View Full Version : Honda Civic / Del Sol (1992 - 2000)
- no cat....
- Intercooler w/o a turbo?
- '97 D16Y7 Adjustable Cam Gear Question
- Battery keeps dieing
- d16 ported cam msd i/h/e!?!?!?!?!?!? how fast how much hp
- Horn not working
- Need some info on nitrous.
- Recommended Lowering Springs
- Will This ECU Be Ok For My 99 EX?
- koni/gc combo + snow?
- GOING TURBO
- picture thread
- pinging/pinking
- What kind of rims that would go with my ek?
- stainless clutch lines
- apexi turbo timer install need help
- crazy isane ideas!!!
- Who is using 215/45/16 on EG6... post pic
- What does this hose do?
- rpm idle stall irregular problem, engine code 14, 17, 3 ( IAC , VSS , MAP ) B20 CRV
- Royal Purple Oil
- water pump?
- Cam Gearssss
- springs question.
- Help!!! AEM Pulley Kit
- Big brake kit for a 92-95 CX with 9.5 inch factory brakes...
- quick msd ignition question.
- What belts needed for b16a into eg swap?
- gsr
- radiator hose fitment question
- reverse lights don't work.
- labor cost to replace radiator
- waht tranny
- el/gsr leather rear seat combo in a ek coupe??
- please help identify, B20 motor engine ? B16 tranny ? LS ECU computer ? specs, codes
- headerz?????????????
- idle rpm stall irregular problem, engine code 14, 17, 3 ( IAC , VSS , MAP ) B20 CRV
- clutch job help!!
- iintake manifold
- D16Z6 Fuel Injector Code??
- how to fix core support on EG6
- help on installing si cluster on eg!
- AEM Fuel Rail Help.
- Quick ECU question
- Headers ???
- what type of intake manifold for d16y7?
- 37820-P8F-A81 what ECU ECM computer is this from?
- how to take off cluster needles????
- Summit mufflers?
- Just bought an eg with b18c1 swap.....its slow???
- Hit a pothole now no turbo???
- need some info on wiring a b16 into a 96 ek coup
- 1/4 pannel
- this clutch/flywheel still useable?
- Spark plug pics,Ls/vtec Gapping?
- Max power on 93 Q
- NEB Question
- heater
- SO i have a question about ecus
- are 5spdand auto speed sensors different?
- motor backfiring
- Quick release steering lock?
- Need help Please trying to wire v-tec
- my tranny is clicking
- "hyperdrive system" ??
- D-Series?
- turbo or not...
- How to adjust a/c belt 93 civic ex
- car runs rough
- msd 6al ignition. in gsr
- Water Pump.... Type-R?
- Identifying a p28
- fender smashed!!!
- Rod bearing tangs...direction?
- brake problems with 92 civic dx hatch
- all motor d16
- need some feedback on skunk 2 full coilover
- Rsx tail lights on a EG
- Power dip low RPM??
- Bad O2?
- who installed h2b?
- axle help
- hondata s200 vs crome?
- Searched!!: Jackson Racing Map Controller Help
- How hard is it to cut sidemarker holes?
- Difference between flywheel
- XS Cams/Valvetrain???
- Torque Wrench
- turbo
- rear wiper switch question
- this is an easy one...
- 92-95 ignition switch trouble
- Power Door Locks Issue
- Getting a Compression test tomorrow...
- Replacing axle
- 2000 SI Going into Limp Mode.. ??
- body kits
- Haven't yet got a solid answer...
- How much should this cost?
- 96 ek hatch starting problem (wierd noise)
- will it swap over?
- new to forum 95 civic dx
- Fuel Pump
- How to install JDM ITR steering wheel on 96 civic?
- Clutch install, got some questions...
- car shakes when riding clutch...?
- What bulb number is that??
- Fuel Rail Mounting Studs
- how to remove the steering wheel hub?
- Help on chassis weights
- 1993 Civic HB
- Anyone no where i can get a grey jdm dash fo my hatch???
- 94 delsol vtech problems
- fix the engine or swap it
- engine swap ?
- Will stock EK shocks/springs fit into EG hatch?
- 1993 Civic HB
- NEED HELP!!!!
- full exhausts/2000 civic
- Naked women.
- ACL Rod Bearings for a b20vtec ??
- d16z6 build articles
- sway bar questions
- Need engine harness help. Del Sol OBD2?
- Where is the heater circuit located in a honda civic '98 dx?
- Ls/Vtec swap, Half Axle Problem???
- mugen header for D16?
- Installing rear camber kit on a 97 coupe
- Remove roof trim?
- 94 civic cooling problems
- turbo vs gsr help cant decide?!?!?!?!?
- turbo d15b
- Rear Brake conversion, anybody know how?
- I had trouble finding my PCV valve for my 1999 civic DX, I can help you find it.
- I love thieves!!!!
- Problem with my jdm sir after full throtle
- nose swap OK ???
- help!!!! fog light wiring for 92 hatch
- Gas for a Year
- 92 Civic, Cluster lights problem?
- oil burns fast, oil in spark plugs
- HELP!! my car is leaning itself out!!!!
- Differences in EK 96-98 and 99-00...
- obd2b to obd1 question, harness swap
- VTI-RS... sedan or hatch?
- 1999 Si O2 Sensors?
- Koyo Radiator Opinions
- EK9 Side Marker install.....cut outs....
- weight difference? Ek hatch and coupe
- transmission, clutch, and suspension questions
- FS: LS transmission
- 99-00 Civic Si Rim Center Caps
- loudest exhaust for 2000 honda civic
- dizzy question
- is there a link to download a eg manual online
- GSR head on JDM b16
- Smogging B20b swapped 93 Civic
- p30 ecu stock motor
- t3/t4 in b16?
- E85. What would it take??
- type R in EG6
- Issues with Sir JDM EG Cluster
- 105300 cam and tuning?
- injector sizes
- Intake manifolds
- deciding on what coilovers for my civic Ex
- civic b20 swap, high rpm during freeway speed, 4000 rpm?
- VISUAL differences between manual and auto y8 mani?
- integra seats in 96 civic sedan - sits higher?
- i think this is a stupid questin
- AutoZone Dual Core radiator!!
- ebay headers
- ls catch can
- CAT problem
- Are these CTR Cams?
- Help
- question about brake swap. i have searched to no avail
- Tie rod ?
- Alternator.....
- Car Idle.......
- questions
- dd boost question?
- 22mm ITR rear sway bar and ASR brace install with Apex'i WS2 issue on EG
- Gauge lights go out when highbeams turned on
- d16 rod options
- brakes suck when ac is on??
- brake pressure trouble when car is running?
- popping sound
- is there such thing as a obd2b gsr or itr (jdm or usdm)without imobleizer
- cluster and climate control light for ek hatch
- Tire Rack: Just Ordered a Part, what should i do ... ?'s inside.
- Gear-Speed.com?
- air conditioning problem
- loud rattling noise from timing belt area ! ?
- anybody have experience with holley airmass headers?
- d16 y7 header question
- After alignment and balance...
- Driver-side bottom torque mount
- Bad oil leak..!!!
- Yet another IACV Problem
- H22 Throttle Body and Intake Manifold.
- Newb Building a D16, need suggestions.
- Question about 96 Interior Color
- 196k?!?!?
- GSR or B16 head?
- ground control coilovers
- D16y7 block on 97 Civic Ex
- Ground post
- pistons rods set
- Wide body Kits for EG
- mount
- Need opinions on a possbile purchase
- RSX front end on a EG?
- EG nine22
- How To Pull CEL, D4, SRS, and ABS Codes (with Code Lists)
- DC Dash Swap In an EG... Is it worth the time and Effort?
- top dead center?
- Alternator (B18c-r on a b16b)
- ls turbo problems with sputtering
- Splash Sheild, Necessary?
- Need: Good Mechanic (S. Orange County, CA)
- rear disc Question
- ARE YOU JDM ?
- speed sensor order???
- What would cause wheel jerk while braking and shifting?
- EM1.... I need some help
- Car Overheated....Head Gasket Blew....How Much $?
- dash lights going out, and sometimes come back on....gurus needed
- Cheap Cat That I can pass smog with?
- any problems with replacing LCAs? Please let me know
- dose the 98 hatch dx come with a front sway bar?
- Engine and transmission Question
- EK EXTERIOR PARTS
- What to do while motor is out?
- Jdm Gsr swapped Eg Coupe
- ~need opinion~
- b18 with auto into a 97 civic:mounting q's
- Ls in vx civic help?
- Building the Perfect B16 egine!!!!
- Where to buy: J's Racing Intake EK?
- Bought a wrecked civic, airbags deployed...help...
- Car runs worse when low on gas!
- im new here
- Cam Seal , Timing belt?!
- is their a difference between the type r flywheel
- eg fogs with intercooler piping ???
- 4 grand gsr into civic?!?!?
- 00 CIVIC SI JDM NAVIGATION install
- jg engine dynamics or dh racing?
- Denji Projectors
