View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what mounts to use for my b16a2 auto swap?
- Failed smog check! High NO
- whats wrong with my knock sensor for my 97 civic ex
- Best Swaybar Setup for my EG Hatch.
- help with my 92 civic sedan dx
- 10W 30 or tranny fluid from honda
- Spastic Idle & Stalling Issues - HELP!!
- how thick is stock integra sway bar?
- 97 Civic LX motor swap question
- what was this?
- nub question,do i have obd1 or 2....swap
- Whoa! my 2000 Civic si is 4x114? WTF?
- so do you think it's worth it?
- people who have pictures of red ej's or eg's i need help
- how do i lose the trial
- will turbo work w/ an auto tranny??
- rear windshield????
- yeah im a noob, wanna fight about it?
- Ebay P06 conversion?
- Quick ?
- really slow need more torque
- H22 swap wont start
- does 18a power steering pump fit on b16a?
- Distributor Rotor Position
- Wierd High beams problem
- Rear-view mirror loose - How to tighten
- HELP check engine code 65
- JDM B16 ECU
- no iacv or tps?
- Need help CEL 22
- Need help uninstalling car alarm in 1996 civic, Please Help!!
- Gap , bad fitment problem. help.
- Leak?
- 95 EX Civic Coupe With delsol style top Will it work
- Stiffen up suspension.
- rebuilt poormans...finally done..one more question..
- Quick Q
- skunk2 cams for daily driven car...but want to have power
- LS Seats with Ek Brackets ---> LS Seats with EJ Brackets help.!!
- cant decide noob to b,h.k,f series
- changed iacv oring, car wont start HELP!!
- P0453 and P0450 CEL
- Tranny Fluid?
- obd-1
- walkthrough for replacing alternator?
- ALIGNMENT?? will i need one after i put swaykit,subframe, and lca's??
- Idle problem with Stock Civic VX
- Burning oil in my b16a2?
- Need help with rear disc Conversion on a 99 civic Dx.
- Yet another P28 question...
- questions about my gsr block?????
- White Guage Face Problem
- poor man type-r
- about an engine swap.
- Plug wires...
- whats the best exhaust for my 93 civ
- 1996 civic si coupe ...? for real idk about this
- quiet exhaust?
- what do you think of this suspension?
- Oil Weight
- another year..another failed emissions test.
- good idea?
- Tachometer not working
- Which Distributor fits
- Need help quick!!!!
- which last longer hawk hps brake pads or oem honda brake pads?
- near miss
- price to press in wheel studs
- P28 for my D16Z6
- QUESTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
- what size rotors/pads for CTR 5 lug?
- Answers to any question to a H22A wiring for a civic is Right HERE<--
- tranny from junk yard
- Misfire Randomly??
- OEM Honda Navigation in EK
- CTR rims = ITR rims?
- (help need) i dont have a jumper harness is there any other way to check for codes
- (need help) dont have a jumper harness is there anyway else to check for code
- Will an EG HID kit fit an Ej8?
- b18c's suck
- what brake pads do i get for 96 honda civic hb with b series swap?
- Rear disc swap
- Know what OBD1 error code 7,10,16,&41 are?
- Just finished a GSR swap in my EK. A few questions.
- z6 vtec head on y8 block?
- Overheating and wiring issues
- swaping back to d16....
- ex tranny on my d15b?
- heater
- 92 Civic with USDM GSR, rear hard to get in gear some times??????
- broken cam sahaft
- Are all B-series IACVs the same?
- Burning oil.
- im selling my jdm gsr del sol (pics)
- Smoking BLUE!! at cold start up ,high RPM's
- where can i get this ecu?
- EG6 Civic 92-95 JDM rear Gather interior
- Poor gas mileage?
- civic help please
- Skunk2 Single Bend VS. Dual Bend
- 1994 honda civic v-tech swap ecu wiring help needed.
- DC knuckles same as EK ??
- EK fog light install
- cranks but no start
- 1999 Coupe rear seats into 97 hatch.
- D15B VTEC (obd1) into 1996 civic ex (obd2)
- EXAUSt
- Low idle (sometimes)
- 98 coupe wiring harness
- B16a2 Help
- SOHC Trans
- 92 Civic Hatch....All motor b18b or boost b18b?
- Gumont Engine Flush???
- What is the diameter size for Greddy Evo (EK)? Is a little rust at midpipe okay?
- "new girl on the block"
- ECU Mishaps?! help!
- russel brake lines
- 1997 civic steering wheel help !
- gsr block, or stick with b16?
- Fidanza flywheel???
- Head Gasket blew now i have a serious problem.......
- which interior pieces are swappable (door panels, a/c control, etc) into '97 hatch?
- anyone ever fabricated a short ram that takes the place of the a/c?
- Cars Pulling?
- installing y8 intake manifold on y7
- tell me what you guys think about this
- help
- Boosted EM1. n00b to H-T
- Ecu question???????
- wheels question?
- new here
- Need help with a GSR motor build!!!!
- Firing order?????
- Please help guys,random check light and bogging:(
- Running Light issue 99 civic si
- TANABE OWNERS! hyper medallion vs Medallion Concept G
- New Here, My car, HI everyone
- oil dipstick
- a/t 2 m/t cluster conversion?
- b16 reliability
- 03' Si Hatch wheels on EG hatch?
- skunk 2 stage 1 cams, valve latch????
- which gas do you use?
- How hard to install y8 intake mani in a y8
- Need start up help!
- How to get the plug out? (Side Mirror)
- serious issue.
- what are some things u can do to an eg interior and exterior wise that are diy?????
- looking for a specific build thread!?!??!?!!??!?!?!?!
- Idle Problems
- lsv idleing rough and fouling plugs...
- cluster problems speedometer, rpm, fuel and temp does not work !!!!!!!
- CEL codes, 99civic!!?
- ECU Question
- obd2b ek dizzy wiring.. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Help with 96 civic wind noise
- ek sedan midpipe on ek hb, will it fit?
- crashed civic
- new guys and need some help
- civic not starting
- spoon twin calipers on 15x7 work equip 03
- clima in del sol
- new kidd on the block !PICCS WORK !
- EG!
- Need help installing a.....
- engine help
- 1998 Honda Civic LX ECU?
- IACV wiring help!! need an answer QUICK!
- Eagle crank good?
- alternator, power steering pump
- dyno
- 93 CX prewired for tach??
- 93 vx tranny question
- Brake Booster/Master Cylinder/Proportioning Valve...which one??
- 6k RPM Idle? (Video)
- Engine light help!
- Broke Caliper Bolt
- newbie to rear drums, and I got a leaky wheel cylinder, now what
- Clock problems
- noob question... do i need LCAs to install lower tie bar?
- Hey, heres a stupid question...(valve adjustment)
- Car shuts off when i put it to neutral
- Looking for Spoon Front Lip Urethane EG
- What's Up With My Civic?
- pics of my car..
- VSS problem?
- Front Bumper Change Question
- Replaced the o2 sensor but still throwing code.
- KEYS!?!?!?!
- Anyone replace speakers in a '99 Hatch?
- Upper mount
- Engine Problem Help!
- How To: Cabin Air Filter For 1998 - 2000 Civic
- Help Needed Please....
- Gen 2 JDM B16A dead spot
- Cars in Limp mode Don't know why
- A/C issue... HELP NEEDED!
- need help please
- pics of my project
- help with my abs
- hey im trying to post pics
- test
- JDM Civic EG4 VTI Hatch?
- I WANT TO DO IT THE RIGHT WAY!
- Electrical-Engine Issues.
- Civic Hatch vs. Del Sol
- ek4 heating system diagram needed
- Changing converter.
- tuning specialists
- looking for an alarm/remote start
- Hawks HPS vs Brembo sport pads
- help i can't remove air resonator
- I'm swapping a JDM B16a auto into my 92EG, 2 or 3 bolt post mount?!
- Need Cylinder Head removal/replacement Tutorials or help.
- stiffer clutch pedal?
- replacing distributor/rotor, but rotor doesn't have a setscrew......
- Sparco Steering wheels Install
- Wetsand CF Hood
- Crank position code 54 (need help with Cal ref)
- EG Brake upgrade - Question
- Electrical Problems
- inspecting bearings
- 99 EK With a GSR Cam Question
- would kyb gr-2 a good combo with tein s-techs?
- turbo trouble
- check engine light on after fuel filter
- Need help. 70mm Tb gets stuck
- help please
- would a 99-00 CIVIC SI GENUINE HONDA TIMING BELT KIT WATER PUMP fit my jdm b16a2?
- blox intake manifold?
- anyone have a site where i can get a input shaft bearing for shoc tranny
- civic fuel pump not working
- Effects of winter on carbon fiber?
- 92 civic h22 bubble
- Coilover dilema...
- 96-98 VS 99-00 Civic HB headlight harness?
- Fuel cut off switch question
- Sohc Tranny Question
- 92 LX vacuum diagram?
- Do yo think these springs rate are good for a DD
- Helping an accident victim!
- guage pods???
- D15B Vtec Block D16Y8 Head
- how to anodized your faded lug nuts?
- Exhaust Question...
- del sol shifter
- obd2 to obd1 alternator splice question??
- how do u strip the whole back? need done by today help ASAP
- help! putting axel on my ek
