View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 del sol si - High idle with no brake MC attached
- 97 JDM ITR Cluster into 99 DX Problems
- obd2a Del Sol b16a2 into obd2b 99 Acura 1.6 EL chassis?
- 98 Civic EX - No Start
- Windshield Wiper ICU - will '96-'00 ICU fit '94 Civic Si?
- Transmission rebuild.
- Civic 1997 Hatchback 1.6i D16Y5 engine.
- 2000 Honda Civic Overheating
- 97 Del Sol Si - Radiator Hoses Won't Fit
- Soft brake pedal and running rough
- 96 Del Sol gas pedal replacement (solved)
- 1996 civic Starts then dies
- 98 Honda Civic LX overheating.
- D16Z6 Intake Manifold Cleaning
- 00 EX civc d16z6 with y8 head and P2P ecu cranks no start and no spark
- 1995 Civic DX Manual, Sometimes Fuel Pump not Priming, CEL stays on
- Muffler broken , Help!
- diagnosing my power door lock problem
- ACG fuse blowing, main relay?
- Eg hatch b18 swap vibration
- idle surge after y8 I'm swap
- Holes developing in my Fuel Rail?
- How to bypass check engine light?!
- 94' civic oil hoses?!
- 2000 Civic LX - Overheating, Milky Coolant
- Radiator burst in stop n crawl traffic (Resolved)
- Ej1 has 4x114.3 rear studs please help
- Mystic Brown interior touch-up paint?
- 93 civic ex auto to manual conversion
- Failed Smog- High NOx
- Axle Slop
- 94 Civic LX - Mysterious overheating
- Honda Ciciv MA8 D14A2 engine starts well and stops
- 93 civic hatch - speedometer doesn't work
- 99 honda civic condenser fan won't turn on.
- EM1 Strut tower brace stud rust
- installed st front sway bar
- Car shut off while driving
- bought EJ6 with aftermarket upper control arms - need ball joints
- 98 Civic D16Y7 - Need gasket between exhaust manifold-cat unit and exhaust pipe A
- 2000 civic si, bogging issue
- 1995 Honda civic ex 1.6l overheating/idle issues
- 97 ex auto - cleaned throttle body and now car wont start
- 94 civic cx hatchback with X problem (solved)
- FactionR's Hatch Build - For Posterity and Inspiration
- Cruise Control Vacuum
- brake master cylinder stuck on brake booster
- Loud Noise
- 96-98 vs 99-00 fuel pump question
- 97 Civic DX manual/d16y8 with D16Y7 IM - Vacuum/Coolant Hose
- 96' Civic Cupholders, Type R?
- 92 civic/y8 head - Motor shakes at idle with battery ground connected
- Would e85 work ok on a 2000 civic ex automatic d series?
- 1995 HONDA EX CIVIC WONT START! PLEASE HELP!
- Del Slow Build
- 92 civic VX, 5-speed - OBD1 or OBD2 injectors question
- 94 Civic EX Failed Emissions
- Voltage drop while attempting to start car
- aftermarket gauge illumination wire tap?
- Integra Type R front and rear seat swap to EM1. Will they fit?
- D16z6 intake on D16y8 swap
- No crank no start help!!
- What are good front lower control arms by brand?
- What's the thread pitch on the threaded shaft bit of a front lower arm? (solved)
- Video: How to disassemble a distributor and replace the internal oil seal
- oil in combustion chamber cause misfire code p1399 (solved)
- Project 97 ex coupe -- F20B with T2T4
- Strange rattle from intake.
- I have four pairs of axles and I want to figure out which are in the best condition
- Replacement Rocker Panels for 94 civic
- OBD2 auto trans into obd1 95 civic
- Cruise Control Stopped Working?
- 97 Ek Coupe Speedo problem
- 97 Ek coupe right blinker staying lit
- Lots of shifter play
- New engine from japan
- Starter prob ?? Solenoid ??
- Need Help Finding 2 Door Sunroof Motor (Also Question on the 2 Motors I Already Have)
- Where to buy EM1 front lip
- How can i tell if my D16Y8 is non vtec or vtec?
- How do I port match a Z6 intake manifold to a b-series throttle body?
- 1995 Civic will not start. Does not turn over. Fuel pump primes.
- 94 Civic - starts and then stalls
- 2000 Civic intermittent grinding noise in 1st and 2nd
- Bent upper control arm - how to tell if spindle is bent as well?
- 98 civic lx driver door harness question
- engine coolant temperature sending unit plug
- 1996 D16Y8 Del Sol intake questions
- EJ8 front plate mounting
- 93 civic ex starting problem
- 99 civic d16y7 obd1 to obd2 conversion
- Miles per tank on your EK3? {Stock d15}
- $200 97 Civic DX Project
- d16z6 - valve cover doesnt say Vtec
- Hot or Cold, car stumbles for few seconds
- 93 Civic 1.5 stalls, won't start, no code on CEL (Solved)
- 93 civic ex (vtec) d16z6, check engine light , code 22
- 95 civic ex - Constant valve cover leak
- Del Sol/D15Z1 - Codes 9, 22 and 41
- How long did your original distributor last? Is 161K miles good?
- D16a7 engine - What ecu?
- Civic EG3 - TPS does not have reference 5V
- 95 honda civic d15b starts but doesn't stay running
- Hissing sound when braking = bad seal between brake booster and master cylinder
- 97 civic d15b7 swap help
- 1997 civic ex leak at back of engine bay?
- 98 Civic LX - odometer stopped rolling
- Where to find oem style 99-00 civic si spoiler?
- 98 Civic Rubbing/Grinding Noise .. I am baffled
- secondary o2 sensor code after replacing cat, etc
- 95 Civic VX - rear is creaking and squeaking (solved)
- 95 civic - Thumping noise only when I turn right - broken axle?
- HELP CAR WONT START (solved)
- How to connect horn in non SRS EG?
- D16y8 oil leak (solved)
- "Tooter" the 1997 hx used car
- Help on passing emission inspection, 1999 DX w/ LS-VTEC
- euro civic 1.4i - Low idle problem with A/C running
- code 21. already did helms troubleshoot
- 95 Del Sol fog -- lights don't work
- Australian 97 Del Sol - Need help locating circuit diagram for the power Transtop
- 99 civic ex - speedo doesn't work after auto to manual swap
- No Spark after finishing vacuum lines - B18C1 in 2000 EX
- O-Rings for the Fuel Injectors..what are they called exactly?
- 93 Civic with a D16Y8 - Alternator Question
- 2000 Honda Civic DX Wipers doing something strange?
- 93' Del Sol D16Z6 Oil Leaking. High Pressure?
- z6 block, y8 head, z6 cam and gear, b7 dizzy - timing problem
- Loose exhaust manifold = engine problem. Help.
- 95 Del Sol, Antenna
- knock sensor
- 96 Honda Del Sol won't start.
- $600 98 Honda civic hatch project
- MilpitasEH2's 94 Civic GSR VX Hatchback build thread
- 93 Del Sol with Transmission grind
- 97 Civic Hatch - Fuel Pump/Electrical Issues?
- Will OEM EG headlight housings obstruct HIDs?
- 1995 Del Sol Rear Window - storing water
- 93 Del sol - Why does my passenger window motor have a 4-pin connector?
- 00 civic ex - Remote key Fob
- 00 civic ex D16Y8 -- maintenance questions
- 94 civic hatch - NO SPARK NO FUEL
- 93 Civic - Non Vtec to Vtec head swap?
- 95 civic - Auto to manual conversion wiring issues
- OBD2 to OBD1 DISTRIBUTOR plug problem
- 93 Civic Si with rear disk brakes - Best Rear Hub and part number?
- 96 civic d16y7 - Many questions
- Cruise control button wiring diagram and removal
- 97 CIVIC POWER WINDOW
- PM3-3 Head code? What Head is this?
- 94 Civic - undrivable when engine is warmed up except with O2 sensor unplugged
- Wiring Diagram for driver harness connection
- 95 Civic Si - fuel pump isn't coming on, main relay isn't clicking, no start
- Milky coolant/ Low coolant
- 98 Civic EX w/ Rear Disc Conversion - bleeding, prop valve, brake booster questions
- 98 Civic LX stalls/bogs down intermittently
- del sol water pump question
- Idle adjustment 92-95
- Is the sprocket keyway mashed beyond use? PIC
- steering column cover screw size and thread?
- 98 civic ex 4door vtec engine swap
- 98 civic headlights need help
- 98 civic ex 4 door under dash fuse box diagram help please
- 99 civic lx overheating only when stopped after driving long periods
- 00 EX w/ GSR swap, no ECU or Fuel Pump power, and yes I searched
- D16Y8 swap into 00 Civic - need help with vtec wiring
- Shorter bleeder screw on clutch slave cylinder?
- What Thermostat Can I Use?
- Need help ASAP stumped on crank no start problem
- Cranks, fuel and spark is present. But wont start (solved)
- SHIFTER HAS MILES OF PLAY!!!
- Russell brake line problems
- Evaporative System "Not Supported"
- 92 civic all 4 brakes locking up! Booster? Mc?
- 95 DX Auto, cranking but no start, good spark, good fuel
- Automatic transmission compatibility.
- AC condenser and radiator fans operation
- No Crank, No Start, No Nothing, Dash lights come on
- So, where do I pour Seafoam to pass California Smog on my 1994 Honda Del Sol?
- 99 Civic - Connect Cig Lighter to Radio wires?
- Window rolls up but not down?
- 1993 Del Sol driver side window glass
- 1996 Civic DX Water pump short bolt length?
- 1997 civic ex; car won't start possible alarm problem?
- Broken Muffler Bolt
- No ac!! Heater control panel??
- Engine swap on 97 Questions
- No start 1996 Civic DX Hatch 5SPD
- 00 Civic Si - rpms increase to 1000-1100
- 95 Civic 5-speed - No power to starter
- disc swap ebrake STRUGGLE
- Honda del Sol Automatic Transmission Shift Issues
- EJ9 Track car conversion help?????
- Dashboard compatibility
- Help! 93 Del sol Si - Leaking Clutch master Cylinder/ Upgrade..
- Swap nightmare. Need advice
- 99 Civic HX no power to ECU and fuel relay
- 97 Del Sol Tire conversion
- 2000 honda civic will not start, and i completely baffled
- frayed wires, soaked in dirty oil... how to clean/seal?
- 1999 Honda Civic SI AC vent temps
- Rally Hatch build thread
- h22a1 swapped 95 - idle problem with A/C running
- 2000 civic dx coupe vibration
- Civic EJ9 d14z2 track car
- Help me ID engine bay parts and ECU in my Del Sol
- Parking lights and dash lights stuck on when car is on?
- 1996 Civic EX overheating...
- Rear Snow Tire Cupping - Chunks of Tread Missing
- 99 civic has no power when key is turned
- Not starting when at operating temp
- My 93 del Sol won't run
- 1997 Civic lx coolant temp switch wiring
- A/C Compressor won't kick on automatically
- civic si 1993 doesnt start
- B16a2 swap into 99 Civic DX?
- No spark igniter problem '94 Civic
- Fixing Cruise Control 95 Civic Ex
- Civic Ferio VI-RS to USDM Civic DX?
- Install ek4, ek9 windshield wipers on my EM1?
- Will the rocket bunny spoiler for the 96-00 coupe fit the sedan?
- B16a2 swap into ?
- Help! Broken vehicle speed sensor
- D15b7 with z6 head
- 98 civic hatch - CIVIC EXHAUST LAYOUT~
- Exhausted broke after cat. Cheapest Fix?
- EM1 Vin Question
- 95 del sol d16z6 - water pump looks weird
- 95 del sol - headlight switch broken off
- 00' Civic EX Coolant Temp Sensor
- d15z1 with a d16z6 head runs poorly
- 00 Civic DX - in and out engine power and misfire codes
- Benefits of skunk 2 stage one single cam on a d16?
- D16 Build Questions
- Input shaft?
- Manual rack, pinion gear stuck
- A/C compressor engages and disengages
- Air in clutch line (wont go into gear)
- Ek9 steering wheel hub
- Alignment / Suspension / AXLE? Issues! Help.
- A/C System Fubar'd After Maintenance
- Weird A/C & temp issues
- 97 Civic DX A/C BLOWING HOT AIR !!
- 99 Civic SI: Sat for 3 years with blown head gasket
- 95 Del Sol SiR w/ D15B7 stock swap - IDLE PROB
- CEL for IACV/EVAP-Civic 2000 si with GSR B18C1
- Who knows any good quality tail lights that don't leak?
- 2000 Honda civic SI: Question about rear hubs.
- 95 civic coupe d16z6 fuel problem
- 98 Civic LX with P0505 IACV problems
