View Full Version : Honda Civic / Del Sol (1992 - 2000)
- S2000 header donut gasket work on JDM ITR header
- city lights on jdm eg headlights. seeking guidence.
- Air induction kits!?
- 3500 RPM rev limt...whats that mean?
- What kind of Civic is it?
- rims size on 01+ civics
- What color have you painted your brake rotors?
- "Clink" noise coming from my wheel area... 2000 Civic Si...?
- The Friendly Wave
- how to wire horn to momo steering wheel
- I NEED HELP!
- Headlight conversion
- My suspension setup, will it all work
- throwing code 17 on my ecu vss... need help
- Need a little help, somebody please...
- Need help with wiring an o2 for a y8 mini-me
- cluster problem, need help please
- Holy $hit, I almost hydrolocked my car!
- CTR PISTONS?
- Does this sound like a good deal?
- Del Sol AVCR location
- Mugen Twin Loop
- So what should i do to my car?..
- whats the lifespan of a brake caliper
- Wheel Question
- H22 Tranny noise - Help appreciated
- Coolant leaking overnight...bad water pump?
- Thermostat problems
- '92 White Civic Hatchback For sale!!
- Adjusting cam gears
- Timing on B18C1 in an SI hatch???
- Camber wear
- non-cf spoon or spoon style mirrors
- Maintenance required light keeps blinking.
- Manual Steering Rack Conversion on EK
- my horn don't work
- my first swap - opinions please
- GS-R trannys worth?
- Taking out the pin that holds the shiftlinkage on...help me please!
- QUICK QUESTION: Is there a difference between top hats?
- NEED HELP WITH BARO SENSOR PROBLEM
- 4.5" Intake Filter
- Fuel management: what are you running?
- Engine upgrade or engine swop ?
- which sway bar kit
- i need a body shop!!
- Getting ready to put new piston rings in. Need walkthough on rehone.
- idle surging problem
- just B20Z wiring issues
- Possibly buying a rusty 93 si hatch.. I need the H-T expert's opinions. *56k gonna take a long time
- in need of 92-95 p28/p72 ecu diaphram
- which del sol is which?
- G-tech pro?
- how to: take off crank pully on b18c1?
- Horn
- 99-00 tailight tint
- civic si performance
- motor transplant necessities?
- 2000 Honda Civic Si Coupe -> in europe?
- importview.com??
- intake question....
- piture request white hatch with white roof
- Piping Size Help - Thanks
- Anyone Making Brushing for LS rods for d16 blocks?
- vx rims - how much $$ ??
- 92 B7 -Z1 Head Swap
- 99 si wheels
- feeler: what should i ask!?
- 92 honda civic motor
- IAVC Problem
- 4X100 vs. 4X114.5 Making them fit and redrilling questions
- HELP!!! MY car has no electric at all!!!
- how much are n1 axlebacks? and are they worth it...for my 96 ek
- Sway Bar Question
- Trouble with my SiR 99 !!!
- Clutch Problem
- need a wing ASAP
- Radio security code entry?
- sunroof ?
- Dyno'd the hatch,whatcha think?
- Transmission ID
- 2001 Civic Ex Coupe
- D-serries tranny ratios?
- Working on a D16Y8......
- Please guys take a look at this
- Tires for VX wheels
- h22 eg w/4pt neuspeed bar is a no go
- OEM is better..
- Easy Fuel Pump Wiring Question
- LS Clutch Cable vs. YS1 Clutch Cable... Same?
- anyone use mityvac vacuum brake bleeding kit?
- I have some Z6 swap questions
- sidemount ic??
- puttin stock suspension back in.. have a few q's??
- troubleshooting my engine
- Minnesota Junk Yards/Auto Parts
- can some one help me with power window in chicago?
- Transmission reliability
- who knows swapwhore101?
- Need some local help.
- I've got a '99 EX, and a 92 B18a head, can i put it on a OBD2 block?
- What Color?
- N1 Exhaust mount below or above LCA?
- has anyone here ever put del sol door panels in an EG hatch?
- best civic?
- turbo on a 94 civic ex coupe?
- o2 sensor ?
- 96 D16 w/vtec injectors in 95 d15b7
- anyone heard of these pads before?
- ever have this happen to you?
- f23a1 in to 94 civic cx? got some ?'s
- si climate control
- About side mirrors???
- Replacement motor mounts.
- Now bad is it? (big pics).
- anyone have a civic alternator bracket?
- TEIN Basic Damper any good?
- speedometer isnt working
- solid cel on hondata, red light blinking, car runs SOMEWHAT alright
- what year did p24 parts come from
- bling bling baby
- Which blinker wire?
- Strut question?
- Cel Codes
- What is the difference?
- 2000 SI Cluster into 92 DX
- Brake swap help . . .
- avid racing parts.... yeh or neh?
- HELP! Need a Helms PDF for a 99 civic.
- Help with dropping my car.
- after market brake upgrade
- what in the zc is it?
- SUGGESTIONS FOR EXAUST?
- Why would you use only the ITR exaust cam?????
- 97 Civic Headlight Removal
- NEED HELP ASAP. Distributer wiring
- I've got I/H/E what should I do next?
- Worst day ever... thread stripped
- Where does this cable go?
- CEL dosnt store?!
- how to find out the engine model number?
- questions about b18c1 obd2 into a 95 del sol S...
- Air Conditioning Questions.
- Problem - Catalyis efficiency below threshold
- crx Si rear sway bar on Eg?
- need help with baro sensor
- d16a6 Sohc. How much in NA form
- Another suspension question
- Azenis wear-related question . . .
- how much is 99-00 si going for??
- tranny making weird growling noises
- JDM B18C Drive Shafts versus USDM B18C5
- 99-00 si wheel weight?
- ? Anyone ever bought JDM Headlights off ebay?
- keeping it cool
- Pics and performance of a DC header and full exhaust?
- Exhaust on a 93 Civic EX
- HID QUESTION ASAP
- What power steering pump do i have????
- Need a camshaft choice
- Installing new A/C
- converting b18b obd1 into obd2?
- 04 civic throttle body humming
- kyb gr-2 shocks
- how to fix crx camber in the rear.
- Need Help taking out Idle air control valve "iacv" please help!
- Requesting Dyno Shop info
- modding a b16 oil pan to fit GSR block?
- whats needed to make it right hand drive?
- someone just broke into my car need help
- Tranny Mount qustion.....B18c into EH
- Rear Lower Exhaust Gasket
- last distributor question, help me before i spend lotsa $$...
- jdm b16, what header
- Help Convincing Pops
- carfax pls....
- LSD question
- Car wont turn on:
- warning unidentified hose found not hooked up
- Carbon Fiber Spoiler......
- Opinions on Aftermarket Radiator Support. (99-00 Civic)
- lsd info needed urgently please look,
- how exactly do you turn your distributor 180??
- 96 1.6 in a 93 civic need help
- how much hp?
- what comes with a new distributor?
- D15B VTEC - What timing Belt and Waterpump Are Needed?
- CTR Headlights...where can u get these?
- Squeaking noise after sway/tie bar install.
- Squeaking for my steering and clutch..... GRRR!!
- OBD2 -> OBD1 distributer wiring
- HX swap help needed... already searched!
- swap vtec wiring
- B16A2 service manual
- Axels....?
- Electronics Problems
- parts from america to holland.
- any one know where can i find those del sol parts for sale? thanks
- anyone know where i can get a wiring harness for a vss 93 civic
- will converting ac from r-12 to r-13a make my ac colder
- how much grease should be on or in the vss
- will low tranny fluid cause speedo/vss problems
- are these real 00 teg type r cams
- cable gearing in a hydro tranny
- where to purchase del sol glass top???
- Header rattle when idling with air conditioner on...
- what type of b-16 motors are there and whats the difference?
- one brake light doesnt work
- clutch makes sound
- SPW Industries
- Aftermarket Springs on 94 DOHC del Sol OEM Struts?
- Autometer Tach W/ Shift Light, Shift Light Not Staying Where Set?
- jdm b16, what oil filter, after swap
- rebuilt b16...is it worth it?
- ECU resetting/ Help going crazy here!
- Factory Service Manual
- 2000 b16a2 into 93 Si Hatch
- Clutch problem???? or not
- Should I Venture into the 4 wheel drive world?
- She's Gone...The Mourning Begins
- Does anybody clean their engine bay with Auto Degreaser?
- need help....car making odd noise
- How to -change your rear targa top seal-
- Does anyone know what this is? Is this a test pipe or a high flow cat? (w/pic)
- b20z2 into a 95hb
- Will I need a spring compressor to install Neuspeeds?
- good recommend suspension set up for daily drive?
- del sol si/civic
- type r cams fit on civic si 92?
- Congrads to IGO4BMX!
- intake manifolds? what goes to what
- help! axel nut issue
- help... fuel leak after changing fuel filter
- D16Y8 Valve Adjustment (Found Something Interesting)
- ELD location?
- question..
- Brake lights out, no power to cd player or horn..
- Does the front bumper of a 2dr fit in a 4 dr??
- Got a swap now speedo problems
- midshaft differences
- Front Wheel Bearing Replacement
- Tranmission Swap - Need HELP!
- A few problems after tranny rebuild....
- hey! (This will need to be moved)
- Has anyone ever ordered from Racing Works???
- 2001 hubcaps
- Installed new battery terminal. Whoa!
- Mitsu 3000GT Headlights On 92-95 Hatch
- Mirror w\ LED blinker Installation help
- after 3 months the head is finally done!!!
