View Full Version : Honda Civic / Del Sol (1992 - 2000)
- speedo/odo not working
- EJ1 front seats price quote.
- EG hatchback lights on 4dr
- 92 Civic Si bumpstop help!
- looking for del sol rear lip
- civic ex lip on del sol mounting questions
- EG Factory Service Manual
- obx lsd? Need some help
- Can someone help me fix my horn?
- best shocks for Neuspeed sport springs!
- Rota SDR on 2000 EX?
- question about lights
- Brake Pedal Too Stiff!! Help with diagnosis ASAP!!
- EG Rear Disc Conversion Question (Pictures Inside)
- few questions
- GSR throttle body and Y8 manifold?
- oil pan question
- whats the ECU i need for a H22A?
- how do i
- Need Urgent Help!!
- Jon Duppong's EK9
- I know OBX is bullshit but tell me what you think about these headers
- will 4 door lights fit my coupe?
- smoke from engine bay
- tranny question???
- Problem with new car?????
- ?dc5 jdm seats will they fit an eg??
- 96-00 ex owners need help ASap
- Need help on Lsvtec
- SUPER low idle
- cleaning solutions
- Are B18 oil dip sticks longer than B16 oil dip sticks?
- Reverse light switch?
- CTR headlights fade or are some lighter?
- someone help a newbie?
- circle earth ground
- gsr into civic hx ecu?'s, mounts?'s, headwork?'s
- 97 dx/z6 swap?
- SOHC vs DOHC
- Need to Sell ASAP!!!
- FOR NEONE WHO HAS BOUGHT A BRAND NEW SKUNK2 IM
- car wont start 98 civic DX technical
- 98 Civic Headlight Housing Installation
- window tint removal gone bad
- Is this grill for a 99-00 Civic?...
- Kyokugen lugs suck
- Del sol all Red tail lights
- Spoon Exhaust worth it?
- d16y8 in 94 civic vx
- blue smoke?
- Anyone with a 99/00 hatchback successfully install OEM power door locks?
- MY POS WONT CRANK OVER HELP PLEASE
- JUN PISTONS & RODS for sale B series
- rad res. support?
- Need Help Quick B18B1 swap in a 99 civic
- out of winter storage...gsr civic dies out!
- exhaust question
- xexon hid h4 replacement bulb
- QUESTION ABOUT EK HATCH WINDOWS<<<<<<<<<
- EK a/c works on '93 Civic hatch?
- Hood Dampers - Del Sol - (92-95 Civic) ?
- 95 EG6 HB tire rubbing on fenders, help ?!?!
- help with valve lash adjustment
- Need help with seperating axle from intermediate shaft
- Removing drum brakes
- swapping out the powersteering rack for a manual rack
- Civic 4 door with coupe lip?
- gsr seats
- Another civic integra dash convertion question
- d16z6 crankshaft rpm rating and d16z6 stock sleeve horsepower rating?
- del sol SUSPENSION QUESTION
- caliper bracket # for 92 SI
- EK Brakes
- stripped bolt/snapped bolt in LCA's
- help me help me help me
- New EK Coupe! Check it out
- Back Firing Problem
- Integra Type R into Civic stuff - need help
- Unorthodox Crank Pulley?? PS Delete only?
- searched..
- Lip Kit Options?
- Pics of my new project Eg:
- Is Omni Power....
- WHAT TRANNY SHOULD I USE FOR A D16Z6 TURBO EG????
- Wierd Noise.. need some advice
- K20 help
- ek sides skirts on eg
- ACL Bearings
- Primer
- IACV question? HELP PLEASE!
- Best set up for APEXi AFC
- name this part??!?! (tranny question)
- Jdm Gsr block, b16 head
- b18c gsr swap into delsol 96 si
- Jazz pro parts anyone?? Jazzproparts.com
- please help, no driving till fixed, removal of axle from half-shaft
- 94 LS WHITE Help with suggestions
- Question about honda tech account
- EG side molding
- My Civic Type-R
- How To: Depin an ECU Plug
- THIEVES + Hondata wiring
- E brake
- ZC automatic engine w/Manual Flywheel....? Help please
- idle problem on a d16z6
- CTR axle mm question
- 96 gsr swap help!
- 1999 honda civic dx
- Anyone know...
- coolant leak on upper hose
- I Need quarter panels!!!!!!
- what year head is this PM3-12
- 1500 for a 96 civic with a blown motor is it worth it?
- Ej1 quarter panel replacements. Where you get them?
- si tranny on a mini me swap what axles
- Broken heater...only works on setting 4
- 1996 delsol d16y8 want more power but dont wanna spend a fortune
- JDM Gauge cluster Question...
- Block off for oem fuelrail / remote mounted fuel press. regulator.
- Hondata question.
- blackhoused/yellow headlights?
- putting a 95 LS in my 93 hatch cx.
- car dies when fan turns on?
- Noise from passengers side
- Engine start up problem.
- 94 gsr swap into 93 [DX] hb
- some ?'s about compression results..
- wondering about ebay turbos?
- How to tell when you have a D15B vtec motor
- m3 mirror install?
- Seat fitment question
- grinding brakes
- GSR Swap Question. Help me out gurus
- need quick answer
- ECU Swap Question!!!
- Mini me y7/y8 Idle. question
- VTEC on-off switch...
- coilover sleeve question
- help.... LS/vtec swap into eg
- GSR front seats in 95 Coupe
- Integra gas tank in a HB?
- EK9 FOG LIGTS ONTO 92-95 FRONT BUMBER
- REQUESTING PICS OF B-PIPE EXHUAST ON EG
- Seatbelt color in 92 cx?
- Researched it for 2 hours....rear speaker brackets 2000 civic hatch?
- MAJOR QUESTION!!!!!
- WTT:YS1 cable tranny + cash for a b16 hydro tranny
- Need help on d15b vtec pistons vs d16z6! (SEARCHED)
- B series in the EG... why is my car so low?
- car keeps poping out of fith gear
- EG6 HB headlight adjustment help?!
- engine painting
- 97 honda civic cx h/b help question
- newly painted GSR VALVE cover
- undoing my wiring harness...
- e brake console?
- where can i get a bomex wing for an 99-00 ek?
- D15B
- gas mileage/car main ect.. question
- DOHC del sol owners check in please...
- red/amber black background cluster is it Australia cluster? eg6 hatch with mph ? if so i need one
- h22 in ej1?
- How to change tranny fluid?
- z6 engine harness question
- I Need honda civic cx eg6 car manual....
- suspension help, buddy club coil overs
- Smoother Ride!!
- h23a question
- gas key
- B20vtec, sounds like it on 3 cylinders or out of time.
- Vx head on Dx block
- broken bushing bolt
- fogs with car slammed
- 1.5" drop.... will I need shocks and camber kits?
- z6 swap
- Del Sol lower JDM fog lights
- hasport mount eg b series
- CEL 22 - VTEC pressure valve? need help!
- s4c transmission problem, check it out please
- timing on b16a
- Wheel hub removal
- Looking at buying a 93 del sol w/ 123k miles -- need some advice
- a few ?'s for my ek!
- d-series flywheel b series bolts ?
- power windows "drop"
- Sad day...she is gone.
- Manual Tranny Question.
- removing rocker panels?
- Car Running Rich, How to fix?
- Is there 2 different front gsr sway bar setups
- Plugs Readers check this, looks like i'm detonating like shit..
- what do i need to take off head?
- dam lower driver side mount help
- new dizzy guts = new dizzy?
- why take out the power steering
- Searched>> #4 piston misfiring+bad gas mileage any help>>
- My 92 CX hatch does not have a MAP sensor. Its missing, it was never there...
- Obd2 car - obd1 ecu + how to check CELS???= Happy!
- FS/FT: Del Sol Si w/ 56K ORIGINAL miles
- i know you guys can help me!
- Will life suck if I leave my iacv unplugged?
- EG/EJ valve cover replacement help...
- vtec wiring harness
- accord/prelude big brakes, do the calipers matter?
- need 99-00 civic si parts
- about fix tix? help pleae
- Which Brake Pads ???
- z6 ??? need answer fast
- GSR vs ITR air box
- Should I trade my ITR interior for SIR? (Pics inside)
- Fog Light installation help!!! for EG......!!!!!!!!!!!!!!!!!!!!!!!!!!
- GSR SWAP in EK.....Del sol support for power steering??
- *UPDATED* CAR RUNS WIDE OPEN (pics)
- jobber vs. honda
- h22 hatch pics
- I'm wondering, what would be the best....
- Coilovers on my Del Sol
- where is this thread..
- Del Sol, help make it fast please
- Trottle body cable??
- 94 Civic Dx - Auto to Manual Conversion *Question*
- mini swap
- Need Type R Rear sway Parts list and diagram
- Leaking distributor seal: Symptoms?
- Terrible Gas Mileage
- Rev Limiter at 7kRPM on P30 ECU.No Codes,Runs Fine Otherwise ???
- Ground Control Spring Rate Suggestions for my set up. (EK)
- rim size
- Ls-R or Ls zero
- Powersteering/ can i live without it? 98 ek
- IAT question
- p28 on a d15b7, what are the effects?
- when i rev. sometimes my cars turns off
- MAP sensor compatibility
- im looking to do the 96-00 ek conversion on a del sol
- $2000 for a 98 dx hatch, is it worth it?
- automatic p30?
- which ecu
- HELP!! jdm b16a with usdm b18b tranny??
- USDM Sol w/ a JDM SiR
- Speedometer wont work
- No spark..
- hatch with jdm ls swap keeps dying
- Would you trade, all things considered?
- valve cover gasket
- gas gauge on 97 civic fluctuating, help
- Please help me.. please
- What are some good tuning shops to go to in the ST. Louis area
- Fuel Cap Part #
- VERY WEIRD, car sometimes dies right after startup (only occasionally)
