View Full Version : Honda Civic / Del Sol (1992 - 2000)
- air blow back noise right after turning car off
- Bomz Coilovers??
- weird NOX numbers on smog, ive searched.
- EG6 B16A Quarte Mile Time
- Uknown hoses?
- oil pump question?????
- d16z6 head swap?
- '93 Civic hatch needs suspension and lowered?
- I NEED HELP........92 civic cx.....???????????????????????????????????
- OIL Pressure and Oil temperature sensors intallation?
- 98 LX A/C Question: Low side pressure way too high
- z6 compression
- civic exhausts
- already searched, 97 dx manifold swappage
- Any tips on how to DIY mirror?
- Is it normal for a 2000 Civic hatchback auto to eat up gas like no tomorrow?
- ftw
- HELP PLEASE power steering loop and mystery parts
- Sound
- Oil Question
- eg civic - sir11 JDM amber cluster...
- two different switches for folding mirrors
- suspension swap question.
- 93 Civic Drum Brake Adjustment
- BUDDY CLUB wide seat install... how??
- Exhaust
- Broken axles. Any Ideas???
- 97 B20 Into EJ2, Harness Question.
- floor the pedal no go! Help
- how can i find out if my motor is stolen ?
- intake temperature
- Is it worth it?
- Will PlexiGlass Melt?
- b16a prices
- H-T meet here in the philippines?
- OBD0 question
- Tach question...not the normal question
- anybody recommend this guage
- dumb KS question
- Suspension help ASAP
- OBD codes P0303, P0304, P1300, P1399
- shift link for b20 in EG.>>??
- help.. rotors
- ls/j spec
- ecu question
- 94 B18 hatch project...
- ECU Problems!!!!
- Car impound because of tranny...
- Pics of Lower Control Arms
- 00 EK CX Hatch Electrical Problem !!!!No Power to the car !
- Can 96-00 Civic DX axle back muffler or exhaust fit on 2000 Civic Si ? ANSWERS PLEASE!
- what if my bump stops are too short?
- honda del sol d16y8
- when changing radiator fluid is it neccesary to change thermostat, or will i be ok...
- Do JDM B18C5 headers fit USDM B16A?
- Pulling Interior Panels
- How do you bleed a clutch?
- PLEASE HELP! IDLE PROBLEM! D15B Swap
- 00 civic seat buckle recall?
- OBD-0 D16A8 ZC into 5th gen civic OBD-1
- What is the best option to lower a 96 Civic coupe EX?
- how to identify a 99si proportioning valve, is it really the same as a 96 dx lx?
- Where can I get a 92-95 sedan cf trunk ????
- swaping a 1997 d16y7 into a honda del sol
- is EK sideskirts (used) for $36 too much??
- H22 Civic Questions
- Should i trust a regular machine shop to....
- climate console
- Got a check engine light code p0505
- clicking noise
- modding sohc vtec head for turbo
- torque damper
- Idle weird??
- need help please
- WILL A H22A FIT INTO MY EG?
- B18C 94-97 (GSR) Long Block Questions
- Why the hell are my brakes so soft still?
- head gasket size?
- help with wheel hub prob.
- I have a screech coming from my 95 civic
- JDM OE HONDA VISORS?????
- Group A Civic (Cameo on one of BMI's videos)
- Brake swap
- s2000 gauge cluster swap into del sol
- Installing b16 head onto b18b1 block
- short shifter ?
- Another squeak thread
- "cheap" FULL coilover OR AGX + GC ???
- St Louis Tuners?
- cold start misfire/bad idle, already searched
- 95 Civic overheating
- CEL Code Help
- 94 civic hatch shuts off (stock)
- Timing belt wirring sound - dizzy assembly seizing??
- Spoon Parts on a Turbo Setup
- JDM Foglight Switch not Lighting up with healights
- all motor?
- any Sols on here running a JRSC?
- crx turbo mANIFOLD ON EK
- Slanted Exhaust FWD
- ITR -97 4 lug brakeswap..
- have i got the right ecu . please look in !!
- Del Sol Cruise Control/Switch Wiring Questions
- Vale adjusment!
- Eg6 si hatchback cluster........HELP
- Gauge problems
- exhaust diameter - searched
- ever get your car/motor swap stolen in socal?
- cam upgrade
- dual vtec?
- where is the cheapest place i can pick up some EK side skirts??
- HELP with my gas gauge (not working) at all!
- engine rebuild soon. oem or aftermarket?
- Pic Request: EG's/Ek's/DC's on 15inch wheels w/ +32 offset
- !!!!! HOW MUCH IS A 2000 CIVIC WITHOUT A TITLE WORTH? !!!!!
- lights
- 92-95 EG/EJ Civic S2K steering wheel and hybrid JDM/USDM gauge cluster
- car wont start, need help
- GSR swap on EK
- where to buy jdm Fog lights?
- civic 96 - Change blower motor resistor
- 99-00 Foglight question....already SEARCHED plenty!!!
- ls vtec in my eg.
- b series owners
- 92 dx 4 door. POWER WINDOW motors interchangeable
- gauge cluster fits
- City Light Bulbs . . . . .
- how much power are you getting from your LS?
- H22 swap done....but a few problems.... bogging and breaking up.....HELP PLZ!
- 96 ex running light issue
- Having clutch and Idle problems after my d15b swap...please help
- head gasket?
- loud sound
- z6 fuel issue
- quick AC question
- oldie but still tricky
- Installing Vtec or Shift Light.
- cars on jack stands .. trying to budge my bolts for my suspension install .. but cant get it
- How to mix coolant/water ratio?
- What engines can bolt onto my d16 transmission?
- cluster harness
- short on the right side of my hatch??
- b18b intake manifold on b16a head
- NEED ALL FOUR 96 B18B MOUNTS....
- b16 tranny question
- make my b18b go faster?
- HELP!!!! 93 civic w/B16 swap AC problems
- brake caliper problem
- Fuel Pressure Problems
- Instrumental Bulb Help
- OBD1 B16A Knock Sensor Issue
- d15b7 timing belt noise
- Problem after doing a compression test
- 7th gen mirrors on a 6th gen?
- need help cant hear the vtec kicks in on my gsr
- the funniest thing i've ever seen... ALSO TECH QUESTION
- D16Z6 head instead
- AC cuts off and on
- cylinder head rebuild
- carfax please
- WTF white smoke from intake??
- removing window motor from door
- Saab Garrett?
- 99 civic si shell salvaged
- bad gas milage .. air filter?
- will hx rims fit on 94 civic 2 door?
- 1.8 LS head on 1.5 honda block
- car runs like a champ on empty
- VIS duckbill spoiler for eg similar to spoon?
- VTEC pressure valve (question)
- do i need new control arms with sway bar?
- Vaccum gauge
- D-Series Removal for Throttle Swivel/Butterfly
- CAM GEAR QUESTION AGAIN!
- what is a good price to offer?
- Friends DC turns off in the morning
- interior bride/status pics
- 3 pistons broken !? new setup,please some help.
- help. skunk2 springs
- Fog light wiring help.
- Cluster lights dont work after installing new cluster.
- axles????
- slotted rotors???
- will a SI front bumper fit on a 97 ex?
- Cams?
- Halogen bulb colors?
- strut bars???
- Install advice for a 2step
- trans light is on
- idling problem with b18b swap-Help a brotha out!
- ITR intake manifold coolant problem
- Eg Ek seats
- what kinda stock rims are these????
- Anyone else running omni-power front camber kit? opinions?
- exhaust manifold
- trans question --- cant remember
- Battery shorting...
- D16y7 headgasket removal; What kind of headbolts??
- Colored 96-98 Corner bulbs
- B18C1 in eg cx evap problem
- srr lca
- Something is wrong with my speedometer
- ten days
- will i pass emmsions...
- D15B VTEC compared to D16Z6
- D16A VTEC?
- I am trying to get ahold of CHADB in regards to his 99 Civic for sale...
- a girl hit my car have a question
- Need Help Type R Seats?????
- help asap
- Seal Rubbers for the Hard Top
- Any guide on removing del sol dash
- Summer coolant, what to use?
- post up pictures of your eg6!!!
- Need ASAP help !
- need answers
- will pre 96 del sol front fit onto 96?
- PLEASE HELP!
- Help!!!!
- check this out??
- HELP: Surging Idle
- d16y7 blox intake mani problem
- How do i know if i have ABS brakes or not?
- JDM D15B VTEC-E
- Remove Door Handle?
- Fused Source of 12V Constant Power
- (Searched)Diffrence between obd2a and obd2b distributer
- boosting, why so much fuel pressure for stock injectors?
- DIfference between Y4 and Y8 TB
- update!!! on the the front of my car.
- BRAKING PROBLEM
- Non-Vtec block, Vtec Tranny+Head swap
- help with A/C on my 95 civic
- Seat fitting Problems...
- Any one have one of these climate controls?
- H-brace?
- need some help with swap
- b16a sir1
- 2 step
- Engine Harness Dash Plug Pinout
- Turbo b16 help
- installing ls vtec into ek
- NO injector signal, NO cel: SOLVE THIS PROBLEM AND I PAYPAL YOU $25!!!!
- pistons ?
- b18c1 idle problem. Starts and jumps to 2 grand and then does if I rev it bogs and barley stays on
- need help on engine codes
- WHERE CAN I BUY: CTR / EK9 Civic Type R CLIMATE CONTROL A/C vents 99-00 HELP PLEASE
- stumped on CEL, are you smart enough?
- B16 del sol swap
- black and gray wire behind cluster
