View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Comptech ICE BOX AND JRSC?????? 99-00 si
- [FAQ] Engine install on a 92-95 civic 5 speed
- OBD2B to OBD1 o2 sensor wiring
- HELP!!! H22 swap into an EG hatch
- '99 Civic: Squeaks Every Time I Depress The Clutch...
- Climate Control Problem! (Directions Not Working)
- Best adjustable shock for EK?
- i need some pics
- Fuse for instrument cluster keeps blowing, short?
- Turbo install
- winterizing blown motor car!
- new owner of an eg coupe.... couple ?'s
- who ACTUALLY has a turboed hx d16y5?
- tightenning throttle cable
- pics of zc d15
- idle problem
- Beaks....
- Does This Swap??? -Disc Conversion-
- SoCal: Need a 99-00 SI for R&D
- Spool valve filter AKA VTEC solenoid!!
- emissions info
- Get some work done in Hialeah,FL
- EK lip on EG?
- NSX rotors with caliper upgrade?
- Weighed the Sol today...
- Problem #2 On Friends 2nd Gen Jdm B16 In Hatch...
- what kinda lugnuts should I get?
- d-series tranny question
- Positive or Negative
- type r head
- Turn signals come on with parking lights HELP!!!!
- b20 vtec set up whats needed??????
- apex-i n1?
- Need help fast
- DIY: Lower Tie Brace beam installation on a 96-00 Civic ANY model
- nice expperemint
- 97 tach cluster
- whats up:-\ (revs go up and down)
- passing emissions help with B18B all motor
- Can not Find Rear Conversion???
- Spoon copy mirrors for eg, anyone know the weight?
- which cam is better gsr, or type r?
- Shop Manual For 2003 Civic
- maintinence reQuired light
- SOHC Turbo Question?
- Anti-Freeze goes here or there?
- 2003 Civic Brake Clips????
- Here's the Wheel Bearing part #'s for 99-00 Civic, 94-01 Integra
- b20vtec build up
- thinking about selling the integra should i get a ek hatch???
- 15x7 wheel offsets
- TEST ONLY smog check with Vafc and cam gear
- '96 Honda Civic
- CX no Clock
- 94 civic cx with 96 or up cluster
- SOHC cam
- 5th Gen Civic Noob here
- Rear disk conversion a must?
- NEED TRANSMISSION HELP
- Very low intermittent wining sound from alternator
- hydrolock is scary shit
- tire question
- 99 EX HEAD
- powerwindow conversion question
- 700whp Coupe - B20VTEC
- car won't start help!
- NSX caliper upgrade new found info!!!!!
- jdm itr header touching b16 oil pan
- hf adapter plate please help!!!!!
- Door lock switch question
- Parts for my 2001 civic ex! HElp!!!
- integra dash hows yours fit?
- BIG PROBLEM...wont rev past 2500rpms?
- So i dynoed my 94 civic today....
- Can I used afermarket EK LCA on my EG ?
- del sol fuse panel pic/diagram???
- http://www.webspawner.com/users/hondactr/index.html
- Has anyone ever herd of this!!!!
- looking for del sol power steering lines
- d16z6 and d16y8 harness question - -
- EK side skirts on a EG?????
- Help with my sensors PLEASE...
- Failed Smog again High NOx
- Cant get axle lugs off
- h22 swap missing at part throttle eg
- [FAQ] How-To: Install Omni (and other) Coilover Sleeves. Part 1 of 2.
- Original Jdm Motor?
- mini me question
- what i need to do to put a civic eg front end on my del sol
- nitrous question
- DIY power steering and abs
- Installing my Alarm
- Anyone know where I can get a momo steering wheel from brand new.............
- 96-98 size light housing as 99-00?
- best swap?
- no fuel...please help
- How much does an OEM radiator cost for a 93 Si hatch?
- Mysterious Hose.... (with vacum???)
- Dashtrim Removal
- LOOKING FOR DOORS FOR 1999 CIVC EX
- overheating
- Clarification of ITR cams VS. CTR Cams
- will engine paint work
- H22 SWAP QUESTIONS
- engine plans
- ITR/CTR Crank Pulley...Anybody Know Specs on this and how it performs?
- wide body kits for civics
- how long did it take to install your tach?
- 93 civic brake ???
- Wheel bearing compatibility, Civic/ Integra????
- Civic Sedan and Coupe Headlights the same?
- 11" two piece rotors?
- Dyno/Time Slip of my EG LS powered Hatch
- civic engine swap-300zx
- sirII engine swap
- clutch problem,plz advise
- AXLE
- just bought a black 93 CX hatch for $150 CDN...wooo hooo
- Are d-series map sensors interchangeable?
- suspension techniques sway bar
- NEED HELP ASAP 92 VX never starts in the rain!!! NEED HELP ASAP SUPPOSED TO PICK UP A DATE!!!
- Help with Physics project (60mph - 0mph stopping distance)
- anyone selling SI or GSR wheels?
- LOOKING FOR AN OVERDRIVE PULLEY
- ****THEFT ALERT: My Ferio is Missing DFW Texas****
- tranny leaking at passenger side shaft entry
- high idle problem
- d18y8....my buddy has question w/new car
- Shop Recommendation for NC
- Installing new wiper motor
- any b series ek's using a b series shortshifter?
- gsr wheel offset
- B16a2 0verhaul!!!!
- Fiberglass dash
- Quick AEM short ram Dimension Question.
- b18b OBD2 into my OBD1 car
- power steering to manaul civic cx swap, WHAT BUSHING!!!
- Civic SI Interior autometer pillar color pod question
- Check Engine Light NO Codes Bogging At 4K
- i was told i can't do this but... [LCA swap]
- E-brake
- radiator fan
- V-AFC II BASE MAP
- jdm parts for the del sol
- B18c Custom Header Exhaust Install, need help with the flange
- Slave Cylinder out??? Please help
- 00 civic fender?
- Engine Swap
- ek civic door handle removal
- b16 timing belt problem
- OBX fuel rail fittings?
- enjo mounts or placing mounts???
- zc dohc (non v-tec) swap in 93 coupe :)... need help though!!!!!!!!!!!
- ek to integra booster and m/c
- grinding/chatter
- Gear Grindage??
- part number of the ek9 air bag tray???
- SRS Light after crash-02 DX
- B16 QUESTION???
- my tire has a tumor
- Good price for an SI?
- Eibach Pro-kits or Neuspeed race springs?
- major motor failure?
- D16Z5 Header on D16Z6
- type r lower control arms
- Low Budget Y7 Build
- Noise from Distributor ---- D16z6
- will a ls 1995 fuel rail fit on a b16a2 jdm ?
- Damage to Floor
- 3pt strut weights
- Why no 99-00 Si Forum?
- Whos Got the Lightest Street Legal EG?
- indentifying/locating console item
- DOES MY CAR HAVE V-TECH ??
- Good DIY mechanic on Long Island? (suffolk county near Stony Brook...need ball joints and timing bel
- D16Y8 or D16Z6, help me out.
- Is 92-95 sedan hood different size?
- 92 cx with Gsr Swap....with stock exhaust???????
- Omnipower LCA
- Adding a crank fluxuation sensor onto a OBD1 block
- Ek9 Jacking Points
- d15b7 head to a d16a good or bad?
- Is there a solvent to remove the corrosion off the battery?
- k20 into 97 honda civic?
- how do people sell carbon for so cheap
- HELP obd2 code p0420 catalytic effeciency
- clutch help
- How do I break in new pads/rotors?
- Need help asap! stereo wiring! ASAP
- what do you guys think of these seats??
- spoon vtec controller for a EG sir2 do they run good?
- door panels
- Speedtech kit
- si or hatch??
- New Member loves the EK
- remote wire for egs
- 1993 Del Sol - S Owners Manual
- Car still overheating
- Aftermarket Tach
- need help with vss.
- RHD hatches?
- speed tech kit
- NOS
- JUMPIN CODE ???? where is the plug located???
- 2nd Gen Jdm B16a Problem In Friends Hatch....
- Taking a deck out of a EG! need help asap
- Need help with my speed sensor ASAP.
- Speedometer/odometer/VSS question.
- Manual steering rack in a Del sol
- speedo wont keep up with car
- MSD 6AL Instalation
- ACT Stage 2 Clutch on 1999 Honda Civic EX
- NOVA...teg in civic wirinig, got cash to anyone thats interested in doing it for me..
- More Tranny Symptoms...
- Throttle body
- b18c1 engine bog
- exhaust question on my EG hatch
- Intake/Exhaust Options, D16z6, California, Performance, Inexpensive
- ecu problem?
- can you identify this as a GSR trans? (pics)
- 89 Crx si or 99 Civic Ex?
- How to make my fiberglass bumper stronger
- Spoon axle back on eg
- 2nd Gen B16a Distributor Wire Order??
- O2 sensor help
- QUESTION about o2 sensor
- 1994 civic VX
- Wiring Diagram for Subs in EG's
- HOW YOU LIKE MY CIVIC SI AND MY HOMMIES CRX
- d-series transmission bolt locations?
- b16 mounts 2000 civic
- gsr master/booster cylinder on 92 hatch.
- b16 mounts
- DIY for b16a valve adjustment?
- Gauge Cluster light bulb question
- Will a 99-00 Si Spoiler fit my 98?
- horn not working...
- Simple tools to get my old pioneer deck out?
- would DOHC vtec delsol exhaust fit on a civic hb???
- I searched... cant find what i need (b20 intermediate shaft)
- are EG and EK hatch cat back exhaust interchangable?
- fmu please help!!!!!!!!!
- 96-00 Hatch, What is all needed to keep the P/S and A/C when installing A b-series
- mcculloch HID problem
- civics interchangeable parts
- 96-98 jdm ek yellow foglights
- lights out but voltage present (bulbs good)
- Jdm gauge cluster problems?
- rev speed meter ques
- civic 96-98 coverted to 99-00 Si
