch?
- any OBD1 hi-flow cat that can pass smog?
- CEL code 1 doesn't go away
- monts of 18c swap
- Hey CEL codes and help
- How do i install these....? sparco spring hooks....pls help...
- evotion camber kits
- Thunderbolt Catalytic Converter?
- mini build up?
- D15B VTEC PCV
- What lip? Maybe it's a one-off...
- in line fuel gauge installetion question
- d17a1 d16a9
- b16 problem
- del sol parts
- Cat Fault Light
- Starting problems...
- Are all 92-95 Civic dizzy caps the same?
- b18c5
- SRS?
- Civic Si, with a b16, having vtec problems
- Question about ITR shocks/springs on EG9
- Question on installing 02 sensor...
- HELP NEEDED FOR REAR DRUM TO DISC CONVERSION ON MY 95 CIVIC EX COUPE
- 99-00 power window conversion. need help.
- DPFI or MPFI?
- in computer helms manual?
- carfax request plz
- Tachometer
- Del Sol - New GSR Swap Wont Start
- VAFC II controller on turbo b16 setup
- Shredded Alternator Belt
- what is better for del sol, KYB GR-2 with Tein or eibach springs?
- ?? on MC for brake conversion
- Valve Stems
- 92-95 hatch
- roof glass panel?
- [honda gurus wanted] a wide range of questions... part 2
- ???Need some help with b16a auto swap!
- Are rays CE28 same as v-speed?
- 99 civic which gear on the headlights adjust the beams side to side?
- hid
- ITR/Legend/NSX calipers with 10.2 discs??
- Converting Auto to Manual
- weird fuel/wiring problem i guess
- test pipe question
- Locating Service connector help please..
- EG vs EK
- Need pics of a stock b16a2 intake manifold.......
- locating tranny type
- which header would u recommend for a 99 em1
- Suspension Swapping... Q&As
- Transmission....
- Whats wrong with my clutch.....Help Please :(
- speedometer went out. help!!!
- New wiring and ecu? Need comfirm.
- front end conversion
- Car running very hot, AC running hot and cold......?
- Cam benefits?
- 4 door eg rear section exhaust
