View Full Version : Honda Civic / Del Sol (1992 - 2000)
- low pressure switch (needle)
- 96 Civic - Same clutch for Denso and Sanden compressors?
- 93 Del Sol - No Fuel on Plugs - Pump Primes
- What’s seats should I get for my EG8?
- AC airvent mode stuck on defrost
- My B20b swapped EJ6 (Redline Issue)
- question about CKP,CYP,TDC sensors
- 1994 eg hatch b20b swap
- Need help 98 Ek hatch with a b20motor
- Budget Resurrection EK-B18C
- My B20b EJ6 (Redline Issue)
- Flush evaporator if compressor seizes?
- Fault code chart
- 93' Del Sol ESi EH6/D16Z6/S24A Transmission
- K20 swap ej1
- 95 EX Civic injectors not spraying searched*
- Transmission shift rod question
- 96 civic DX sedan SRS and horn
- Noob.. need some help for a rather interesting issue
- New guy needs some help!
- 95' civic lx motor stops while car is running
- Motor makes a rattling noise
- P0700 and P0740 in DX with EX Trans
- Header to exhaust
- 96 Civic Sedan - AC Condenser/Compressor Fuse Keeps Blowing
- EJ8 transmission problems
- 2000 Civic no-start
- Oil loss/consumption and stalling d16
- CEL Code 14 Fix
- What header and catback will be good for a 2000 Honda Civic Si?
- Starting problem.
- 2000 Civic harness problem - Advice requested
- I have D16z6 and I need to know if I can put a D16y7 alternator on it?
- Engine mounts
- 93 del Sol auto trans shifter cable
- 1997 Civic LX CEL Misfire and Valves
- 2000 Honda Civic 4D sedan, AT, oil leak
- 1999 Civic "Project Help"
- NEED help on a budget Gilbert, az
- 1997 D15 ENGINE STIFFENERS!?
- 4000 RPM Limp Mode
- Trunk key cylinder replacement
- b16a2...any difference between a 99 and a 2000?
- EK with H22 swap main relay wiring issues
- Idle Problem
- Trying to determine what codes I'm throwing, HELP!
- Honda civic 1999 DX advice.
- D16Z6 oil issues
- BOGS ON ACCELERATION
- D/B series Fuel pump
- Ticking noise start up
- Need some help what Head is this
- ek9 cluster gas gauge wrong?
- 87-91 Prelude seats in ek
- No Crank - No start
- Random No Crank No Start.
- 2000 civic ex to h22 swap
- Noise after clutch replacement
- '98 Civic DX: removing climate slider knobs
- no power to the condenser fan motor.
- DONOT BUY REPLICA SKUNK 2 CAMBER ARMS
- 93 civic ex with d15b7 to d16y8 manual
- Post D16Y7 to Y8 Coolant Leaking
- Relase fork came loose while I was putting my transmission in. Advice please.
- repainted gutted turbo dx eg coupe
- Any knowledge appreciated
- Black rectangle on eg6 dash
- how to clear DTC´s lights on `93 civic?
- What is the technical name for this?
- What is this?
- Side mirrors?
- Need help on B20 motor with Gsr trans build
- Need help I don’t know what this sound is or where’s it coming from
- Turbo d16y8 with vitaras sheared the cam key
- Low Fuel Pressure and Check Engine Light on for Throttle Position Sensor
- 2000 honda civic won't start ecu ground pin 12
- O-ring help - D15Z1 Between head and rocker assembly
- Should you use thread sealer on the fuel line from tank?
- Is this B series Spark plug wire layout correct?
- 2000 civic very small head gasket leak/pressure question
- Having LCA problems
- Del Sol Combination switches
- Radiator options
- Need help on a d16z6!
- 1996 Civic starting problems
- 00 lsvtec civic
- radiator filling up with oil
- TIMING HELP PLEASE!! (D15Z7)
- All 96-00 B series Manual starters the same ?
- D16Y8 CAM HOLDER PROBLEM
- Alternators: Difference Between B-series del Sol and OBD1 Integra?
- Clutch safety switch and cruise switch
- Auto to manual d15b7 to d16z6 swap issues
- Annoying overheating issues
- Low Fuel Trim under load in B16
- 99 d16y8 Head gasket - cylinder head/engine block
- Intermittent Crank, No Start, No Green Key
- Need advice 96 del sol with z6 engine and y8 intake and crank
- 2000 Civic Low idle and no rpm...Help a man please!!!
- Correct Vehicle speed sensor (p0501)
- how to restart a car inactive by a kill switch
- Leak coming from fuel pump?
- Rpms “jumping”
- ECU help
- D series delta cam 272-2?
- y8 to y7
- B18c1
- Crank Position Sensor
- New to mods/swaps...95 eg dx at - 94 eg ex mt
- Good, well known and respected engine importers?
- B20z p1399
- Fluids
- Vtec will not activate question
- D15b VTEC cylinder head threads for headbolts broken
- Hid headlights
- b series head gasket
- Turbo Hatch Cranks but doesn’t start
- 1999 Honda Civic Dx transmission problem
- Header bolt siezed & comletely stripped
- Help with timing marks on crank pulley
- Clutch pressure plate question
- 94 Civic Elec Sys/ ECM Troubleshoot
- B series Clutch release Throwout bearing( hydraulics)
- 96 Civic CX D16Y7, 5 speed Intermittent High Idle
- Evap system error code P1457
- ek coupe b20 swap power steering
- No 5th Gear
- Engine intermittently dying at stops
- Eg motor install questions
- d15b7/y8 mini me smoking bad after sea foam 2 days and 50 miles later
- Noob wondering best bang for the buck swap for my 96 hatch?
- What’s this part called ?
- LOWERING SPRINGS
- EG Door Handle Replacement
- EG ABS Issue
- Repairing Cut Wiring Harness?
- 92 eg hatch rhd subframe
- Does the 96-00 Civic have a starter relay?
- 00 B20B Obd2a or Obd2b ?
- Spark plug holes in valve cover are bent
- Tools for D15Z1 Valve Stem Seal Replacement? For spings/seals
- 2000 honda civic blower motor upgrade?
- Rear Seats compatiablilty
- GsR motor hitting hood
- No start after sitting for a few weeks
- Upper timing cover required or not?
- how to place oem crash sensors airbag civic 93 in European civic eg hatch
- B20v crank but no start
- Best transmission for H22A swap in a 2000 honda civic?
- 93si with GSR swap
- Where can one buy original splash guards?
- Need help 1999 EM1
- Headlight and cluster light issue
- General noob questions
- How to quickly get vtec after turns
- Parts List to make a CTR
- Mis-shifted from 3rd to 2nd at around 56mph What now?
- Variable timing solenoid
- INNOVATIVE mounts
- 5th Gen Si OEM Exhaust/Muffler
- Want some advise before getting into this build
- Difference between 98 - 2000
- 1992 right hand drive swap
- B/D series Power steering
- 96-97 obd2 del sol help
- Radiator fan not working?
- Air Conditioning equal pressure on low and high side
- D15 LOOSE TIMING GEAR, HELP!!
- 2000 Civic EX Trouble Starting
- D16y5 Knock please tell me if it rod or spark knock
- 1999 civic sir/si constant transmission whine
- D15b p28 Ecu codes 3(map) and 21(vtec) help!!
- I need to replace my catalytic converter for my 1994 Honda Del Sol S
- Overfilled Oil - Rough idle and Misfires - 1997 Civic EX
- can rattling like sound
- Turbo b16 wont start
- Will a steering wheel from a civic work in a del sol?
- Dash installation
- D/B series mounts
- 99 honda civic transmission problem?
- 99 Civic LX Sedan Blinking D4
- Code 43
- Play on crankshaft gear/drive?? D15Z7
- 1993 Civic D15b7 compression #'s question
- Weird Idle problem ecu related
- Voltage drop issues
- Evo 8 seats in 1998 civic hatch
- Worth spending 10k on a 99' hatch?
- No spark problem
- B16A3 Redline
- Tranny won't go into gear while engine running
- hard starting SI,part two
- Idle Surge
- Car accelerating on its own P1337
- A good affordable harmonic balancer for b18b1
- 2000 hoodr
- AC problem, right after install
- B16 Coolant system pressure test: what to expect?
- Honda Del Sol/ Civic Questions!!
- 1996 EK9 roof spoiler opinions needed please!
- Axels
- I need help with EG cabin/main harness - C419
- Help With Oil Leaks!!
- High Hc and CO fail
- 1992 Honda Civic VX Air Conditioner Parts/Install Questions
- Brake problem
- Where can I get a preformed brake booster vacuum hose?
- Chassis
- dimensions for 92-95 civic hatchback usdm rear speaker brackets
- Del sol vtec
- Need help buying ac bracket for compressor.
- Distributor
- supplier of civic sun visors?
- Engine harness compatibility: Del Sol
- D15B7 3 stage vtec swap O2 sensor CEL
- Rebuilt head, compression better but still majorly sputtering
- JDM d15b sohc VTEC solenoid gasket?
- my first swap 97 civic coupe
- del sol targa top
- Timing Belt & Water Pump
- Clutch not going into gear/engaging
- Brackets/mount
- B18B1 Will not stay running
- Help with timing!!
- Will a B18B1 or B16 Shift linkage fit a ‘00 B20B
- 98 EK hatch automatic, b18b1 manual swapped
- car bogging randomly/ wont start
- 95 EG Temp needle not working
- EK4 A/C on EG6
- Replacing old OEM tie rod ends
- Ac diagnosis- under/over charged
- Cranks but won't start!
- b18b1 acceleration seems sluggish after timing belt change.
- Oil and coolant problems at the same time?
- Engine swap
- Cant find this part, stores have wrong part listed??
- Auto to manual swap problem
- No crank no start issue
- Any members in Las Vegas? A little help
- 99 Civic si gsr
- What ecu is obd2 for a 00’ b20 Engine
- Lsd trans problem wont roll in neutral
- 98 Civic window problem
- Reuse ARP studs? Or buy new bolts for HG re-do
- B20b for a ek9
- How to tell if OBD2a or OBD2b
- Ac clutch vibrates and knocks
- Torque spec
- Exhaust Fitment Help. Acura fit Civic!
