View Full Version : Honda Civic / Del Sol (1992 - 2000)
- cable tranny..which clutch to buy??
- Moroso Distributor Cap Pic Request...
- NW Reputable Garage...
- 2000 clean Civic Sedan pics?
- Integra radiator install on a 99 SI....
- code P1259
- can someone help me with my powered windows?
- spoon N1 clip
- Is this a good price? Del Sol
- does the 96 civic manual windows same with the auto one?
- shop manual available online?
- CEL 9... Cyp Sensor? Did OBD2 to OBD1 dizzy conversion!
- ls/vtec is slow please help
- Can you swap a 00 civic hatch center dash unit into a 98 civic hatch?
- RSX rear seats in a 92 hatch?
- Friends stock motor is shooting out too much fuel...??????
- Question for those with swapped Civic VXs
- GSR motor... which fuel injectors to use?
- I need help installing my rear seat belts!!!
- Crx Sounds Like A CHOPPER!!! Why? No power, Fresh Rebuild. Exhaust sounds way to choppy
- shifting
- how to post a picture?
- so do people ever get rid of this and make it look clean?
- is my suspension ok .. my rear end was lifted off of the ground from the rear passenger wheel well
- Delsol Fuel Cutoff switch.
- Sunroof Removal in a EJ1
- Intermediate Wiper Not Working
- Temperature Gauge doesnt go anywere stays at zero..
- b16 turbo in 94 coupe
- 3 of my lights dont work D: help
- B16 turbo or ITR all motor?
- Stiffer springs vs better shocks
- HOW TO GET PLASTIC OFF TAILGATE
- D15B2+D16Z6 compression
- What gas mileage does your SWAPPED EK hatch get?
- leaky Driver Side Drive Shaft to Transmission Seal?
- eg rails on 98+ integra seats. will it work
- Apexi VFAC II wiring diagram
- name of a bolt please??????
- problem with axel
- DIY for auto to 5spd swap in eg
- t25 or t3/t4
- Restrictive exhaust?!
- EG/EJ1 e-brake cable, What else fits?
- d16y8 in 95 4dr
- Just to make sure this is the oil pressure switch, would like your input.
- Need to find...Southern California Engine Swap Shops....
- MAIN RELAY problem
- I broke my oil pressure switch on my B16, wonderind what all pressure switchs are interchangeable.
- bad timing?????
- omggg i dnt have much time!! PLZ HELP!!
- oh god not another freshly swapped electrical problem
- Intake gasket question....please help
- Help! How do i remove my door handles?
- VTEC problems!!!!..
- what do you think?...
- 4x114 Brake conversion on Del Sol
- valve cover question??? need help bad
- Best Crankshaft for Turbo set up?
- wierd delayed starting problem.
- does this look fixable??
- V-TEC control
- VTEC= High idle untill warmed up???
- b16 shift points?
- HELP EG with a GSR swap
- 98 civic with b18b engine, how big of pistons can i put in?
- God Damnit
- Rubbing sound on deceleration?
- IM swap
- Right Front Squeaking
- IM cleaning
- head gasket
- EG sidemarkers on an EK?
- exhaust help
- Radio help 95Civic
- nitrous or sohc turbo???? wat shud i do
- rpm Jumps around when idle *Searched*
- Steering rack problems.
- 95 Civic Si for Sale TurboCharged
- Fog Lamp question
- Do I need an o2 sim?
- Hey i need help!
- vic 1996 for Hey i need help!
- ouch
- any body want to buy a set of rear SI disk brakes or a dash for a 92 civc hatch?
- which rotor to get??
- Del Sol SI Vs. Vtec
- removing ac
- how to check EACV
- NRG Racing seats???
- fuse question .. need help
- BIGGER THROTTLEBODY FROM H OR B SERIES ON A Z6.
- modifying a european honda civic
- vx tranny on d16z6?
- Civic Sites
- D to B series question regarding air conditioning...
- Top end racing?
- master cylinder?
- Fuel pump?
- Y8 INTO AN EG WITH Z6
- 99-00 SI oem fog instalation question
- Anyone heard about JSP cf hood?
- Car won't pass inspection...just need stickers till end of July
- distributor help!
- New tranny noise?, axle problem?, leak?
- What rear seats will fit in a Civic coupe?
- d15b7 crank in a d16z6 possible?
- cortney green!
- What rod/piston combo to use w/ JDM D15B
- 93hatch, where can i find the mesh stuff? more details inside...
- Had my ceheck Engine Code pulled...any opinions?
- "L" Bracket
- did i f up? zc for eg
- sohc turbo question
- What d-series motor does the SOHC Del Sol VTEC have? d16????
- what size (cc) injectors are in a 95 cx hatch?
- Low compression?
- 02 sensor heater wire ?
- has anyone tried these other than on ground control?
- Center Caps?
- 1999 Hatchback VTEC?
- Reinstalling A/C
- ANYONE HAVE A CIVIC SI WITH A AEM FUEL RAIL????????
- AUTO TO MANUAL CONVERSION...
- can i use obdI prelude injectors for a obdII d16y8
- HomeLink Garage Door Remote Installations
- I Need A Car!!
- Correctly remove the bottom grill on a 96-98 civic
- my engine is making a weird type of a grinding noise.
- need help on 97 hatch
- The LS/vtec set up
- Hello everybody I'm new and in need of help (94 civic Si hatch)
- Hard to Find 92-95 Civic Hatch VX?
- throttle body measurements
- Do 98 civic DX hatchbacks have wires for vtec on the engine harness?
- installing clutch, have question on where to grease
- 3rd and 4th gear grind after 1500 miles of motor swap
- Questions about an EG6
- 95 Civic Hatchs
- EG duck bill.....
- Need help installing a 96-98 oem civic rear lip onto the 99 civic rear bumper
- Need help with radio
- Need help on my 92 civic hatch.
- Del Sol front end conversion?
- The last modifications of my ek-3
- bought an eg sol for 1000, tryin to swap a new z6 for boost....
- Help got a question about the chargespeed sideskirt for a 99 civic hatch...
- soch vtec turbo
- car wont start question
- Will The P28 Be Just Like A P72?????
- What cats are you guys using to pass smog in California
- D16z6 intake manifold on a D15B7 engine?
- question about axle backs
- yo yo I need help with a headlight question
- Whats the better buy?
- So im doing a swap in my car and find an immobilizer, what to do?
- chipped ecu
- Ls non vTec in an EF 89. what all do i need for wiring?
- quick suspension question
- Camber kit needed?
- help please.
- Ground control help
- Fuel Pressure regulator question (searched)
- EDM EG Specifications
- rear lca
- best kind of mil eliminator for cel code p0135?
- SWAP QUESTION...Can A/C remain after an engine swap?
- Caliper sticking?
- A couple of ls in eg questions.
- Wiring Problem
- pulley/wheel on P54/P7J A/c Brackets... needed?
- NEed help on how to drain ac.
- ADVISE: SALVAGE TITLE...Are these smart buys?
- OBD1 D16Z6 into 97 EX
- electric impact guns
- b16a2 swap into a 1996 civic coupe
- 50 shot
- junkyards?
- How do you remove the crank pulley.........
- Valve springs.
- Can you swap transmissions?
- Integra ecu?
- need 5lug spindles where do i buy??
- d16y8 rev limit
- Should i buy this car?
- Cant find part
- EK CIVIC STOLEN IN LONG BEACH, CA
- PLEASE HELP IDENTIFY THIS SEATBELT CLIP
- Inspections failed.... explain ?
- help with search.
- d16y5 swap to a 92 vx...?! can it work easily?
- yellow head lights in illinois
- AXEL PROBLEM PLEASE HELP ASAP
- overheating
- Need to know if my friends 2000 Si is real, before he picks it up?
- 2000 EM1 repair manual!
- h22 swap axles
- Zex Cam Question!
- What is a tapped head?
- IAT sensor clip help! ASAP.
- 2.5" piping on a stock muffler
- DOHC VTEC decal
- Problem with starting car
- Fuel Pump Not Priming, Not Receiving Power
- z6 Header HELLPPP
- couple noises
- FINALY GOT AN EG!!!!!!!
- IACV?? help a new EGer out
- gsr motor swap!
- what the? heat shield bolts
- steering wheels shakes..why
- vx rear diffuser panel
- engine swap costs..
- Does the tranny oil have to be drained to replace the clutch.
- radio
- 98 civic ex, thinking to put a b18b, need help
- need to pass smog
- short shifter
- got a new ek, so im losing a few things...
- jdm itr into my eg hatch
- Glass & Window Track
- coil overs
- A/C and Heater
- VTEC solenoids
- Seperating Corners and replacing outter lens?
- Vision Style DC Mirrors?
- civic rear disc swap
- stupid question but help please!!
- Finally got my motor...one more question ASAP!!!
- wheels and weight
- which would be the best engine for 1/4 mile times for a 93 civic hatch?
- Fidanza Flywheels, Can they be resurfaced?
- check light help
- Genuine SI lip?
- What causes power surging with the A/C on???
- Need help with 99-00 civic si ecu wiring diagram.
- Which a/c belt do I use? (searched)
- Diffrences in B series Vtec heads
- suspension problem
- Difference between b16-a3 and b16-a2?
- What is a D16z6 worth?
- HELP!!! cant find chip for my car
- problem with stuttering noises form exauhst
- Automatic Vs. Manual
- OBD conversion question
- 94 Civic EX Questions...
- Need some advice here.
- brake rotors
- p08 governor max out at 122 mph ??
- serious problem (00 civic si)
