View Full Version : Honda Civic / Del Sol (1992 - 2000)
- AEM pulley fitment
- Cruise Control?
- Replacing Power Steering Pulley
- Civic Type R Suspension: lca, fork, swaybars, etc.
- p30 pistons/rings and eagle rods?
- gsr cams in a b16 please help
- head gasket removal on an aluminum block.
- a few stupid questions about JDM b16 swap into 95 hatch
- anyone have any pics of a EBP civic with gunmetal rims
- Leaking Tranny
- converting a y8 intake manifold from automatic to work on 5-speed
- 96 2dr exhaust on 95 4dr?
- IAB wiring?
- d15 motor
- engine mounts for B-series engines. all 88-91 civics
- EG Interchangability
- integ H&R sport springs on 97 civic?
- itr or race setup gear ratios
- My new toy whooo wooooo
- Civic Hatchback OEM Foglights
- debating on what engine suits me.. need opinion/advice
- ATTN: Please do not post pix of your rides...please read.
- Manual transmission fluid help
- Might be dumb, but Post annoying stuff your car does...
- changing my drivers side axle...do I need to drain the tranny fluid?
- Spoon Stuff
- What is that tie bar looking thing that connects the engine to the car body?
- MSD sci-l?
- Civic Hatchback
- H&R Race Spring Rates.
- d16b head on d15b
- another d15vsd16 question
- What would be the possible whp of this setup?? Butt-dynos accepted..:)
- Tranny swap?
- Z10 engineering SUCKS
- EG springs on an EK??
- DX ecu?
- Tranny Prices
- my headlights are tweaking out
- size toyos for 16in regamasters?
- thought this iwas interesting pikes peak civic???
- ITR 5 lug on ek hatch
- Help removing/installing bumpers please
- temp. on cluster dont work **** what coulb be the problem ***
- Anyone Know what lip this is?
- ok late nighters, plz help.. CEL code questoin
- Del Sol Carbon Lip
- Exhaust Compatibility question- I know, I know, don't flame!
- Dynoed My B18C5 with V-AFC Tuning - Chart, Pics, and even a VIDEO Too!
- Tire Question
- acouple diff. front end conversions for eg6.
- What proportioning valve is this???
- HKS plug question
- Sychrone question.
- Cross Drilled and slotted rotors
- facing little problems here... help??
- need carfax report. can anyone help?
- Ex brakes on a Dx do i have to change the control arms?
- My car is back in action with pics(56k ehhh)
- How can I learn?
- Rear Bumper Question
- 95 Civic EX compared
- carbon fiber hood wont fit correctly
- My JRSC on 00 si
- cricketing suspention
- Difference between JDM and USDM EG Front Bumpers?
- What's your opinion on ROTAs?
- Sorry if this has been asked before, but couldnt find a whole answer...
- alignment question . . .
- Coilovers/ camber kit question
- Do I need bigger injectors with new Cams?
- auto/5 speed conv, need help with Cruise Control Unit
- under what circumstance can cops look underhood?
- Looking into 92-95 Civic Coupes.
- knock sensor wire color on 95 teg harness
- How to install - "EG6 GATHER'S INTERIOR" into USDM Hatchback??
- JDM EK Air Vent...
- HELP del sol swap done but.............
- o2 sensor stuck, need help fast!!
- Convert to SI or drop a turbo
- I hate SNOW!!!!
- Amount of time to change lower control arm?
- disassemble door panels on my 1997 4 door?
- What type of oil are you guys running?
- Additional HP
- my heater wont work ?
- OT: How many Km can you run with Mobil1 Tri-Synthetic...
- 92-95ex cam gear in 96 lx?
- CEL code 41 ?
- DC Sports exhaust
- How do you fit buddyclub spec 3 on hybrid hatch? wtf?!
- full member benefits
- Well ball joint replacement didn't go as planned.
- 93 del sol paint jobs
- vtec / si del sol differences
- Ex/Dx grille shell on si grille
- lug nuts??
- overheating problem
- CEL....ECU related
- What kind of pulleys AEM or UNORTHODOX RACING!
- Well the new EP3 seats bolt straight on 96-2000 civics?
- RPM shift light
- Where to get a good set of HID's
- GASkets for WS exhuast
- Ek shell
- Need axles, looking for opinions (rebuilt or used) Which is better???
- Front suspension squeeks when turning wheels...
- gsr cluster
- After about 3000 Miles is your car suppose to waste any oil at all. (Bseries Vtec Blocks)
- 5th Gen Rear Seat Removel
- Lugnuts with rotas?
- Cam gear question
- school me!! i dont understand compresion ratio's
- Carfax please
- How do some of you deal with no power steering....
- Finally Got My Car Painted *56k BEWARE*
- ITR clutch disc w/light weight flywheel OR just Exedy racing clutch and resurface fly wheel??
- Question about new Civic
- Where to get seat rails from?
- bitch pin
- HCP Mounkit Groupbuy...??
- Removed my a/c and now im concerned wether or not i should put this back on(pic)
- What'd I break? Tranny/Diff Question.
- Car stolen...lookin for new car
- What suspension?
- dowel pins help!! lsvtec
- Need help deciding on Tires.
- All 92-95 civic coupes with a Rear Type-R Lip
- I'm at acrossroads here guys . . .
- Sparco Spring Rates.............
- 566WHP 412ft torque Street Civic on boost
- right cv boot ripped ,nothing serious to worry about???
- Check Engine Light Code 14
- 99 si rolling chasis
- b16 block im about to get
- b18c5 (atuo) for del sol for my mom
- WTF!! they will sell anything....
- vtec not working?
- Will a 99/00 SI front sway bar fit an EG?
- best measurement for exhaust system for b series and h series vtec
- Snow messed up my hatch. Help me out to identify the part.
- Where can I get these little body parts...
- Does ITR muffler fit on EG civic?
- The reason you *should* use loctite...T-belt PICS inside
- . clutch question
- what tranny is the most durable?
- anyone have H22 wallpapers?
- ES motor mount topic
- Suspension is BOUNCY
- how do i start up a engine to see if it good or not
- exhaust question
- ITR Tranny in an EG6...
- This looks like it's from a civic
- help with speedometer?
- who makes that trianglur front strut tower bar
- K&N vs. Green
- Who has delt with these guys?
- help on b16a head...
- camber kit?
- R & D dyno ??? how are they??
- has anyone ever.....
- Part number on EK9 power folding mirrors....
- b18c5 in eg swap
- D series tranny
- si tranny in an ex?
- turbo d16z6
- My motor came in today!!! 56k beware!!
- whats a common swap for...
- going for my goal....13.xx all motor b16a
- Helm for 92 or 93 civic
- turbo ls or type r
- You have $12k to build a civic, what do you do?
- Is this Eg a good buy???
- whats wrong w/ my tranny?
- Got a 2001+ civic and changed the oil? (yourself)
- oil pressure gauge?
- boring to 2.0
- Weight?
- I am wondering what the average cost is for a H22 swap? Anyone???
- Question about Camshafts
- d16 civic engine
- has anyone heard of this compnay
- any hybrid hatches running nitrous?
- Integra cluster in civic? will it just plug right in? does it fit? pics? i need some help..
- Carbon Fiber lips
- Must Read
- engine work on a 94 Del Sol Vtec
- All you EG B18B owners!
- Gears for Sale!
- 2002 Civic - auto tranny fluid change
- How do you shave badges off?
- venom intake manifold
- just picked up mah new baby
- Idle problems
- Tranny rebuild?????
- how would i know if......
- yahoo room for honda tech
- burning oil
- i think i have a vacume problem ...please help.
- "as seen on tv" ding king
- Carbonex carbon fiber hoods
- Question on Clutch engagement.
- What Gauges With Turbo
- setup for car
- ITR/CTR Shift knobs
- EK shirt challenge open to all
- bores?
- Flakes?????
- greddy ss header question(colors?)
- opinion needed...PLEASE
- 91 Civic Front Seats
- How do you afford ALL your parts?
- smoke when warming up
- doing my suspension......what should I do?
- balljoint crap on civic PT2. (with pics this time)
- JDM civic front bumper
- FAQ: CORRECT V-AFC Wiring Diagrams?
- Can I convert a D16Z6 distributor to fit a D16Y8 head by....
- Motor has a hard time starting at first.
- Alternator
- what camber kit yoo running . . . ?
- are there VINs
- what screws to use for my aftermarket side skirts?
- brake question!!
- H22, or B20VTEC
- Some Serious questions....
- alignment needed??
- Color of CTR carpet
- B18can't get my suspension back together after swap
- WTF is up with these windows
- anybody have a hatchback for sale??
- what turbo kit? h22 civic
- I think it's time to make a Stolen Car forum
- clutch problems
- Disappointed with Sprint Springs
- car wont start please help asap!!!!!
- Question about the VAFC
- need help installing ingalls camber kit
- this intake mani has 3 coolant hoses .. where does the 3rd go (civic DX)
- intake problems
- where can i get EP civic seats for my Ek
- 99 Civic Si A/C bracket same as P54 del sol?
- Missing Vtec Oil Pressure Switch
- 97 honda civic springs for sale??
- JG Throttle Body / Skunk Cams question...
- del slow seats
- window keeps falling off rail
- anyone with a helms for a 99-00 Si
- what do i do for top end power?
- window cement or motor mount inserts?
