View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Parts for sale Y8 series parts
- Stripping interior question
- question?
- What is that thingy majiggy called?
- motor swap
- Hi-Performance Axles
- Integra Cluster -> 5th Gen Civic
- Car won't start, please help!!
- H&R Eg Civic springs, Which ones are front?
- EG ? - anyone ever move the brake light to the rear window?
- question for all u californian street racers
- what suspension set-ups do you guys have
- I just need a title, and some windows!!!
- vtec not hitting...
- 5g & 6g hatch ?
- clutch problems
- Whats MY redline?
- Turbos and Automatic transmissions
- fuse to pull when doing compression test
- MAXIM - the vis lip
- Anybody know how many lbs. to torque the headbolts for a 1.6 Sohc
- pic request (already searched)
- Sparco Evo?
- HID people i need your help...
- cant post anywhere else
- Air/Fuel Ration quage wiring
- What armrests will fit in a 95 civic ex?
- Civic with H22 swap, Axles for sale....
- GSR dash in EG???
- well i know it's a stupid questiton to you guys but.....
- will a 94 ex tranny fir a 99 ex?
- We need everyones help!!!!!!!!!!
- Which ECU for a b16a2 in a '93 si?
- My b18c1 swap feels a little sluggish in first and second gear!
- Big problems please help
- anyone playing midnight challenge?
- Which Cam for B16A2
- Tell me somthing.
- pic post - steering wheels
- Replacing mirrors
- how do u fix a cracked front kit???
- NY/NJ/CT Tristate H-T Meet
- NEED HELP: Motor burning MAJOR oil!
- something about civics
- brake upgrade
- Why Is My Chassis Squeaking?
- how to fix my gas guage?
- break light
- nitrous oxide experts help
- What is the difference between these CAI's??
- Anyone need a factory 92-95 hatch wing (fs)
- V-AFC controller I purchased this today.
- In need of answers
- Coilover question
- Installed a new thermostat! Needle won't stay out of the RED / HOT!
- Cant decide what to name my CRV block? help..
- help on swap.....please..!!!!!!
- Just wanted to wish everyone Happy Holidays!!
- in need of help!
- $5,000 to blow on the Eg (hatch)! Ideas please!
- replica carbing bar ?
- need help removing nut
- Philly Xmas Meet, Arnolds Carts part 2
- Where to get Specialty Products camber kits
- d16y8 in a 94 civic
- Skunk 2 Intake Manifold
- shift light???
- 2nd gears popping out!
- new best 1/8 mile time. 1994 Si w/b18c
- Dome height same as Piston-to-Deck Height??
- pros and cons of ITR 5 lug into a ek?
- obd1 LS 92-95 into obd1 civic 92-95
- 94 d16z6 $450 good price?
- Koni Reds Vs. KYB AGXs
- si rotors
- Today's projects (not too bad 56k should be ok)
- need D series engine!
- Hatch
- Brake upgrade
- Integra console
- Cam and Intake Manifold swap.
- R springs on EK
- any good shops in so cal?
- Motor mounts for Civics
- JDM VTi D-series LSD (S20) and SRR final Drive (not compatiable)
- coilovers
- help me!! is this real Mugen???
- HELP... wierd idle..
- How to identify d16z6 distributor?
- info/pictures request: EK apexN1
- HELP!! Ontario government is trying to stop us.......
- honda lsd vs. phantom grip
- spoon weave hoods
- shifter bushings
- Engine Rebuild
- Mini-me: 91 Si on DX w/ p28
- D-series to B-series in your EG, throttle cable...
- Has anyone ever replaced axles on their 5g civic? Need tips!
- check this out
- Back tire wobble...?? help please
- wheels on 99si
- howdy all newbie here (pics)
- Grinding Clutch :(
- bore diameter
- need some pointers with 98 dx please
- 94-01 teg seats in 5th gen hatch
- install this in my civic
- How do you change out trunk springs?
- videoo new carrr
- brake pad question
- More Spy Shots of Project EK!!!! Dial up Watch the F#ck Out
- I have a GSR rear sway bar- what else do I need to install on a 95 Coupe?
- what ecu for a ls swap in an eg hatch?
- California Ref Q's
- jdm mirrors.....not fully funtional.....
- jdm header fitment
- Civic hatch B20VTEC turbo
- does a 99-00 rear bumper, fit on to a 96-98 civic coupe?
- installing new rotors
- Problems with the idle on a B16
- 99-00 civic si guage cluster ?s
- newbie question
- Reupholstering seats.. or get new ones
- Timing belt question??? need help
- Broken axel
- new
- Just talked to Osaka!
- CA Emssions - Would my VX hybrid be legal?
- Throw out bearing
- 99-00 Bumper Compatible w/97 Civic?
- need help
- shopping for hybrid a few questions...
- ferio seats?
- traction ?
- CTR civic COUPE??? Is it true?
- 95 si brakes
- OH NO!!!!
- Blizzak MZ-02's... down to wear bars after 3 weeks?
- What's needed for a EK front end conversion on a EG hatch?
- Heater problem
- my shocks are dead???
- quick question.. EK/eg/dc2 Rear LCA compatibility
- auto tranny w/ headers and cat= tranny failure???
- where can i get....
- Who's got a full access pass to overboost.com?
- What models carry the 1" master cylinder/booster?
- wh00t, gsr brakes
- UPS was good to me today
- Honda is trying to own me!!!!
- What is this?
- Camber/Alignment Question.
- DC Area
- Type R Carpet
- what act clutch ?
- crazy swap for a civic!!!!
- Help on where to buy a rebuild kit/place to rebuild a Mitsubishi TD04 turbo
- learn me bout brakes
- anyone around the Long Beach area willing to help me with my EG...
- Got A Question Rim Size
- So I'm going from a Stock 2000 DX to...
- What's first?
- I'm looking for a good SoCal junkyard?????
- how much would you pay?
- 95 GSR cluster in 93 hb???
- Easiest Brake Master Cylinder Upgrade Yet for 1992-1995 Civics...
- CRX SI seats into an EG ???
- Mini Me Swap
- Anyway to adjust uneven trunk gaps around bumper?
- More pics of my blinging motor.
- egt probe install but what does these temp mean?!!!
- Wrecked EK worries!!
- Where to buy ctr lip?
- groupbuycenter
- Sway Bar And Shocks
- adding power steering?
- *PiX* My Lip finally came in
- TL HID's in my hatch?
- 99 civic sedan tail lights fit 96 sedan
- antilock brakes, can it be done?
- what intakes are u guys running? and y ?
- Do all JDM Integras have 36 mm axles?
- jdm sir del sol
- anybody used ericks racing ecu upgrades on their del sol or civic?
- Would you buy this for your Civic 4dr or 2dr?
- cluster & climate control bulb sizes?
- Do you guys like this 99-00 LIP??
- 97 civic door moldings
- B17 head
- Nitrous Question?
- Looking at this engine. What do you think?
- h22 in a 92hatch...
- egr
- Can someone gimme an idea of settings for VAFC for b16a2 USDM
- Thanks to tonyxcom made public...
- easy question
- EK rear discs....anyone
- wheight reductions
- NVA...Winchester...builden up for war!
- HELP! Unable to Install integra Brake baster on a 92 Civic... counterclock wise booster
- 99 civic si headlights
- has anyone ever had?
- Will a 99 si door fit a 2 door hx???
- Spoiler Removal
- Gutted Coupe?
- a bit OT: JGTC on Speedchannel
- del sol siting in henderson
- What intercooler size is best for EG6 hatch?
- are valves and springs interchangeable from an older head to a newer head?
- quick tranny question (94 d16z6)
- Can you Identify
- Complete D16Z6 swap pricing....
- what about kyb agx shocks
- some stuff for the EG guys... xmas clearance lol...
- V-AFC Pricing
- Place Racing number?
- looking for a d16 head (who to buy from?)
- Is it worth putting in power windows, locks, steering?
- Fight with UPS Guys
- How much does the B18C Clutchmasters flywheel weigh?
- are short shifters worth getting?
- How much to get your lip painted?
- UPS Fairy paid me a visit*
- b16b swap
- can someone run a block # for me????
- The EG forum has gone through the Shizzolator y0!
- honda oem question: gauge clusters
- Question about V-afc hack.....
- Carbon fiber hoods
- ctr folding mirrors......
- b16a or b18b
- nsx oil filter
- Which copper ngk plugs for 99-00 si motor(b16a2)
- something is wrong withmy baby please help me!!!
- flushing engine for oil change???
- Intermitant wipers
- Hook a brotha up II
- hey guys what is the stock idle for a d16z6?
- Hook a brother up...
- WTB: duckbill rear wing for EG
- Ground Control + new shocks/struts
- DC JDM 4-1
- GSr dash in a EK?
- My winter beater............
- what type Paint?
- Changing bulbs in projectors
- civic gx pistons
- Other types of racing?
- VIS carbon fiber spoon wing on ebay for 200 good deal!
- IACV applications.
- EK(96-2000) coupe exhaust on a EJ(92-95) coupe?
