View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 96 honda civic dx ftp sensor problems
- B16A work on P08 ECU :/
- B18b cable trans sol swap alignment issue
- D16z6 bogs
- B18A1 Swap into 98 Civic coupe -- Looking for info on swap parts needed
- 95 civic completely dead from fuel pump switch
- How can I test a MAP sensor?
- 1992 civic bad gas mileage please help
- d16y7 block with y8 head?
- my first Honda (fully building street sleeper) eg hatch
- adjusting ek headlights
- 99 civlx 4dr Exhaust System Urgent Help!
- Another Sidemarker Question - 3-4 minute delay in parking, cluster, and tail lights
- EK with B18b Swap which O2 Sensor?
- HOW TO GET SCRATCHES OFF OF MY DEL SOLS WINDOW??
- 95 del sol/B16 swap - need help identifying connectors
- 92 Civic dash lights not working
- Where does this sensor go?! 98 Civic DX
- Yakima Snowboard Roof Rack 96 ex
- 95 civic A/C doesn't work
- remove rear view mirror ek coupe!?
- had brights on and car turned off
- PCV system (Breather Box) removal
- ek power window and door lock on my dx ek hatch
- Hood release cable replacement?
- How do I retrofit a stock 99 Civic CX with A/C ( I searched)?
- Harness plug for EK fog light button?
- 97 Civic -- What parts are needed for k24a2 swap?
- 98 b18C-R into 2000 Si questions
- smoke at start up
- What sensor does this plug go to?!
- z6 head and jdm d15b bottom end?
- b16 oil leak around corner of head and header tube
- wiring harness and computer for mini-me swap
- Polyurthane Bushings - help installing
- d15b bottom end z6 head what spark plugs to use?
- getting keys for my car?
- How much should I pay? 1995 B16 civic DX
- 96-00 Civic: Why are #74 replacement gauge cluster bulbs loose?
- 06+ Civic cluster into a ek? possible? (Im good at wiring) lol
- 94 EG Build
- tranny problem help plz
- 1997 Honda Civic has rust spots on the body?
- Leakdown testing without the head?
- 92 DX Suddenly Running Like Crap
- d16y8 blew, found some B20s for super cheap, need some advice
- 1995 del sol vtec / si differences
- Need to smog but...
- civic LED in rear spoiler where to buy just the LED?
- Reassemble D16 Bottom end w/motor in car?
- Checking Dizzy O ring
- ls/vtec -- Timing belt half a tooth off
- WS2 Exhaust Install Question: 98 civic
- looking for a rhd front clip
- DA exhaust on Del sol?
- 1994 Civic DX Map sensor mixup...
- swaping d15b7 into 99 civic ex auto?
- 2000 civic si dizzy problem
- 94 civic dx JDM D15B still hesitating after tune up
- mishimoto rad/ silicon hoses question
- gsr a/c setup
- need help b4 i do some stupid shit
- 1996 civic dx coupe.... B18b1 swap?
- 92 dx hatch turn signal failure
- Coolant nipple sealing? What to use...
- rainwater leak on heater box/blower - 1997 coupe
- 97 DX hatchback brake lines and fuel lines
- Help!!
- Smoking B16a2
- y7 with y8 manifold Can someone help me out?????
- need chase bays wiring help for EM1
- code 15 help
- compression check what is pin 2 and 8 connectors to remove?
- 94 civic automatic: Will ignition switch out of a 5-speed fit and work?
- 1999 ex shifting problems. any help thanks =)
- Thinking about getting the timing belt done
- Fuel Pump Cutoff Switch Q
- B16B or Turbocharged D16Y8?
- EG hatch w/ H22A leaking... something?
- 00 HB power window conversion / Keyless HELP!!!
- del sol budget build.
- eg f20b almost done
- 94 del sol - gray and black connectors near left trunk hinge. What are they for?
- valve seals and piston rings
- EG Si Sunroof??
- Car won't go into gear all of a sudden - only with engine on.
- VTI SOHC D16Y8
- traction with my h22 eg hatch?
- Most reliable way to achieve a mid 13 sec EK hatch?
- motor bogging
- 97 Civic/sohc zc won't start - has spark and fuel
- Oil leak on D16Z6
- Differences between a b18c5 96-97 specs and b18c5 98+ specs?
- 00 ex fuel pump taking to long to prime
- ***spark plug hit by piston??***
- LS with y7 exhaust and rpm rattle
- z6 rough idle, dies after pressing gas, all out of ideas!
- 95 Civic won't start, fuel injectors not firing
- 00 civic lx wipers won't turn off
- Using a block tester
- replacing the driver side motor bracket?
- Looking for a parts list B18 LS into 97 CIVIC EK help
- how to remove the ignition switch
- d16z6 eh3 idle issue. done everything. please help
- wierd noise after transmisson change :(
- Would an IAT sensor code cause an idle problem?
- Replaced tie rods and now can't get it aligned!
- Sound deadening
- 94 Del Sol si Fog Lights ?
- Full coverage insurance prices?
- EK Civic Wont Start - fuel pump doesn't prime
- Transmission housing won't get back in place?
- wanting to replace my z1 with a z6. tips or suggestions?
- What can i do to gain HP in D16y7 and still stay smog legal??
- NEED HELP: 92 civic Si with stock Engine shuts off while making U-turn
- Swap for my 2000 civic?
- 2000 Honda Civic ex Idle problem
- Wink Mirror mounting In a Del sol?
- What mods for d16y8 to beat k20z1
- 1999 civic cigarette lighter
- bumper light or fog light option
- replacing the transmission and clutch tomorrow...d16
- 1997 honda civic lx d16y7 engine question
- 94 civic won't start at all..no power..nada
- 2000 Civic EX Breathing
- 96 civic NO CRANK / NO START
- Replacing top spool valve gasket
- 98 civic d16y7 p28 ecu non-vtec sputtering @ 3500rpm
- No start, main relay clicking fuel pump not turning on.
- 95 Civic transmission leaking pretty bad. Is driveway repair possible?
- 93 Civic:Problems after overheat
- Continuous coolant issues with my 97dx...
- CEL for waterpump? 98 CIVIC
- Strange noise from front end-wheel bearing? easy answer im sure
- 15X8 Issues.
- Smoke, Should I worry? Vid
- Does this sound like an ignition switch problem?
- clutch+mudflap questions eg hatch
- About to trade wrx for 95 EG Need some help
- Can i use EK parts in an EG
- crazy idle please help
- Hard to start after fuel up
- Do EK9's have a dimmer switch?
- 1993 civic ex sedan passenger water leak HELP!!!
- anyone has a moon roof wiring diagram
- 96 civic Smoking, But not that easy to figure out
- Vtec Killer Cams
- 99 civic battery goes dead overnight
- worth a complete 2K civic front end a sc3431
- Prop Valve for 5 lug
- Need help installing gauges in 93 hatch
- 97 Civic HX 2dr CEL/emissions troubles
- Oil Seals a.k.a Cam seals ( Need Help ! )
- Front Wheel Bearing Replacement with Harbor Freight Tool Set 66829
- Help with compression analysis for d15b vtec 110k
- 2000 Honda Civic - Dashboard lights not working
- anyone ever done a b16 with p73 pistons and itr cams
- Just got a em1 this week!!!!!!!!!!
- b16a2 vtec engagement
- car wont start but gets all power, what do i do?!?!
- 98 coupe tachometer jumping????? VIDEO INSIDE
- Test Pipe Question
- Where would you look for a kill switch if you were a........
- 94 Civic D15B7 eratic idle problem
- Car shakes when shifting from 1st to 2nd gear. Clutch problem?
- 94 civic ex rough idle on startup cold or hot
- Del sol usdm integra front clip
- 2000 Civic shakes when turning left
- Help! I just replaced my front UCA, now pulls!
- No cluster lights sometimes from On II position
- Help please some dumb @ss broke into my car
- 94 Del Sol wont start
- is the ckf sensor the same as a crank position sensor on a 97 civic?
- Sohc Del Sol build
- 93 civic - Is it possible to make it all wheel drive?
- what ac belt to use
- Wanna rebuild my B16a,Dont know what to do with bottom end?
- D16y7 to D16y8 swap. What parts do i need to finish it?
- High HC levels CA Smog
- 97 Del Sol one piece headlights?
- 95 civic ex auto - d16a with p28?????
- GSR swap 93 del sol
- cable and hydro tranny help :P !
- 96 civic will not start up
- Car Wont Start, Tried Everything! Help?
- need help for clutch now :P
- 1996 Civic Headlight wiring harness
- in need of a sohc pro...torgue specs
- 92 Civic fuel pump removal
- 1999 Honda Civic Si B20 VTEC (2nd Gear Problem)
- 95 EG Civic gas meter fluctuating?
- Just bought 97 Civic EX vtec for $1300
- DIY: 99-00 Civic Baby Carseat Mounting
- 2000 dx , p1509 start then die.
- 99 CDM Civic Si w/ 4 cylinder misfire codes
- 97 EX Lower Balljoint
- White Dials
- 98 civic ex - low idle problem only one time
- What is the purpose of the clutch switches?
- Weird clicking/grinding noise when changing gears - Honda Civic 98 Automatic
- Painting Window molding
- DIY headlight restoration
- Auto Trans Fluid Type?
- a proper suspension setup
- 94 Civic Ex. Will not start occasionally after short drive.
- crank position sensor in 95 civic si
- Trying to get my car inspected. --CEL p0141-
- black housing headlights for eg coupe
- LHD RHD differences
- turn signal gayness
- Z6 head d15b bottom end timing issues help
- duckbill cf ???
- B16A cut engine harness.. goin into 00 dx
- 1993 Del Sol SI: Rack and Pinion
- weird clunking noise? cv joint ? help
- 94 dx intermittent problems
- b16a into 00 dx!!
- CV REMOVAL TROUBLE!
- College DelSol Build
- Where is my Crankshaft Sensor? 94 DX
- ECU jumper harness help!!
- 93 d15b turbo - getting too much fuel
- Optional Audio Console
- brown coolant?
- power steering switch
- 94 Civic DX jumped timing help
- 95 d16z6 turbo...plug & wire recommendation
- Would B20z with chipped P28 be able safely to rev higher than 7K rpms?
- blinking battery light
- Humming noise
- Smell of gas/exhaust at start up
- 98 Civic/B20B swap - Idle hunting
- b16b or b18c5?
- d16y8 problems, eating coolant and more, puzzled
- suspension question.. help =[
- new car
- Transmission fluid/check/leak question
- Complete Brake Fluid Flush
- car cranks, doesnt start.
- 94 civic sedan - B20b swap that retains auto transmission ?
- B16A Eg Stall followed by temporary no start
- my 97 hatch project
- Driverside window issue EG civic coupe.
- 1995 Del sol & 1999 civic Si - No A/C
- what does it take to change TDC sensor
- Ticking noise in engine
- EK ls/vtec -- Is it necessary to run with torque mounts?
- 93 Civic CX Burns Oil -- Any recommendations on a cheap build?
- b16 swap into ek hatch help
- clutch installation question
