View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I need to fix my clutch pedal...
- ok day 10 another problem
- vehicle shakes at 55
- K20 motor??
- quick transmission question(s)
- 96 dx int mani the same as the ex?...
- 93 delsol vti running problem
- In Dash Wiring harness..
- Jdm side markers.. how to i put then on?
- about del sol and integra parts.
- need info on puting engine together
- Few questions about a b18 swap.
- quick question need help
- Buddy Club N+ spec coilovers
- d series injector sizes
- 99-00 ex exhaust manifold
- Spoon Exhaust question
- What does the stock manifold for a Z6 look like...?
- fuel pump or main relay not working
- *Searched* need wiring diagram for 2000 civic hx...remote start hook up
- Do I need a front and rear camber kit???
- how to tell if ur T-belt is loose?
- ????need help???new oil pump... now i have a oil leak?? ???need help?
- Hey guys, first honda, first 5 spd!
- Axle Question
- Rhd HEater box question
- question
- pic request of a 5th gen sedan with ls mesh wheels
- a/f gauge quick ??
- noob civic 93 dx starting problem HELPP!!
- Where should I buy a cylinder head?
- Auto to manual...cruise control?
- Help with Turn signal
- Pic request
- External Gas Light
- Question..
- 96 civic Help!!!!!
- will 98 integra rear hubs fit on 99 si rear disk brakes????? help!!!!!!!!!!!!!!!!
- Help with Civic
- 2000 Civic Si
- Looking for JDM climate control for EG civic
- foglight diameter size
- fog light switch
- Cold air intake? Weapon R?
- Need help on EK foglight switch JDM with USDM
- power window q
- b16 crankshaft
- 2000 Civic -> 1995 Civic, Are the rear control arms the same?
- Are my Lma's going bad?
- a/c problem!
- Turbo d15z1
- Help: Automatic Transmission Control System Malfunction
- B16a Turbo Help inc pics
- Starter kill? ... need help
- D15B vs D16Z6 head differences? . . . searched but no luck :(
- civic parts help
- Power EX Door swap
- 92-95 Honda Civic
- B16a running rich
- Who are these guys?
- new throw out bearing: oem? or cheaper ones just as good?
- the most rare JDM civic you will ever see.
- Honda Access Visor Install Problems
- 10,000th swap question
- Car sat for a year, now clutch feels messed up
- Will it wear out?
- Type R lip
- how do i know if vtec is blasting or not?
- breather hose from valve cover to intake tube? smog issue
- D15b o2sensor???
- silverline muffler?
- Antifreeze Loss
- hook up question...
- what to check for when buying a used head..
- Universal racing seats
- Who sells new 92-95 EX/SI front lips?
- Carbon Fiber hood...
- problems with poor mpg and sluggish highway driving with 2000 civic ex
- 99-00 EJ8 climate control bulbs
- Idling problem
- Worn clutch? (2000 Civic EX
- problem with OBD-I B16...
- lights on si radio question
- D15B7 timing belt fix
- check engine light came on .......seriously confused
- Creek sound from driver side rear wheel
- Feedback on EG power window swap
- Installing Remote Start On A Stickshift
- automatic shift kit
- Sedan as project car?
- HR lowering springs not lower?
- cel 15....
- Bad Tranny Bearings??
- eg hatch D16 swap running on 2 cylinders
- D16y8 manifold issue on d16y7 engine
- Na i didnt
- How high can a jdm b18c(sir-g) safely rev?
- my timing belt snap ?
- car WON'T shut off???????
- when should i have vtec engaged?
- how does Vtec work in simple terms?
- wtf is wrong with my vTEC plz help me
- Suspension Question???
- Need help with Air Conditioning problem... SoCal has been HOT lately...
- bad catalytic converter
- 'normal' intake manifold for 97 dx?
- integra type r spoiler on ek coupes??
- A/C help!!!
- 00 civic si power steering ?
- Torque Numbers Drop Right After 5000RPMs, What's The Cause?
- V-Tech Problem plz help!!!!
- Tranny Q's!!
- 92 Si electrical problems
- d-series turbo $$$$4-sale$$$$fullll KIT
- Sway Bars
- thermostat in a 93 civic
- need a fresh start....
- AC compressor
- del Sol VTEC 1/4 times
- 96-00 pedal assembly into an eg?
- Sweat The Small Stuff
- what does do you have to do to pass BAR
- What year GSR integra header to use for GSR swap into 96-00 civic EK?? (searched)
- spoon's EK9
- what the hell just happened?
- Racing Seat question
- were can i find oem factory hoods
- front lower ball joint
- Trying to hook up AC with my swap, will d series stuff work?
- IF I LOWER MY CAR WITCH COILOVERS DO I USE FOR MY CAR OR FOR MY MOTOR?
- Tucking 15's with 205/50/15's.. Will i rub on slicks?
- The Situation
- d15b What camshaft to get???
- d16y7-d16y8 injectors
- Gram Lights PLEASE HELP
- SOHC ZC VTEC valve cover bolts
- spark plug help for 97 gsr
- si sway bar on a ex
- wondering what times are people getting with a b16a stock in an Ek hatch?
- Random technology CAt?
- Need help - alignment kits
- Someone help me!!
- Pinging/Detonation?
- have anyone used a random technology CAT?
- suspension suggestions for street / occasional dragstrip
- Engine list - post water repairs
- Any one ever do a complete paint job interior/exterior?
- New Honda Owner
- New Honda Owner
- ls vtec swap what is the proper clutch
- JDM EK fog lights, i need the instructions for it, i seem to have misplaced it
- someone help me solve my clutch/tranny problem!!!!
- flywheel hurting topspeed?
- Axles? Or something else?
- help changing a steering column
- Troubleshooting code
- new car selling old
- New to the site
- I cant figure out why my car is running rich... maybe you can.
- Leakin antifreeze???....
- My H22A : parts list and cost , not cutting corners
- World famous hatchback
- 00 si injectors
- twin disc clutch and t4 turbo manifold
- how hard is it to swap b16a2 block with jdm GSR or TYPE R block??
- help with Lower control arm
- Stage 1 cams?
- need help on apexi vtec controller install
- soft clutch pedal...
- Grade Logic. Need answers.
- civic/integra a/c compressors
- best combination
- b16 into CX hatch, new Cat needed?
- head bolt striped HELP HELP!!
- Del Sol Brake Question
- Help! Fuel line into fuel filter busted
- changing manuel to power doors
- GSR transmission Question!
- 99 Integra Brakes on EG
- HELP Check Engine (codes 1 & 43)
- Disc Brake Conversion?
- energy bushings endlinks
- swapped manifolds, and car wont start.
- 98 civic cx question
- Question about Wire Harness
- Auto to Manual Swap
- d16z6 engine help
- B16A differences
- Anyone have any experience with this machine shop in Anaheim, CA?
- can anyone help do a tranny and clutch swap? (so cal. Orange county)
- what pipe do i have to use when swapping to b18c5
- Jdm omni power test pipe 2.5
- Code 21 - What are the causes?
- WHICH AC-SYSTEM TO GET?? PLEASE HELP
- sputtering car? help.
- 98 Civic DX (D16y7) to 94 Civic EX (D16z6) swap, what do I need to make it work?
- KILL SWITCH HELP!!!
- Compression Test readings, are they good????
- Crank Position Sensor Help
- I need help with a gauge cluster swap... *searched*
- Passenger Electricity Help
- A/C Compressor/Condenser
- need a test for coil
- Recently Purchased 97 Civic EX... Please HELP!!!
- 00 si won't start!
- b16 vs b18 noise?
- will this shift linkage work in a 96 del sol si with b18gsr swap?
- Dropping/Reinstall Tranny - Can You Do It Yourself? Easiest way?
- civic type r cams
- Climate Control Switch?
- Sat in my Si for the first time in a year today...
- how can i get my rear to be lower
- ecu for 99 si??
- ecu trivia
- JDM ecu different from usa?
- camshaft/VTEC dilemma
- another swap help thread.. ( searched.. clutch line.. )
- help: transmission control system
- stud n nug nut stripped for ej8
- Colour Help
- Idle Surge Problem! I searched and still can't figure this out...
- gsr tranny problem...help please
- VTEC problem
- LS swap
- Need some help with ECU
- any a/c for sell?
- Paint deal
- can't exceed more than 85 mph
- (Another) OBD1 - OBD2 Conversion Q
- Getting a Del Sol
- H I D Install how help plzzzzzzzzzzzzz(EK)
- throttle body question
- hatch locks ??????
- spoon direct flow pipe + D16?
- From EG to EJ8, and loving it..
- quick question about ex doorlocks
- d16y8 haed on d15b7 block with ex tranny
- 6-puck clutch and pressure plate?
- ? on shift knob
- Never heard this sound before?
- b16a in to a b16b
- ecu 4 ls/vtec
- where is the fog light fuse????
- car wont start(not a usual case)
- problem with passegner locking
- Radiator core support
- questions about mini-me swap
- need fast answer, is del sol AC same as civic
- ek power windows/doors
