View Full Version : Honda Civic / Del Sol (1992 - 2000)
- d16y7 timing belt off -- but which way??
- Random slow start 95 civic DX automatic
- 92 civic dx hb, was there ever an arm rest for the center?
- D16 or B20?
- windshield wipers won't work - blown fuse
- 1999 Stock Civic Overheat Fluctuations....
- 92 Civic DX HB convert from blue interior to black
- 2000 SIR -- No power in Vtec + weird noise.
- 92 4door ignition problem
- Having some issues with my mechanical timing
- 1996 Civic EX - Headlights dull, replace bulb or whole unit?
- teg shifter in ek
- 2000 civic foglight question
- d15b7 into 96 hx - stutters andf hesitates with P06 ECU
- 92 4 door auto - ignition problem
- D16 head gasket help !!?
- mike's 94_eg project
- 2000 civic si driver side window wont work
- Any issues with cutting AC belt?
- 95 civic d16z6 turbo...smoking exhaust HELP!
- Can the Honda 15/16 master cylinder work with a single diaphragm booster
- 97 DX radiator hose removal tips, anyone?!
- Poor man Type R, running extremely rich.
- ek mount question
- Aligment question
- low fuel pressure...possible causes?
- 97 civic EX stock with CAI
- B16 - surging idle issues
- Solid Motor Mounts?
- d15b7 no spark/weak spark
- Vtec solenoid leaking
- tokico spring performace affected after being cut?
- Cel 14 at random times.
- 96 civic getting bad mileage, please help.
- eg hatch vandalized.. windows broken
- 96 Civic -- New map sensor, now running rich?
- d16y8 to d16y5
- 98 civic is misfiring on all 4 cylinders
- what is vtec spool?
- Stripped oil pan drain threads D16Y8
- 99 Civic DX B16A2 Swap -- Power Steering Rack Question
- How convert a manual P07 ecu to auto?
- rpm's won't drop with clutch engaged?
- 1995 civic Lx -- Distributor Mystery?
- 30 mpg to 20 mpg Drop In Gas Mileage for 00 Civic
- need ls tranny help hydro to cable swap
- 98 floor harness and gas tank question
- Does a 97 Civic LX 5-speed have an Idle Control Sensor?
- 97 hatch wire harness
- 99 Civic EX - need input on air intake and exhaust system upgrades
- 94 Del Sol VTEC Build
- helms
- 97 EX/Lowering Springs
- What headlights to get for my HID's
- 2000 EJ8 Spoiler Plugs
- Del Sol dies while driving
- 98 Civic EX - Popping sound when cornering after hitting curb
- b series del sol build
- Transmission Casing removal?
- dc2 srs momo steering fit on an ek4
- Random blue sensor with no plug on back of HX block?
- Anyone ever done a zc swap in an eg sedan?
- 97 Civic LX -- Which Headlights wires activate high beam
- 00 civic DX - temp gauge affected by left blinker or high beams
- e-brake light coming on when car is running
- Harmonic Balancer - what will fit on a 92 Civic LX?
- 94 civic w OBD2 98 d16y5 swap - questions about axles, O2 sensors, and motor mounts
- Ordering parts from honda?? quantity
- Stock 92 Civic dx -- would aem or injen air intake improve power?
- B16a temp sensor broke off
- jumped tooth on d15b?
- How do I make my wife's 98 Civic LX automatic faster?
- 00 Civic Si Main Relay Clicking but starts
- B18A swap in Del Sol, trying to iron out some electronics bugs
- Need help putting together a high gas mileage manual Civic with performance discarded
- 94 honda civic Started drove 50 feet stalled as i drove in 1st wont start now
- Replacing steering rack on EG, reuse tie rod clip..??
- 99-00 SI cluster in a EG
- B18B1 swap hatch, idle & acceleration problems.
- Spoon B16B ??
- 97 hatch shell - How convert d16z6 to OBD II? Can 92-95 si tranny be used?
- Noises - Howling when braking and popping when accelerating
- Car still moves when I press the brake pedal
- need a good camber kit for 92 civic
- Wheel aligment and aftermarket coilovers -- steering wheel not straight
- 2000 Honda Civic Chugging (Codes: P0300, P1399, P0170)
- Fuel pump for B18c
- 94 Civic sedan -- Should I stay sohc or go dohc?
- 1998 Civic LX - Water Pump Broke - Timing Belt Gonzo
- 95 Civic VX gas mileage - Is 43.3 mpg good or bad?
- 96-00 Honda Civic Manual
- 2000 civic Clutch question
- 96 EK Hatch o2 sensor problem
- What's all the fluids
- Which petrol is good for a 92 Civic carb?-AUSTRALIA
- Engine bog 94 Civic D15B7
- 92-95 interior fuel pump cover leaks fumes ???
- dashboard light tips
- 97 Radiator support on 99-00 front end?
- Softer Springs for Coilovers?
- Need help! Plz & Thx
- dohc vtec cam cap possitions
- 92 Civic Hatch DX D15b7 wiring harness compatibility?
- Upgrading Grounding wires - can you suggest data gathering to compare before/after?
- Throttlebotem1 J swap build thread
- What is the difference between replacing distributor internals, and replacing it?
- 96 Civic EX Window & Sunroof stuck open
- Need input on modifying my stock intake
- Installing a tow bar on a Civic 1993 sedan that has never had one?
- Carburetor problem!
- *DIY* How To: Sand/Prep/Paint 99-00 EM1 Si Grill
- Default OBD2a HX O2 Sensor -TO- OBD2a 4 Wire O2 - Assistance Needed
- Valvoline 5W30 Max-Life - is it synthetic blend?
- Outer tie rods -- Moog vs Napa MCR brand????
- F22 in eg hatch plz help
- Looking for a new exhaust
- j35a8 in my eg advice
- Any good online places to buy honda parts?
- Tuned p28 for boost on d15b7?
- Can Anyone Determine What This Sound Is (Video)
- 00 civic - lost power, smelled something burning, engine had no oil
- 97 DX CEL+coolant issue...
- re RPM tach issues.
- New 95 civic owner - no oil spilled out and oil filter was dry when replaced
- passing smog with JDM D15B
- 94 del sol limp mode bad ecu?
- 2000 civic overheating
- please help! 2000 civic ex alternator problems
- Need information about 97 Civic SI clone 97 from Miami
- 3" mandrel catback
- b18b1 swap got problems need help
- 93 cx throwout bearing
- DX hatch loses power on the freeway and dies. Help please!
- d16z6 in to 96 cx hatch
- 1998 Civic DX - no spark problem, need help
- Will it work - eg hatch front bumper on an eg coupe??!!
- eg hatch with h23 prob...with axles......help
- No turn signals but hazards work
- civic wont go into gear just revs.
- EG B18C swap, few things wrong. Pics***
- Bucking and a P0505
- Mysterious Stall and Battery/Oil Light pops on outta no where!!
- distributor b18c jdm and usdm si/d16y8 harness
- HID Bulb Question - one bulb doesn't work after a rain
- p2E ecu???? With a d16y8..
- Brake lights won't turn off
- Convert OBD1 motor to a OBD2
- EM1 SI Gauge Cluster ?????
- Identifying OEM panels?
- D16 -- I put the pistons in backwards
- AEM Cam gears
- 95 civic dizzy problem
- 95 Del Sol Clutch problem
- Help :( Guages and blinkers won't work and car won't shift out of park.
- Help with fender/door on 96 ek
- 98 civic ex - idle problem when battery light turns on
- Non-vtec motor in VTEC civic, cant pass inspection?!?!
- 96-98 Civic Climate Control - what bulbs fit???
- 94 Civic EX won't start
- idle issue help
- 2000 civic Idle Problems
- 1992 Honda Civic DX Hatch wiring problems and idle/power issues
- 98 Civic - surging idle and CEL codes 7, 14, 41, and 65
- Charcoel Canister Delete
- EM1 - which header would have the most gains?
- Does a 94 lx window regulator fit in a 94 ex? HELP!>!>!>!>!>!
- Honda Part # Request
- Using Blue RTV on the TB- Will it hurt anything?
- k24 or b18c?
- Gauge lights dimming when pressing the gas?
- H22A EG Hatch {Hasport Mounts}
- B18C1 Into 00 EM1
- 95 Civic Ex...Project Build 450 whp Goal
- just did an auto to maual swap need help
- Battery won't stay charged , alternator is good also. 00' civic si
- Has anyone found EG sideskirt clips in "bulk"?
- lift up gear knob on a standard reverse gear box ?
- 94 civic si - brake lights not working!
- 93 Civic Engine Swap Questions
- Type r swap in eg???
- Windshield wiper motor
- unsprung 6puck in a killa
- Headlight Question?
- HELP!! AC PROBLEM - high side ok, low side has no pressure
- What is this piece
- brake light recently came on and stays on, need help
- em1 ac fan help. how does fan attach to the motor?
- Will EG 4 door front & rear seats fit in EF Hatch??
- Skunk2 Coilover sleeves?
- EK---Steering wheel clicks and squeeks when turning. Clock spring?
- EJ1 B18C TYPE R SWAP?
- Is it ok to switch from a D15b7 to a D15b2 for a 1994 Civic DX?
- weird stuff goin on wit my a/c compressor
- Aftermarket Lip install
- Do I need a new computer if I am going from a Non-Vtec to a Vtec?
- help with my mini me swap!
- Oil Leak
- civic question
- Gsr eg rev problem??? Please help
- fuel pressure gauge
- Radio and Dome light doesn't work
- installing new compressor and drive belts
- Honda Civic lx 98 radiator fan not working
- B18a1 swap headaches in a 1993 Civic EX coupe!
- 1997 Civic Hx domelight help
- 1995 Honda Civic Dx Coupe Engine Swap HELP
- 98 Civic EX coupe power window problems
- Where purchase D2 coilovers for 97 Civic?
- OEM seats that are interchangable for EK hatch
- d16y7 parts manifold on d15b?
- 99 EM1 tips and Transmission problems
- DIZZY HOOK UP MANUALLY
- Dropping D15 into D16 shell - mounts don't match
- i need mini me swap help d15b7 block d16z6 vtec head setup
- gouged LCA while pressing out bushing *PICS*
- New to imports, came from off-road - What engine is in a 98 Civic EX?
- full coilover suggestions... tein, skunk 2, function & form, megan... ect.
- transmission rebuild?
- Just bought a new hatch - no power and high surging idle
- Shifter Bushing? - ej8
- 94 civic dx: Problem idling in drive and reverse
- 92 hatch si - my fuel gauge reads incorrectly
- B18B1 swap bolts
- B18 Swap Questions
- Honda Civic ZC twincam
- 97 HX Need a new Cat but dont want to spend the $ quietest header/exhaust combo?
- EG B&M Shifter Probs...
- 310cc Injectors fitment on my 99 ex
- Changing the A/C, P/S and Alternator belt tomorrow. Need some tips
- weather proofing
- 1992 DX hatch sway bar mounting hardware
- Power folding mirrors question
- 95 dx autocross coupe build
- non d16 on d15 block.. will it fit with other stuff?
- 92-95 4dr oem floor mat
- D16y7 high idle problem
- 94 civic JDM d15b shuts off while driving
- b20 swap eg doesnt crank over
- Went over crack in pavement and car now pulls to the right
- Del Sol Front Lip Question...
- EJ6 with GSR Throttle body plate will not close, rpms stay high.
- car's first CEL: came on in a pull, went away after 10 miles and restart
- D16Z6/D15B2 MinimeTiming Problem
- JDM b16 swap into '00 dx
- Many CEL codes and fuse 15 keeps blowing/Suggestions for 98 civic hatch cx
- How much to install Catalytic converter & O2 sensor
- coolant hose issue
- S4c trans question
- EK Hatchback Tail Light pigtail harness help!!!
- Can I swap a Si tranny and d15b7 block/d16z6 head into my Del Sol?
