View Full Version : Honda Civic / Del Sol (1992 - 2000)
- HELPPPP!!!! code6 lsvtec eg hatchback
- Valve cover bolts seeping oil
- 2000 B16 (civic si) INJECTOR QUESTIONS
- d16z6 upgrades
- 92 Civic Si Under-dash Wiring harness
- how to mini me swap d16y7 to y8 head cylinder
- LS Vtec not passing Washington State emmissions. Please Help!
- 1998 civic has troubles starting when warm
- 94 eg hatch rear speaker question
- acura 1.6 el won't start!!! no clicking noise!!!
- fixmyrustdotcom still in business?
- Need help/suggestion with b16 timing belt
- Clutch Pedal Sticking.
- B16 Distributor FSM procedure testing question
- Will these fit my 96 cx hatch?
- distributor brand for 97 civic
- RPM Problem and vibrating
- need help with fuse box battery and harness ground
- how to find out what kind of honda i have
- valve spring compressor attachment?
- 97 ex slightly overheating
- Fuel Pressure Regulator Help
- New to cars
- KP Gasket Co. (Altrom)
- whats the hose called under my distributor
- help 95 civic has fuel cut out if i floor it
- fuel pump
- Ek hatchback tail-light mod?
- Del sol b16b vs 2011 k24
- Buying a $300 93' del sol as first ever project car.
- 2000 civic swapped with 97 ex fuel pump not getting power
- removing 100mph limit?
- Broke heater hose always
- Help with D16ZC SOHC Vtec swap
- please close
- Suspension help
- gas pedal and throttle cable issue
- temp guage fluctuating
- Need Help Please
- 1997 civic running hot?
- 93 Civic Ex, New to the Honda World!
- Replaced plugs/wires/cap, now car will not start
- car dont start
- Civic EG,water in trunk FIX
- 97 Civic - Radio ChOp jOb
- just bought 97 ex,couple quirks
- 1998 civic sludge in coolant??
- Hฺelp my B18C swap on eg won't idle
- 4-1 Type-R header making my car quieter?
- Repetitive Thumping and Clunking from Rear Wheel 93 Sol
- Honda civic cx 97 1.6 sudden stall while driving
- performance upgrades
- 1995 honda del sol - RPM issue
- Interior room?
- Proving fake JDM fenders.
- Exhaust pipe Questions
- B16b smoking white,Headgasket? Rings?
- d16y7 reliability upgrades?
- what do you guys think about my valve stem
- brake line position diagram 4 a 93 ex sedan EH9 + ABS
- Civic '98 spark shows only once when cranking
- is this a real Si
- fog light installment
- Is this the "oil control oriface" hole?
- D16Z6 Sputtering in VTEC
- 96 civic swap no power
- d series ticking under load
- d15b2 block on d15b7 head
- Header Comparison Questions
- O2 sensor w/ No cat - 99 Hatch
- 99-00 climate control..metal braces/frame?
- 97 civic d16y7 misfire
- d16y harness
- eg tailgate q
- boosted mini me oil pan question (blow back)
- 98 Ek overheating!!!!
- How would a skunk 2 universal muffler sound?
- BBS
- Really low idle when my car driven for a while?
- seat mounts weld in
- What in the world is wrong with this car 97 civic?
- 98 ek powered window n lock problema
- 98 honda ek hatch powered window n lock questions
- 1999 honda civic lx 1.6L timing belt replacement DIY?
- B16A header bolt size
- New to the Honda game
- 94 Del sol power window issues
- AC high pressure relief valve question
- 95 Civic dx coupe w/b16a2 swap issue`
- question of seats mount brackets
- Cluster guage and LEDS
- 1992 CX Honda Hatch w/ B20B swap Idle Issue
- Turning a power rack into manual
- o2 sensor
- FBP?
- just bought a 2000 ex 169k need advice
- Sputter/Ignition Cutting @ Operating Temp?
- motor mounts question
- AC Squeals - Light Weight Crank Pulley?
- front lca nut broke. help
- D16Z6 Random Misfire
- 95 Honda Dx Hatchback. Overheating after replacing my radiator hose?
- Rough running until CEL turns on???
- Fried ECU, what do?
- What should I do to my 93 Ex Civic Coupe?
- Potential New Owner
- 1995 del Sol Si Cruise Control Issue
- Mini-me Crank Pulley Questions
- 95 Honda Civic DX Headgasket replacement question...
- Cyclical/pulsating hum from wheels
- D16z6 accelerates slow after warm.
- 96 Del Sol electrical problem?
- EK siR and si brakes
- No RPM drop with clutch pedal pressed
- b18b1 boosted vs infinity g35
- Help, looking for del sol sizes!
- Strange battery and Check engine light problems
- 1999 Honda civic si vtec solenoid hardware size
- Anyone got a free haynes manual 1993 civic link?
- 97 Civic Hatch DX D16Y7 tranny motor mount
- Exhaust Question
- F2B H2B help
- Will tokico blues from an Ek fit on my eg
- Need help with Aluminum Radiator size of hoses...
- Spontaneous123's 92 Civic SI Build
- Cutting Skunk2 Springs
- '94 Civic DX brake lights do not work
- Adjusting headlights in 2000 Honda Civic Si
- 98 Civic with transmission issues
- What engine is this?
- Loosing Coolant/ No leaks
- 96 civic dx engine replacement
- Racing Harness
- wire harness color diagram
- has my transmission been swapped?
- '94 Civic DX Head Gasket Replacement Question
- Jdm climate control on Audm 2000 ek1
- 95 Honda Civic EX Steering Rack Rebuild Kit
- Need information about P1K manifold
- 1993 Honda Civic DX Overheating
- B16 RPM's are fine at idle but engine shakes and shudders occasionally
- easiest way to straighten out steering wheel?
- RYZILLA's 98 ex Build. Come correct.
- 97 Del Sol B16 swap tips/help?
- 2000 civic Si misfiring
- Ep3 steering wheel in ek
- gauges for d16z6 Del Sol
- Starting problems. Advice?
- 92 Honda civic taillights/corners not working
- Where can i find a book all about my car/how to fix everything
- b16 misfire at low rpm..need help
- 99 civic lx D16y7 swap to jdm D16A
- HELP!!!! 92 DX D16Z6 Check engine light always on but no CEL
- throttle body question
- 94 civic ex interior harness
- B18CR swap into 94 EG SI issues (please help)
- Does da function forms fit ek ?
- 1994del sol manual
- 96-00 Ashtray/Cig lighter add on help
- poor orange spark issue (all new)
- EM1 CTR Headlight City Light Question
- TPS Troubleshoot procedure? Question about verbage
- 99 civic ex auto trans problem, code: p0730
- d15z3 MA9 civic 5 wire o2 sensor wiring help
- Del Sol air dam
- 00 civic ex sunroof frame removal question
- 1.6L civic dizzy
- D series moroso oil pan help
- P08-6
- Coolant leak from under throttle body
- id jdm b16a2 intake manifold?
- tranny goes into 4th but wont accelerate
- d15b into 2000 civic lx what ecu can i use
- Rack and pinion question
- New Battery, New starter, still wont start.
- UNKNOWN FRONT LIP $5
- Spindle's balljoint replacement?
- What model?
- Pirelli 205/45r16 any experience guys?
- 98 hx overheating any help.....
- bride seats legit check?
- Custom Engine harness build: Help Decoding plugs
- Confirm which alternator?
- Cracked mounting point on block
- Please help me with a engine bay picture
- 93 hatch jdm p30 eld?
- 99 Civic SI. Factory OEM Alarm Problem. Won't Start.
- What is this, what does it do, and can i replace it?
- Leaking coolant under distributor
- Megan Racing Black Series Exhaust
- my type r cluster swap
- 96 Civic - do I have a vtec head?
- B16A dies while driving when i press the clutch
- 96 integra subframe into 96-00 civic hb
- I WANNT TO KEEP MY AC...HELP!!!
- Clutch pedal issue
- 98 CRX - what do I look out for?
- Removing 2nd O2 sensor WRT to limp mode
- raping integras..? parts for 95 EJ2
- 97 ex rpm fluctuation @ high rpms
- 98 Civic - P0420, stumble, and idle problems
- EM1 Wideband question, Help!
- 1993 DelSol Si failed emissions (epic NOX fail)
- So what's the secret on how to remove oil pump back plate screws?
- Best Replacement bushings.
- Complete Suspension for a 97 civic coupe
- d16y8 into 93 civic ex?
- CIVIC HATCHBACK 98 - changing gear and cigarette lights to led/blue bulb
- Rebuild. Engine squeal?? Help
- nut on inside of subframe broke off
- Guy gave me the wrong cluster or something?
- 00' Civic Only Starts With Jump
- Ej8 - D16 Jerking Problem?
- Wiring issues
- need help identifing cams in built gsr
- Drivers Door Knock noise on 98 EX Civic when braking and accelerating
- 1997 Honda Civic 1.6L rear passenger wheel issues
- b16a2 idle surging when hot
- Brake drums to disc conversion?
- vtec head swap?
- Salvage Title Brake and Light Inspection Question
- 97 EX Sedan has noise while turning
- cooling system questions
- powered rack and pinion removal
- civic 94 start and die 2or 3 times then starts fine
- Mini-me oil jet question
- Question for 93 EG6 center console
- Power Steering & Rack & Pinion ??
- Acura proportioning valve in my ex?
- Aeromotive FPR instal question
- Auto to manual swap question?
- random rough idle and kicking
- 95 Del Sol S ran rough, stalled and won't restart
- transmission issue?
- Best parts for my 2000 SIR ?
- shifting into 2nd problem...
- need help 95 civic lx-spark plug wire order
- Driverside Front Wheel 93 Civic si
- replacing heater hoses.
- Dash light turns off when it turn the headlight on
- dx/lx/ex dash/engine harness compatibility
- 92 civic rack & pinion question
- Code 41 on a Civic CX
- How to fit 70mm cat-back to swapped EK?
- Swapping out/in instrument cluster...
- Catalytic Converter
- 92 Honda civic mini me overheating problems!!!
- Honda Del Sol Dirt Car Need Transmission advice
- 96 Civic - P0705, P0135 and P0155
- Caliper slider pin bushing part number?
