View Full Version : Honda Civic / Del Sol (1992 - 2000)
- jdm ek9 side marker question
- Si Coupe Re-Build . . . . . . Will I Ever Learn?
- calipers difference
- del sol VTEC stupid swap question
- difference between srd's and sr3
- heat crack maybe
- something is rattling in the cat converter
- Losing power, need some help
- D15B VTEC
- HOW CAN I MAKE MY Z6 HALL ASS?
- Where is Civette??????
- 240cc injectors...how much hp are they good for?
- EJ1 bike rack!!!!
- Power window harrness questions
- OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched
- 24400(a) headlamps WTF!?
- Do i have a Knock sensor on my engine ? ( searched )
- 96 civci ex
- What tranny with a CRV (K24) in an EJ (95 2dr coupe)?
- H22 went dead! electrical?
- HELP! JDM CTR MOMO SRS Steering Wheel
- ******2000 Black Civic Hatch Stolen in JC,NJ***************
- Car shuts off when coming to a stop
- code 8 tdc sensor
- ebay skunk2 ecu?
- Obd2-Obd1 jump harness help
- D16Y7 into 93 CIVIC EX
- how to change a distributor
- lambo doors for sale
- Aem cam gear on d15b
- B16 head on D16 block Possible?????
- LS head for sale, fully built
- passenger window
- How many motor mounts involved in a B18 swap into an EK?
- New Apexi WS2 exhaust causes buzzing?
- Cluster Problem
- High Compression Pistons for D16Z6
- Energy Suspension bushing kit
- EX HARNESS FOR B16
- anyone running the HARDRACE mounts?
- code 7 tps wiring issues
- jdm map sensor
- Spark Plug question
- My gauge needles don't light up !?
- B20 problems
- New to civics, not to honda
- gota question about swapping my engine
- Need help with exhaust choice....
- DIY Auto to Manual Tranny
- stupid question but i need it answered ...
- Will I notice a gain in hp/torque wise with Apexi WS2 exhaust on d16y8?
- install request integra radiator in civic
- which way to go.
- D15b7 need help
- Adding A/C (Air Conditioning) to a 1999 Civic Hatchback CX that didn't come with it Factory
- turning head to TDC
- CTR quick question....
- Some Somewhat Electronically Technically Stuff For You Guys
- Need Help
- suspension???
- car wont start
- New Member LemonsEH2
- tranny grind?
- RHD Conversion. Question about VIN on firewall. (calling out ALL RHD converted owners)
- Damn this forum
- driving an auto tranny
- 98 ek stall problem
- 94 EJ not starting need help please...
- My car rattles and Shakes....
- werid noise from my drive side wheel
- civic and integra wheel bearings, same OD? i know ID is different
- foggies
- will a cargo cover from an si fit in a dx?
- b16a2 tq?
- speed sensor/thermostat problem
- Burning Oil
- Leaking clutch fluid (need help)
- 97 honda Del Sol for sale - 2950
- car tugs
- Are 5 lug brakes worth it? *opinions wanted*
- Need help! GSR motor won't start
- Really need help with my sputtering problem :(
- Need help!!
- 1st gear
- turbo sol
- B16A2 OBD2B into 1996 Civic DX OBD2A (wiring clash)
- help with h22 swapped ek hatch
- Help with JDM P30 ECU
- my b18 throwing a cel 14
- Tanabe Medallion Touring
- weather seal del sol
- Need info
- Where to get FITV for B16a
- Rear Lower Tie Bar - Finally got it mounted!!! Check it out!
- High RPM problem?
- center console
- Zenki & Kouki EK Civic
- Help LX idles at 1500 rpm?
- Okay New distributor now having other problems ?
- 1 quick question about stainless clutch lines
- transmission problem
- bypass hose removal on gsr block
- Where can I
- Adjusting aem cam gear...
- New member's 94 Civic
- thinking about doing a ls swap
- Engine Removal
- manual transmission
- questions abou buying a jdm motor
- help me find delSol parts - 1995
- Civic Vss
- is it possible to smog jdm b16a?
- apexi n1 ?
- connecting a scanner to a chipped ecu?
- boosted y8
- Please help me! Easy crank sensor question! Help me techies!
- project mu type hc+ pads users out there or other mu pads ?
- One way plates to buy car
- tansmission problem please help this is my DD
- the worst thing just happend to me :(
- Small but annoying problem.....
- SRS Unit identification
- Help w/ my 97 Hatch !!!
- Engine swap need guide
- Need help with this...
- Leak help, and fuel mileage help...LS swapped 94 4 door DX...
- TPS specs anyone
- HELP...CLUTCH PROBLEM
- antenna block off plate
- antenna
- have a reving problem
- does stock eg comes in b16a1?
- *If you have a B16 Powerd EG Hatch post here!*
- AEM WB o2 install question
- pcv valve removal help
- mini me/timing belt help..please help!!
- itr IM in B16A2
- When doing an oil change, should I warm the car up completely first, or leave it cold?
- Best motor to boost and why?
- battery and gas milage
- stock steering wheel size?
- need some quick assistance with the alternator guys!
- need a lil auto to manual help...
- gaskets????
- ef motor mount in eg hatch?
- Time for a new exhaust.. help
- Please help?
- Is my Civic toast?
- D15b original exhaust
- Why won't my car turn on?
- why would you want a del sol
- Type-R Cams Issue
- OBD2 into OBD1 ... Need help!
- 00 si seats in my 98 hatch??
- civic cupholders q
- trailing arm bushing - oem or enegry suspension?
- bushing help
- CHECK ENGINE LIGHT
- Breather
- Cat Delete, Now have White Smoke
- my car it been burning GAS what might be wrong? PLEASE HELP
- if i was to lower my car some more.....
- cant find the answer to this anywhere
- suggestions before i swap my engine
- ek/eg weight diff...
- will 14 inch rims fit on GSR DISK CONVERSIOn?????????
- Skunk2 shock and spring combo...
- The lovely D16Y5, Any Ideas
- 97 civic auto transmission problem
- Anyone with full rear interior stripped.. have rear speakers? if soo where do you mount them?
- Help..
- Help With My Y8
- flowmaster on a civic???
- Clutch problem? need help
- throttle body help
- Where the guys at, you know...
- 1993 Sedan to Coupe Front Clip Swap??
- B16a Hatch-20 mpg!
- b18b1 in 96 ex........
- Short problem
- Does anyone else have a problem with the horn not working on a CTR EK9 wheel?
- how to find out wat trany it is
- turbooo
- ITR swap into 97 hatch question?????
- alternator question...
- Honda civic pcv valve
- d16z6 into a 98 civic
- RSX seats into 97 coupe
- i cant figure out how to stop the leaking????
- The answer to "Can I put a coupe rear sway bar on my EK Sedan"
- Time for a new clutch? Which one to buy?
- I NEED SOLID INFORMATION ABOUT MOUNTS
- V2 cold air intake for EJ8
- mini me swap
- EK or EJ?
- Where can I get a tapped fuel filter banjo bolt?
- ludatic98
- d16y8 swap into 96 civic hb
- Electircal problem
- rpm issue
- Too Much Oil?
- Will 94 civic seats fit into 2000 si
- Cleaning Spark Plug
- clutch bleeding?
- Need help wit H22 into EG. What are these things?
- CKF by pass obd2a car...jdm 1997 obd2 type r motor/ecu
- timing belt help
- 92-95 SI harness?
- 00 si wiring
- recommendations for my civic
- Discussion: Does anyone swap in B-series anymore?
- sohc 1.6 throttle body spacer??
- gas mileage
- u-joint in steering column
- Car only starts when WET, HELP!
- putting a a/c on a b18b
- power windows. ek
- CLUTCH HELP
- I need help finding a place to buy oem bushings
- crack and pop sound
- DIY: Using stock throttle cable with B16 swap
- auto-manual swap
- Do short trips really damage your motor? How and why?
- recaro seats
- OBD1 B16 and GSR harness the same?
- Many 6th gen civic EX's without VTEC ('96-00) in Canada
- antifreeze
- 92-95 civic airbag tray
- problem with starting car
- Ignition locked up..key won't turn...any advice to this Honda Girl would be wonderful!
- how can i see my pm?
- how do i check cel
- Rod and Main Bearing Color Codes, Plastigauge color.
- Nasty Puddle and Car Won't Start
- H.I.D
- which spark plug wires are best for 96 honda civic ex?
- Want to Learn about Cars
- Bent wheels???
- B16 or B18????
- injectors
- Alternator and Regulator Amperage problems?
- Identify this green plug on OBD2B harness
- Jdm B16 distributor is different than US. ?
- TUrbo my Y8, please help tryed searching and the forced Induction thread no answers
- finally finished my jdm b18b swap in a eg
- OEM Z6 Pistons...
- 99-00 Civic Si OBD2B question
- vtec conversion help
- Cleaning up vtec solenoid???
- I've always wondered which method of braking wears down the brakes faster..
