View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Swapping a B18b1 into a 97 Civic ex
- Idle problem need help asap
- Rebuilt block - looking for proper start up procedure
- civic si/em1
- WHATS A D15B7 CHANGEOVER WORTH? :D
- k swap???
- B16A2 - Thermostat & Solenoid - torque?
- dsm injectors! ?
- Is my starter dying or???
- Anyone know how to install A/C Receiver Dryer?!
- Buying 95 civic EX with some upgrades
- anti freeze Leak
- Cam question
- gsr 6500 rpm redline and no vtec?
- CAT Conv., Pre & Post O2 Sensors ('98 Civic)
- rack and pinion
- Auto B16 Swap in an EG/EK?
- how do I tell if a used catalytic is good or bad?
- changing fuel filter issue
- ecu change help
- friend's 92 civic won't start - no spark or fuel
- 94 civic dx starting issue
- At Speed RPM issue
- Eg subframe in ek?
- problem witn my A/C ( honda civic Si 92 )
- 1996 Civic HO2S Problem
- 92 Civic CX/JDM B16 - fuel injectors not working (solved)
- Aftermarket replacement cat, o2 bung placement question...
- What kind of pistons will fit on pr3 rods
- Car keeps draining my battery!!
- what 2 do now?
- Anti-Theft Failures
- Vacuum line routing
- b16a crank but wont start!
- Bent Hub ?
- Ls non vtec question!
- Whats with all the blown head gaskets as of late?
- 96 ex hesitating on bumps.
- Multiple Misfires
- water leak
- D16y8 block with a d16z6 head.. timing issues.
- FAILED Smog-Catalytic Converter
- Coolant flush by a shop to remove air
- what would make my b20v choke and bog on rev's
- dont like what i see with my compression test - 120,120,120,120
- Good aftermarket taillight company?
- 93 dx bad idle please help changed the iacv
- Cant get doors to unlock?! Stuck actuators? Please help.
- b16a del sol cranks but wont turn over. HELP!!!
- can ground control top hat, fit on tein basic for eg
- Civic LX 97-Drove through water, now jolting when accelerating
- Good deal or no? what to look for? b16a2
- Idling Problems B16a
- Help Del Sol tranny leak (pics inside)
- VTEC PROBLEM !!!HELP!!!
- Check Engine Lights after Installing ALternator
- Rear Main
- 99 Civic SI - Noise when stopping - rattle
- valve cover paint
- K20 or B18
- 93 dx sedan new exhaust
- gauge cluster
- 97 civic hx turbo swap
- 1995 LX Electric Door Locks No Longer Working
- B16 del Sol started fine and died after sitting for awhile, fuel issue?
- Need new axles. Would these fit?
- How to adjust/replace trunk latch
- Fuccckkk my life.
- Check Engine light for 02 Sensor
- Civic lx 97 Dash Lights (Climate Control)
- Cooling fan doesnt turn on.........
- will 99+ civic coupe exhaust fit 94 civic coupe?
- car overheats after driving for 15-20min
- help please brake fitment
- Need Help Domani Front clip
- OBD1 B series Vtec distributor compatible on D16?
- Quick Question JDM D15b
- 1993 Honda Del Sol "S" Swappable Underdash Wire Harness?
- Honda Civic Ferio - What bumpers fit?
- Oil Light flickering, Car Cutting ofF, ETC.
- Idle, stutter, and weird smell problem
- got a problem have no idea (help)
- Power doors into Civic hb cx
- convert power windows to manual windows?
- Need some help please, clutch inspection cover bolt size
- refreshing suspension
- My compressor has a leak - How do I fix it?
- Is the catalytic converter really needed?
- d16z6 vitara turbo build help
- 95 Civic -- low gas mileage problem even after a tune up
- ticking noise
- EK motor question?
- Aerodynamic Question???
- Surging idle and coolant from exhaust
- passenger tire shakes
- why did no cat just finally trip CEL?
- Turning my Civic into a race car
- sputtering, hesitation z6
- Rev problems after manifold swap
- Wheel bearing went out
- 95 dx hatch brake caliper upgrade what master cylinder?
- 93 Civic revs from 1100-2100 rpm up/down constantly
- Can a 98 CD player play burnt CDs?
- dissapearing water?? no visible leaks
- Desperate cabin harness compatability help!
- blower motor squirrel cage
- 96 ek civic d16y8 reverse lights will not work
- help locating parts for my 00 rhd 4dr civic build
- 93 civic DX planning 96 gsr swap - which ecu?
- B16 into EG
- A/c Checklist
- 99-00 em1/ctr lip mounting hardware
- New Distributor Or TDC Sensor
- Bad Idle-Sporadic Idle in park and while in gear stopped.
- 94 Civic EX Noise
- Proper D16Z6 Timing/ Idle Adj Procedures
- Another Security Feature to Think About
- ls/vtec obd2 ek wit obd1 ecu n jumper givin weird codes
- finished y7y8 minime, runs good but P0505 came on
- odd knocking!?!?!?!
- S2000 springs on civic/integra
- 00' EK Gauges Not Lighting Up
- Can Torn Trailing Arm Bushings *Prevent* Proper Alignment?
- b18b1 ls vtec has an idle problem!!
- Need help with ls vtec swap into a civic ex please.
- Eg6 front lip
- Trouble Shooting help Misfiring D16z6
- knock sensor
- I can no longer say anything bad about Autozone
- p0420 code
- d16z6 transmission and axle question
- 1996 del sol engine swap
- b20v intake manifold bracket fitment
- DelSol - Removing the plastic pieces that are around roof/back window?
- will b series starter work on a d series?
- 99 Civic Si Salvage
- 94 Civic DX/D16Z6 swap - seems to make no more power at 5k rpm
- b20v head gasket and oil plug problem
- what taillights are these? pics
- B-Series Vtec Issue.. Need Guru level Help!!!
- Searched but Not found!! Distributor 10 pin Harness!
- Nosiy valve train, already replaced LMAs. Help!
- Car starts 1/3 of the time
- Installing an autometer a/f gauge on a civic vx
- inconsistent starting + overheating 94 EX D16Z6
- 94 Del Sol S - brakes don't work and transmission pops out of gear
- b16 having some smoking issues could use some help
- SI hood on my LX
- '96 Civic, caliper piston diameter important?
- wierd idle problem d16y7
- My door shocks me
- Boosted civic bogging at low rpms.HElP
- 95 Civic gas tank installed wrong? Fuel pump is too close.
- Del Sol Custom Sub Box- 10s and 12s
- 92 civic hatch - fuel pump won't prime and CEL code 0 after wire tuck
- Motor Wont Start, Died Out of nowhere
- b series swap ?s in my 98 civic
- ground controls on stock struts?
- B16a WONT START PLEASE HELP
- Real low idle & non-start after turning off
- need some ideas!!!!
- Fast idle surge y7-y8 swap (vid inside)
- EG HATCH WILL NOT DO ANYTHING
- 97 cx hatch coolant consumption
- weird problem!!!!!!
- Z6 Camshaft
- Honda Del Sol?
- 93 ej1 build
- Will an obd2 ecu work on an obd1 motor?
- b20v/b16a head PCV system setup
- gsr swap into eg coupe
- 1996 Del Sol PARKING BRAKE LIGHT!!! Help
- '95 Civic, no crank, no start.
- Rust in cylinders and coolant well corrosion...How to fix? [pics]
- Car starts, then shuts off.
- Anyone know part numbers for driver side window channel?
- '92 civic, blower motor has me stumped
- 1998 ex engine swap that won't fire
- No compression at all in #2 cylinder
- b16 woln't start
- Found this in my IM, name this part!
- Looking for a battery trunk relocation write up.
- K24A4 EK Hatch Q's
- '96 Civic: greasing brake pads newbie question
- After 3 starters car still wont crank(push start only)
- Need info on new Brake system 93 del sol S
- What engine should I swap into my 93 Del Sol S? Pt.2
- engine swap, plus y8 intake mani on y7 question
- 94 Civic - Fluctuating idle, bouncing speedometer, and no gas cap hiss
- 93 Del Sol -- Where to buy floormats?
- stripped out valve cover bolt threads
- milky oil in the head what can cause this
- Grease - What to use for windows and seals on Del Sol?
- all motor b series, cam gear setting
- weird idle on first run. B18C1
- Replacing LMAs, how hard to change cam seals? & some other Qs
- Torque wrench and specs on D16y7
- D16Y8 VTEC To JDM D15B VTEC Swap
- Need help on a 98 civic swap
- 93 Civic VX- Right turn signal light on dash turns on when I brake
- what lip is this?
- obd2 ek 2step????
- 99 stolen coupe needs new bumpers, help!!!
- JDM EG6 front brake pad question help!
- With cruise control on, SOMETIMES engine revs to 3K rpm when clutch pedal pushed down
- 2000 SI hood help
- cel evap code
- Civic Hatch 99 CX sway bar?
- EK hood Bra
- smallest 10k RPM Tach for 2000 EJ6
- replaced rear brake hard lines, brakes still aren't working.
- problems with swap in new car.
- 00 Civic EX - stutter, hesitation, code P0420 - problems worsen when raining
- 94 coupe not cranking when turn key, fuel pump constantly priming
- d16a block
- blown d15b to d16z6 swap questions.
- VTEC problem
- New Project!!
- 95 Civic and NEW starter wont spin.
- B18B vtec head swap
- non-vtec motor installed in a 98 civic ex vtec
- 93 Sol 134A GSR compressor Conversion Help
- GSR A/C Line conversion help
- '99 ex civic/water on floor boards,no where else??? help me plzzz
- IN NEED OF B16B INTAKE MANIFOLD DIAGRAM OR HOSE LAYOUT
- Proper way to remove clips in engine bay
- 1993 honda civic dx spark problems
- climate control stays on after i turn the car off
- 96-98 coupe lip fit 96-98 sedan?
- Rear drum to disc using stock trailing-arm
- 97 civic 2door lip help
- CIVIC CONDENSER AND RECEIVIER DRIER HELP NEEDED PLEASE
- how to wire up the vtec
- trunk leak 95 coupe
- wat body parts will fit my 92 cx hacthback
- Are Denso Double Platinum plugs worth it or should I stick with standard Denso plugs?
- B20B vs. B20B1 vs. B20Z block only
- DTC 1259a engine change D16y8 to D16A
- How to replace wire box inside driver side door?
- unused pins at ECU connector?
- Recommend best coilover for money.
- How much is too much for Ek a/c system
- motor mount inserts b18c6 in EG6
- Oem part website help
- Violenty Shaking Steeirng Wheel....Here's the Breakdown
- D15B With a D16 VTEC Parts !
- Why is my 2000 Civic Guzzling Gas?
- radiator fan doesn't work, diagnosis left me stumped
- del sol bottom fogs.
- Broken civic window tab that connects to regulator help
