View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Noob
- What type of springs
- difficulty in changing gear
- light weight flywheel
- 96-98 bumper on 99-00
- catch can
- fuel pump with only 6psi
- Changing Tranny Oil???
- video of my and my friend racing
- what motor is stock in 96-99 hatchback?
- O.K., turbo timer won't work with factory 99si keyless-HELP!!!!
- SI front...
- Best oil for vtec?
- Quick question...
- a new role model for all you del sel owners
- ex mani hx mani??
- my car gets no spark and no fuel injection firing
- Stock tach not working after swap
- carfax anyone??? please waiting on fax, about to buy eg
- Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
- Ok for REAL!> who makes a GOOD 99-00 civic sunroof filler kit?!
- What will I run in a 1/4 with this setup?
- what's the best suspension you has been on-------- post info here
- 99-00 si oem optional tape player?????
- High Idle
- LS/VTEC in 00 Si with B18C5
- Any Jdm clusters for 99-00 SI?
- Header Question
- Whats better rota slip streams or spoon sw388?
- is this a good deal?
- registering a rhd in oregon. is it hard?
- putting z6 intake mani on sohc zc
- what to do about my trans?
- what do you think looks better on a 99-00 SI?
- where to find?
- im a new meber why cant i set posts in diffrent forms like aperance/causmetics and more????
- ITR rear section
- [FAQ] D16Y7 / Y8 MINI-ME WRITE-UP.... WITH PICS (56k, maybe not)
- armrest in EG
- Custom Windshield Banner --> installation dilema -interesting topic please help-
- how much for a tranny rebuild
- where can i find del sol carbon fiber lips
- which brake lines do i use with ITR calipers going on an EK???
- how much whp would i get for a dyno
- Simple Green for car seat cleaner??
- Jdm Header and cat question
- Just got my anti theft device
- Need help selling my Integra.
- o2 sensor
- 95 gsr tranny in to b16
- Exhaust Manifold Gasket Q - Help
- b16. knocking. lose power. smoke form valve cover. help
- lines on the firewall???
- custom tweeter?
- GSR rear swaybar or Si rear swaybar on a 96+ civic hatch???
- JDM cluster installed no brightness adjustment???
- FS: FRONT BRAKE PADS - Cobalt GT-Sports, and OEM pads -
- '94 civic with Integ computer...check this out
- DC integ rear sway instal on EG coupe what do i need to do?
- SCAMMER ALLERT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
- Bright yellow lights?
- JDM Headlamp Conversion on 92-95 Civic??
- Interior design??
- compression test ?
- Will eibach 96-00 civic sportline springs fit my car?
- Is there a difference between Canadian and American Manufactured Hondas?????
- main relay question
- JDM del sol cluster.
- turbo b16b or spoon b16b
- gsr rear disc onto a ex couple of questions
- Possible Bad Headgasket
- update! battery/ altenator problem
- Rage Custom Alloy wheels - any info?
- Are these real Spoon Wheels?
- Another Diagnosis (SP)
- oil leak
- spark plug socket size
- ****I broke a valve cover bolt of inside the head on a d16z6****
- WIERD NOISES FROM ENGINE/EXHAUST! PLEASE HELP
- getting a new car, help me pick!
- does any 1 know how do to a POTS mod?
- Where to mount seatbelts?
- ...homemade rear strut bar...
- 5Zigen Pro Racer A-spec exhaust? power and sound
- Can anyone tell me how to sand and prime my car?.......
- Rear Disc Conversion on a 2001 Civic Ex ???????????
- 5 lug conversion...
- B20b question what can I do
- high flow cat.
- header for d15
- I have a d16y5 HX what should I do.
- IT WONT START
- Type R or LS Turbo in a CIVIC
- 98 gsr brakes ???
- d15b7 engine timing
- F20B into a Civic EX
- Header smoking and strange smell after install??
- IDLE HELP!!!!!!!!!!
- gsr wont rev past 7000
- How to: 11 inch brakes on 4 lug
- How difficult is it to replace head gasket?
- advice
- Help I have no opinion or ideas of my own, help me spned my money!!!
- Can I put a trailer hitch on my 96 civic?
- Mesh Grille?
- looking for a 1 piece coilover... need help
- what else would i need and would u buy this?
- What intake is this?
- D15B7 and D16A6 valve springs the same???
- the difference between 96-98 and 99-00 lips on Civic HB Ek's?
- BLOW OFF VALVES...???
- Possible dyno results
- Hatch owners!!!!!!!!!!!!!!!!!!!!
- b18b/b20b SHIT ANYTHING AND EVERYTHING
- quick Q's-->gauge install
- sohc horsepower gains.
- anyone know who is selling this?
- what would be a good camshaft/cam sprocket combo for a japanese sohc motor?
- How to fix my rims shine problem?
- TRADE: My Accord..*PICS*
- Where to buy 00 ctr 5 lug conversion with rims?
- Cleaning engine block
- Can some help me find a usdm gsr or typ r for my dieing 95 civic dx.
- Fiber Glass Vs. Carbon Fiber
- About to buy EG, lots of miles, need your help on motor sugg.
- Converting from y7 to y8 intake manifold I have a few questions.
- Thinking about buy a Civic Hybrid. anyone have one?
- cutting alt-c wire after swap charge problems?
- 96-98 climate control to 99-00 climate control
- help me someone QUICK!!!!!!
- What intake for 95 Ex with b18c swap?
- Quick question about oil consumption
- Any Power from a D15
- Turn siginal problems
- Here are some alarm install tricks and anti theft tricks to keep your car yours.....
- sus on a EG6
- Buddy Club vs JIC
- Is this a 96-98 or 99-00 headlamp?
- picking out an exuast
- list of JDM manufacturer web addresses
- overheating
- JDM ITR headlights on an eg
- tell me if i covered everything
- I have $600 to spend...
- need help!
- EK gauges in EG cluster???
- tein springs
- wiring harness fried
- dropzone camber kit.any good?
- 99 GSR into 92 EG Mount/Bracket Question *PICS*
- pics of my ek Sedan
- V-tech heads on D16
- carfax please! :)
- Making ITR calipers fit on 99 Civic Si knuckles
- People in FL JDM front clip
- itr rear sway bar question
- weird idle and stalling
- Car theft, we gotta stop it (mainly for nova but all posts welcomed
- Theres 6in of snow outside!!!
- BUY AN AUTOLOCK NOW!
- JDM cluster vs USDM cluster
- 16x7 wheel with a offset of +60 on a ek hatch??
- B16 AC bracket and alternator question. Please help
- HHELLPP!!!! Interior light fuse keeps blowing!!!???
- FS: WingsWest Body Kit 96 Civic 2dr
- Helpppppppppp:WTB: Fuse Box for 92-95 CX Hatch, Under the hood fuse box
- jdm shit CF rear spoiler for 97 hatch
- obd2 to obd1 conversion....now the car idles funny :(
- civic type r transmission identification
- Mini-me idle problem
- Anyone sell OEM parts..? like this... (pics inside)
- Changing valve springs and retainers(B18C)
- need new radiator support? help with spot welding
- SRR sway kit install
- little custom SI lights
- LS motor swap price question
- ITR head vs the B16 head.
- Spoon N1 rules....
- EG Si w/ a 2001 usdm typer r swap????
- Suspension parts for 98 coupe
- Almost Stolen Exhaust!
- OK to drive car 3 hours without a tranny mount?
- Thermostat write up.. for all you guys over heating.
- MAP/TPS swap over to GSR TB
- Any 99-00 EK's with mugen MF8's
- help civic b16
- lets see some 99-00 civic EK's
- B16a2 tranny to B16a JDM HYDRO Tranny????
- hid help
- BMW computer in civics
- vibrations going on and off from the car??
- carfax...help?
- werid KNOCKING noise
- Tires for my HX rims... please help!
- a/c fan rattling, some help please?
- Throwout Bearing making noise.......
- Used pistons - Hone the block or not?
- how many miles do you get per tank
- Need to borrow engine hoist!!
- 1/4 mile times
- Problem wit b20V in Eg6, dont start?? help!
- I have 97 civic ex coupe want to make a 5 speed what tranny can i get
- How much for ek9 power mirrors?
- Oil filter block
- What Cuases?
- just need some reassurance before i buy...
- Quick FPR question
- I need a rear sway bar for my delsol. I searched the classifieds. No luck.
- -------Stock spring reintall question
- Stock B16A2 V-AFC settings? (rough)
- Torque Mount Question
- Chasis
- park light dont work
- Remove Trunk release/gas lever....
- Piston to deck height? Please help..
- Where can you buy a race built auto transmission for an EK?
- Questions about a b18c swap. ECU, FUEL PUMP, CRANK PULLEY etc...
- SRS question???
- need help just put b18c in my hatch and header hits
- 1/4 mile time question?
- Need help with speakers on '98 civic coupe
- h22 es suspension. progress springs/coilovers or groundcontrol springs/coilovers?
- anyone ever ship a b-series swap??? Need to know approximate shipping weight
- HELP!!! My window is fu#@ed!!! And its COLD!!
- You running without a tach?????
- Cruise control for 97 Civic CX
- 94 civic ex cluster bulbs
- Del Sol w/ tein suspension?
- wrapping eg door panels
- can we get pics of ....
- AEM Fuel Rail Fitting Q
- Which Bushings do I buy
- Legend caliper brake swap?
- Roll bar ?
- Power Door locks and windows into EK?
- NOLOGY PDA DYNO
- Difference between fogs.
- Help "Club Honda Norway". Voting in Norway for best car maker!! We need your help...
- B16B Deck Height
- 5 Lug Conversion......?
- What compression would p29 pistons be in a D16Y7 motor?
- need help installing car alarm Car Pro CPX2600
- Dyno testing site??
- 92-95 and 96-00 rear control arms
- survey on a motor ... what a jdm gsr in my 98 ek .... what are your thoughts
- mini me questions
- anyone using an Autopage Car Pro CPX2600 car alarm???
- please helllllllllp with wiring
- fuel injector cleaning any good??
- my first swap - problems
