View Full Version : Honda Civic / Del Sol (1992 - 2000)
- header on d16y7
- Prelude and EK9
- del sol front bumper
- noob question about swapping clusters
- How to get to bottom middle nut on intake manifold with head still on the car....
- How to remove alternator?
- Need To Get Flywheel To Stop Turning
- Mini Me swap tech help. VTEC WIRING DIAGRAM NEEDED
- CEL??
- BUYING A STREET LEGAL RHD HONDA
- new gauge cluster i just got done with
- brakes
- smog check question!
- jdm p30 AT ecu work with a '00 b16a2 on 96 civic?
- posted at (1:18:27 PM)
- NEw timing belt Kit, which one though?
- ? about brakes
- searched....safc wiring
- removed my air bag, would anyone buy it?
- new here.
- 93 hatch jdm b16 tell me what my ecu is please
- door panels anyone?
- Two questions. Friend wantrs to drop 92-95 LS in 96 Hatch whats needed.
- Short Shifter in my 2000 EM1
- BIG PROBLEM: White Smoke from exhaust!!
- Bitch Pin
- sputtering away in the rain in pa...
- Front Left Wheel Noise - Vibration Weird
- hey lads quick queston on uberdata
- No Code Getting Thrown!
- brake light problem! help!
- hondata s200
- Cable to Hydro Conversion Question
- gallery?
- im a nooB on here well to this screen name...
- SRR Distributor
- Omnipower Test Pipe
- seafoam... cat friendly?
- Questions about 1998 LX Sedan
- installing intake gasket (d16z6)
- wasting oil
- b16a in a 92 eg civic vx bogging starts to die out help:(
- 99' Civic Si
- Name this stock rim
- clutch
- Mugen Twinloop or Apex N1
- whats the dif between i-vtec and vtec
- ping sounds 98 civic
- burned EG6
- wiring vtec on Jdm b16a swap..
- A/C Compressor Drive belt replacing question 98 honda civic lx
- How can you tell if your motor is blown?
- is my engine okay?
- Want to build an all motor single-cam(help)
- wiseco pistons
- will the 59300 cam make power up till 7750-8000rpms?
- Hight beam light always on
- Need help ASAP
- water in engine?
- air conditioning/powersteering install?
- help new motor won't ever sputter
- Shifter Question!
- MSD caused check engine light to come on???
- Cleaning muffler
- hesitation and bogging before 3000rpm..wats the deal?
- eg6 tailights
- 99-200 power window conversion ???
- Sunroof Visor
- 99 civic cabin filter??????????
- B18C GSR vs SR20DET
- help 95 eg civic/Skunk 2 camber kit not fitting do I need something else?
- Searched: Dome light getting power one side still not working..help!!
- New to Honda
- Fuel Rail? and Vacuum/fuel pressure question?
- Misfire.
- stock intake manifold
- 1999 civic ex tranny fluid...
- Would a 99-00 civic hood fit on a 98 civic?
- Question about Head Gasket
- B16A 88-91 (SiR I) ?
- Mini Me help
- Uh Oh, What Is This (trans/axle related)
- '00 Civic Si full rebuild, turbo, tranny ?'s
- B16 into EG, QUIK HELP PLEASE!
- iacv pinout fix (yes another thread on it)
- B16A2 (99-00 SI) Axle Stuck
- SI gauge cluster help
- A/C Compressor question
- Clutch Kit OR Clutch Master Cyl. and Slave Cyl. install?
- i need help!! 94 civic turbo
- d15b jdm vtec (help)
- couple of questions
- AEM fuel reg with Victor X manifold
- Ebay performance chip? I think not.
- JDM b16a / SMOG question.
- I REALLY NEED HELP!!!!
- JDM B16A obd0 to obd1 swap...
- HOW DO HID's LOOK IN NON PROJECTOR HEADLIGHTS
- EK automatic tranny in an EG? will it work?
- I REALLY NEED YOUR HELP... engine blown? IDK, I NEED HELP ASAP PLEASE!!!
- Car Overheating issues???
- Removing Dash?
- Power Steering Removal?
- iM reAllY nEw iN tHis gAmE...
- plz help!!!!!!!! question on window regulator interchangibility
- tire sizes
- fried ground!? ****HELP****
- Problem adding freon to 95 civic
- Tanabe GF210s for Eg
- clunking/bang sound when braking...
- cash value
- What kind of rims are these?
- Engine Gods need your opinion! Bent valve again.. :(
- TDC
- If you have done an Integra dash swap in you eg, could you take a look please.
- iaac valve?
- 94 civic ex sputtering
- Supporting Motor Methods (clutch install)
- z6 harness for y8 motor?
- starter making grinding noises
- 00 SI hard to put in gear
- i'm new ht
- Greddy sp
- Picture of Type R Throttle Body plz
- Window Help
- EG Seats for Hatch and Coupe
- VAFC settings
- Adjust Valve Timing?
- Code 3 searched through 20 pages.
- Cluster & Cliement Control Light?!?!?!
- ls/vtec
- Help (Test only time.)
- jdmd15b swap question
- Fender Brace for EG
- I'd really appreciate you guys' help, Paint estimates... please
- power steering..
- Invidia exhaust on a sol/b series car. Anyone heard it?
- help with engine noise/knock
- sterring wheel vibrating?
- Tuning for a honda? Power Fc tuning myself?!
- Question about back pressure...
- One thing after another.....!!
- Video Turbod16 / where else did you want me to put it.. honda-tech sink...
- where do you post video?
- '96 Speedometer went out...any help?
- Adjustable cam gear problem
- JDM Foglights wiring help.
- Noob with overheating EG
- EG Auto Tranny Differences
- question: exhaust temp and battery warning lights come on
- b16 turbo question
- Forced Induction, engine swap or better car?
- Forced Induction or engine swap?
- Need a HOW TO on engine wiring B16 1996 Civic Thanks!
- Ebay Axles?Ebay Axles?
- auto to manual parts price
- im picking up an integra shell
- got b20 need a tranny need help
- H.I.D fitting
- CF DUCKBILL SITE?
- Is it ok to keep on disconnecting my main relay as an antitheft precaution
- what engine is dirent drop in for 99 ek hatch
- EG8Lip ?
- Eg interior
- What is needed for obd2 y8 into 93 Si?
- accord to civic
- Y8 head $75 should I get it? Pics.
- Chocolate milk in catch can????
- eagle rods and ???
- need help with EK heater /ac control box
- Cluster Switch
- switching from automatic to manual trans
- EG Radio Location?
- Rear Disk Brake question 00 EX
- EG Sedan with hatch bumper?
- Idle surge issue
- Hubcentric Ring size?
- Looking Into buying a EG
- I need your help guys..
- looking for a used motor company in south
- What's the best way to cut and shape plastic? (Material on our oem mudguards)
- 93 honda civic hatch with bad window regulator
- What kind of header or exhaust manifold should I get?
- 94-01 Integra mugen wing on Delsol??
- Exhaust for 4door dx
- i want power steering
- Back Pressure?
- Valve adjustment help
- D15 intake manifold
- owners of jdm headers... help
- dizzy part question, spring and charcoal piece
- fule pump question
- A video of my friends 00 civic si and friendds gsr
- Fitment of JDM ITR 4-1 Header on GSR EK
- Strange charging problem
- What do you think??
- d16 just wont turn over ????
- DOHC vtec gsr emblem
- 5 lug brakes problem
- Drivers Side Engine Mount, what are my options, ran into a problem....
- What kind of civic is this for?
- Engine cranks over but it won't start
- crankshaft pulley bolt sheared and pulley went flying
- I want lots of power and reliablity
- Quick ?
- quick question: tach problem
- inspection time!!!
- how hard?
- Thumping and clicking sound while driving and stopping
- Intake manifold question? p32?
- head gasket help for a b20 vtec on boost
- Question
- can i drive a car with no intake at all?
- want to put ac in my non ac car. what to do?
- a little electrical problem....
- 1999-2000 civic hatchback turnsignals
- d16z6 p28 ecu Question?
- Time for a new starter?
- any good and dependable shops in michigan?
- fuel cut-off switch question..
- 98 civic ..Shift linkage...
- 00 Si NEED HELP
- What are d16 oil pan torque specs?
- plug wire question
- Loose stock air intake box
- sohc manifold swap!!!!!! help, idle
- 93 EG CX with d16z swap getting a cel code 21. Need some help.
- Off subject. For SD locals! I am now doing chipping for the 92-95 obd1's.
- h22 swap with a/c?
- Head Gasket Question?
- CAI water cover?
- THE ULTIMATE SLEEPER ENGINE: d15z1 build
- 96civic ex....non v-tec?????
- where to paint ur front end 4 cheap??
- How do i replace the head unit in a 2000 ex?
- Stock injector size, same through different series??
- Knocking noise at low RPMs
- Distrubutor obd2-obd1
- skunk2 intake manifold vs b16b intake manifold
- injector problem
- how much would you pay for a 95 4-door shell?
- vtech sensor
- b20/b16 v-tech head vs. b18/b16 vtech head
- I need help with my drivetrain
- ECU question
- Please help IAVC Question
- FPR: Aeromotive
- f22a4 swap into a 94 del sol s
- D-Series.org!! 99% HP/TQ'less idiots! Let the fun begin!
- B20 TPS question (yes, searched)
