View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what to do???
- suspension installation question
- SHORT SHIFTER QUESTION
- ls wheels or meshe wheels/
- d16y8 line question
- serious discussion: boost on stock b20 sleeves
- Pic request: GSR and Si header
- single shot of my 1997 sedan
- Wich motor Should I swap Need some help!!!!
- FS: 2000 Civic Shell w/motor
- DC radiator in EG?
- This the end for my EM1...
- K20A2
- NEED HELP GETTING CIVIC EK9 PARTS
- Weird CEL
- eg rear swaybar bushings
- Airwalk bumper
- Honda Oil + Filter, VS ?
- 99-00 em1 swaybar on a 92 civic vx?
- wat is a "time cert"
- hey how do u check ur pm messages lol
- Tokico Illumina shocks
- Registering a JDM RHD Civic EG Hatch in CA HELP!!!!
- work cr01 wheels
- Greddy Ground Wire System
- Intake Manifold (d-series)
- LCA's
- Help-Doing Swap
- Car almost stalls..
- Si Springs/Struts
- Any insight on power locks/windows
- Si Lip??
- another camber kit question!
- Wire Tuck
- Exhaust ? (searched)
- 99-00 si owners> How do I get the door panel on the drivers door with the tweeter also??????
- missfire when cold wtf!
- EG civic W/H22 wiring by hasport need help!!
- Got spark but dont know how to set timing for distributor! HELP PLEASE
- question about tranny housing stud...
- Timing Help on d15b in an ek
- Rod and Main Bearing availability
- Whats this side of the car called (The black strip on the door of a honda civic 96 dx)
- can't find o2 sensor wires in car
- no one in the Tech section is answering, should be easy question
- were this ground goes ??
- Rear Main Seal Leak...Or Is It?
- Gauge Cluster ? need help within 3 hours.!!!!
- Removing paint from plastics?
- Damage to Driver side rear quarter panel (If it is in fact a quarter panel) HELP!
- Need to swap from a 96-98 auto tranny to 92-95 auto tranny
- Quick ??? about 99-00 coupe rear lip
- ----help. how do i take out the back seats of me eg hatch----
- i need to confirm a question
- CAI Help For My 95 Civic cx Hatch
- !!!11mmx1.25 pitch tap!!!
- HELP: SI Swap On A EX Harness Distributor plug is different?...
- HELP: SI Swap On A EX Harness Distributior plug is differnt?...
- Can a intermdiate shaft be bad? Just the bearing? Wheel shake....
- half cut help
- shatty shifter
- b16a for sale
- about to get my motor pulled
- Pricing a SWAP for CIVIC
- 92 civic hatch o2 sensor wiring
- Should i get these heater pipes?
- what else needed to swap h22
- Differences between EX and HX (yes i searched)
- is this suppose to be like that?
- Need a quick confirmation
- CRX vs Del Sol
- INFO ON THROTTLE BODYS FOR A Y8
- i keep leaking gas, why? HELP!
- 92 civic eg
- are cam gears worth $100
- No fun
- strut noise
- p06 with d16z6?
- tach an speedo light along with running lights dont work ?
- quick eg questions?
- passenger headlight not working after hid install..please help..
- k20 swap
- Troubleshooting 94-96 Teg cluster in 99 Coupe...
- help need before ordering Chamber kit Si 00
- 17s or HXs with Azenis?
- a/c compressor not coming on..where should i start?
- Best Honda parts resource?
- 4x114 brake replacement question
- rusty rims
- .Gettin your car Bar'd
- Parts For Sale
- 92 eg (not selling, just want opinions.)
- Sense? My car performs between when the weather is cold.
- Are the side mirrors for 92-95 civics all the same?
- P28 ECU..Conversion?
- ls block b20 head gsr tranny ???
- ecu?
- AC question
- WTF happen to Ecucontrol.com???
- putting a 1994 GSR motor into my eg, anyonw know where the evar purge solenoid is?
- help...
- Oil Leak or Bad CV Axle? B16A2
- !!!!Quick Q on JDM CRX headlight!!!!
- Need quick answer!!!!
- Quick question intake question...
- After market power door locks???
- need help with my defroster
- 1992 hatch header fitment
- NEED SUGGESTION ON MY very first PROJECT ~~
- P28 --> P72 GSR WILL IT WORK?
- top fuel bar for 92-95 civic hatchback!?
- cigarette lighter
- ECU and sensor grounding points?
- Would a Camber Kit be needed for H&R Sport Springs?
- tires in irwindale link
- del sol rear "firewall"/trunk area. need a diagram. water stuck.
- sohc build up
- cleaning recaros
- Cleanest EG
- dude...what the heck is wrong this time.
- help me pls...
- Rollbar for the Sol
- o2 sensor
- crower turbo cam id?
- Timing Belt's OEM Spec is at WHAT degree?
- Megan racing exhaust how loud?
- tranny parts interchangeability
- H22 EG shifter cables issue
- Just picked up the new project....94 EG2 VTEC
- Which fuel pressure gauge to buy?
- ANYONE WANTING TO TRADE "99 CIVIC SI?
- D16y8 Street Car
- got a fuel pump issue
- ek b18c help
- EJ1, EM1.... what's a 97 Civic EX?
- need help with tranny problem....
- how can you tell if a block is sleeved?
- replacing distributor tomorrow....is there a guide?
- HELP ACCIDENT
- Skunk2 full coilovers for a 93 si
- cold air intake any good?
- Free Service for 95-97 Honda Vehicles
- Rims for Sale
- solid check engine light
- b16a head gasket... OEM or SPOON?
- clutch
- clutch question, worn or not?
- B18b in a 96 hatch
- Searched but would like more....EJ1 PICS please
- Welding Stainless Steel?
- Fuse problem?
- I Have Options!
- wtb:cheap ls swap b18b!!!!!!
- eg jdm gauge cluster
- !!!!!!!!!!!!!!!!!!!!PROBLEM WITH CRANK PULLEY!!!!!!!!!!!!!!!
- yup
- Chassis codes?
- Car SHAKES when i start moving like its going to stall. HELP
- Ground Control Applications
- hello, im new here
- EG DOOR wiring... need a little help!
- Fuel Pump Wiring question
- My car is billowing white smoke - HELP!
- wiring schematic 95 honda civic
- White Smoke
- GSR pistons inside a B16 block
- LS B18B Intake manifolds
- blew my motor, what are my options?
- Unbearable wheel hop!!!!! Worst I have ever seen/felt!!!!!
- Turbo Kit Help!!!
- Trying to find a certain picture...
- EG lips comparables...
- Where can I get my flywheel resurfaced? Doing a clutch job
- work wheels
- car runs like shit...
- help!...my 2000 Civic Si is throwing a code
- Idle problem only under load...
- BIZARRE Crank/No Start. Please Help.
- HELP!!!!! Problems With b16a2 OBD2 Swap
- ***OIL STAINS UNDER MY CIVIC?? WHATS THAT??***
- ***LOWERING MY EK?? WHATS A GOOD HEIGHT?? HELP***
- Strange viabration/noise
- exhaust donut?
- Tire Size for Circuit 8 on ej8
- CLUSTER QUESTION
- B20b guys... Cooling Fan Temp Question
- No Speedo WTF HELP!!!!!
- Civic Si VS. EX
- i NEED si wheels or slipstreams
- whats the differance?
- Does integra(DC) armrests fit in EG's?
- alarm system
- misc tech question *help please*
- ECU Codes: 14, 95, 91
- B16A2 tranny problem need help !
- apexi filter help!!
- can i add power steering to my civic?
- turbo ???
- 99-00 Civic Fog Light Question
- Thread pattern for stock exhaust bolt
- how to install a timing belt and water pump
- d15b oil pump seal / crank seal / front main seal
- repin mirror clip
- Help... Exhaust and header fitment question d16y7
- Help me wire up my horn, Momo wheel, NRG hub + Quick Release
- Parting out B16 Head.. I need this part
- eg progress
- high idle on a 93b16 obd1 hatch
- good deal?
- can anyone tell me what this clip is?...and if its important
- why NOT to buy an OBX LSD!!!
- 94 hatch cx 13.2 qt. time
- umm help please
- Non Starter + CEL Stays On + Can't get Code to Flash up when Service Connector Jumped
- What is this number?
- my 94' civic coupe ex stock bumper cracked
- Pic request: Black em1 (or similiar) w/ Volk GT-U's!!
- Dose anyone know all the chassis codes for civics?
- Engine VIN Location
- idle question
- need help with bucking LS in civic
- LOOKING FOR COREY TRANGHBER IN TN!!!!!! LOOK LOOK LOOK
- what are somethings that u have to do before installing a turbo kit??
- y8 Intake manifold swap: throttle cable issue
- P30 and P28
- I NEED BIG BOY SEATS!!!!
- damn check engine light!!
- will d16y8 auto ecu work for a manual car??
- shift linkage prob....!!!!!!!!!!!!!!!!!!
- Problems with swap.codes,wiring
- Trunk rattle
- b16a2
- NEED HELP QUICK- NEED TO GO TO JUNKYARD
- H22 SWAP HELP
- 96-97 del sol bumper
- stock fiberglass hoods?
- d series cable trans in a hydro can???????
- spline hub?
- will 92-95headers for a civic hatchback fit my 98 civic hatchback.
- CIVIC TRANNY?
- Stupid swap question?
- d15 staying cold
- need tips for mounting FG2 '06 SI seats in ek
- help me get rid of this smell
- ex and si front swaybars, same?
- trouble with cam timing
- b20 block b16a2 head questions for a 96 civic
- EM1 Cluster bulbs
- Newbie quesion: Battery light comes on while driving
- will any b-series axles work for my b16a swap (ej8)
