View Full Version : Honda Civic / Del Sol (1992 - 2000)
- What muffler is this?
- Couple of questions b16 related help (i will paypal $$3)
- Tire wear question
- smell gas inside the car.. what could it be and how can i fix it?
- quick question (2)
- why is this thing not starting
- Stock exhaust heat shield OR Thermal wrap stuff
- gsr fuel pump
- h center caps for sawblades
- obd0 b16 obd1 b16
- gab centercaps?
- Questions about DC2 dash into EG
- installing new dash
- '93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions...
- performance for my 2004 civic?
- Gsr Cluster Plugs in cluster into EG?
- will any B-series IM's fit on a D16y8
- my 1999 honda civic si.........?
- zc question
- ACT UK Suppliers / Good Garages ?
- Civic owner needs advice
- Will any VSS work from a 92-95 civic on my 1994 civic si?
- what the price>
- Motor Swap or...
- 04 civic short shifter?
- 93 cx/dx
- Basic ? for anyone
- JDM 4.785 in JDM B16 tranny.
- jdm b16a gen 2 into 95 EJ coupe ALREADY SEARCHED
- Hey! new to honda tech!
- JB Weld a Radiator?
- PIC request - Beaks kit/ITR rear sway installed on 99-00 Si.
- Why swap ECU's in a JDM d15b?
- problem with checking codes
- got a carbon fiber question
- Radio Blockoff plate
- GC question...
- well i heard my lic. # over the intercom at LOWES today!!! :crook:
- Is this fuel filter just for EGs? Anyone need it?
- motor decision...need opinions
- Newbie question
- Header question
- gauge cluster calibration
- Wiring from a dx to zc..
- No Vtec
- 96-98 Civic OEM SIR LIP
- i need to know what transmission i should go with
- second gen str fuel rail?
- Installing GSR Dash in a EG...Need wiring help!!
- HELP! some monkey broke my gas door!
- Need Help with B16 Swap!
- 92-95 h22a injectors okay for my setup?
- please help
- WOOT!!!! i just bought my motor :D
- OMG+++ a real question....
- s20 Tranny install and prep.
- bulb size for clear tails...
- ? on best lowering springs
- 1996 Main Relay Location??
- windshield wipers won't stop!
- Almost 160k on my d16z6 and a grand to spend what do I do/
- Optima 6 pack batteries
- ITR Swap with AC in EK Hatch?
- ECU/ VAFC Question
- ek fenders buckle ??
- How do you disable an alarm
- Knocking or valves tapping?
- Pickup Tube?
- B16A2 or B18C1
- Need b16 help
- 99-00 Si Dizzy (pic request)
- Clutch Questions?????
- front brake upgrade for 96 hatch
- eg6 strut bar
- Code Problem
- mugen muffler getting it shipped here from japan.. need help advice.
- Sorta a Noob question
- B18c1 missing after warm up
- carfax please
- HELP with car, Wont start, just cranks and cranks and then makes a clicking sound??
- where to get si grill
- Why Does my idle drop down to zero when running...?
- which block should i buy
- EG Front strut bar... Which ones require no drilling?
- K20A Type R Motor or H22A Motor w/LSD
- How to take off grease stains from panels and seats...
- gaz cooler
- post your eg pic!
- Repair panels?????
- Loud repetitive thunking noise from driver side wheel well. "What" or "Who" is the culprit?
- Is this really true? "Kuwano Direct Power System"
- CAR WONT START
- Doing AEM Front O.E. Caliper Big Rotor Brake Kit
- best 195-50-15 tires???
- h22a or b18c5
- who makes the best fitting mugen lip?????
- Civic VX Wheels question..........please help....
- *NEWBIE* Will 2000 Integra Leather fit into a 2000 Civic coupe? or a 1996 Hatch?
- timing question???
- Questions about the JDM N1 crank pulley?
- Is there a Apex-i VAFC wire harness for OBD-1 cars?
- What shocks to go with h&r race springs...
- State Ref'd Pros I need ur help!!!!!!!!!!!!!
- 2000 Civic How to reset 'Maint Req'd"(Service Reminder Light)
- headlight adjustment on eg civic
- does anyone know how to connect a autometer tach
- no tires available
- FUEL Rail and Cam gears???
- HELP: miscellaneous little EG problems
- vafc install... please help me out
- Will ITR rear seats bolt into a EK hatch?
- Water Temp Gauge?
- [FAQ] 92-95 EG EX SI power windows coming off track? I fixed mine... =)
- headlight Q?
- RSX seats.......comments
- b16a2 what muffler
- 97 civic dx b18c motor swap
- Speaker interference with engine
- need help with my civic rpms..
- Got My Custom Hatch-Specific Car Cover. VERY Pleased!
- Tail Lights arent working
- Suspension Help
- Jdm climate control Help
- Will GSR axles work in my 93 civic ex??
- Rear Wheel Bearing
- anyone know what could cause this???
- so whats an EG9?
- low on gas...tuff start!!!
- Anybody know how to register a car in another state? Emmissions is killin me!
- Does anybody have the write up for a gsr cluster into a eg?
- removing power steering
- Edelbrock Turbo or swap?
- how can you get power steering on a non-power steering car? (96civic dx)
- what dyou think of a D17?
- trouble starting when low on gas!!!!
- b16 crank b18 block
- erebuni cf spoiler
- Civic engine swap recomendations
- Timing belt tension....
- NOT THE RIGHT PLACE FOR THIS BUT JUST WANT THIS QUESTION ANSWERED
- Code 15 - found the problem, what do i need to do to fix? Melted = Bad
- sportlines w/tokico blues
- gsr shift linkage bigger or smaller???
- Will pay someone in So Cal to install my OEM power window & Locks?
- Anyone have a A'PEX GT Spec exhaust system?
- Powder coating Plastic? Can it be done?
- 2000 D16Y7 installed in 1998 Civic Lx
- o2 sensor question
- please help my son really messed up
- Diff Car Specs
- JDM EK fenders?
- Suspenson question
- Staring wheel problem
- Which for my safc?
- long, but would like opinions
- So much for the Hondata idea...
- Help! weird problem. heat and idol
- d16z6
- Power steering
- Bumper Brace Screws
- engine swap or d16z6 turbo?
- how to remove window cranks?
- where to get parts
- 00 civic Si air condition question ??????
- what to look for in a civic?
- looking for some advice
- ATTN: BAR cert guys!!! Please help me!!
- Best Rods?
- 99 Stock exhaust
- trading in 2000 civic SI????
- I need some advise on how to make my HB faster....
- Noob question: How fast? EG hatch w/b18/turbo 7 psi?
- NEED HELP W/ HEAD ..D15b8 to a 16 valve head
- anyone here have their ebp civic si stolen in san jose, ca today?
- P30/PR3 parts on a P72 head, is this normal?
- JDM D15 vs Mini Me
- What different transmissions are compatible with the D16y8?
- quick question, ITR tranny vs SiR-II tranny
- Spark plug wires
- Does Check Engine Light ALWAYS MEAN that the civic........????
- I need advice on b18b vtec and i have a question please help me out.....
- "JDM" EG headlights
- People with Del Sols
- a/c fan wont come on help
- what do you think of the civic VX
- HX on Low Pros?
- Moderator please veiw this
- New Clutch???
- d16a6 head bolts work with d15b2?
- PCV Valve for JDM B16A2
- can someone please help i need a write up or instructions on install of one piece front end
- USDM vs. EDM - Catback and exhaust systems!
- 2003 Civic EX OBD code reader
- Idle problem, need help
- WTB:Red Del Sol Zig-Zag Floor Mats!!
- D-series VTEC vs. nonVTEC dizzy, what's the difference?
- how to fix quarter panel rust?
- My hatch is falling apart...
- Lookin to do a full Type "R" swap into a Civic 96-99, prices?
- Car won't start! PLenty Of spark/Fuel/Battery/Compression just keeps cranking??
- Simple sidemarker wiring question, (I did search)
- Compressing springs...DIY??
- lights dim under 3500 rpm...
- No fuel 00 civic dx
- Steering Wheel Alignment
- Clutch pedal feels....spongy
- whats the difference between z6 and y8 head??
- anybody got the torque specs
- helms request 96-00 civic
- To turbo or to swap that is the question?
- drilling through body?
- is my block aluminum?
- Post axle install... car shudders
- check engine light
- 6pt bolt in autopower cage in an EK
- multiple misfiring
- honda civic hard starts.
- (EM1 part number request) Does anyone know the part number of...
- 99/00 SiR master cylinder and power booster. 15/16 bore.......... Does it match up to a EH DX hatch?
- auto h22 in cx
- k20a2 swap into a EG?
- Si radio console into 96-98 civic
- I went DOHC. SOHCs stay strong! ALSO, some advise.
- Phasenine redeems themselves
- Front strut bar and rear lower tie bar from an 00 civic fit a 92 civic HB?
- D16Y8 camshaft
- 94 CIVIC SI coupe HEADLIGHT question
- This Cat good Enough to pass emmisions??
- Port and Polish Exhaust ports
- Del sol and zex purple box
- 92-95 civic - center console?
- eat my short!
- Engine swap needing help
- Mugen twin loop exhaust.
- bulb #s for a integra cluster?
- type r guages
- Will an SRS cable reel from a civic fit on any honda.
- DIY Door Siding Question
- searched still no help
- F#%K HELP
- drop in gas mileage
- ground control compatibility
- throttle body for d16 mani
- EK9 City lights... know where i can get em???
- Em1 track times :(
- Help with my motor question
- h22 rev limiter accord euro-r problem.
- Ill pay a person to do a LS cluster into a EG. *SO CAL* 714
- h4 to h4h
- crank pulley belt size
