View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Dual exhausts?
- tokico hp shocks & springs
- How much does it weigh(searched)
- b16a2 good compression with a leaking head gasket.
- Need help figuring out my CEL code reading.
- 95 Civic coilovers/shocks
- JDM throttle body-HELP!!
- which diffrent between d16z6 , d15b-3stage and d16a6 ?
- 93 civic dx exhaust manifold bolts on in a 93 civic ex?
- need flame help, what better place
- Blizzak LM-25 on a Civic
- 99 Civic White flakes In Coolant?
- B16 timing belt ?
- Ugh, My Exhaust Broke
- Replacing struts
- where should this hose go?
- how big is the fog lights for a...
- '00 A/C w/ GSR Swap Question
- Car Not idling right after swap, any help?
- red honda civic jacked
- ANY SUGGESTIONS FOR LOWERING KITS?
- what gauge wire for negative battery terminal ground?
- hey
- s2000 steering wheel into EK?
- topnoss need help on mini swap <=======
- Timing Help!!
- IM stuk need help
- suspension problems help!!!!
- CAI question new to this installin
- NRG engine damper install pics
- Built Minime vs B16A G2
- Got a new IACV and Idle is still Jumping......
- fuel switch problem integra type r! help!!
- d16y5 problem need help pls!!!!
- Bypass Code 6??
- For you guys /w missing or damaged 92-95 fog light covers
- Any one use OBX mufflers ????
- accelerating problems
- Brake Pedal Sinks A Little While After Being Held... What's Wrong?
- Axle Breaking...
- Lights dims after gsr swap?
- werid problem
- False RPMs?
- heater problems
- Ouch! is this correct?
- CRX seat will fit in EG?
- y7/z6 mini me swap troubles..
- quick question on DC headers
- NEED A EG OR EK SHELL
- NEED A D SERIES ENGINE
- What engine works with what???? 1988 CRX Si in a 1993 Civic cx?????
- Lips
- LS running rough
- oil filter
- eg b16- or trade for y8 turbo???
- whats wrong?!?!
- cant hit reverse now! WTF!!
- Exterior door handle replacement
- will this fit?
- Suspension question
- alil white smoke, maybe pinging.. not sure.. ???
- JDM Climate control install
- cl master and boosted swap 1"
- CODE 21, help so i can fix this, need someone who can explain what is wrong
- Will a 00 em1 helms be sufficient for a gsr swapped 00 hatch?
- What type of RC injectors?
- fuel gauge reading wrong
- 2 OEM headgaskets for boost?
- B16a et.
- SERIOUS Clutch Problem NEED HELP FASTT
- INjectors?
- Jdm Corners 4dr
- two differant 5spd y8 manifolds?
- Tranny popping out of gear???
- Rear disc problems?
- Which is the best seafoam method, and are there any risks?
- disc brake ?
- what would be the right choice
- Broken CTR headlight tabs
- lol RHD
- Gauge still not workin
- 4g63/t problem
- 96-00 Civic Power Locks Question - Picture is this my actuator?
- white smoke
- looking for a B18b
- fluid coming out of my exhaust......
- Lookin for a B-Series Motor
- changed thermostat and now heater is not working...
- civic swap..axle help
- Obd2a to obd1 - no power - no CEL codes
- Ecu codes? Sputtering B16a.
- ? to all I need some advice
- drive shafts too short???
- Throwing code 7
- bolt pattern
- reverse is hard
- o2 Sensor
- brake issues
- obd1 o2 sensor help
- car likes to bog and give me a damn code 9
- b20 tranny
- 2000 Si: Which wires for the power grounding kit?
- honda cx a/c and p/s questions
- Just failed smog, Here are the results (Help)
- Head Gasket Blown Questions
- motor shopping. i have a question
- Cabin harness & MAP sensor
- Shifting Problems
- sway bar help
- lowerd. uneven?
- Tranny problems after/during b16 swap in 97 coupe
- del sol problem
- 92-95 Rear Window defroster difference
- Looking for the best replacement for OEM Brakes.
- where to buy lower tie bar bolts
- noobstah help
- Car starting problems
- running rough
- help on clutch master cylinder
- 31 MPG vx WTF
- H22 Swap in a 95 Civic Ex
- `92 EG Hatch/ K20A2 Swap - STOLEN!
- Air Filter
- Crower are Crane???
- chipped p28
- how much do you pay for insurance to drive your si???
- main relay swap.. civc cx to GSR
- projection light ?
- Getting shocked everytime I touch my car... Wont turn over and start... short somewhere?
- ABS problem
- Opinions on swaps
- B20 vtec questions
- DID I REALLY SCREW UP?
- Headlamp question
- any one selling a d16y8 engine complete
- DAMN CEL!!! Someone help, CEL 21 vtec solenoid
- Strange noise?
- just bought my del sol
- Door Lock Problems..
- CLUTCH PROBLEM
- crank angle sensor
- JDM tuning+misc parts NEED list....
- z6 vs y8 vtec head
- discussion on ex tranny vs y7 tranny
- Speedo not working and...
- Recommendations on Engine Swapping?
- manifold?
- how much compression
- Need help diagnosing my car!!
- bump
- Will the stock EK coupe exhaust work with a swap?
- wtf.,....wheel question
- key stuck
- Lowering it?
- wheel locks?????
- corrusion on my distributor cap
- question on VSS?
- b18 civic
- Need Help!!!???
- Distributor Wire Up.. need help asap
- A Good Deal?
- walboro fuel pump problem
- Hid help Please
- spun rod bearing or main bearing?
- 99 dx auto swap Q searched..
- Code 65 - Oxygen Sensor Heater (Secondary) Question?
- hey, 2 quick questions my ctr cluster's srs mil stays illuminated, but the dx cluster doesn't,what i
- need paint code!!!!!
- ek cluster question.....
- hey can find anything on cv joints! could some1 help me out/
- need help!!! could some1 tell me how to replace my cb joint in my civic?
- iacv need to pass emissons code 14
- too good to be true?
- quick noob ?
- How to bleed coolant
- antenna help plz, searched already
- 93 Civic Lights out question.
- Boosted Civic not starting I NEED HELP!!!1
- Question about JDM 4-1 Header Heatshield??
- Progressive Springs - Proline vs HR Sport
- Need advice...Got my stolen engine back, 12 years later...
- vtec and cel problems need help!!
- side molding adhesive help
- ECU people please help..
- b-series swap, axles make poping noise?
- 99-00 Civic Si Cluster Question?????
- JDM question
- motor mounts
- Swap ordered! Question also!
- 1995 civic HB CX doing an engine swap, what should I do?
- P08 Questions ??
- hid question
- Finally automatic to manual coversion completed
- y7/y8 coolant lines?
- JDM B16 OB1 help
- secondary O2 sensor question
- will 97 stock springs fit 99 ex?
- throttle bodies
- B16 SWAP PROBLEMS!!
- exhaust
- Quick question about a d16z6 (95 EX)
- help finding jdm cluster install
- newbi questoin
- Pin trick for CEL light flash in '99 EX?
- Civic will not start
- How would you guys repair this?
- 1995 JH Civic Ex D16Z6 question?
- D series header
- ECU CONVERSION HARNESS?
- finishing up swap power steering pump bracket question
- Starter/battery/alternator gone bad?? car wont turn over...
- just installed new radiator - having issues with bleeding coolant system
- Main Bearing???
- psi... help!
- really quick cat question
- wont go in gear
- EDM del sol aux light mounting issues?
- air/fuel ratio gauge hoookup question.
- motors?
- code?
- EF and EG steering wheel hubs compatible?
- Are brake pads interchangable?
- IAC VALVE..BAD IDLE
- Paint Gurus Inside
- Si jerking side to side.
- ANTENNA INSTALLATION HELP!
- Members from KENT ???
- MOMO Apache troubles..
- coilovers?
- Weapon R Coilovers
- s2000 engine start button for 2000 civic si
- What to look for when buying a EG civic (92-95)
- Brake lights not working please help.
- ES Oval with Greddy Evo piping...quiet sounding?
- creeking noise
- tranny swap and CEL light
- Does anybody knows where the transmission located in 93 Civic EX?
- 92 Civic Hatch HELP !
- ECU God's: Please Help
- HELP....MY CAR WONT START!!!
- civic eg side mirrors? taking them off....
- Weight Of Del Sol
- Hood pins?
- what brake pad are you using?
- Just curious...
- whooshing noise from front end
- 92-93 civic hb
- Has anyone tried to put 99-00 fogs on the 96-98 civic front bumper???
- 99-00 civic Si o2 sensor
- Stainless Manifold for a D14?
